fredokl 422 Signaler ce message Posté(e) 17 octobre 2022 (modifié) Et ben dis donc, ça bosse en ce moment chez Fibaro. Ou peut-être que les deux dernières Beta n'étaient vraiment pas stable pour le coup! Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. Main features: 1. Redesigned the way user access settings works From now on, it is possible to grant access to devices and scenes by entire sections or rooms in the system. Access to newly added devices and scenes will be automatically granted if an entire section or room is selected. New user will automatically have access to the entire system from the beginning. 2. Scenes can be assigned to rooms From now on, all types of scenes can be assigned to rooms, not just categories. 3. Z-Wave devices exclusion wizard Z-Wave exclusion is now available in new wizard style. Additionally there is an option to start exclusion directly from failed inclusion process. What's new: Devices Added Gateway filter to devices list. Added possibility to filter out power metering devices from mobile application energy panel. Changed UI for icons selection. Heatit ZM Single Relay 16A support. Heatit ZM Thermostat 16A support. Heatit Z-Push Wall Controller support. Heatit Leakage Stopper support. Network Automatic selection of network connection type in FTI if only one is available. Nice* Optimized support for OXIBD module. Other Optimized trim of events database. Performance improvements. Added system notification about potential performance loss due overheating. Added possibility to clear all system notifications at once. Profiles Changed UI for icons selection. Quick Apps Power sensor device type added to QuickApps. Removed password saving option in browser for secret variables. Rooms Changed UI for icons selection. Scenes Added validation for time inputs in block scenes. Devices used in scenarios and hidden later are now shown on the devices list. Scenes name limit is changed to 60 characters. Changed UI for icons selection. Update Translations support for devices Update Service.** Devices update now available using remote access. Z-Wave Performance improvements.** Bug fixes: Alarm Some alarm scenes are not listed in Alarm tab. Climate Panel Some devices set to "Hold" in manual mode returns to schedule anyway after 7 days. Climate zone deactivation does not work for some device types. Dashboard Favorite position label defined by user is not used on dashboard tiles and sidebar. Alarm status "dots" on sensors tiles does not change color according to current zone state. Scrolling long names does not always show the full text on device tiles. Devices Issue with displaying current values of bit-mask type configuration parameters. Cannot navigate to child device using "parent-child" tree when filters are enabled. Newly added device is not visible when filters are set. After adding a camera, modal for adding "other devices" stays open. Wrong battery status for Sensative strip Guard 700 in some cases. Binary sensor cannot be used for Video Gate linked device. Missing possibility to sort devices using battery level. Minor fixes in UX for new devices filters. Missing support for some actions related with color control (fading, enhancing, stop color change). HeatIt ZM Thermostat 16A set-point issue requires reconfiguration to work properly (introduced in 5.121.28 beta). Elero* Devices are marked as dead during binding procedure in rare cases. Gateway Connection Incorrect role handling for FIBARO RGBW 1. Missing possibility to exclude device from slave gateway. Nice* Redundant "Stop" button for gates on control dialog in mobile application. Removed redundant step in "pairing a remote in gateway" binding process. Other Fixed Recovery UI issues in German language. Wrong display of "not used" RAM value in diagnostics. Not saved system language during FTI in some cases. Notifications creation time is calculated according to browser time, not system one. Mismatched translations when leaving Recovery mode. Some cases encountered system booting issue after update (introduced in 5.121.28 beta). Incorrect notification about HC3 gateway overheating (introduced in 5.121.28 beta). Newly added devices access issues for mobile app and web interface users (introduced in 5.121.28 beta). Quick Apps Missing logs in console after page refresh. Quick App sprinkler device type is not supported in Garden Panel. QuickApps content loading issue while using the remote connection (introduced in 5.121.28 beta). Scenes Unnecessary popup with "unsaved changes" in some cases for Scenarios. Update Impossible to start second update for battery-operated device.** Last target in devices update stays in "In Progress" status even if whole process ended.** Z-Wave Engine crash in some cases during multiple network management operations.** Known issues: Z-Wave Engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. Gateway connection is not available in the new Z-Wave engine version. * - does not apply to HC3L (Home Center 3 Lite) ** - applies only to Z-Wave Engine 3.0 Version française: 5.132.45 Merci d'utiliser notre passerelle ! Assurez-vous de mettre à jour la dernière version pour profiter des nouvelles fonctionnalités et améliorations. Caractéristiques principales: 1. Refonte du fonctionnement des paramètres d'accès utilisateur Désormais, il est possible d'accorder l'accès aux appareils et aux scènes par des sections ou des pièces entières du système. L'accès aux appareils et scènes nouvellement ajoutés sera automatiquement accordé si une section ou une pièce entière est sélectionnée. Le nouvel utilisateur aura automatiquement accès à l'ensemble du système depuis le début. 2. Les scènes peuvent être attribuées à des pièces Désormais, tous les types de scènes peuvent être attribués à des pièces, pas seulement des catégories. 3. Assistant d'exclusion des appareils Z-Wave L'exclusion Z-Wave est désormais disponible dans un nouveau style d'assistant. De plus, il existe une option pour démarrer l'exclusion directement à partir du processus d'inclusion ayant échoué. Quoi de neuf: Dispositifs Filtre de passerelle ajouté à la liste des appareils. Ajout de la possibilité de filtrer les appareils de mesure de puissance à partir du panneau d'énergie de l'application mobile. Modification de l'interface utilisateur pour la sélection des icônes. Prise en charge du relais simple Heatit ZM 16A. Prise en charge du thermostat Heatit ZM 16A. Prise en charge du contrôleur mural Heatit Z-Push. Support Heatit Leakage Stopper. Réseau Sélection automatique du type de connexion réseau dans FTI si un seul est disponible. Nice* Prise en charge optimisée du module OXIBD. Autre Garniture optimisée de la base de données des événements. Amélioration des performances. Ajout d'une notification système concernant une perte de performances potentielle due à une surchauffe. Ajout de la possibilité d'effacer toutes les notifications du système à la fois. Profils Modification de l'interface utilisateur pour la sélection des icônes. Quick Apps Type de périphérique de capteur de puissance ajouté aux QuickApps. Suppression de l'option d'enregistrement du mot de passe dans le navigateur pour les variables secrètes. Pièces Modification de l'interface utilisateur pour la sélection des icônes. Scènes Ajout de la validation des entrées de temps dans les scènes de bloc. Les appareils utilisés dans les scénarios et masqués ultérieurement sont désormais affichés dans la liste des appareils. La limite du nom des scènes est passée à 60 caractères. Modification de l'interface utilisateur pour la sélection des icônes. Mise à jour Prise en charge des traductions pour le service de mise à jour des appareils.** La mise à jour des appareils est désormais disponible via l'accès à distance. Z-Wave Amélioration des performances.** Corrections de bogues : Alarme Certaines scènes d'alarme ne sont pas répertoriées dans l'onglet Alarme. Panneau climatique Certains appareils réglés sur "Hold" en mode manuel reviennent quand même à la programmation après 7 jours. La désactivation de la zone climatique ne fonctionne pas pour certains types d'appareils. Tableau de bord L'étiquette de position favorite définie par l'utilisateur n'est pas utilisée sur les vignettes du tableau de bord et la barre latérale. Les "points" d'état d'alarme sur les tuiles des capteurs ne changent pas de couleur en fonction de l'état actuel de la zone. Le défilement des noms longs n'affiche pas toujours le texte complet sur les vignettes de l'appareil. Dispositifs Problème d'affichage des valeurs actuelles des paramètres de configuration de type masque de bits. Impossible d'accéder à l'appareil enfant à l'aide de l'arborescence "parent-enfant" lorsque les filtres sont activés. Le périphérique nouvellement ajouté n'est pas visible lorsque les filtres sont définis. Après l'ajout d'une caméra, la fenêtre modale d'ajout d'"autres appareils" reste ouverte. Mauvais état de la batterie pour Sensative strip Guard 700 dans certains cas. Le capteur binaire ne peut pas être utilisé pour le périphérique lié à Video Gate. Possibilité manquante de trier les appareils en fonction du niveau de la batterie. Corrections mineures dans UX pour les nouveaux filtres d'appareils. Prise en charge manquante pour certaines actions liées au contrôle des couleurs (estompage, amélioration, arrêt du changement de couleur). Le problème de point de consigne du thermostat HeatIt ZM 16A nécessite une reconfiguration pour fonctionner correctement (introduit dans la version bêta 5.121.28). Elero* Les appareils sont marqués comme morts pendant la procédure de liaison dans de rares cas. Connexion passerelle Gestion incorrecte des rôles pour FIBARO RGBW 1. Possibilité manquante d'exclure l'appareil de la passerelle esclave. Nice* Bouton "Stop" redondant pour les portes sur la boîte de dialogue de contrôle dans l'application mobile. Suppression de l'étape redondante dans le processus de liaison "couplage d'une télécommande dans la passerelle". Autre Correction des problèmes d'interface utilisateur de récupération en langue allemande. Mauvais affichage de la valeur RAM "non utilisée" dans le diagnostic. Langue du système non enregistrée pendant FTI dans certains cas. L'heure de création des notifications est calculée en fonction de l'heure du navigateur, et non du système. Traductions incompatibles lors de la sortie du mode de récupération. Certains cas ont rencontré un problème de démarrage du système après la mise à jour (introduit dans la version bêta 5.121.28). Notification incorrecte concernant la surchauffe de la passerelle HC3 (introduite dans la version bêta 5.121.28). Problèmes d'accès aux appareils nouvellement ajoutés pour les utilisateurs d'applications mobiles et d'interfaces Web (introduits dans la version bêta 5.121.28). Quick Apps Journaux manquants dans la console après l'actualisation de la page. Le type d'appareil d'arrosage Quick App n'est pas pris en charge dans Garden Panel. Problème de chargement de contenu QuickApps lors de l'utilisation de la connexion à distance (introduit dans la version bêta 5.121.28). Scènes Popup inutile avec "modifications non enregistrées" dans certains cas pour les scénarios. Mise à jour Impossible de lancer la deuxième mise à jour pour les appareils fonctionnant sur batterie.** La dernière cible dans la mise à jour des appareils reste à l'état "En cours" même si tout le processus est terminé.** Z-Wave Plantage du moteur dans certains cas lors de plusieurs opérations de gestion de réseau.** Problèmes connus: Z-Wave Engine 3.0 Certains appareils Z-Wave ne sont pas entièrement compatibles avec la nouvelle version du moteur Z-Wave. La connexion à la passerelle n'est pas disponible dans la nouvelle version du moteur Z-Wave. * - ne s'applique pas au HC3L (Home Center 3 Lite) ** - s'applique uniquement au moteur Z-Wave 3.0 Modifié 18 octobre 2022 par Lazer 5.130.45 1 Partager ce message Lien à poster Partager sur d’autres sites
fredokl 422 Signaler ce message Posté(e) 17 octobre 2022 Bon installé et déjà des problèmes. La box pert sa connection réseau aléatoirement. Je vais attendre demain pour voir si ça continu sinon retour en arrière! Partager ce message Lien à poster Partager sur d’autres sites
fredokl 422 Signaler ce message Posté(e) 17 octobre 2022 Autre chose, je trouve l'interface très peu réactive avec cette version. Les icônes des appareils et QA sont très long à charger! C'est une version "beta" estampillée "stable" pour le fun? Partager ce message Lien à poster Partager sur d’autres sites
Bloug 277 Signaler ce message Posté(e) 18 octobre 2022 (modifié) 5.130.45 pas encore testé ! Modifié 18 octobre 2022 par Bloug Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 457 Signaler ce message Posté(e) 18 octobre 2022 Ils n'ont pas résolu le problème de lenteur d'affichage des icônes du dashboard introduit dans la beta précédente, c'est assez navrant. Je me demande s'ils n'ont pas poussé la stable un peu précipitamment, car c'est la même que la beta + hotfix sorti le lendemain. Bref c'est une stable que je vais m'abstenir d'installer sur ma box de prod. 1 Partager ce message Lien à poster Partager sur d’autres sites
fredokl 422 Signaler ce message Posté(e) 18 octobre 2022 (modifié) Oui problème non résolu pour l'affichage. Mais j'ai remarqué que l'affichage est plus rapide avec certain navigateur que d'autre. Sinon pas eu de perte de réseau et de redémarrage de la box cette nuit. Après reflexion, cela c'est produit lorsque je voulais modifier certains droits sur les accès à la box, notamment les scénarios. Je retente une manip ce soir pour voir. Modifié 18 octobre 2022 par fredokl Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 457 Signaler ce message Posté(e) 18 octobre 2022 Même problème de lenteurs d'icônes avec Firefox et Chrome. J'ai créé un topic, au cas où vous voudriez pousser la demande : https://forum.fibaro.com/topic/62569-slow-icons-display 1 Partager ce message Lien à poster Partager sur d’autres sites
jojo 2 608 Signaler ce message Posté(e) 18 octobre 2022 ke trouvais sympa le fait que si on ajoute un appareil à une pièce déjà entièrement autorisée pour un user, il en hérite. Mais à la lecture de vos retours, je passe mon tour Partager ce message Lien à poster Partager sur d’autres sites
ericl78 72 Signaler ce message Posté(e) 18 octobre 2022 Mise à jour effectuée RAS pour l'instant Partager ce message Lien à poster Partager sur d’autres sites
Sowliny 225 Signaler ce message Posté(e) 18 octobre 2022 Comme je l'ai indiqué pour la m.à.j vers la 5.121.28, je vais aussi m'abstenir pour le moment, ma HC3 étant également en prod. Je ne trouve pas d'arguments suffisants pour tenter le coup. Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 457 Signaler ce message Posté(e) 18 octobre 2022 Surtout qu'en plus il n'y a pas des masses de nouveautés dans cette version. Je me demande bien ce qui a pu pousser Fibaro à la passer aussi vite en stable. Partager ce message Lien à poster Partager sur d’autres sites
jojo 2 608 Signaler ce message Posté(e) 18 octobre 2022 ils étaient probablement nostalgiques des débuts de la v4 de la HC2 ??? Partager ce message Lien à poster Partager sur d’autres sites
Dragoniacs 433 Signaler ce message Posté(e) 19 octobre 2022 Je crois qu'ils ont raté 2 beta et ont voulu stabiliser rapidement le truc.Envoyé de mon M2012K11AG en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
flacon030 146 Signaler ce message Posté(e) 19 octobre 2022 (modifié) Pour ma part tous semble toujours OK Seul le device YR Weather est toujours figé ou presque il y a de longue période ou il n'y a aucune valeurs A voir le reste dans le temps Modifié 20 octobre 2022 par flacon030 Partager ce message Lien à poster Partager sur d’autres sites
ROBBEJP 31 Signaler ce message Posté(e) 25 octobre 2022 Hello tout le monde, Version toute foireuse, j'en ramasse encore mes dents Elle a été retiré il y a quelques heures... En gros: - Problème de plantage réseau impliquant des reboot de service - Réseau Zwave qui ne communique plus ... ou mal - Scène qui disparaissent puis réapparaissent après reboot - Casper le petit fantôme qui sort de la boite et fait peur à maman - ... 2 Partager ce message Lien à poster Partager sur d’autres sites
Dragoniacs 433 Signaler ce message Posté(e) 26 octobre 2022 Ah je me demandais pourquoi ma box ne me la proposait plus...Envoyé de mon M2012K11AG en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
flacon030 146 Signaler ce message Posté(e) 26 octobre 2022 curieux cette histoire Perso je ne rencontre aucun problème pour le moment Partager ce message Lien à poster Partager sur d’autres sites
ROBBEJP 31 Signaler ce message Posté(e) 26 octobre 2022 Il y a 1 heure, flacon030 a dit : curieux cette histoire Perso je ne rencontre aucun problème pour le moment Je n'avait pas personnellement de soucis particulier depuis la mise à jour ... jusqu'au jour où, d'un seul coup, des plantage réseau sont apparu. J'ai tenté plusieurs reboot (je suis câblé en RJ45) et paf quelques heures après... j'ai pas compris. Me suis connecté sur le forum officiel pour voir ... et suis tombé sur l'article. J'ai de suite lancé un rollback et plus de pb, ça tourne nickel now Le 19/10/2022 à 13:12, Dragoniacs a dit : Je crois qu'ils ont raté 2 beta et ont voulu stabiliser rapidement le truc. Il ont raté les BETA et la stable aussi Partager ce message Lien à poster Partager sur d’autres sites
fredokl 422 Signaler ce message Posté(e) 26 octobre 2022 Constat depuis l'installation de la mise à jour. J'ai quand même laissé tourné cette version pour voir si elle était stable dans le temps, et ben, après les déboires du début (perte de réseau, crash de la box et lenteur d'affichage), je dois admettre que pour moi, elle tourne bien pour le moment. Mise à part les lenteurs d'affichages qui sont toujours présentes, la box ne perd plus le réseau et pas de crash non plus. Mais bon, j'attends quand même la nouvelle version stable avec impatience! Partager ce message Lien à poster Partager sur d’autres sites
