Lazer Posté(e) hier à 10:19 Signaler Posté(e) hier à 10:19 Changelog Version 5.180.17 STABLE Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. What's new: Dashboard Added visual feedback for devices with power metering on the device tiles. Devices Performance improvements in binding processes from the mobile application. Heatit Z-Water2 device support added. Heatit Z-TRM6 DC device support added. Updated device dialog for Sound Switch device type. Added a hourglass icon for scheduled actions for HVAC devices. Improved handling of HVAC devices using Fahrenheit scale for temperature control. HeatIt Z-Temp3 support added. Fantem Home Energy Meter Gen 8 support added. Aeotec Home Energy Meter Gen5 2P (US region) support added. Added a possibility to change HVAC devices icons. Elero Added support for legacy Combio JA Pulse device. Added support for Awning device role for various motor types. Gateway Connection Possibility to connect hubs from different networks based on provided IP. Nice* Updated chip SDK for stability and performance improvements. Optimized network configuration for better performance. Domi WSC parameters template updated. Other Updated definitions for binding instructions for the Yubii Home app. Implemented automatic restart of services in case of backup restoration failure and other errors. System boot-up procedure performance improvements. Quick Apps Improved loading time for content provided in the webview. Removed success toasts for webview content which covered the content of the Quick App. The exported QuickApp file now contains a device description. Added automatic code completion for RefreshStateSubscriber function. Plugins Added support for Satel Integra 256 in old FW revision. Scenes Function hub.setTimeout now returns a timeout ID that can be used to clear an ongoing timeout using the hub.clearTimeout. Default behavior for predefined scenario changed - from now no devices are selected by default. Z-Wave Various legacy devices support added to Z-Wave 3.0 engine.** Reconfiguration of the device now keeps original name of the devices entities.** Z-Wave radio module SDK updated for Yubii Home and Home Center 3 Light. Zigbee Introduced the mechanism which prevents losing the network configuration in very rare cases. MOES Human Presence Sensor ZSS-QY-HP (and other revisions) support added. Bug Fixes: Access The advanced user can't remove user's mobile device in Access settings even if right Access is granted. The installer can't upload a backup into the system. Small UI fixes in whole system for the advanced user depending on specific access rights. Installer does not see system notifications for administrator. Backup Error while uploading a Cloud backup in rare cases. Cameras Lack of local preview for some cameras in Safari browser. Dashboard Fixed issues with displaying large values on device tiles for sensors. Lack of state label for binary switches without power metering. Devices Fixed http error 404 when opening thermostat control dialog after deleting climate zone. The header in device protocol-specific notifications is incorrect. Fixed refreshing advanced parameter values when using mobile app device binding process. Inversion settings, device role and favorite positions are not restored in some cases after performing a soft-reconfiguration. Fixed an issue with setting the wake-up interval for battery devices to 0 in some cases after saving the configuration. Custom door lock icons are not displayed. LinkedDevice (binarySensor) does not update the last breach time. Custom icons do not work for CO Detector device type. Lack of correct icons for Silent Open and Silent Close actions on the control dialog. Thermostat Linked Device - fixed the issue when cooling and heating actor is the same device. Qubino Flush Dimmer 0-10V - fixed optional temperature sensor handling. Restored old sets of icons for some device types. Elero UI fixes to the device binding process. Energy Panel Billing periods comparsion - incorrect trend arrow status in UI. Error during saving Energy Panel settings in some cases. Garden Inconsistent behavior when saving settings for watering time when editing sequences. Gateway Connection Issue with Force Removing of the Z-Wave device from the Slave hub.** Issue with listing slaves list in large IP network. Restoring a backup after replacing a slave with new unit fixed. Stability improvements. History Missing thermostat set-point name in history entities. Nice* Rain detector state not always shows correct status for a Climatic Sensor. Fixed binding procedure from the mobile app for BiDi-Multisensor. Corrected parameters template for TT2NBD. Other Fixed an issue with some translations refreshing on the fly when changing the Hub language. The e-mail notification from device added to Slave hub shows wrong device ID in the content. Changing home location using https does not work correctly in some cases. Minor UI/UX fixes. Plugins Fixed camera preview issue for the Nice Cameras plugin after changing the encoding from h265 to another one. Missing IP field configuration in Philips Hue. Fixed issue with Nice Cameras support in scenes when passwords with special signs are used. Quick Apps Fixed an issue with cutting out dropdown content in new device control dialogs. Dropdowns does not work correctly when new view is disabled for mobile application. Function setColorComponent doesn't refresh the view when custom color components are used. Template for Color Controller device type updated. Recovery UI fixes in the recovery interface on Linux based systems. Scenes Issues with saving scenes content via http API when content contains spaces. When adding a simple scenario via the Yubii Home App in installer mode, the description field is covered by the system keyboard. In some cases, in block scenes it is not possible to use push notifications for a specific mobile device. UI fixes in the Yubii Home scenario creator. It is not possible to use negative values in Energy Panel balance blocks. Fixed setting slats position for FGR-224/Rol-Control2 group in block scenes. Fixed issue in Custom Scenarios when FGKF-601 is used as a trigger. Z-Wave Removed not supported "Reconfigure" option for all Z-Wave devices in Z-Wave settings.** Fixed issues with mesh network reconfiguration. Known issues: Z-Wave Engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. * - Does not apply to HC3L (Home Center 3 Lite). ** - Applies only to Z-Wave 3.0 engine. 2 2
flacon030 Posté(e) hier à 13:02 Signaler Posté(e) hier à 13:02 Mise a jour effectué, affaire a suivre
henri-allauch Posté(e) il y a 22 heures Signaler Posté(e) il y a 22 heures Mise à jour effectuée sur Box de Test -> Passage de 5.160.42 à 5.180.17 A suivre
TitiXsi Posté(e) il y a 22 heures Signaler Posté(e) il y a 22 heures (modifié) MAJ Faite, sympa ces petites tuiles d'indication de conso sur les icones Modifié il y a 22 heures par TitiXsi
