Cmoi20 Posté(e) le 24 novembre Signaler Posté(e) le 24 novembre Firmware 5.191.20 BETA 24/11/2025 Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. What's new: Access Fixed error when deleting users. Devices The "Save to Event Panel" checkbox has been fixed to prevent data from being saved. Added support for cooling mode for the Thermostat & Climate Zone plugin. Curtain track device integration with the role "curtain" set in the system. Added a mechanism to prevent the possibility of adding custom icons with different extensions for one device. Updated translations for Heat Activator plugin. Network It is possible to turn off WiFi when an external USB ethernet adapter is connected. Nice* BiDi-EVB Hirschmann (TT1NBDEVB) device support. Preserved the parameter value after the binding process for BiDi interfaces. The current battery level of the devices is retrieved immediately after the pairing process. Added support for battery level indication for new firmware of Next Solar tubular motor. Other Improved system performance for larger configurations containing connected Hubs. Fixed the autocomplete suggestion list in the search field for Other devices. Removed category selection when creating rooms. Quick Apps Added the ability to disable one log channel in Quick Apps using a dedicated function. SNI TLS extenson support for MQTT protocol. Scenes Added an option to define title to email notifications called from Lua (Quick Apps and scenes). Users Users removed from the Hub do not function as VoIP users.* Z-Wave Updated parameters templates for MCO thermostats. Added additional (optional) parameter to force direct communication for the device update procedure for Z-Wave 2.0. Optimized the operation of the Z-Wave Device Update tab by adding a loading mechanism for devices in the reading/processing state. Added the ability to select the Hub for resetting the Z-Wave network.** Bug Fixes: Access Fixed the problem of logging out the Advanced User from some interface tabs in the absence of some permissions. Devices Fixed the issue where Nice Camera plugin doesn't show any video with the low res option enabled. Fixed calibration settings for FGD-223 (DoubleDimmer-Control), minimum value cannot be set higher than maximum. Fixed DSK code display when pairing devices, all numbers are visible. Fixed activity of the update verification button in the Z-Wave devices Update tab. Fixed the redundant display of the message about the unavailable dimming option in the FGD-223 (DoubleDimmer-Control) device configuration wizard. Fixed the ability to download a template for the FGD-223 (DoubleDimmer-Control) device. Fixed roller shutter status updates in the user interface. Fixed error 502 when changing parameters of the FGD-223 (DoubleDimmer-Control) device.** Fixed icon display for remote controls during binding wizard in Yubii App. Fixed issue with moving to the next step after 60 seconds when adding devices. Fixed operation of the Z-Wave device software update queue. Fixed values sent for the slider when testing the FGD-223 (DoubleDimmer-Control) device. Fixed problems with setting parameters for channels of the FGD-223 (DoubleDimmer-Control) device in some cases. Fixed rare save issues for the On/Off mode of the FGD-223 device (DoubleDimmer-Control). Energy Panel Fixed the appearance of the date field for the Energy Panel in the panel settings. Gateway Connection Fixed Slave device role setting after factory reset. The configuration description for slave devices in the Connect Gateway tab has been corrected. Fixed setting favorite positions for Bi-Rec lightining devices in Gateway Connection setup. Styled the authentication screen for the slave device. Nice* Fixed the display of binding mode selection options for Nice devices in the mobile application. Other Fixed display of text with icons in Profiles. Fixed LED behavior according to the device manual.* Fixed graphic quality on the login screen. Fixed the issue of the disappearing date header for notification groups when deleting at least one notification from a given day. Fixed sorting for some notifications in the notification panel. Minor UI/UX fixes. Quick Apps Fixed dropdown refresh in Quick Apps. Reduced spacing under buttons in Quick Apps. Scenes Fixed the appearance of percentage sliders in block scenes. Fixed the scenario editing icon to be more visible. Removed installer email selection for send picture to user option in block scenes. Update The update file is deleted on checksum error so that it can be downloaded again. Users Fixed the display of a language settings error when changing the language before logging in as a standard user. Advanced User has no rights to full-screen camera preview. Z-Wave Devices from the Slave Hub are correctly removed when the Z-Wave network is reset on the Master device. Everspring ST814 device model for Z-Wave 2.0 and Z-Wave 3.0 engines has been made consistent. The operation of the Z-Wave "End learning mode" button has been fixed, the mode is now ended correctly. Known issues: Z-Wave Engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. * - Does not apply to HC3L (Home Center 3 Lite). ** - Applies only to Z-Wave 3.0 engine. Security: Hidden information regarding some of the camera configuration for Installers. Some cipher suites for TLS that are no longer recommended have been disabled. Updating sudo to a higher version. 2
Cmoi20 Posté(e) le 24 novembre Auteur Signaler Posté(e) le 24 novembre Firmware 5.191.20 BETA 24/11/2025 Français (traduction Google) Merci d'utiliser notre passerelle ! Assurez-vous de la mettre à jour vers la dernière version pour profiter des nouvelles fonctionnalités et améliorations. Quoi de neuf: Accéder Correction d'une erreur lors de la suppression d'utilisateurs. Appareils La case à cocher « Enregistrer dans le panneau des événements » a été corrigée afin d'empêcher l'enregistrement des données. Ajout de la prise en charge du mode refroidissement pour le plugin Thermostat & Climate Zone. Intégration du dispositif de rail de rideau avec le rôle « rideau » défini dans le système. Ajout d'un mécanisme pour empêcher la possibilité d'ajouter des icônes personnalisées avec des extensions différentes pour un même appareil. Traductions mises à jour pour le plugin Heat Activator. Réseau Il est possible de désactiver le Wi-Fi lorsqu'un adaptateur Ethernet USB externe est connecté. Bon* Prise en charge du périphérique BiDi-EVB Hirschmann (TT1NBDEVB). La valeur du paramètre a été préservée après le processus de liaison pour les interfaces BiDi. Le niveau de batterie actuel des appareils est récupéré immédiatement après le processus d'appairage. Ajout de la prise en charge de l'indication du niveau de batterie pour le nouveau firmware du moteur tubulaire Next Solar. Autre Amélioration des performances du système pour les configurations plus importantes contenant des hubs connectés. Correction de la liste de suggestions de saisie automatique dans le champ de recherche pour les autres appareils. Suppression de la sélection de catégorie lors de la création de chambres. Applications rapides Ajout de la possibilité de désactiver un canal de journalisation dans les applications rapides à l'aide d'une fonction dédiée. Prise en charge de l'extension SNI TLS pour le protocole MQTT. Scènes Ajout d'une option permettant de définir le titre des notifications par e-mail appelées depuis Lua (applications rapides et scènes). Utilisateurs Les utilisateurs supprimés du Hub ne fonctionnent pas en tant qu'utilisateurs VoIP.* Z-Wave Modèles de paramètres mis à jour pour les thermostats MCO. Ajout d'un paramètre supplémentaire (optionnel) pour forcer la communication directe lors de la procédure de mise à jour de l'appareil pour Z-Wave 2.0. Nous avons optimisé le fonctionnement de l'onglet Mise à jour des périphériques Z-Wave en ajoutant un mécanisme de chargement pour les périphériques en état de lecture/traitement. Ajout de la possibilité de sélectionner le hub pour réinitialiser le réseau Z-Wave.** Corrections de bugs : Accéder Correction du problème de déconnexion de l'utilisateur avancé de certains onglets d'interface en l'absence de certaines autorisations. Appareils Correction d'un problème où le plugin Nice Camera n'affichait aucune vidéo lorsque l'option basse résolution était activée. Paramètres d'étalonnage fixes pour FGD-223 (DoubleDimmer-Control), la valeur minimale ne peut pas être supérieure à la valeur maximale. Affichage fixe du code DSK lors du jumelage des appareils : tous les chiffres sont visibles. Correction du fonctionnement du bouton de vérification des mises à jour dans l'onglet Mise à jour des appareils Z-Wave. Correction de l'affichage redondant du message concernant l'option de gradation indisponible dans l'assistant de configuration du périphérique FGD-223 (DoubleDimmer-Control). Correction de la possibilité de télécharger un modèle pour le dispositif FGD-223 (DoubleDimmer-Control). Correction des mises à jour de l'état des volets roulants dans l'interface utilisateur. Correction de l'erreur 502 lors de la modification des paramètres du dispositif FGD-223 (DoubleDimmer-Control).** Affichage corrigé des icônes des télécommandes pendant l'assistant de configuration dans l'application Yubii. Correction d'un problème qui empêchait le passage à l'étape suivante après 60 secondes lors de l'ajout d'appareils. Correction du fonctionnement de la file d'attente de mise à jour logicielle des périphériques Z-Wave. Valeurs fixes envoyées pour le curseur lors du test du dispositif FGD-223 (DoubleDimmer-Control). Correction de problèmes liés au paramétrage des canaux du dispositif FGD-223 (DoubleDimmer-Control) dans certains cas. Correction de rares problèmes de sauvegarde pour le mode Marche/Arrêt du dispositif FGD-223 (DoubleDimmer-Control). Panneau énergétique Correction de l'apparence du champ date pour le panneau Énergie dans les paramètres du panneau. Connexion à la passerelle Paramètre de rôle du périphérique esclave corrigé après la réinitialisation d'usine. La description de la configuration des périphériques esclaves dans l'onglet Connect Gateway a été corrigée. Correction des positions favorites des dispositifs d'éclairage Bi-Rec dans la configuration de la connexion à la passerelle. J'ai personnalisé l'écran d'authentification pour le périphérique esclave. Bon* Correction de l'affichage des options de sélection du mode de liaison pour les appareils Nice dans l'application mobile. Autre Affichage corrigé du texte avec icônes dans les profils. Comportement des LED corrigé conformément au manuel de l'appareil.* Qualité graphique améliorée sur l'écran de connexion. Correction du problème de disparition de l'en-tête de date pour les groupes de notifications lors de la suppression d'au moins une notification d'une journée donnée. Correction du tri de certaines notifications dans le panneau de notifications. Corrections mineures d'interface utilisateur/d'expérience utilisateur. Applications rapides Correction du rafraîchissement du menu déroulant dans les applications rapides. Espacement réduit sous les boutons dans les applications rapides. Scènes Correction de l'affichage des curseurs de pourcentage dans les scènes de blocs. L'icône d'édition de scénario a été améliorée pour être plus visible. Suppression de l'option de sélection de l'adresse e-mail de l'installateur pour l'envoi d'images à l'utilisateur dans les scènes de bloc. Mise à jour Le fichier de mise à jour est supprimé en cas d'erreur de somme de contrôle afin qu'il puisse être téléchargé à nouveau. Utilisateurs Correction d'un problème d'affichage des paramètres de langue lors du changement de langue avant la connexion en tant qu'utilisateur standard. L'utilisateur avancé ne dispose d'aucun droit à la prévisualisation plein écran de la caméra. Z-Wave Les périphériques du concentrateur esclave sont correctement supprimés lorsque le réseau Z-Wave est réinitialisé sur le périphérique maître. Le modèle d'appareil Everspring ST814 pour les moteurs Z-Wave 2.0 et Z-Wave 3.0 a été harmonisé. Le fonctionnement du bouton « Fin du mode d'apprentissage » Z-Wave a été corrigé ; le mode se termine désormais correctement. Problèmes connus : Moteur Z-Wave 3.0 Certains appareils Z-Wave ne sont pas entièrement compatibles avec la nouvelle version du moteur Z-Wave. * - Ne s'applique pas au HC3L (Home Center 3 Lite). ** - S'applique uniquement au moteur Z-Wave 3.0. Sécurité: Informations cachées concernant certaines configurations de la caméra pour les installateurs. Certaines suites de chiffrement pour TLS qui ne sont plus recommandées ont été désactivées. Mise à jour de sudo vers une version supérieure. 2
henri-allauch Posté(e) le 24 novembre Signaler Posté(e) le 24 novembre C'est Noël avant l'heure car en plus de cette BETA il propose aussi : Avis important La version 5.190.39 est un correctif pour la version 5.190.38. Cette mise à jour résout les problèmes suivants : Correction d'un problème d'ouverture du fichier d'archive des événements du Hub. Que d'énergie .....
TitiXsi Posté(e) le 24 novembre Signaler Posté(e) le 24 novembre Citation Z-Wave Modèles de paramètres mis à jour pour les thermostats MCO. Alors, là je vais attendre un peu avant de faire la mise à jour
Sowliny Posté(e) le 24 novembre Signaler Posté(e) le 24 novembre (modifié) J'ai commencé la lecture du log, et la mention du FGD-223 (DoubleDimmer-Control) m'interpelle. Je n'en trouve aucune trace nulle part. Certainement une coquille ? Modifié le 24 novembre par Sowliny
Barelle Posté(e) le 24 novembre Signaler Posté(e) le 24 novembre Cela semble pourtant exister : https://manuals.plus/nice/fgd-223-double-dimmer-control-manual 1
Sowliny Posté(e) le 24 novembre Signaler Posté(e) le 24 novembre Merci @Barelle ! En effet voici le manuel : fgd-223-double-dimmer-control-manual.pdf Cependant, malgré une recherche en mentionnant "Nice" je n'en trouve pas trace en tant que module (que des FGS-223). Uniquement le manuel. Peut-être pas encore commercialisé (?).
Sowliny Posté(e) le 24 novembre Signaler Posté(e) le 24 novembre Après une recherche à l'aide de GPT : Le FGD-223 semble être commercialisé en France, entre autres par "allotelecommande.com" (> 101€) https://www.allotelecommande.com/accessoires/micromodule-nice-doubledimmer-control-ref-301620530301/.
Nico Posté(e) le 24 novembre Signaler Posté(e) le 24 novembre Ahh ils sont passés au blanc et badgé Nice, je ne savais pas.
TitiXsi Posté(e) le 7 décembre Signaler Posté(e) le 7 décembre Tiens... Je rebondis. Ils ont autorisé un adaptateur USB ethernet ? Pour palier le fait que le port d'originalité est un 100Mb ?
TitiXsi Posté(e) le 7 décembre Signaler Posté(e) le 7 décembre Le 24/11/2025 à 10:54, Cmoi20 a dit : Network It is possible to turn off WiFi when an external USB ethernet adapter is connected. Ici 😉
Lazer Posté(e) le 7 décembre Signaler Posté(e) le 7 décembre Il y a 2 heures, TitiXsi a dit : Tiens... Je rebondis. Ils ont autorisé un adaptateur USB ethernet ? Pour palier le fait que le port d'originalité est un 100Mb ? Alors sur la HC 3 Lite c'est possible, car elle n'a que le Wi-Fi de base, et on connait tous la (non)-stabilité du Wi-Fi. Mais sur la HC3, je ne vois vraiment pas l'intérêt de s'emmerder avec un adaptateur Ethernet USB ? Sachant que le gigabit est inutile pour une box domotique (pas de transfert de fichier, etc). Le choix d'un port 100 Mbps est tout à fait pertinent de la part de Fibaro, d'une part ça réduit les couts de production, et d'autre part ça réduit la consommation électrique, ce qui est intéressant pour l'utilisateur. Par ailleurs, ça n'apporte aucune restriction, même sur les switchs récents avec les ports en 2.5, 5, et même 10 Gbps, la vitesse est toujours rétrocompatible avec le 100 Mbps (en tout cas sur les modèles que j'ai vu, UniFi notamment) 3
Sowliny Posté(e) le 7 décembre Signaler Posté(e) le 7 décembre Il y a 2 heures, TitiXsi a dit : It is possible to turn off WiFi when an external USB ethernet adapter is connected. Effectivement, je n'avais pas fait attention. Je scrutais plutôt quelque chose qui améliorerait la localisation ()...
TitiXsi Posté(e) le 7 décembre Signaler Posté(e) le 7 décembre Il y a 4 heures, Lazer a dit : Alors sur la HC 3 Lite c'est possible, car elle n'a que le Wi-Fi de base, et on connait tous la (non)-stabilité du Wi-Fi. Mais sur la HC3, je ne vois vraiment pas l'intérêt de s'emmerder avec un adaptateur Ethernet USB ? Sachant que le gigabit est inutile pour une box domotique (pas de transfert de fichier, etc). Le choix d'un port 100 Mbps est tout à fait pertinent de la part de Fibaro, d'une part ça réduit les couts de production, et d'autre part ça réduit la consommation électrique, ce qui est intéressant pour l'utilisateur. Par ailleurs, ça n'apporte aucune restriction, même sur les switchs récents avec les ports en 2.5, 5, et même 10 Gbps, la vitesse est toujours rétrocompatible avec le 100 Mbps (en tout cas sur les modèles que j'ai vu, UniFi notamment) Effectivement ça n'apporte rien sur la HC3... Et j'avais oublié que la lite était en wifi seul. Je trouvais ça curieux quand même 😁
Lazer Posté(e) le 8 décembre Signaler Posté(e) le 8 décembre L'information est passée inaperçue dans le changelog, mais cette version apporte quelques modifications sur l'API, cela a été documenté par Fibaro dans un post dédié sur le forum officiel : https://forum.fibaro.com/topic/79587-update-5191-beta-crucial-changes-for-api-scenes-and-quickapps/ Here are the key changes in API, scenes and QuickApp that the new version offers. 1. Added an option to define title to email notifications called from Lua (Quick Apps and scenes). The email subject could be customized by adding an optional parameter to the method for sending an email to users: In case of LUA Scenes: hub.alert("email", {userId}, emailBody, false, emailSubject) In case of Quick Apps: hub.alert("email", {userId}, emailBody, emailSubject) 2. Added the ability to disable one log channel in Quick Apps using a dedicated function. Quick App log level can be set using following assignment in the LUA code on Quick App: self.logLevel = log_level where log_level could have one of the following values: NONE, ERROR, WARNING, DEBUG, TRACE. Example to set Quick App log level to WARNING which will allow only errors and warnings to be displayed in console: self.logLevel = WARNING 3. Added the request to synchronise the sort-order in the system according to administrator configuration. New API endpoint was introduced to synchronize (reset) sorting order of devices and scenes for all users back to the order that is assigned to the admin: POST /api/sortOrder/syncUsersWithAdmin Only admin, installer and support are authorized to call that API endpoint. 4. SNI TLS extension support for MQTT protocol. LUA MQTT Client that uses TLS by default enables SNI TLS Extension by default since version 5.191. In case of some problems there is a possibility to switch SNI off by the following setting in connection options: self.client = mqtt.Client.connect(brokerURI, { port = 1883, tls = { useSNI = false } }) 2 1
jojo Posté(e) le 9 décembre Signaler Posté(e) le 9 décembre Le 08/12/2025 à 13:58, Lazer a dit : hub.alert("email", {userId}, emailBody, emailSubject) mais il n'y avait pas déjà ceci ? hub.call(2, "sendEmail", "Subject", "Body ")
