fredokl Posté(e) le 15 janvier Signaler Posté(e) le 15 janvier Firmware 5.200.13 STABLE 15/01/2026 Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. Important notice Version 5.200.13 is a hotfix for version 5.200.8. The update resolves: Fixed an issue with the Wi-Fi network settings display***. Quick Apps crash fixed by adding support for calling debug functions as static. Fixed an issue with controlling roller shutter controllers with Curtain or Lamellar curtain role from Dashboard. Fixed an issue with sending an incorrect argument when saving a predefined Light Scenario. What's new: Access Fixed error when deleting users. Devices The "Save to Event Panel" checkbox has been fixed to prevent data from being saved. Added support for cooling mode for the Thermostat & Climate Zone plugin. Curtain track device integration with the role "curtain" set in the system. Added a mechanism to prevent the possibility of adding custom icons with different extensions for one device. Updated translations for Heat Activator plugin. Removed battery indication support for some devices with old firmware that do not support battery reporting. Network It is possible to turn off WiFi when an external USB ethernet adapter is connected. Nice* BiDi-EVB Hirschmann (TT1NBDEVB) device support. Preserved the parameter value after the binding process for BiDi interfaces. The current battery level of the devices is retrieved immediately after the pairing process. Added support for battery level indication for new firmware of Next Solar tubular motor. Other Improved system performance for larger configurations containing connected Hubs. Fixed the autocomplete suggestion list in the search field for Other devices. Removed category selection when creating rooms. Quick Apps Added the ability to disable one log channel in Quick Apps using a dedicated function. SNI TLS extenson support for MQTT protocol. Scenes Added an option to define title to email notifications called from Lua (Quick Apps and scenes). Users Users removed from the Hub do not function as VoIP users.* Z-Wave Updated parameters templates for MCO thermostats. Added additional (optional) parameter to force direct communication for the device update procedure for Z-Wave 2.0. Optimized the operation of the Z-Wave Device Update tab by adding a loading mechanism for devices in the reading/processing state. Added the ability to select the Hub for resetting the Z-Wave network.** Updated Z-Wave SDK to 7.21.7 GA.*** Bug Fixes: Access Fixed the problem of logging out the Advanced User from some interface tabs in the absence of some permissions. Climate panel Fixed errors that occurred when setting the Off mode in the Climate Panel schedule. Devices Fixed the issue where Nice Camera plugin doesn't show any video with the low res option enabled. Fixed calibration settings for FGD-223 (DoubleDimmer-Control), minimum value cannot be set higher than maximum. Fixed DSK code display when pairing devices, all numbers are visible. Fixed activity of the update verification button in the Z-Wave devices Update tab. Fixed the redundant display of the message about the unavailable dimming option in the FGD-223 (DoubleDimmer-Control) device configuration wizard. Fixed the ability to download a template for the FGD-223 (DoubleDimmer-Control) device. Fixed roller shutter status updates in the user interface. Fixed error 502 when changing parameters of the FGD-223 (DoubleDimmer-Control) device.** Fixed icon display for remote controls during binding wizard in Yubii App. Fixed issue with moving to the next step after 60 seconds when adding devices. Fixed operation of the Z-Wave device software update queue. Fixed values sent for the slider when testing the FGD-223 (DoubleDimmer-Control) device. Fixed problems with setting parameters for channels of the FGD-223 (DoubleDimmer-Control) device in some cases. Fixed rare save issues for the On/Off mode of the FGD-223 device (DoubleDimmer-Control). Fixed some translations of the Heat Activator plugin for the Polish version. Fixed redundant battery status notifications and their translations. Energy Panel Fixed the appearance of the date field for the Energy Panel in the panel settings. Gateway Connection Fixed Slave device role setting after factory reset. The configuration description for slave devices in the Connect Gateway tab has been corrected. Fixed setting favorite positions for Bi-Rec lightining devices in Gateway Connection setup. Styled the authentication screen for the slave device. Nice* Fixed the display of binding mode selection options for Nice devices in the mobile application. Fixed control of venetian blinds when using BiDi-Shutter and BiDi-Awning modules. Other Fixed display of text with icons in Profiles. Fixed LED behavior according to the device manual.* Fixed graphic quality on the login screen. Fixed the issue of the disappearing date header for notification groups when deleting at least one notification from a given day. Fixed sorting for some notifications in the notification panel. Fixed an issue with the use of an outdated password reset email template for some languages. Minor UI/UX fixes. Quick Apps Fixed dropdown refresh in Quick Apps. Reduced spacing under buttons in Quick Apps. Scenes Fixed the appearance of percentage sliders in block scenes. Fixed the scenario editing icon to be more visible. Removed installer email selection for send picture to user option in block scenes. Added missing parameters for thermostats in scenes. Fixed the display of the scene list in the interface for the Norwegian language. Update The update file is deleted on checksum error so that it can be downloaded again. Users Fixed the display of a language settings error when changing the language before logging in as a standard user. Advanced User has no rights to full-screen camera preview. Z-Wave Devices from the Slave Hub are correctly removed when the Z-Wave network is reset on the Master device. Everspring ST814 device model for Z-Wave 2.0 and Z-Wave 3.0 engines has been made consistent. The operation of the Z-Wave "End learning mode" button has been fixed, the mode is now ended correctly. Known issues: Z-Wave Engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. * - Does not apply to HC3L (Home Center 3 Lite). ** - Applies only to Z-Wave 3.0 engine. *** - Applies to hubs using Z-Wave 700 series chip. Security: Hidden information regarding some of the camera configuration for Installers. Some cipher suites for TLS that are no longer recommended have been disabled. Updating sudo to a higher version. 1 1
fredokl Posté(e) le 15 janvier Auteur Signaler Posté(e) le 15 janvier TRADUCTION GOOGLE: Merci d'utiliser notre passerelle ! Assurez-vous de la mettre à jour vers la dernière version pour profiter des nouvelles fonctionnalités et améliorations. Avis important La version 5.200.13 est un correctif pour la version 5.200.8. Cette mise à jour résout les problèmes suivants : Correction d'un problème d'affichage des paramètres réseau Wi-Fi***. Correction d'un plantage des applications rapides grâce à la prise en charge de l'appel de fonctions de débogage statiques. Correction d'un problème de contrôle des volets roulants avec le rôle « Rideau » ou « Rideau lamellaire » depuis le tableau de bord. Correction d'un problème d'envoi d'un argument incorrect lors de l'enregistrement d'un scénario d'éclairage prédéfini. Nouveautés : Accès Correction d'une erreur lors de la suppression d'utilisateurs. Appareils La case à cocher « Enregistrer dans le panneau des événements » a été corrigée afin d'empêcher l'enregistrement de données. Ajout de la prise en charge du mode refroidissement pour l'extension Thermostat et Zone climatique. Intégration des rails de rideaux avec le rôle « rideau » défini dans le système. Ajout d'un mécanisme empêchant l'ajout d'icônes personnalisées avec des extensions différentes pour un même appareil. Traductions mises à jour pour le plugin Heat Activator. Suppression de l'affichage du niveau de batterie pour certains appareils dotés d'un ancien firmware ne prenant pas en charge ce signalement. Réseau Il est possible de désactiver le Wi-Fi lorsqu'un adaptateur Ethernet USB externe est connecté. Nice* Prise en charge de l'appareil BiDi-EVB Hirschmann (TT1NBDEVB). Conservation de la valeur du paramètre après l'appairage pour les interfaces BiDi. Le niveau de batterie actuel des appareils est récupéré immédiatement après l'appairage. Ajout de l'affichage du niveau de batterie pour le nouveau firmware du moteur tubulaire Next Solar. Divers Amélioration des performances système pour les configurations importantes contenant des hubs connectés. Correction de la liste de suggestions de saisie semi-automatique dans le champ de recherche pour les autres appareils. Suppression de la sélection de catégorie lors de la création de pièces. Applications rapides Ajout de la possibilité de désactiver un canal de journalisation dans les applications rapides via une fonction dédiée. Prise en charge de l'extension SNI TLS pour le protocole MQTT. Scènes Ajout d'une option permettant de définir le titre des notifications par e-mail appelées depuis Lua (applications rapides et scènes). Utilisateurs Les utilisateurs supprimés du Hub ne fonctionnent pas comme utilisateurs VoIP.* Z-Wave Mise à jour des modèles de paramètres pour les thermostats MCO. Ajout d'un paramètre supplémentaire (optionnel) pour forcer la communication directe lors de la procédure de mise à jour des appareils Z-Wave 2.0. Optimisation du fonctionnement de l'onglet « Mise à jour des appareils Z-Wave » grâce à l'ajout d'un mécanisme de chargement pour les appareils en cours de lecture/traitement. Ajout de la possibilité de sélectionner le Hub pour réinitialiser le réseau Z-Wave.** Mise à jour du SDK Z-Wave vers la version 7.21.7 GA.*** Corrections de bogues : Accès Correction du problème de déconnexion de l'utilisateur avancé depuis certains onglets d'interface en l'absence de certaines autorisations. Panneau climatique Correction des erreurs survenant lors de la configuration du mode Arrêt dans la programmation du panneau climatique. Appareils Correction du problème d'affichage de la vidéo par le plugin Nice Camera lorsque l'option basse résolution était activée. Correction des paramètres d'étalonnage du FGD-223 (DoubleDimmer-Control) : la valeur minimale ne peut pas être supérieure à la valeur maximale. Correction de l'affichage du code DSK lors de l'appairage des appareils : tous les chiffres sont désormais visibles. Correction du comportement du bouton de vérification de mise à jour dans l'onglet « Mise à jour » des appareils Z-Wave. Correction de l'affichage redondant du message concernant l'option de gradation indisponible dans l'assistant de configuration du FGD-223 (DoubleDimmer-Control). Correction de la possibilité de télécharger un modèle pour le FGD-223 (DoubleDimmer-Control). Correction de la mise à jour de l'état des volets roulants dans l'interface utilisateur. Correction de l'erreur 502 lors de la modification des paramètres du FGD-223 (DoubleDimmer-Control). Correction de l'affichage des icônes des télécommandes pendant l'assistant d'appairage dans l'application Yubii. Correction du problème de passage à l'étape suivante après 60 secondes lors de l'ajout d'appareils. Correction du fonctionnement de la file d'attente de mise à jour logicielle des appareils Z-Wave. Correction des valeurs envoyées au curseur lors du test du dispositif FGD-223 (DoubleDimmer-Control). Correction de problèmes de paramétrage des canaux du dispositif FGD-223 (DoubleDimmer-Control) dans certains cas. Correction de rares problèmes de sauvegarde du mode Marche/Arrêt du dispositif FGD-223 (DoubleDimmer-Control). Correction de certaines traductions du plugin Heat Activator pour la version polonaise. Correction des notifications redondantes concernant l'état de la batterie et de leurs traductions. Panneau d'énergie Correction de l'affichage du champ de date du panneau d'énergie dans les paramètres du panneau. Connexion à la passerelle Correction du paramétrage du rôle du périphérique esclave après une réinitialisation d'usine. Correction de la description de la configuration des périphériques esclaves dans l'onglet « Connexion à la passerelle ». Correction du paramétrage des positions favorites pour les dispositifs d'éclairage Bi-Rec dans la configuration de la connexion à la passerelle. Amélioration du style de l'écran d'authentification pour le périphérique esclave. Nice* Correction de l'affichage des options de sélection du mode de liaison pour les périphériques Nice dans l'application mobile. Correction du contrôle des stores vénitiens lors de l'utilisation des modules BiDi-Shutter et BiDi-Awning. Autres corrections : affichage du texte avec icônes dans les profils. Correction du comportement des LED. 1
TitiXsi Posté(e) le 15 janvier Signaler Posté(e) le 15 janvier (modifié) StaAaAaAable ou presque stable ? 😁 Pourquoi ils n'utilisent pas des paramètres optionnels au lieu de supprimer des paramètres dans les fonctions mise à jour... 😔 Comment on peut coder un fw sans garder la compatibilité avec les fonctions précédentes... Fibaro, vous avez des tests cases de non régression ? Modifié le 15 janvier par TitiXsi
jjacques68 Posté(e) le 16 janvier Signaler Posté(e) le 16 janvier (modifié) MAJ faite, RAS pour le moment... Modifié le 16 janvier par jjacques68 1
fredokl Posté(e) le 16 janvier Auteur Signaler Posté(e) le 16 janvier RAS ou RAZ (remise à zéro)? C'est pas pareil. 1
flacon030 Posté(e) le 16 janvier Signaler Posté(e) le 16 janvier mise a jour effectué aussi on verra dans les prochains jours.
Lazer Posté(e) le 16 janvier Signaler Posté(e) le 16 janvier J'ai fait la mise à jour sur ma box de test, pareil, rien à signaler
TitiXsi Posté(e) le 16 janvier Signaler Posté(e) le 16 janvier Estc ce que l'un d'entre vous testerai l'instruction hub.alert("simplepush" pour voir si ils ont fixé vs précédente stable .. ? Merci 🙏🏼
mprinfo Posté(e) le 16 janvier Signaler Posté(e) le 16 janvier Moi il y a un truc que je ne comprend pas dans le changelog C'est quoi un FGD223 ?Envoyé de mon Pixel 8 Pro en utilisant Tapatalk
ericl78 Posté(e) le 16 janvier Signaler Posté(e) le 16 janvier voilà la doc, un double dimmer https://manuals.plus/nice/fgd-223-double-dimmer-control-manual
mprinfo Posté(e) le 16 janvier Signaler Posté(e) le 16 janvier Super merci je ne connaissais pasJ'avais cherché sous Google et je n'avais rien trouvé Envoyé de mon Pixel 8 Pro en utilisant Tapatalk
Lazer Posté(e) le 16 janvier Signaler Posté(e) le 16 janvier Han j'étais passé à coté de ça trop bien je veux vite vite je vais acheter Ah bah non.... faudra attendre qu'il sorte je suppose, mais j'ai des doubles interrupteurs, ça va être ultra pratique pour gagner de la place dedans
Sakkhho Posté(e) le 16 janvier Signaler Posté(e) le 16 janvier La dernière version m a bien refroidi … pas envie de faire un restore de nouveau. J hésite fortement à mettre à jour. Envoyé de mon iPhone en utilisant Tapatalk 1
TitiXsi Posté(e) mardi à 12:49 Signaler Posté(e) mardi à 12:49 Voilà, MAJ faite ... Je me suis forcé à mettre à jour mes 15QA et 46Scènes avec mon code partagé sur le hub.alert J'ai modifié l'appel en utilisant fibaro.alert et j'ai supprimé les paramètres inutiles ...
TitiXsi Posté(e) mardi à 13:01 Signaler Posté(e) mardi à 13:01 disons que si on commence à prendre du retard ... après c'est cuit
Sakkhho Posté(e) mardi à 20:52 Signaler Posté(e) mardi à 20:52 Voilà, MAJ faite ... Je me suis forcé à mettre à jour mes 15QA et 46Scènes avec mon code partagé sur le hub.alert J'ai modifié l'appel en utilisant fibaro.alert et j'ai supprimé les paramètres inutiles ...Donc cette mise à jour ne corrige pas le bug précédent et on doit faire des modifications. Depuis dimanche , sans que je comprenne vraiment pourquoi (je suis tjs sur mon backup) la HC3 ne tourne pas rond. Mes scénarios GEA certains se déclenchent d autres non, la mise à jour des QAs ne fonctionne pas vraiment (exemple Tempo edf ou la mise à jour du status des roborock …) L accès direct aux devices marchent en revanche normalement Je suis en déplacement donc pas simple de comprendre mais j ai l impression que c’est suite au backup automatique du dimanche ou un dévice bavard qui sature tout ? Une idée ?Je me suis dit que je mettrai à jour pour voir mais si je dois aussi modifier les QAs ensuite …
TitiXsi Posté(e) mercredi à 07:28 Signaler Posté(e) mercredi à 07:28 Si tu utilises la fonction hub.alert alors tu aura sûrement des choses à modifier...
