jang
    209
    42
Tout ce qui a été posté par jang
  1. jang
    telecommande virtuel
    Like this?
  2. We can't disable or change font/color of button (except for unicode characters) I understand that you would like to disable one option but still show the user that the option exists. "There is Open Door, but it's not available right now" An alternative, that may be understandable for the user, is to have a single button that serves both functions and changes text between "Open Door" and "Close Door". Another alternative is to change the text of the inactive button to be strike-through letters (unicode), "O̶p̶e̶n̶ ̶D̶o̶o̶r̶" https://www.contentharmony.com/tools/strikethrough-text-generator/
  3. Well, it's a bit tricky. If you use setProperty, it will not call the QAs updateProperty method. Some QAs may have written code to override the logic for QuickApp:updateProperty and then it's not called. The other problem is that the Device:updateProperty that QuickApp:updateProperty inherits from, do update the QuickApp's objects self.properties[prop]=value If we only call setProperty, self.properties.value will differ from fibaro.getValue(self.id,"value") which could cause issues for some QAs... One could check if the device is a QA and call updateProperty, and if not call setProperty... local isQACache = {} local function isQA (id) if isQACache [id]~= nil then return isQACache[id] end local d = __fibaro_get_device (id) if d then for _,i in ipairs(d.interfaces) do if i == 'quickApp' then isQACache[id] = true return true end end end isQACache [ id ]= false end takes on average 10ms per QA for my 200 QAs. And the result is cached so checking same id is then fast...
  4. This only works if the device is a QA. QuickApp's have 'updateProperty' defined as an API. I would recommend api.post("/plugins/updateProperty", { deviceId = 20, propertyName = 'userDescription', value = 'FWPP1' })
  5. jang
    QuestionS HC3 et LUA
    No there is no reason. Except maybe a wish to bring all functionality in under fibaro.* - but they can't remove setTimeout due to old QAs/Scenes. function fibaro.setTimeout(time,fun) return setTimeout(fun,time) end Like the rebranding of fibaro.* to hub.* - but also here, to be backward compatible with QAs/Scenes they can never remove fibaro.*... Another mystery is that Fibaro maintains 2 implementations for the fibaro.* functions. One for Scenes and one for QAs - and they are not always in sync... My thinking has been that it is 2 different consultant companies that do the Scene engine vs the QA framework... :-)
  6. Have you tried it? Did it work for you?
  7. jang
    Déclencheur Event QA HC3
    What kind of animal is Conso Live (Enphase_MeterTotalConsumptionPower_Updated) that is expect to send an event/signal. Another QA? another zwave device? something else?
  8. Problems: 1. You set 'value' but test 'state' 2. If you click 'off' -> 'on' quickly you may end up with 2 running loops... I think @laser meant something like this (but here we use the property instead of a local var) local function loop() if (hub.getValue(plugin.mainDeviceId,"value") == true) then print("Run Loop action") end -- loop setTimeout(loop,1000*loop_value_sec) -- secondes end loop() function QuickApp:turnOn() self:debug("binary switch turned on") self:updateProperty("value", true) end function QuickApp:turnOff() self:debug("binary switch turned off") self:updateProperty("value", false) end
  9. jang
    recuperation valeur json
    Unfortunately not. I have QAs that don't work on the HC3L because I use os.time() a lot. os.time(), these days, returns a value dangerously close to what fits in 32 bits and when doing arithmetics with the value, calculating time, it sometimes overflow and create bad results on the HC3L... So, I recommend the HC3L only for block scenes... For dev platform I use https://forum.fibaro.com/topic/66394-visual-studio-code-vscode-for-quickapp-development/ Life is too short for trying to develop directly on the HC3/HC3L...
  10. jang
    Are you running it on a HC3 Lite? Fibaro, in their wisdom to save space, compiled the Lua environment for the HC3L as 32bits... ...which cause all kinds of issues like these...
  11. jang
    Les Childs pour les Nuls
    and if you run hierarchy through graphviz...
  12. api.put("/rooms/239",{icon='User1002'})
  13. jang
    Commandes HTTP - GET
    local commands = { Opened = "https://airsend.cloud/device/xxxxx/command/4/?session=???", Closed = "https://airsend.cloud/device/xxxxx/command/5/?session=???", Stopped = "https://airsend.cloud/device/xxxxx/command/3/?session=???", } function QuickApp:command(cmd,state) assert(commands[cmd],"Bad command") local http = net.HTTPClient() http:request(commands[cmd], { success = function(response) if response.status == 200 then print('OK, réponse : '.. response.data) self:debug("base shutter "..cmd:lower()) self:updateProperty("state", state or cmd) else self:error("Erreur : status=" .. tostring(response.status)) end end, error = function(err) self:error("Erreur : " .. err) end, options = { method = 'GET' } }) end function QuickApp:open() sendCommand('Opened') end function QuickApp:close() sendCommand('Closed') end function QuickApp:stop() sendCommand('Stopped',"Unknown") end
  14. The only problem is that hub.call can't return any value - to do this you need to add additional sorcery...
  15. Well, you have the tools, the rest is just some list manipulations... ;-) local days = { monday=0, tuesday=1, wednesday=2, thursday=3, friday=4, saturday=5, sunday=6 } local function map(list) local r ={} for _,e in ipairs(list) do assert(days[e],"Bad day:"..tostring(e)) r[e]=true end return r end local function flatten(list) local r ={} for e,_ in pairs(list) do assert(days[e],"Bad day:"..tostring(e)) r[#r+1]=e end table.sort(r,function(a,b) return days[a] <= days[b] end) return r end -- self:setSprinklerDays(4,{"monday",wednesday"}) -- will set scheduled days to monday and wednesday for sprinkler schedule 4 function QuickApp:setSprinklerDays(sprinkerId,list) return api.put("/panels/sprinklers/4" ,{ days = json.util.InitArray(flatten(map(list)))}) end -- self:addSprinklerDays(4,{"monday",wednesday"}) -- will add monday and wednesday to currently scheduled days for sprinkler schedule 4 function QuickApp:addSprinklerDays(sprinklerId,list) local days = map(api.get("/panels/sprinklers/"..sprinklerId).days or {}) for _,d in ipairs(list) do days[d]=true end return api.put("/panels/sprinklers/4" ,{ days = json.util.InitArray(flatten(days))}) end -- self:removeSprinklerDays(4,{"monday",wednesday"}) -- will remove monday and wednesday from currently scheduled days for sprinkler schedule 4 function QuickApp:removeSprinklerDays(sprinklerId,list) local days = map(api.get("/panels/sprinklers/"..sprinklerId).days or {}) for _,d in ipairs(list) do days[d]=nil end return api.put("/panels/sprinklers/4" ,{ days = json.util.InitArray(flatten(days))}) end function QuickApp : onInit () print(self:setSprinklerDays(4,{"monday","friday"})) print(self:addSprinklerDays(4,{"saturday"})) print(self:removeSprinklerDays(4,{"monday"})) end
  16. Btw, this is the json encoder/decoder used in QAs https://github.com/harningt/luajson/ (Scenes use another implementation)
  17. You could try local ListDay = json.util.InitArray({}) --<----- empty array MyPanel = api.get("/panels/sprinklers/11" ) res = api.put("/panels/sprinklers/11" , { days = ListDay })  The reason is that the json.encoder don't know if the Lua table {} should be encoded as an empty json key-value table "{}" or an empty json array "[]" The json.util.InitArray() function creates an object that the json.encoder always encodes as an array. Of course, the suggestion above only works if api.put uses the QAs built-in json.encode...
  18. jang
    Bug MAJ slider
    Yes, it's really buggy. Try to add function QuickApp : OnReleased ( event ) self : updateView ( "slider" , "value" , "75" ) -- Any other value than 25... self : updateView ( "slider" , "value" , "25" ) end
  19. jang
    os.clock vs os.time
    os.time gives seconds in absolute time since 1973... os.clock returns cpu timed used so far by the process (QA or Scene). When the QA starts the os.clock will return 0, and then start to count cpu time used. cpu time used is usually smaller then absolute time (over any measured time interval)
  20. jang
    Command Class Time Parameters
    ...it's kind of an mqtt mechanism between QAs... but with a much simpler api...
  21. jang
    Oh, finally someone discovered that function :-) Yes, it's really cool and quite efficient as the publisher only sends to subscribers actually subscribing on the event (source filtering). Also it works well with the fibaroExtra event mechanism that makes it easy to work with HC3 device and internal events.
  22. I wouldn't call it a mega optimization... If it would run million of times / sec I would agree... but not for 4 times per second... Of course it's not the monthly energy savings that are of importance here but to make sure we can complete the 4 calls per seconds and still do all other stuff... ...then 0.26 microseconds is more like a micro optimization... local n,t0=100000 a = { b = function() end } c = function() end local d = function() end print("----------") t0 = os.clock() for i=1,n do a.b() end local v0 = (os.clock()-t0)*1000 print(string.format("Time '%s' = %0.6f",'a',v0/n)) t0 = os.clock() for i=1,n do c() end local v1 = (os.clock()-t0)*1000 print(string.format("Time '%s' = %0.6f",'c',v1/n)) t0 = os.clock() for i=1,n do d() end local v2 = (os.clock()-t0)*1000 print(string.format("Time '%s' = %0.6f",'d',v2/n)) local save = (v0-v2)/n printf("Saving %0.6f milliseconds per call, using local fun vs global table fun",save) printf("Saving %0.3f seconds per month, using 4 calls / second",30*24*3600*4*save/1000) ...and the answer is [19.04.2023] [07:27:56] [DEBUG] [QUICKAPP1090]: Saving 0.000264 milliseconds per call, using local fun vs global table fun [19.04.2023] [07:27:56] [DEBUG] [QUICKAPP1090]: Saving 2.734 seconds per month, using 4 calls / second
  23. Excessive typing can affect your health
  24. print(os.date("%FT%T%z"):sub(1,-3)..":00") print(os.date("%FT%T%z",os.time()+24*3600):sub(1,-3)..":00") Assuming timezone offset always even hours.
  25. jang
    CURL Token en LUA
    You shouldn't encode response.data. It's already encoded. Just use decode. The '\n' is no problem. print("My_Json:" , response.data) local My_Json = json.decode ( response.data ) access_token = My_Json.access_token token_type = My_Json.token_type expires_in = My_Json.expires_in print ( "access_token:" , access_token ) print ( "token_type:" , token_type ) print ( "expires in:" , expires_in )
