Support Gea
Steven
Il y a 6 heures, pepite a dit :
Hi @Kristiano sorry for the late answer
Yes you can put any properties of a device as a trigger.
I kept the "506 secured" as a trigger only.
Still can't get anything in the log for the new code. Still my code is triggered. (First 2 GEA lines)
GEA.add({"Value", id["UTILITY_DOOR"], 0}, 30*60, "Förrådsdörr olåst >30min")
GEA.add({"Value", id["UTILITY_DOOR"], 0}, -1, "", {"HttpRequest", "https://10.0.1.31:8088/spc/area/2/unset", "PUT", ""})
-- tests
GEA.add( {"DoorLock", "Value"}, -1, "The door is : {Result}")
GEA.add( {"DoorLock", 506, "Value"}, -1, "The door is : {Result}")
GEA.add( {"DoorLock", "Secured"}, -1, "The door is : {Result}")
GEA.add( {"DoorLock",506, "Secured"}, -1, "The door is : {Result}")
[DEBUG] 16:03:17: Started by event of GEA 6.07 (mode property [506])
[DEBUG] 16:03:17: --------------------------------------------------------------------------------
[DEBUG] 16:03:17: @0s [Validation*] #54 [Value, [506,0]][HttpRequest, ["https:\/\/10.0.1.31:8088\/spc\/area\/2\/unset","PUT",""]]
[DEBUG] 16:03:17:    [Started] #54 [Value, [506,0]][HttpRequest, ["https:\/\/10.0.1.31:8088\/spc\/area\/2\/unset","PUT",""]]
[DEBUG] 16:03:17:         [action] [HttpRequest, ["https:\/\/10.0.1.31:8088\/spc\/area\/2\/unset","PUT",""]]
[DEBUG] 16:03:17: @0s [Validation] #56 [DoorLock, [506,"Value"]]
[DEBUG] 16:03:17: @0s [Validation] #58 [DoorLock, [506,"Secured"]]
[DEBUG] 16:03:18: STATUS200 - DATA : {"status":"success","data":"null"}
[DEBUG] 16:03:21: --------------------------------------------------------------------------------
[DEBUG] 16:03:21: Started by event of GEA 6.07 (mode property [506])
[DEBUG] 16:03:21: @0s [Validation] #54 [Value, [506,0]][HttpRequest, ["https:\/\/10.0.1.31:8088\/spc\/area\/2\/unset","PUT",""]]
[DEBUG] 16:03:21: @0s [Validation] #56 [DoorLock, [506,"Value"]]
[DEBUG] 16:03:21: @0s [Validation] #58 [DoorLock, [506,"Secured"]]
[DEBUG] 16:03:24: --------------------------------------------------------------------------------
Hi @Kristiano You receive any push ? "The door is" ?
I don't remember wwhich code you use for "HttpRequest", could you paste it here please ?
With 506 secured as a trigger, could you try this please ?
GEA.add( {"DoorLock",506, "Secured"}, -1, "The door is : #value#", {"HttpRequest", "https://10.0.1.31:8088/spc/area/2/unset", "PUT", ""})
Le 14/04/2018 à 08:35, Sakkhho a dit :
hello les amis, je repost la demande car mon message s'est perdu après la demande de Smart et Flechg
si vous avez un moment pour trouver une piste...
merci
bon malgré votre aide j'ai toujours ce bug
incomprehensible
j'ai desactvité la ligne de GEa et j'ai mis dans le main loop
while true do
   fibaro:call(fibaro:getSelfId(), "pressButton", "1")
   fibaro:sleep(60*1000)
pour appuie toutes les 60s - est ce que c'est OK comme ca ?
on va si ca plante aussi
Bonjour
Pourriez vous me dire si une erreur s'est glissée dans ces quelques lignes?
Ceci ne veut pas fonctionner depuis que j'essai d'utiliser la fonction "Monthly" intégrée à GEA.
Merci d'avance pour votre aide
  -- Backup le 1er samedi du mois
  GEA.add({{"Time","01:30"},{"Monthly", "Saturday"}} , 30 , "Backup mensuel de la HC2" , {{"Scenario", id["SC_HC2_BACKUP"]},{"Email", id["USER_ERIC"],"Backup mensuel de la HC2 - #date#","INFO TECHNIQUE - HC2"}})
  GEA.add({{"Time","02:00"},{"Monthly", "Saturday"}} , 30 , "Suppression mensuel du plus vieux backup de la HC2" , {{"Scenario", id["SC_HC2_BACKUP_SUPP"]},{"Email", id["USER_ERIC"],"Suppression mensuel du plus vieux backup de la HC2 - #date#","INFO TECHNIQUE - HC2"}})
Le 30/04/2018 à 14:31, Dragoniacs a dit :
@pepite
J'ai mis ton code dans la partie config(), ça tourne.... reste plus qu'à ouvrir une fenêtre pour voir ce que cela donne (pas de garantie que je le fasse ce soir, ça caille à mort !!!)
Je pense que ton code fonctionne partiellement.
J'ai cette ligne qui gère plusieurs fenêtres :
  GEA.add({"Or",{id["PF_JARDIN"],id["PF_RUE"],id["FEN_RUE"],id["FEN_CUISINE"]}}, 10*60, "#name# est ouverte depuis #duration#", {{"Repeat"}})
J'ai ouvert la fenêtre de la cuisine.... aucun message (pas même partiel !)
J'ai ouvert la PF du Jardin : message complet, avec le nom !
je crois que seule la première est prise en compte....
Aide moi
après la mise à niveau vers 4.180, GEA ne fonctionne pas
Je n'ai rien changé dans son code
[DEBUG] 02:08:29: --------------------------------------------------------------------------------
[DEBUG] 02:08:29: Started automatically of GEA 6.06 (mode autostart)
[DEBUG] 02:08:29: Use minifiertools v. 2.00
[DEBUG] 02:08:29: Check automatic every 30 seconds
[DEBUG] 02:08:29: Creation of GEA_Tasks6N global variable
[DEBUG] 02:08:29: Creation of GEA_HistoryN global variable
[DEBUG] 02:08:30: [1;31m2018-05-06 02:08:30.842913 [ fatal] Unknown exception: /usr/share/lua/5.2/json/decode.lua:91: Unclosed elements present
J'ai supprimé les variables, mais cela n'a pas aidé
J'ai aussi commencé GEA sans mes instructions, seulement avec un test " GEA.add(true, 0, "Démarrage de GEA le #date# à #time#")", ça ne marche pas non plus
J’ai eu un problème +/- similaire
1 j’ai copier mon code dans un éditeur de texte
2 supprimé la scène GEA et les fariable gea
3 crée un nouvelle scène ou j,ai colé le code GEA
4 enregistrée
et ça fonctionné peut être d’avoir changée ID (nouvelle scène GEA)
OU
Simplement supprime tout les ligne de commande et enregistre
et si pas de message d.erreurs
colle tes ligne de commande progressivement et enregistre à chaque ajout de ligne
Modifié par 971jmd
salut a tous
voila j ai cette ligne
 GEA.add({"Weather", "cloudy"}, 0, "XXX", {"VirtualDevice", 156, 13})
est ce que j interprète bien si cloudy alors vd 156 Bouton 13
parce que dans l api je suis bien cloudy mais rien ne se passe
merci encore
Voila comment j ai fait pour me servir de l état
j ai mis dans le mainloop d un vd le code suivant
HC2 = Net.FHttp("127.0.0.1",11111)
response = HC2:GET("/api/weather")--ip/api/weather a mettre dans
								----navigateur
	-- enregistrement du retour de l API dans une table
local response = json.decode(response)
local Wind = response.Wind
local temperature = response.Temperature
local humidite = response.Humidity
local etat = response.WeatherCondition
fibaro:debug("la vitesse du  vent est de " .. Wind .. "km/h")
fibaro:debug("la temperature est de " .. temperature .. "°C")
fibaro:debug("l'Humidité est de " .. humidite .. " %")
fibaro:debug("condition " .. etat .. "  ")
fibaro:setGlobal("EtatWeather", etat) ---- Créer la variable EtatWeather qui recoit cloudy clear ou rain ect...
fibaro:sleep(50*60*60) ----sleep de 5min
créer la variable EtatWeather qui reçoit les conditions mais on peut aussi créer des variables pour la température le vent ect...
ensuite dans Gea
GEA.add({"Global", "EtatWeather", "clear"}, 30, "XXX", {"VirtualDevice", 156, 13})
si cela peut aider
cdt
@971jmd Merci pour votre aide,
Mais malheureusement, même la nouvelle GEA n'a pas fonctionné avec la nouvelle ID ;-(
Restauration de la sauvegarde (effectuée sur la version 4.170) était effective (mais pas fais sur 4.180).
Le problème était probablement lié à la copie du navigateur et au mauvais encodage des caractères, imposé par le site Web de HC2
Bonjour à tous,
Désolé, un peu occupé avec tous ses ponts ;-)
Pour les malades du Weather, pouvez-vous essayer cela svp ?
GEA.add({"Weather", "WeatherCondition"}, 0, "Le temps est {Weather}")
Et vous avez tenté avec WeatherLocal ? Qui traduit Weather en fait ;-)
Il y a 15 heures, flechg a dit :
								----navigateur
ensuite dans Gea
si cela peut aider
cdt
salut
je cherche a réaliser la même  chose avec http://xxxx.xxxx.xxx.xxxx/api/panels/location
mai ça ne fonctionne pas
merci pour ton aide
response = HC2:GET("/api/panels/location")
local name = response.name
fibaro:debug("le nom est " .. name .. " ")
Modifié par 971jmd
@pepite
Une nouvelle idée ?
Envoyé de mon SM-A520F en utilisant Tapatalk
@971jmd il faut mettre l id qui apparait quand tu mets  http://xxxx.xxxx.xxx.xxxx/api/panels/location ensuite
 HC2 = Net.FHttp("127.0.0.1",11111);
response, status, errorCode = HC2:GET("/api/panels/location/id"); --- id a changer avec ton Id
jsonTable = json.decode(response);
  fibaro:debug(response);
local nom = jsonTable.name;
 fibaro:debug(nom);
@pepite j avais essayé ce que tu as proposé ca retourne bien l état mais dans gea cela ne fonctionne pas :15:
GEA.add( {"Weather", "Cloudy"}, 0, "", {"VirtualDevice", 156, 12})
GEA.add( {"Weather", "rain"}, 0, "", {"VirtualDevice", 156, 12})
 ca a appuyé dans les deux cas  c est pour cela que je suis passé par une variable:74: bonne soirée
Le 2018-05-02 à 11:01, pepite a dit :
Its not getting triggered.
The thing is that "secured" carries value "255" instead of "1". Is this handled?
Kristian
Petit souci lors du passage de la V5 à la V6 avec SceneActivation ....
Commande qui marche avec la V5 (pas d'entête 472, seulement 472 sceneActivation) et qui ne marche pas avec la V6
    GEA.add( {"SceneActivation", 472, 14}, -1, "Portail SUD ON", {{"turnOn", 80}})
Merci  :74:
