HC3 - 5.041.50 - BETA - 28/09/2020
mprinfo
HC3 - 5.041.50 (beta)
Thank you for using the FIBARO Home Center 3!
Our constant improvements are to make your experience better. Be sure to update to the latest version to enjoy new features.
What's new:
Block Scenes
Selecting user or device in Notification/Push action block.
Simplified conditions for Z-Wave door locks.
Climate
Brand new climate zones control dashboard, available to any user:
Setting selected zone or whole house to manual or vacation mode.
Going back to schedule from manual or vacation mode.
Dashboard
Control of door lock type devices from the right sidebar.
Devices
Nice BiDi-ZWave notifications of obstacle detection, force exceeding, and hardware failure:
Inactive by default in device notifications settings.
To be displayed in system notifications panel or sent as push or e-mail messages.
Generate relevant events to history panel.
Available as conditions in block scenes.
Improved time shifter with four different timespans under device charts.
Possibility of copying the Z-Wave configuration parameters settings from another device. New linked device -
Multilevel Sensor with four possible statistical functions.
Notification when any device belonging to linked device was removed.
Possibility to set theoretical power consumption for devices without power metering.
Increased the maximum number of digits in Z-Wave door locks pin codes to eight.
Support for Era Inn Edge Tubular Motor version 1.1 or higher.
Support for REHAU RE.GUARD Smart water control system.
Support for Steinel RS LED D2 Z-Wave.
Garden
Displaying name of the weekday for a next watering sequence.
History
Added button to quickly go back to the top of the list.
Improved readability of events related to device reconfiguration.
Lua Scenes
Blocked the possibility of sending an empty push/interactive-push message.
Network
Improved the responsiveness of network settings page for mobile devices.
Nice
Support for Nice bi-directional devices using PLN2+ communication protocol.
Possibility to force the Nice device synchronization if the device does not respond.
Assigning default device category based on its type when adding a new Nice device.
Backup and restore of Nice mono-directional devices.
Other
Redesigned order of items in the left sidebar.
Indication of sortable columns in the tables.
Minor fixes to the dark theme of the interface.
Unified behaviour of drop-down lists.
Two new language versions: Chinese simplified and Portuguese BR.
Improving the performance of the interface.
Quick Apps
Displaying the complete view of the Quick App in the FIBARO Home Center mobile app.
Autocompletion of global variables names in getGlobal() and getVariables() functions.
Prompting for a list of actions and device properties in the left sidebar.
Possibility to set a role of the roller shutter device type.
Improved closing and removing of edited control.
Added support for WebSockets.
Scenes
Brand new scenes control dashboard, available to any user:
Running a scene with one click on the tile.
Scenes divided into active and inactive.
Displaying when the scene was recently launched.
Filtering scenes by categories or using a search bar.
Possibility of showing scenes which are hidden.
Added search engine in scene settings.
Unified order of scene categories.
Update
Possibility of cancelling the downloaded update before its installation. I
mproved displaying of current and available software version.
Bug fixes:
Block Scenes
Action block for a group of devices is not available.
Editing any block scene results in an excess of requests that overload the interface.
Dashboard
Showing and hiding hidden rooms results in the wrong devices being displayed.
Devices
No icon of an unconfigured device when adding a new Z-Wave device.
Removing a device belonging to a climate zone from a linked device results in system crash.
No camera image preview for a video gate linked device.
No notifications from devices are sent when set to active by default in the latest update.
Values on device charts are not sorted according to timestamp.
General
No possibility to set date and time manually.
History
Incorrect icons for FIBARO RGBW 2 (FGRGBW-442).
Nice
Internal server error when adding a new Nice device.
Other
Services are not restarted automatically when restoring the backup was cancelled.
Plugins
No camera image preview for FIBARO Intercom when using a remote access.
Profiles
Enabling any profile that runs the block scene results in an excess of requests.
The profile to which the user has no access does not refresh automatically.
Recovery
Resetting the network settings requires a manual reboot of the gateway.
Scenes
Copying a few scenes one by one makes the interface unavailable for several minutes.
Scenes based on user's location are not triggered properly.
Update
Error 409 when trying to cancel an ongoing update download process.
Modifié par Lazer
  • Thanks 1
Quelqu'un a trouvé la doc pour utiliser les WebSockets ?
Je ne trouve rien, ni sur le site officiel, ni sur le forum officiel...
Ils n'auraient quand même pas osé ne pas partager la documentation complète, ce n'est pas leur genre ! :rolleyes:
@Krikroff tu n'aurais pas un petit bout de code à nous partager, histoire qu'on se mette quelque chose sous la dent et qu'on commence à explorer les possibilités ?
il y a 5 minutes, mprinfo a dit :
P'tin de grffiers à la con ! j'en suis à mon 5ème restore après 2 factory reset, là j'essaye avec un vieux backup pour vérifier si mon dernier est vérolé.
ça sent vraiment le support ou alors je réinstalle from scratch mais là c'est encore une autre histoire...
Problème identifié mon plugin satel foutait la grouille, j'en ai cramé des heures avec cette M.....!!! Maintenant que j'ai supprimé / recréé le plugin faut que je me tape tout mon code pour le réaligner avec les nouveaux IDs, le panard !!!
[mention]Lazer [/mention]c’est une drôle de pratique de sortir des fonctionnalités sans la documentation associée Pas encore eu le temps de regarder mais j’ai une petite idée sur le sujet, je vais voir...
[mention]TonyC [/mention] et bien j’ai eu chaud aux fesses dis-moi, j’ai passé la bêta avec ma Satel .C’est quoi l’explication du support ?
Il y a 11 heures, Krikroff a dit :
[mention]Lazer [/mention]c’est une drôle de pratique de sortir des fonctionnalités sans la documentation associée emoji1787.png Pas encore eu le temps de regarder mais j’ai une petite idée sur le sujet, je vais voir...
[mention]TonyC [/mention] et bien j’ai eu chaud aux fesses dis-moi, j’ai passé la bêta avec ma Satel emoji33.png.C’est quoi l’explication du support ?
Salut @Krikroff, j'ai passé une bonne partie de la nuit à trouver la cause de ce bordel, pas d'explication car pas contacté. Je ne pense pas que le plugin satel soit la cause en soi, enfin si mais probablement parce qu'il c'était barré en coquillettes sournoisement (le logsdump en témoigne ... ) .
Donc je l'ai viré, upgradé puis réinstallé après avoir effectué la mise à jour, c'est passé comme une lettre à la poste. Plus de 100 modules à réaligner dans le code car réattribution de nouveaux IDs bien sure .... Bref je ne pense pas qu'il faille incriminer le plugin dans tout les cas, donc tu dois pouvoir y aller les yeux fermés, gardes en un quand même ouvert on ne sait jamais, mais au moins tu sauras quoi faire sans trop galérer :) .
Il y a 6 heures, jjacques68 a dit :
aaaah bon ben je sais ce que je fais ce soir :) ... ...
On peut passer directement de la 5.031.33 à la 5.041.50 sans passer par la 5.040.37 ?
En principe, oui !
(j'ai déjà eu l'occasion, mais avec HC2...)
Moult backups avant bien sûr !
Ca commence très fort, 2 erreurs signalées (apparemment lors du backup cloud) :
(backup anormalement long...)
Error while dumping Z-Wave memory
(pas d'explication...)
Not enough space
(mémoire = 50% - stockage = 78%, 52% sur le cloud)
Donc pas de mise à jour dans ces conditions.
Et (very hard) reboot (arrêt avec le bouton, débrancher la prise, et rebrancher few minutes later...
(Et là, le voyant vert de mise à jour disponible est apparu !)
Après suppression de tous les backups (sauf 1) du disque et du cloud, re-tentative de sauvegarde.
Fenêtre "Creating backup" bloquée à 80%, pendant au moins 5 minutes...
Et ensuite, toujours cette erreur "Not enough space" !
Allez, je me lance !
Bon c,'est fait ! Successfull !!!
Petit détail : APRES la mise à jour, il est bon de se déloguer, puis se reloguer pour voir apparaître le nouveau bandeau à gauche.
Celui qui permet entre autres d'accéder aux scènes et surtout au retore en cas de pépin.
J'ai pas fait gaffe au début, et je restais sur l'ancien bandeau : le clic sur la roue dentée (accès au scènes, etc...) ne fonctionnait pas.
Légère sueur froide dans le dos...
Mais non, tout s'est arrangé après le nouveau log...
PS1 : Je vais retenter une sauvegarde dans le cloud, juste pour voir...
PS2 : Voyant vert clignote toujours comme un fou ! (ça sent un petit reboot curatif !)
Modifié par Sowliny
Idem !
C'est ce souci du détail qui distingue(ra toujours ?) Fibaro... :2:
Et toujours ces foutus labels "24min il y a {{time}}" !
En attendant la résolution de ces menus désagréments, ça semble bien tourner.
Oserais-je parler d'une interface plus réactive ?
PS : le système a enfin remarqué que la mise à jour a été (bien) effectuée, et a éteint la LED verte !
Modifié par Sowliny
tu m'as fait rire @Nico en modules physiques appelés zones ou outputs dans la satel (plus généralement dans les systèmes d'alarmes) je n'en ai qu'une soixantaine mais il y a des "modules" logiques (toujours zones ou outputs) pour retourner des états par exemples, j'en ai une floppé plus ou moins utiles, donc une bonne centaine en tout.
Sinon versailles j'ai hésité mais le proprio à des gouts bizarres coté déco, puis il doit être narcissique car il y a une pièce pleine de miroirs, je ne veux pas savoir ce qu'il fait dans cette pièce, ça ne me regarde pas !!...  puis le jardin, j'ten parle pas, pas que ça à foutre que tondre tout le WE ! les voisins, j'oubliais les voisins, aucuns savoir vivre, ils débarques dans ton jardin, tranquilles, avec leur nappes, leurs petits paniers et il sont là, ils vont dans la piscine avec des bateaux, bref c'est comme s'ils étaient chez eux. Non vraiment j'ai pas pris :D
EDIT:
Je viens de trouver un tit bug un peu chiant, api/networkDiscovery/arp est en berne, a plus ko. Donc plus de scan arp possible pour les scènes de présence...
Modifié par TonyC
  • Haha 2
