Lazer Posté(e) le 23 avril Signaler Posté(e) le 23 avril Firmware 5.203.68 BETA 23/04/2026 Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. Main features: Z-Wave reconfiguration process improvements Improved devices reconfiguration process in the Z-Wave 3.0 which was migrated from version 2.0. What's new: Energy Panel Integration with Tibber monitor to allow automatic rates update for Energy Panel (Available only for addresses located in Germany, Norway, Sweden or the Netherlands). KNX Added roller shutters/blinds integration for the KNX protocol. Other Removed PKO Assistance plugin from the system due to official termination of cooperation. Z-wave The ability to manually add parameters at each endpoint. Improved Z-wave3 engine resilience to communication issues in Security S0.** Improved error messages displayed during Z-Wave engine migration to make it easier to understand the issues that occurred. Support for Z-Wave 3.0 in Installer App.** Bug Fixes: Climate Fixed issue with saving climate zones in some cases. The FGT thermostatic heads are not synchronised with the schedule. Devices Changed the content of several notifications that appear when adding Smart Start devices to prevent user confusion.*** Fixed QR code camera preview for Smart Start on tablet versions.*** Fixed the display of svg icons in the mobile app for Sprinkler and NICE Siren devices. Fixed problem with CoolAutomation plugin to receive correct feedback/status in mobile application. Smart Start available for some devices which does not support it.*** Fixed the ability to select a room other than the default one for devices added via Smart Start in the mobile application.*** Fixed the ability to configure advanced settings for devices after a Z-Wave migration. Fixed UI for Advanced Configuration for the Keyfob lock button and unlock sequence. Elero It is not possible to control Elero Lighting RGBW after pairing it with the system if the LED output is turned off during finishing binding procedure.. Gateway connection Smart Start DSK code is not displayed for devices added to Slave gateways.*** Wrong backup type while software update for slave hubs. Devices from different phisical networks are listed as a target destinations in associations. KNX Fixed a KNX connection error that occurred when reconnecting after a long period of time. Fixed problem with reconnecting the KNX bridge after performing a 'clear configuration' action. Nice* Fixed issues with Nice PLN2+ motors controlled as a group using Linked Device. Fixed the operation of some group actions causing i.a. malfunctions in scenes. Fixed an issue with removing device Domi WSR when the device is inactive. Other Added real-time refreshing of history entries for Z-Wave Central Scene events and scene-related events. Fixed an issue where the reboot sometimes didn't work properly. Minor UI/UX fixes. Profiles Fixed problem with triggering changes via profiles. Quick Apps Fixed problem that HTTP responses other than 2xx (300 and higer) don't return response body. Corrected validation of variable names to allow editing of existing variable values. Fixed an issue with the display of custom icons for remote controllers in Quick Apps. Scenes Fixed problem that net.HTTPClient strips query string parameters in LUA scenes. Fixed the behavior of sliders in block scenes for the setColor action, sliders now function independently. Fixed an error that block scene with setting Manual mode to "Hold" does not work on HC3L/YH hubs. Optimization of scene running. Fixed an issue with saving a predefined scenario when some devices are selected. Update Moved the setting related to system version information from the final stage of startup to the earliest possible point in order to reduce incorrect version data in recovery mode. Changed the order in which services start during initialization to avoid issues during updates. Fixed the behavior of the progress bar when canceling an update download; the progress bar is now hidden. Z-wave Fixed the visibility of updates for Z-Wave devices on both engine versions. Fixed issues with migrating the Z-wave engine from version 2.0 to 3.0. Fixed battery indicator display after the Z-wave engine migration. Fixed support for the Notification Command Class on devices following the Z-Wave engine migration. Some of the templates not working properly after the Z-Wave engine update. * - Does not apply to HC3L (Home Center 3 Lite). ** - Applies only to Z-Wave 3.0 engine. *** - Fully supported in the upcoming Yubii v2.5.3 application 1
jmg38 Posté(e) le 23 avril Signaler Posté(e) le 23 avril Bonjour, je suis surpris que l'on passe d'une version beta ( qui a duré longtemps) à une autre béta. A quand la version stable?
Lazer Posté(e) le 23 avril Auteur Signaler Posté(e) le 23 avril (modifié) Boarf, passer d'une Beta à une autre Beta, ça ne m'étonne pas avec Fibaro Faudrait chercher dans l'historique, mais je suis sûr qu'on a déjà eu plus de 6 mois à enchainer des Betas entre 2 Stables. Et encore, on pourrait aussi parler des Beta-Stable-Pas-Stable EDIT : plus sérieusement, ils sont en train de fixer les bugs de la migration du moteur Z-Wave v2 vers v3, donc laissons laisser avancer pas à pas sur cette étape importante et critique Modifié le 23 avril par Lazer
TitiXsi Posté(e) le 23 avril Signaler Posté(e) le 23 avril Personnellement, toujours pas intéressé par cette MAJ :) 1
Nico Posté(e) le 28 avril Signaler Posté(e) le 28 avril @jjacques68, et tu as migré en Zwave V3 ou non ? 1
ericl78 Posté(e) le 29 avril Signaler Posté(e) le 29 avril et voilà, mise à jour effectuée, à valider maintenant Mais pas de passage à Zwave 3 :=)
jjacques68 Posté(e) le 30 avril Signaler Posté(e) le 30 avril Le 28/04/2026 à 22:45, Nico a dit : @jjacques68, et tu as migré en Zwave V3 ou non ? Non non, toujours en v2 Après je sais pas si tous les modules sont compatibles ? Sî oui pourquoi pas essayer ? Le retour en V2 est possible ?
Nico Posté(e) le 30 avril Signaler Posté(e) le 30 avril Re aucune idée, migration non proposée sur HC2
TitiXsi Posté(e) le 30 avril Signaler Posté(e) le 30 avril Il y a 3 heures, jjacques68 a dit : Le retour en V2 est possible ? Je ne crois pas justement...
Lazer Posté(e) le 30 avril Auteur Signaler Posté(e) le 30 avril Restauration de la sauvegarde précédente
TitiXsi Posté(e) le 1 mai Signaler Posté(e) le 1 mai Il y a 8 heures, Lazer a dit : Restauration de la sauvegarde précédente Je panique toujours à cette idée... Pourtant, je l'ai fait plusieurs fois... Mais là première avait planté... Obligé de tout réinstaller sur HC3L... Ça me fou encore la chtouille 😅
ericl78 Posté(e) le 1 mai Signaler Posté(e) le 1 mai Moi de mon côté, j'attends au moins une dizaine de retour à ce sujet avant de me lancer. 75 devices connectés, pas l'envie de mettre la pagaille chez moi. Bon, je reconnais que si tout le monde fait comme moi, nous y arriverons jamais :=) Merci s'avance aux volontaires
jojo Posté(e) le 1 mai Signaler Posté(e) le 1 mai @jjacques68 & @ericl78 : fous, mais pas téméraires ... 1
jjacques68 Posté(e) le 1 mai Signaler Posté(e) le 1 mai Il y a 13 heures, Lazer a dit : Restauration de la sauvegarde précédente Ah ça m’interesse ! Ça a été testé par qqun ?
Lazer Posté(e) le 1 mai Auteur Signaler Posté(e) le 1 mai Oui, par tous ceux qui ont eu leur box plantée depuis des années... Perso mon HC2 avait plantée 1 fois (je l'avais bien cherché aussi...), nécessitant une restauration, mais jamais avec ma HC3. Faut bien comprendre que la migration du moteur Z-Wave v2 vers le v3 n'a aucun impact sur le réseau Z-Wave et les modules eux-mêmes, ça se passe uniquement dans le logiciel du contrôleur Z-Wave, donc la box HC3. 2 1
jojo Posté(e) le 1 mai Signaler Posté(e) le 1 mai Il y a 5 heures, Lazer a dit : Faut bien comprendre que la migration du moteur Z-Wave v2 vers le v3 n'a aucun impact sur le réseau Z-Wave et les modules eux-mêmes, ça se passe uniquement dans le logiciel du contrôleur Z-Wave, donc la box HC3. c'est pour cela qu'un restore de la sauvegarde fonctionne. Et un restore est un très vieux processus, donc ça ne me fait pas peur. Si tu es inquiet, essaye un restore sur ta box de test (avec un bakup de ta box de test), voire même teste la migration, et le restore, sur ta box de test (il fau bien qu'elle serve à qqch)
jmg38 Posté(e) le 14 mai Signaler Posté(e) le 14 mai Après une sauvegarde(locale et cloud) je suis obligé de réactiver mes scénarios ? VL = 5.202.54 (beta), HC3. Avec la dernière version béta est ce que le PB existe toujours? Merci pour vos réponses.
