Lazer 8 477 Signaler ce message Posté(e) 2 mars 2023 Firmware HC3 & HC3L Version 5.140.17 Stable Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. Main features: 1. New way of controlling devices from Dashboard sidebar Completely redesigned control of color controllers. Support of color temperature setting for the Zigbee devices. 2. New predefined scenarios designed to control lights based on time conditions and gates status What's new: Climate Added possibility to assign temperature sensors for climate zones. Dashboard Possibility to add devices from the dashboard. Added battery level indicators on devices tiles. Devices Optimised procedure for adding devices for all protocols. Improved UI/UX and performance for device page filters. Added filters clearing mechanism when leaving the page. Added the description field for every device type. Redesigned family of devices view. Energy Modified page layout for energy meters configuration in panel settings. Gateway connection Added an option to define Slave IP address manually. Added additional redundancies for unexpected changes in network configuration. Nice* Improved support for OXIBD status updates. Added generic support for legacy Bidirectional shutters. Improved support for device specific notifications. Other Improved algorithm for gateway overheating notifications. Minor UI/UX improvements. Plugins Added support for pulling the latch for the Tedee door lock. Improvements for Heat Activator plugin. Quick Apps Added support for the Base Shutter device type. Scenes Added the filters for Scenes page. Added "tolerance" option for Energy Panel block scenes. Improved blocks content loading performance for large systems. Added the description field for every scene type. Changed the order of steps for Scenarios. Update Added possibility to update all devices. Added additional warning before upgrading to the beta version of the hub. Zigbee Improved generic support for lights and color controllers. Z-Wave Added handling of suspended device interview during the adding procedure for battery-powered devices.** Support for different revisions of the Aeotec Multisensor 6. Support for the ZW800 series MCO IR2900 thermostat. Support for the Everspring SP103.** Bug fixes: Climate The zone control freezes if the last setpoint is set at 5:00am. Dashboard Redundant page refresh in some cases (introduced in 5.131 beta). Devices Issues with the display of some configuration parameters values. Elero* The RolSolar device is incorrectly marked as disconnected. Using favorite positions in group actions does not work. Excessive battery drain for the RolSolar shutter. Energy Energy charts are malformed occasionally. Negative energy consumption data in the panel after clearing the energy data in some cases. Negative power consumption values for "Grid consumption" setting in some cases. FTI No masking of Wi-Fi password during the first configuration on Firefox. Gateway Connection Connection issues in specific network configurations. In some cases the system does not boot correctly when the master gateway update fails. Nice* Losing possibility to control devices in some cases. Fixed issue with binding some mono-directional devices. Custom icons for mono-directional devices not visible. Issues when pairing new models of roller shutter with BiDi protocol. Other Added possibility to enable remote access for support from recovery system. Standard user cannot remove interactive push. Issues with controlling the linked-device thermostat in some configurations. System crash while deleting a non-existing notification. Wrong time in history after the change from winter time to summer time. Adding more than one Other device by clicking the add button excessively. The state of devices is not refreshed when pressed run scene button without refreshing the page. Other UI/UX fixes. System stability fixes (introduced in 5.131 beta). Incorrect radius instead of diameter in the Location tab. Plugins Lack of live preview for Helios 2N plugin. Tedee lock plugin loses connection to services (introduced in 5.131 beta). Profiles Incorrect display of climate panel settings. Incorrect display of sliders in profiles settings. Quick Apps Secret variable value visible in the webUI after saving. Scenes Elero RolMotion blind is controlled even if excluded from a simple scenario. Incorrect display of sliders in block scenes. Cannot edit Scenarios via mobile app in remote connection. No possibility to enter exact minutes in no later/earlier fields in scenarios (introduced in 5.131 beta). The filter in the room drop-down menu does not work properly (introduced in 5.131 beta). Zigbee Wrong time unit during the adding process. Z-Wave No possibility to update Z-Wave devices added in Security mode. Lack of handling unsolicited reports from devices using CC Basic.** Issues with updating devices from file in some cases.** Incorrect default role for the Zooz ZAC36 valve. Improved adding procedure when using S2U security level.** The exclusion process cannot be closed after an error has occurred. Known issues: Z-Wave Engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. Gateway connection is not available in the new Z-Wave engine version. * - does not apply to HC3L (Home Center 3 Lite) ** - applies only to Z-Wave Engine 3.0 2 Partager ce message Lien à poster Partager sur d’autres sites
flacon030 148 Signaler ce message Posté(e) 2 mars 2023 Mise a jour effectué RAS pour le moment Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 336 Signaler ce message Posté(e) 2 mars 2023 Soyons fous je viens de mettre a jour mes 2 box on verra bien................. Partager ce message Lien à poster Partager sur d’autres sites
Renan 14 Signaler ce message Posté(e) 2 mars 2023 Mise à jour RAS. Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 336 Signaler ce message Posté(e) 2 mars 2023 Impressionnant le code pour éteindre toutes les lumières api.post("/devices/groupAction/turnOff", json.decode("{\"filters\":[{\"filter\":\"or\", \"value\":[{\"filter\":\"isTypeOf\",\"value\":[\"com.fibaro.binarySwitch\", \"com.fibaro.remoteBinarySwitch\"]}]}, {\"filter\":\"or\", \"value\":[{\"filter\":\"propertyEquals\", \"value\":[{\"propertyName\":\"deviceRole\", \"propertyValue\":[\"Light\",\"NightLamp\",\"GardenLamp\",\"Bracket\",\"Rgb\",\"Rgbw\"]}]}]} ,{\"filter\":\"visible\" ,\"value\":[\"true\"]}]}")) Partager ce message Lien à poster Partager sur d’autres sites
TitiXsi 66 Signaler ce message Posté(e) 3 mars 2023 MAJ ok hier mais j'ai une question annexe ... Ca fait 2 fois que mon dashboard local change de port :42 puis :43 et ce matin impossible sur le 43, et bim le 44: fonctionne ... C'est lié aux MAJ de la box ? C'est connu ? suis-je le seul ? Comment faites vous, sans allez sur votre routeur pour retrouver votre gateway ? Merci Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 477 Signaler ce message Posté(e) 3 mars 2023 Je n'a pas compris ta question.... le port, c'est toujours 80 (http), ou 443 (https), et il ne change jamais. Ce ne serait pas plutôt l'adresse IP dont tu parles ? Dans ce cas, le mieux est de fixer l'IP. Soit depuis ton serveur DHCP (la box internet), ou mieux encore, directement dans la box domotique (Réglages > Réseau) Partager ce message Lien à poster Partager sur d’autres sites
jojo 2 612 Signaler ce message Posté(e) 3 mars 2023 Il y a 23 heures, Lazer a dit : Added battery level indicators on devices tiles. +1 1 Partager ce message Lien à poster Partager sur d’autres sites
jojo 2 612 Signaler ce message Posté(e) 3 mars 2023 Il y a 23 heures, Lazer a dit : Minor UI/UX improvements. + 5000 Partager ce message Lien à poster Partager sur d’autres sites
ericl78 73 Signaler ce message Posté(e) 3 mars 2023 maj effectuée RAS Partager ce message Lien à poster Partager sur d’autres sites
Dragoniacs 436 Signaler ce message Posté(e) 3 mars 2023 Ici aussi, ça roule Envoyé de mon M2012K11AG en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 336 Signaler ce message Posté(e) 4 mars 2023 Je rencontre un soucis avec cette version le probléme rencontré et lors du démarrage de la box si on a une scéne en autostart qui appel l'api cela retourne un json vide la solution pour contourner ce probléme et de mettre un sleep de quelques secondes au début de la scéne Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 477 Signaler ce message Posté(e) 4 mars 2023 ça fait pareil avec les QuickApps ? Dans tous mes QuickApps, j'avais pris pour habitude de mettre un timeout de quelques secondes avant le démarrage de la main loop, j'ai été bien inspiré 1 Partager ce message Lien à poster Partager sur d’autres sites
jjacques68 602 Signaler ce message Posté(e) 4 mars 2023 RAS pour le moment... Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 336 Signaler ce message Posté(e) 4 mars 2023 ça fait pareil avec les QuickApps ? Dans tous mes QuickApps, j'avais pris pour habitude de mettre un timeout de quelques secondes avant le démarrage de la main loop, j'ai été bien inspiré Pour les Quickapp je ne sais pasCe qui m'a mis la puce à l'oreille pour les scènes c'est la scène qui averti le démarrage de la box qui me retourne un nil à la place du numéro de série Envoyé de mon BLA-L29 en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
Sowliny 225 Signaler ce message Posté(e) 4 mars 2023 (modifié) Cette fois, je fais cette m.à.j. La dernière était la 5.120.10 ... @Lazer, je note le timeout au debut des Main de QA ! (je suppose que c'est pour favoriser l'initialisation des paramètres (dont les variables) de la QA). + 1h : mise à jour effectuée, reboot sans souci ! Modifié 4 mars 2023 par Sowliny m.à.j. Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 477 Signaler ce message Posté(e) 4 mars 2023 La vraie raison du timeout au début de mes QA, c'est parce que j'en ai beaucoup, et au boot de la box il est inutile qu'ils se déclenchent tous au même moment, créant un pic de surcharge. Temporiser de quelques secondes ne peut que faire du bien. Moins le QA est important, plus la tempo est longue. Et si tu prends tous les QA qui ont un cycle de 60 secondes, ça fait un pic de charge toutes les minutes. Là encore, décaler le pic de charge au démarrage, permet également d'éviter le pic de charge récurrent toutes les 60s. 1 Partager ce message Lien à poster Partager sur d’autres sites
Sowliny 225 Signaler ce message Posté(e) 4 mars 2023 Merci pour la précision - très logique. J'utilisais le principe anciennement sur ma HC2. Mais sur la HC3, pour le moment, jusque là, j'évite d'accumuler trop de process simultanément. Partager ce message Lien à poster Partager sur d’autres sites
Sowliny 225 Signaler ce message Posté(e) 4 mars 2023 Un effet "collatéral " ? Sur l'appli mobile, le souci des icônes remplacées par un point d'interrogation a disparu ! Partager ce message Lien à poster Partager sur d’autres sites
jjacques68 602 Signaler ce message Posté(e) 4 mars 2023 il y a 32 minutes, Sowliny a dit : Sur l'appli mobile, le souci des icônes remplacées par un point d'interrogation a disparu ! ah moi j'en ai toujours !! Partager ce message Lien à poster Partager sur d’autres sites
Sowliny 225 Signaler ce message Posté(e) 4 mars 2023 (modifié) Bizarre, bizarre... Je viens de vérifier, et je confirme. Plus aucun point d'interrogation, que ce soit dans le "Tableau de bord", ou dans les pièces. Ma procédure de m.à.j de la HC3 (rien que du classique) : - sauvegarde locale - sauvegarde cloud - mise à jour et reboot (automatique). Pas non plus de m.à.j de l'appli disponible sur le PlayStore (je suis actuellement en 1.18.0). J'avais juste reçu la notification de la mise à jour vers la 5.140.17 dans l'app. Yubii. Que j'ai poliment déclinée, car j'ai préférer opérer à partir de mon PC. Modifié 4 mars 2023 par Sowliny correction Partager ce message Lien à poster Partager sur d’autres sites
jjacques68 602 Signaler ce message Posté(e) 4 mars 2023 (modifié) suis aussi en 1.18.0, je viens de supprimer les données de l'application, reconnecter le compte, mais change rien, j'ai quelques icônes qui manquent toujours... mais moins qu'avant... Modifié 4 mars 2023 par jjacques68 Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 336 Signaler ce message Posté(e) 5 mars 2023 Idem aucun soucis d icônes sur mon yubii Android Envoyé de mon BLA-L29 en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 477 Signaler ce message Posté(e) 5 mars 2023 La mise à jour 1.18 de l'application mobile Yubii a été publiée il y a quelques jours, et corrige normalement le bug des icônes, ce n'est pas lié à la version du firmware de la box (je suis encore sur une vieille version) On en parle ici : Partager ce message Lien à poster Partager sur d’autres sites
Sowliny 225 Signaler ce message Posté(e) 5 mars 2023 (modifié) J'en tombe... ! Je n'ai pas souvenir d'avoir fait cette mise à jour de l'appli. Ou alors... mais dans ce cas ça m'inquiète A moins qu'elle n'ait été automatique ? Comme je me dis que ce n'est jamais le cas, ça renforce mon inquiétude Je voulais justement aller faire un tour sur le sujet... Quoi qu'il en soit, la correction est efficace. Modifié 5 mars 2023 par Sowliny Partager ce message Lien à poster Partager sur d’autres sites
