2516 -
28
Normally when you install the Global VD, you get the IDs of each camera in the camera list displayed in the global VG. You have also been able to test the "HomeMode" data of the global variable "VG_SSM_Parameters" to know the current status of the presence and press the button according to the value. Like : local Parameters = fibaro: getGlobalValue (VG_SSM_Parameters) local status, Parameters = pcall (function () return json.decode (Parameters) end) if Parameters.HomeMode = false then ' press button ..... You should be able to install a second Global VD and a second scene for your second Synology NAS. You will also need to think about changing the following variable by specifying the name of the second scene. local Scene_Surv_Station_Manager = "Surv Station Manager" -- Name of the Scene used to execute actions And change the VG in all VD and scene for the second SSS : VG_SSM_Parameters = "SurvStationManager", -- Global Variable used to transmit Parameters between VD Main loop, Buttons and Scene VG_SSM_User_Data = "SurvStationManager_User_Data", -- Global Variable used to transmit users datas between VD Main loop, Buttons and Scene VG_SSM_Status = "SurvStationManager_Status", -- Global Variable used to indicate the status off Surveillance Station Indeed, it is related to your configuration. SSS takes precedence when you set up 24/7 recording. One of the aims of my request is precisely not to record continuously to avoid the wear of hard drives and also for the protection of the privacy of the people living in the house. Does the problem appear on CAMs attached to the primary or secondary NAS or both? If it is on the second one, it may be related to the use of Synology "Central Management System (CMS)? So, in summary, your problems are essentially related to your context of use and not bugs. I will see if it is possible to manage cameras when connected via Synology "Centralized Management System (CMS)"
C’est pour ça que j’évite autant que possible le Cloud. D’ailleurs avec nos HC2 qui sont connectés via Fibaro iD, nos amis de Fibaro ont également accès aux Cams configurées dans nos HC2. En ce qui me concerne elles sont toutes sous Surveillance Station sur mon Nas Synology avec un pilotage depuis ma HC2. Ça limite les risques. A méditer.
Pour info une new qui pourrait t’intéresser au sujet des services et pratiques de certains collaborateurs de Ring. http:// https://www.igen.fr/accessoires/2019/01/les-employes-de-ring-ont-pu-espionner-les-sonnettes-et-cameras-de-leurs
Est-il possible de récupérer et sauvegarder les vidéos/images sur un NAS type Synology ?
Merci oui. Ça fonctionne parfaitement. +1
Tout le monde ne peut pas s’appeler Apple et savoir maîtriser le Hardware et le Software. CQFD
Hello @Krikroff, j'ai comme l'impression que tu disposes de beaucoup d'info. sur tout ça Tu participes aux beta tests (Appli. & Devices) ?
J'adore
Bon je sais, l'actualité du jour ce n'est pas ici, mais est-ce que l'un de vous a fait des tests sur les fonctions PTZ ? et si oui pourriez-vous me faire un retour ? Attention au retour de flames ? en ce moment vous êtes à cran avec la nouveauté Fibaro du jour.
MAM78 a répondu à un(e) sujet de fredokl dans Applications Smartphones et Tablettes
Bien venu au club. Et ce n'est pas une histoire Belge C'est du Polonais -
Heureusement que lorsque nous publions nos DEV sur le forum, ils sont un peu plus abouti. Sinon nous nous ferions incendier en direct live -
lucky guy -
Pas vraiment sur l'application iOS. Notamment lorsque tu vas sur l'onglet réglage (en bas à droite) et lorsque tu changes la sélection des typologies de modules ça lag et ça bug. Le simple slider d'une lampe piloté par un dimmer. lorsque je slide. Ca glisse sur la page d'à côté. C'est pas vraiment ce que j'appellerait "fonctionne bien" Effectivement 3 secondes versus 4 sur l'ancienne. Mais compte-tenu des fonctionnalités disponibles. Je trouve cela pas flagrant. Personnellement l'accès et la visualisation sur une page de l'ensemble des pièces est un manque important pour moi. Pour le design, pourquoi pas, ça donne un coup de jeune. Pour ce qui est du fond blanc pas mal mais la mode passe au fond noir actuellement. C'est difficile d'être dans le coup. Ils ont prévus 3 fonds (Blanc, Bleu claire, Bleu nuit) mais pas le noir ou gris foncé. C'est pas bon pour la console de batteries de nos smartphone. Il y a encore beaucoup de boulot avant d'arriver aux fonctionnalités disponible sur l'ancienne application. J'espère qu'ils ont une grosse équipe dessus, sinon nous allons pouvoir utiliser encore pour un certain temps l'ancienne en espérant qu'ils continuent de la maintenir puisqu'il faut pas se faire d'illusion pour les évolution sur l'ancienne ça va être mort. -
Comme je l'ai indiqué sur le forum officiel. Trop de choses sont manquantes. Du coup nous sommes obligés de continuer a utiliser l'ancienne application. Du coup cela va fortement limiter la communauté à contribuer aux tests de l'application. -
MA HC2 était plantée. Erreur 503. Cause ? (upgrade V4.53, ...) Visible mais impossible de les ouvrir pour utiliser les boutons ! Seul le bouton ou Slider est accessible ! Le slider bug un max. Lorsque tu slides, tu obtiens de défilement des pages sur les catégories d'objets et non le réglage du % de niveau Légèrement amélioré depuis le reboot de la HC2 Ca sent la sortie en urgence pour le CES et une grosse pression de leur nouvelle holding italienne Ce n'est pas une très belle entrée en matière pour eux ! -
Mais quelle daube cette application : même pas possible d'allumer une lampe les VD ne sont pas accessibles temps de réponse execrable Ergonomie a ch... ... Pour une V1 c'est une honte. Comment est-il possible de laisser sortie un soft avec cet état de maturité. J'ignore si c'est un effet de bord de l'upgrade en 4.53 mais je n'arrive plus à faire fonctionner l'ancienne application sur mon iPhone Je vais tenter un reboot de ma HC2 !!! -
Qu’est-ce que c’est que ce truc ?
Ci-dessous une traduction google qui je pense te donnera une bonne idée de ce qui est dit dans l’articket. La liste des entreprises polonaises qui seront exposées au CES 2019 est assez modeste. En conséquence, FIBARO s'efforce d'être présent lors de tous les grands événements en Pologne et à l'étranger liés à l'IoT, aux technologies ou même aux intérieurs. CES, cependant, est unique, c’est là que la première aura de tout nouveaux appareils Fibaro. La société a déjà révélé les premiers détails. La première excellente information est le fait que nous verrons pour la première fois à Las Vegas une nouvelle application permettant de contrôler les périphériques FIBARO (principalement ceux qui utilisent la technologie Z-Wave). L'application consiste à utiliser un assistant intelligent et une technologie d'apprentissage automatique. C'est une bonne nouvelle, car l'application actuelle s'éloigne principalement des normes actuelles. L'application a été créée en Pologne. L'application FIBARO HOME Center et l'IFA Smart Implant présentés à la foire ont reçu les CES Innovation Awards. FIBARO Walli est une annonce très intéressante concernant les nouveaux produits au CES 2019. Il doit s'agir de toute une série de prises et de commutateurs. Cela peut constituer un ajout très intéressant à l’offre Switchy et Wall Plugów. En ce qui concerne HomeKit, nous verrons une nouvelle bande de contrôleurs LED Rainbow de deux mètres. Vous pouvez également acheter le contrôleur lui-même et utiliser une autre bande RGBW. Ce pilote dans la version prototype que nous avons eu l'occasion de voir lors de l'IFA à Berlin. FIBARO disposera de plus de 70 mètres carrés d'espace d'exposition à Las Vegas, que je compte bien entendu visiter et voir de nouveaux produits en action. Je dois avouer que je comptais sur les effets directs du mariage de Fibaro avec Nice et les moteurs à portique intégrés. Nous verrons ce qui sera présenté en entier à la SCÉ. Et ce n’est pas le seul événement de cette année où Fibaro sera exposé.
programation pour allumage automatique d'un seche serviette
MAM78 a répondu à un(e) sujet de ds1327 dans Chauffage et Energie
Mon idée est de profiter des différentes fonctions disponibles sur le radiateur et ne pas utiliser que le mode on/off. Donc de préférence de passer par la gestion via fil pilote. Est-ce qu'un Qubino est la seule, voir meilleurs solution ? Question subsidiaire : Utilisant les panneaux de chauffages avec le Heating Manager @OJC pour mes autres radiateurs (à eaux) est-il préférable d'utiliser la méthode on/off avec le solution de @OJC ou utiliser les 6 différents modes via le Fil Pilote (Confort, Confort -1°, Confort -2°, Éco, Hors-gel, Arrêt) ? -
tout dépend du mode de détection de mouvement que t'utilises : Oui (via les notifications de Surveillance Station) pour la détection de mouvements par la caméra Oui (via les notifications de Surveillance Station) pour la détection de mouvements par le logiciel Surveillance Station Non apriori pour la détection par un événement externe (type détecteur de mouvements). Pour le moment (après quelques tests) : J'arrive bien à enregistrer dans Surveillance Station les snapshot (via le bouton prévu à cet effet) J'arrive bien à envoyer une notification textuelle par mail en utilisant les règles d'actions de SS. Mais je n'ai pas réussi à joindre dans l'email de notification un snapshot. Il est toutefois possible (dans les règles d'actions) d'ajouter l'exécution d'une requête HTTP à destination de YAPUSS - Passerelle "Universelle" Surveillance Station de @sebcbien), mais je ne l'ai pas encore testé.
Hello les gars. Un petit UP au cas vous n’auri pas vu ma demande ci-dessus -
@Nico mais là, ont joue plus dans la même catégorie et le même budget
Quel module est-ce vous utiliseriez pour commander via fil pilote sur un sèche serviette ACOVA ? -
Hello @Cardane comment se passent tes tests ?
Mes résultats SpeedTest, très proche de ceux @Lazer : Pour l'armoire, moi j'ai fais chip mais efficace : un meuble haut de cuisine percé sur le haut du meuble pour le passage des câbles : 2 goulottes électriques fixées sur le haut du meuble dans lesquels j'ai intégré : (percées également pour le passage des câbles) des prises électriques Legrand pour brancher mes équipements positionnés dans la meuble (mes switch et mon routeur Orange) et un passage pour la Fibre Orange. des prises RJ45 Legrand sur lesquels sont raccordées l'ensemble de mes câbles en provenance de mes pièces. Cela fait office de bandeau de brassage. Voici une photo qui date un peu, mais elle donne une bonne idée de l'ensemble. Depuis, j'ai doublé les prises électriques et les prises réseau. Intégré le routeur Orange, .... Concernant les ondes, ma HC2 principale est à l'étage donc non perturbée par les ondes. Seule ma HC2 de backup est dans le placard. Maintenant au prix des prises Réseau Legrand 6,44 euros l'unité prix vue sur internet multiplié par le nombre de prises, il est peut-être possible de trouver un bandeau de brassage moins cher. Mais tout dépend du nombre de prises RJ45 nécessaires.
