V4.031 Hot Fix - 09-01-2014
SebDel
Liste des modifications logicielles 4.031:This version is hot fixing version addressing some of issues reported by users. There are no new functionalites.
4.031 Hotfix
Resolved Issues:
#0002363: Motion sensor parameters can no longer be set
#0002419: Change Icon
#0001983: Icons on Fibaro
Setting Assocations for battery devices
Setting Wake up time for battery devices
Setting Parameters for battery devices
Device Support:
Qees Retoshell Dimmer - added device template
Flush Qubino Dimmer - added device template
Known issues:
Power Mettering may not work properly for some devices
Net Atmo plugin may stop working after few hours due API limits
UBS Temperature is not visivble on iPhone/iPad client
RGBW Controler may not work propery when used in in/out mode
Alarm Panel doesn't work in some specific configurations
Plugins for TV Sets of various manufacturers may not work with its newes firmware due to restricions provided by new devices firmware. There will be added detalied information about suported firmwave versions within plugins.
Satel - adding plugin progress bar disappears during configuration. Please wait about 15 minutes before performing actions on Satel devices.
Devices Polling may not work properly - devices state in UI may be refreshed only after action taken.
Breached sensor with Arm Delay causes instant alarm after being armed
Data range selection in event panel doesn't work properly
Devices imported via Gateway Connection may have no icons
Gateway Connection status of dead device between master and slave controller may be different
Devices not properly configured on 3.X may not be converted properly
Reconfiguration may not work properly in some cases
On mobile clients devices may be visible in different categories than configured
Advanced settings for some imported devices may not work properly
Horstmann Thermostat HRT4-ZW higher battery usage in some cases
Doorlocks some functions may not work properly
4.031 Hotfix
Resolved Issues:
Device Support:
Known issues:
  • Upvote 2
Pareil ...en espérant du mieux pour les appareils à  batterie !
Car la sirene ZM1601 ..impossible de la faire marcher avec la 4.030.
Le porte clé KFOB2 ...impossible de faire de sceneactivation  avec la 4.030
Et j'ai pas encore essayé le detecteur de fumée d'Everspring ...je croise les doigts ! :)
Le principale c'est que Fibaro réagi dans le bon sens on ne peut pas régler tous le probléme en quelques jours il va falloir du temps plusieurs mois je pense.
Mais ils font de gros efforts surtout au niveau communication on ne va tout de même pas leurs reprocher cela
  • Upvote 2
