HC3 & HC3L - 5.180.17 - STABLE - 07/05/2025
Changelog
Version 5.180.17
STABLE
Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
What's new:
Dashboard
    Added visual feedback for devices with power metering on the device tiles.
Devices
    Performance improvements in binding processes from the mobile application.
    Heatit Z-Water2 device support added.
    Heatit Z-TRM6 DC device support added.
    Updated device dialog for Sound Switch device type.
    Added a hourglass icon for scheduled actions for HVAC devices.
    Improved handling of HVAC devices using Fahrenheit scale for temperature control.
    HeatIt Z-Temp3 support added.
    Fantem Home Energy Meter Gen 8 support added.
    Aeotec Home Energy Meter Gen5 2P (US region) support added.
    Added a possibility to change HVAC devices icons.
Elero
   Added support for legacy Combio JA Pulse device.
   Added support for Awning device role for various motor types.
Gateway Connection
    Possibility to connect hubs from different networks based on provided IP.
Nice*
    Updated chip SDK for stability and performance improvements.
    Optimized network configuration for better performance.
    Domi WSC parameters template updated.
Other
    Updated definitions for binding instructions for the Yubii Home app.
    Implemented automatic restart of services in case of backup restoration failure and other errors.
    System boot-up procedure performance improvements.
Quick Apps
    Improved loading time for content provided in the webview.
    Removed success toasts for webview content which covered the content of the Quick App.
    The exported QuickApp file now contains a device description.
    Added automatic code completion for RefreshStateSubscriber function.
Plugins
    Added support for Satel Integra 256 in old FW revision.
Scenes
    Function hub.setTimeout now returns a timeout ID that can be used to clear an ongoing timeout using the hub.clearTimeout.
    Default behavior for predefined scenario changed - from now no devices are selected by default.
Z-Wave
    Various legacy devices support added to Z-Wave 3.0 engine.**
    Reconfiguration of the device now keeps original name of the devices entities.**
    Z-Wave radio module SDK updated for Yubii Home and Home Center 3 Light.
Zigbee
    Introduced the mechanism which prevents losing the network configuration in very rare cases.
    MOES Human Presence Sensor ZSS-QY-HP (and other revisions) support added.
Bug Fixes:
Access
    The advanced user can't remove user's mobile device in Access settings even if right Access is granted.
    The installer can't upload a backup into the system.
    Small UI fixes in whole system for the advanced user depending on specific access rights.
    Installer does not see system notifications for administrator.
Backup
    Error while uploading a Cloud backup in rare cases.
Cameras
    Lack of local preview for some cameras in Safari browser.
Dashboard
    Fixed issues with displaying large values on device tiles for sensors.
    Lack of state label for binary switches without power metering.
Devices
    Fixed http error 404 when opening thermostat control dialog after deleting climate zone.
    The header in device protocol-specific notifications is incorrect.
    Fixed refreshing advanced parameter values when using mobile app device binding process.
    Inversion settings, device role and favorite positions are not restored in some cases after performing a soft-reconfiguration.
    Fixed an issue with setting the wake-up interval for battery devices to 0 in some cases after saving the configuration.
    Custom door lock icons are not displayed.
    LinkedDevice (binarySensor) does not update the last breach time.
    Custom icons do not work for CO Detector device type.
    Lack of correct icons for Silent Open and Silent Close actions on the control dialog.
    Thermostat Linked Device - fixed the issue when cooling and heating actor is the same device.
    Qubino Flush Dimmer 0-10V - fixed optional temperature sensor handling.
    Restored old sets of icons for some device types.
Elero
    UI fixes to the device binding process.
Energy Panel
    Billing periods comparsion - incorrect trend arrow status in UI.
    Error during saving Energy Panel settings in some cases.
Garden
    Inconsistent behavior when saving settings for watering time when editing sequences.
Gateway Connection
    Issue with Force Removing of the Z-Wave device from the Slave hub.**
    Issue with listing slaves list in large IP network.
    Restoring a backup after replacing a slave with new unit fixed.
    Stability improvements.
History
    Missing thermostat set-point name in history entities.
Nice*
    Rain detector state not always shows correct status for a Climatic Sensor.
    Fixed binding procedure from the mobile app for BiDi-Multisensor.
    Corrected parameters template for TT2NBD.
Other
    Fixed an issue with some translations refreshing on the fly when changing the Hub language.
    The e-mail notification from device added to Slave hub shows wrong device ID in the content.
    Changing home location using https does not work correctly in some cases.
    Minor UI/UX fixes.
Plugins
    Fixed camera preview issue for the Nice Cameras plugin after changing the encoding from h265 to another one.
    Missing IP field configuration in Philips Hue.
    Fixed issue with Nice Cameras support in scenes when passwords with special signs are used.
Quick Apps
    Fixed an issue with cutting out dropdown content in new device control dialogs.
    Dropdowns does not work correctly when new view is disabled for mobile application.
    Function setColorComponent doesn't refresh the view when custom color components are used.
    Template for Color Controller device type updated.
Recovery
    UI fixes in the recovery interface on Linux based systems.
Scenes
    Issues with saving scenes content via http API when content contains spaces.
    When adding a simple scenario via the Yubii Home App in installer mode, the description field is covered by the system keyboard.
    In some cases, in block scenes it is not possible to use push notifications for a specific mobile device.
    UI fixes in the Yubii Home scenario creator.
    It is not possible to use negative values in Energy Panel balance blocks.
    Fixed setting slats position for FGR-224/Rol-Control2 group in block scenes.
    Fixed issue in Custom Scenarios when FGKF-601 is used as a trigger.
Z-Wave
    Removed not supported "Reconfigure" option for all Z-Wave devices in Z-Wave settings.**
    Fixed issues with mesh network reconfiguration.
Known issues:
Z-Wave Engine 3.0
    Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
* - Does not apply to HC3L (Home Center 3 Lite).
** - Applies only to Z-Wave 3.0 engine.
  • Like 3
  • Thanks 2
MAJ Faite, sympa ces petites tuiles d'indication de conso sur les icones
Modifié par TitiXsi
Soyons fous, allons y, ça sera pas pire que les deux dernières dites stables ....
Modifié par WENS
alors, je ne sais pas si c'est lié au nouveau FW avec les tuiles de conso ... Mais j'ai certain devices qui ne remontent plus la conso instantanée, j'ai pensé à un problème de modèle...  :
- KO Qubino ZMNHBA2 (double switch 2*4A)
- OK Qubino ZMNHBD1 (double switch 2*4A)
Qui dispose de ce genre de Qubino et peut vérifier ?
Modifié par TitiXsi
Mise à jour sans aucun souci.
Il me semble que le fonctionnement est plus fluide qu'à l'habitude, notamment en ce qui concerne l'émission (et surtout la réception) des push.
J'ai même récupéré la détection d'un détecteur Steinel IR, installé sur ma terrasse - câblage électrique sans erreur (vraiment basique), et ayant déjà bien déclenché une scène d'éclairage.
J'avais pourtant vérifié et re-vérifié tout, de A à Z, et fini par laisser tomber. Tout était correct, mais au final aucun allumage du plafonnier...
Bien sûr, j'attends quelques jour pour réévaluer toute cette chaine de détection.
Et j'ai cependant toujours un problème de remontée de consommation sur un Wall Plug, certes pas jeune, mais exclu, réinclus, reparamétré, etc... sans jamais avoir une conso réaliste et surtout cohérente.
Mais je ne vois (certes, je suis polarisé sur un autre projet depuis deux ans environ...) que les sempiternels ajustements mineurs, toujours mineurs...
Rien qui solutionne par exemple la localisation et la détection périmétrique.
Réflexion tout personnelle : tout cela me fait penser à une "propriétarisation" du Home Center vers le monde de Nice sans grand espoir d'une plus grande ouverture...
Mais comme je l'ai écrit plus haut, je fais peut-être fausse route.
J'ai aussi installé la mise à jour ce matin, mais comme je venais d'un très ancien firmware 5.150 qui datait d'il y a 1 an et demi, j'ai eu quelques effets de bords et bug... changement de comportement du LUA par exemple, mais ça ne date pas forcément de ce nouveau firmware là.
J'ai déjà corrigé le plus gênant (version 1.51 de mon QA GCE partagé tout à l'heure), mais il me reste 2 QA qui se comportent étrangement, j'ai des messages inattendus.... à creuser.
A part ça, tout semble fonctionnel.
@Sowliny je pense que tu as raison sur l'orientation de Fibaro vis à vis de son écosystème Nice.
Mais ce n'est pas franchement nouveau, la tendance est là depuis le rachat, après soit la box nous convient telle quelle, soit on va voir ailleurs, comme beaucoup l'ont déjà fait...
Perso ça me convient actuellement comme ça, malgré le peu de nouveautés, et puis surtout je n'ai pas le courage et le temps de tout refaire ailleurs (Home Assistant par exemple)
Bien sûr que ca me convient !
Il y a encore beaucoup de potentiel.
Ce qui m'attristait un peu, c'est la perspective (certes lointaine) de devoir justement changer d'(éco)système.
Comme tu le dis, ça me convient encore largement, et au final, moins un système subit de gros bouleversements, moins sont élevés les risques.
Toutefois, si un jour je devais "aller voir ailleurs", je pense que je privilégierai une solution perso basée sur un ou des microcontrôleurs en réseau.
Le 14/05/2025 à 12:26, TitiXsi a dit :
Hello, je reviens là dessus. Personne n'a perdu de conso instantanée sur certains devices ?
mise à jour exécutée aussi  -> Passage de  5.160.42 à 5.180.17
Il m'a proposé une reconfiguration du Capteur MCO ( )  et malgré une configuration douce, il a chamboulé tous les ID
On va voir dans les jours qui viennent  si j'ai aussi des comportement bizarre de LUA comme @Lazer
Bon ce matin ça tourné à priori bien, puis cet après midi après une sauvegarde ( donc un reboot ) j'ai un problème avec le QA Tempo RTE ( je poste la trace dans le post du QA )
Non pas de problème c'est une erreur serveur RTE ( Coïncidence )
Modifié par henri-allauch
Curieusement, ma box clignotait, j'ai effectué un reboot et j'ai de nouveau mes puissances depuis aujourd'hui ...
