Le 31/07/2025 à 10:33, flacon030 a dit :
Oui c’est se que je fait aussi pour domochart, mais pour grafana et influx db c’est pas la même histoire, sans parler des scènes et de gea que je dois modifier à chaque fois
Chez moi Grafana va lire la même DB que Domochart, et oui, il faudra également faire la modif dans Grafana.
Pour GEA et autres, j'utilise la QA DeviceID, certes c'est chi..., mais ça facilite
brefs j’en ai marre, je voie pour supprimer un maximum d’éléments de netatmo
bienvenue au club !
Le 31/07/2025 à 10:48, flacon030 a dit :
si non autre suggestion, faire un qa crypté avec jeton payant avec mise à jour automatique comme le qa de influx db qui est payant mais avec mise à jour automatique
Interesting. Please, can you provide me a link to mentioned Influx db QA? Where I can find it? Thank you
Le 01/08/2025 à 22:43, flacon030 a dit :
Je ne connais pas le qa DeviceID
il se trouve ou?
dans ma signature ...
  • 4 semaines après...
Le 31/07/2025 à 09:27, Sankotronic a dit :
Hi @flacon030,
You are completely right about needing to reinstall encrypted QA each time when there is an update released.
I guess with encrypted QA that will be always the case, needing to replace QA, because I do not believe that Fibaro will change anything related to encrypted QA and security in the future.
On the other hand I do not find that as a big problem. Most of my work does not need much of the upgrades except in case like with Netatmo decided to again change their API or server domain. Since that is something that does not happen very often...
In case of my work, there is always possibility to get unencrypted version that can be then easily upgraded by changing code, but that has a price.
Hello Sankotronic. Plugin was working fine until today, after a problem with global variable on another point.
I just seen after that I have not moved all to .com address, so done (I am on HC2 version).
But always the same, I have already regenerated token, I have :
Any idea ?
Update : I found, I need to delete NetatmoW_scene_[scene ID]
Hi @Nico,
Sorry for late replay. To renew tokens for Netatmo Weather station standalone version follow this steps:
  1. Get new tokens at Netatmo my apps
  2. Open Netatmo weather scene and paste new tokens to code
  3. Delete global variable NetatmoW_scene_[scene_ID]
  4. Save scene and run it at least once manually so that global variable is generated with new tokens
Instead of deleting global variable you can just change local variable scVersion from "3.2" to "3.3" and then save scene and run manually at least once. Hope this helps.
