SebDel Posté(e) 9 janvier 2015 Signaler Share Posté(e) 9 janvier 2015 Liste des modifications logicielles 4.031:This version is hot fixing version addressing some of issues reported by users. There are no new functionalites. 4.031 Hotfix Resolved Issues: #0002363: Motion sensor parameters can no longer be set #0002419: Change Icon #0001983: Icons on Fibaro Setting Assocations for battery devices Setting Wake up time for battery devices Setting Parameters for battery devices Device Support: Qees Retoshell Dimmer - added device template Flush Qubino Dimmer - added device template Known issues: Power Mettering may not work properly for some devices Net Atmo plugin may stop working after few hours due API limits UBS Temperature is not visivble on iPhone/iPad client RGBW Controler may not work propery when used in in/out mode Alarm Panel doesn't work in some specific configurations Plugins for TV Sets of various manufacturers may not work with its newes firmware due to restricions provided by new devices firmware. There will be added detalied information about suported firmwave versions within plugins. - Satel - adding plugin progress bar disappears during configuration. Please wait about 15 minutes before performing actions on Satel devices. Devices Polling may not work properly - devices state in UI may be refreshed only after action taken. Breached sensor with Arm Delay causes instant alarm after being armed Data range selection in event panel doesn't work properly Devices imported via Gateway Connection may have no icons Gateway Connection status of dead device between master and slave controller may be different Devices not properly configured on 3.X may not be converted properly Reconfiguration may not work properly in some cases On mobile clients devices may be visible in different categories than configured Advanced settings for some imported devices may not work properly Horstmann Thermostat HRT4-ZW higher battery usage in some cases Doorlocks some functions may not work properly Liste des modifications logicielles 4.031:This version is hot fixing version addressing some of issues reported by users. There are no new functionalites. 4.031 Hotfix Resolved Issues: #0002363: Motion sensor parameters can no longer be set #0002419: Change Icon #0001983: Icons on Fibaro Setting Assocations for battery devices Setting Wake up time for battery devices Setting Parameters for battery devices Device Support: Qees Retoshell Dimmer - added device template Flush Qubino Dimmer - added device template Known issues: Power Mettering may not work properly for some devices Net Atmo plugin may stop working after few hours due API limits UBS Temperature is not visivble on iPhone/iPad client RGBW Controler may not work propery when used in in/out mode Alarm Panel doesn't work in some specific configurations Plugins for TV Sets of various manufacturers may not work with its newes firmware due to restricions provided by new devices firmware. There will be added detalied information about suported firmwave versions within plugins. - Satel - adding plugin progress bar disappears during configuration. Please wait about 15 minutes before performing actions on Satel devices. Devices Polling may not work properly - devices state in UI may be refreshed only after action taken. Breached sensor with Arm Delay causes instant alarm after being armed Data range selection in event panel doesn't work properly Devices imported via Gateway Connection may have no icons Gateway Connection status of dead device between master and slave controller may be different Devices not properly configured on 3.X may not be converted properly Reconfiguration may not work properly in some cases On mobile clients devices may be visible in different categories than configured Advanced settings for some imported devices may not work properly Horstmann Thermostat HRT4-ZW higher battery usage in some cases Doorlocks some functions may not work properly 2 Lien vers le commentaire Partager sur d’autres sites More sharing options...
mprinfo Posté(e) 9 janvier 2015 Signaler Share Posté(e) 9 janvier 2015 Mise a jour en cours..... Lien vers le commentaire Partager sur d’autres sites More sharing options...
Bywatt Posté(e) 9 janvier 2015 Signaler Share Posté(e) 9 janvier 2015 mise a jour en cours... Pas d'illusion juste un pansement sur une jambe de bois Lien vers le commentaire Partager sur d’autres sites More sharing options...
Vince Posté(e) 9 janvier 2015 Signaler Share Posté(e) 9 janvier 2015 Pareil ...en espérant du mieux pour les appareils à batterie ! Car la sirene ZM1601 ..impossible de la faire marcher avec la 4.030. Le porte clé KFOB2 ...impossible de faire de sceneactivation avec la 4.030 Et j'ai pas encore essayé le detecteur de fumée d'Everspring ...je croise les doigts ! Lien vers le commentaire Partager sur d’autres sites More sharing options...
Kr1s Posté(e) 9 janvier 2015 Signaler Share Posté(e) 9 janvier 2015 On pourrait lancer un projet Kickstarter pour les aider un peu ? 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
mprinfo Posté(e) 9 janvier 2015 Signaler Share Posté(e) 9 janvier 2015 Le principale c'est que Fibaro réagi dans le bon sens on ne peut pas régler tous le probléme en quelques jours il va falloir du temps plusieurs mois je pense. Mais ils font de gros efforts surtout au niveau communication on ne va tout de même pas leurs reprocher cela 2 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Vince Posté(e) 9 janvier 2015 Signaler Share Posté(e) 9 janvier 2015 @Krls .. une idée de départ ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
mprinfo Posté(e) 9 janvier 2015 Signaler Share Posté(e) 9 janvier 2015 SUPER on peut enfin changer les icones du Fgs221 Lien vers le commentaire Partager sur d’autres sites More sharing options...
xtrem57 Posté(e) 9 janvier 2015 Signaler Share Posté(e) 9 janvier 2015 Mise àjour OK Je retrouve enfin mes icônes :-) Lien vers le commentaire Partager sur d’autres sites More sharing options...
dodobibi Posté(e) 9 janvier 2015 Signaler Share Posté(e) 9 janvier 2015 Le porte clé KFOB2 ...impossible de faire de sceneactivation avec la 4.030 Pour moi, le KFOB2 ne fonctionne plus depuis la 4.018. J'espère qu'ils vont corriger cela. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Krikroff Posté(e) 9 janvier 2015 Signaler Share Posté(e) 9 janvier 2015 J'ai visiblement des gros problèmes avec SATEL sur cette mà j , Christophe et les autres patientez peut-être avant de faire l' upgrade Lien vers le commentaire Partager sur d’autres sites More sharing options...
carfnann Posté(e) 9 janvier 2015 Signaler Share Posté(e) 9 janvier 2015 après la MAJ, plus moyen d'accéder àma HC2, et comme je suis àdistance je ne peux pas savoir si elle est plantée... arf Lien vers le commentaire Partager sur d’autres sites More sharing options...
kabutop Posté(e) 9 janvier 2015 Signaler Share Posté(e) 9 janvier 2015 @Krikroff: trop tard en même temps ça marchait pas avant... Lien vers le commentaire Partager sur d’autres sites More sharing options...
Vince Posté(e) 9 janvier 2015 Signaler Share Posté(e) 9 janvier 2015 Ah merci Fibaro , la 4.031 m'a corrigé : la sirene Vision Security ZM1601 .. Ok le détecteur de fumée d'Everspring SF812 .. Ok ! Bon toujours pas de sceneactivation pour le porte clé KFOB2 !! Lien vers le commentaire Partager sur d’autres sites More sharing options...
carfnann Posté(e) 9 janvier 2015 Signaler Share Posté(e) 9 janvier 2015 c'est bon c'est reviendu, ca a pris du temps Lien vers le commentaire Partager sur d’autres sites More sharing options...
Phycus Posté(e) 9 janvier 2015 Signaler Share Posté(e) 9 janvier 2015 Salut à tous. Pour ma part elle est plantée au redémarrage. Seul le voyant download clignote. Je vais faire un redémarrage forcé. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Phycus Posté(e) 9 janvier 2015 Signaler Share Posté(e) 9 janvier 2015 @ Carfnann : Combien de temps? Lien vers le commentaire Partager sur d’autres sites More sharing options...
Krikroff Posté(e) 9 janvier 2015 Signaler Share Posté(e) 9 janvier 2015 @Kabutop, ouais mais c'est vraiment un binz pas possible maintenant ... Lien vers le commentaire Partager sur d’autres sites More sharing options...
kabutop Posté(e) 9 janvier 2015 Signaler Share Posté(e) 9 janvier 2015 Je viens de supprimer l'intégration de mon alarme. On verra plus tard. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Krikroff Posté(e) 9 janvier 2015 Signaler Share Posté(e) 9 janvier 2015 !Oui c'est aussi une solution Lien vers le commentaire Partager sur d’autres sites More sharing options...
Phycus Posté(e) 9 janvier 2015 Signaler Share Posté(e) 9 janvier 2015 Bon bin tous les voyants sont éteints. Cependant elle répond au ping. Là j'ai peur Lien vers le commentaire Partager sur d’autres sites More sharing options...
mprinfo Posté(e) 9 janvier 2015 Signaler Share Posté(e) 9 janvier 2015 Oui après la mise jour il faut attendre un moment avant de pouvoir de nouveau y avoir accès. Environ 2 a 3 minutes aprés que les 3 leds soient ok Lien vers le commentaire Partager sur d’autres sites More sharing options...
fab971 Posté(e) 9 janvier 2015 Signaler Share Posté(e) 9 janvier 2015 MAJ 4.031 effectuée. OK. Changement icones OK. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Phycus Posté(e) 9 janvier 2015 Signaler Share Posté(e) 9 janvier 2015 Non làau redémarrage les Leds font leur cinématique puis toutes les Leds s'éteignent.(en façade) Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) 9 janvier 2015 Signaler Share Posté(e) 9 janvier 2015 Bon je tente 4.024 vers 4.031, de toute façon les plugins ne passent pas en 4.024 non plus chez moi, donc bon... Lien vers le commentaire Partager sur d’autres sites More sharing options...
