Krikroff Posté(e) 2 septembre 2014 Signaler Share Posté(e) 2 septembre 2014 Nouvelle version 3.907 Bêta, uniquement pour les personnes 3.591 Bêta. New version announcementANNOUNCING Fibaro Home Center v 3.907 Beta.About Version-------------------This version mainly concentrate on adding better support and integration for more devices (not only z-wave device).Important part of software responsible for management z-wave devices was rebuild from the scratch for better support different devices types.New Home Center software introduces support for plugins. Plugins give support for new devices and new functionalities without modifying HC Firmware. Plugins can be used for controlling devices via different protocols and standards like TCP/IP, IR*, RS 232*, UPNP. Plugins have their own user interface and can call all APIs available on HC2. Possibility of building plugins by independent developers will be introduced in next versions.* required additional hardware.New functionalities--------------------------Drag & Drop for devices and scenes - available on home, devices and rooms screens. Assigning devices to rooms and changing its order is now much easier and faster.Magic Scenes - new, simplified and easy to use graphical way to create scenes based on condition > action flow.Temperature Panel - allows to see history of temperature changes in rooms and on each device.Diagnostic Panel - general information about HC working condition like CPU & RAM usage, free space on hard drive. Will be extended in future versions.New Z-Wave engine - redesigned and rewritten from the scratch. Now is faster and has better support for devices.Z-Wave Door Locks support - controlling and PIN settings.Thermostats - extended controlling for thermostats from manufacturers like: Honeywell, Trane Corporation.Extended tamper for sensors - exclusive information for motion detection and violation of sensors.Fibaro Smoke Sensor extended support - level of smoke and gap to alarm level is reported and visible on charts at iPad and Web Page. Sensitivity level is now easier to set.Fibro Motion Sensor new device - when seismometer mode is turned on new device reporting tremors is available. Charts for temperature and illuminance. Additionally information about sensor violation.Device hiding - device that is not in use can be hide without removing it.Device deactivation - deactivated device is visible in UI but can't be controlled.Multithreading added for HC (server and z-wave) - now engines work much faster.Event panel moved - for better usability now is available in menu on right side of screen.User rights management - moved to Configuration.Block Scenes improvements - for device only available actions are visible, scene activation block added and logical conditions grouping using brackets.Lua Scenes - updated tooltips for devices.Plugins:Plugins are grouped in categories: Safety, Cameras, Climate, Multimedia, OthersPlugins searchNetwork devices search via ARPPlugins category Safety:DSC Alarm - for DSC Alarms,Helios Basic - integration using Basic license,Helios Gold - integration using Gold licenseMobotix - for Mobotix videophone,Satel Alarm - for SATELPlugins category Camerasmore than 100 devices from various manufacturersPlugin category ClimateCarrier FuranceWS Davis VantagePlugins category MultimediaLG BlurayLG TVNC + mediaboxXBMC Remote ControlDenon AmplifierLG BlurayOnkyo AmplifierPhilips BlurayPioneer AmplifierSamsung TVSonosSony BluraySony TVPlugins category OtherPhilips HueWake on LANOther changesMany other improvements to the system Lien vers le commentaire Partager sur d’autres sites More sharing options...
Did Posté(e) 2 septembre 2014 Signaler Share Posté(e) 2 septembre 2014 Mince, pas de plugin pour TV Panasonic. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Krikroff Posté(e) 2 septembre 2014 Auteur Signaler Share Posté(e) 2 septembre 2014 Toujours pas mon Viera sous la main ... Lien vers le commentaire Partager sur d’autres sites More sharing options...
shrek3166 Posté(e) 2 septembre 2014 Signaler Share Posté(e) 2 septembre 2014 Merci Krikroff Upgrade en cours ... Nicolas Lien vers le commentaire Partager sur d’autres sites More sharing options...
Did Posté(e) 2 septembre 2014 Signaler Share Posté(e) 2 septembre 2014 Je ne disais pas ça parce c'était ton message, on a tous plein de choses à faire à la rentrée mais parce qu'il y a pas de marque dans la liste mais pas la nôtre, peut-être plus tard (dans la v4? ou 5). Lien vers le commentaire Partager sur d’autres sites More sharing options...
Krikroff Posté(e) 2 septembre 2014 Auteur Signaler Share Posté(e) 2 septembre 2014 @Did, je sais bien c'était juste pour dire que je n'avais pas oublié notre échange @Nicolas, ... Lien vers le commentaire Partager sur d’autres sites More sharing options...
Did Posté(e) 2 septembre 2014 Signaler Share Posté(e) 2 septembre 2014 Merci Krikroff. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) 2 septembre 2014 Signaler Share Posté(e) 2 septembre 2014 Intéressant cette mise àjour. Des retours ? Qui l'a testé, ça ne casse pas tout ? Je suis bien tenté. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) 2 septembre 2014 Signaler Share Posté(e) 2 septembre 2014 Par contre Krikroff, j'ai regardé sur le forum officiel, et c'est toi qui annonce la nouvelle version ? Cela veut dire que c'est la beta annoncé dans le powerpoint il y a 10 jours devenu Alpha ? Car effectivement, on me la propose en mise à jour auto directement depuis la console de la HC2... Comme Lazer, je suis plutôt intéressé du coup... Et surtout, retour arrière possible ou non (Sans passer par un recovery depuis 0) ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
TonyC Posté(e) 2 septembre 2014 Signaler Share Posté(e) 2 septembre 2014 après MAJ et depuis mon accès distant, c'est pas top, je vois apparaître 3.901 beta ? Je peux également voir qu'un auto backup 3.907 a bien été effectué.... Par contre plus aucun modules de visible et là c'est pas cool ça sent le restore à plein nez ce soir enfin si ma femme ne m'a pas écorché vif avant .... 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Krikroff Posté(e) 2 septembre 2014 Auteur Signaler Share Posté(e) 2 septembre 2014 il y a du mode de chez Fibaro sur le forum.fibaro.com: A.Socha, I. Szymanski, m.roszak , hop : http://forum.fibaro.com/viewtopic.php?t=4964 Attention: Users who use version alpha from 3.901 to 3.906 need to perform recovery first and update from 3.590 or 3.591 after restoring backup Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) 2 septembre 2014 Signaler Share Posté(e) 2 septembre 2014 Et désormais ils l'annoncent bien en Beta !!! Je crois que je tente ce soir du coup ! Lien vers le commentaire Partager sur d’autres sites More sharing options...
BenjyNet Posté(e) 2 septembre 2014 Signaler Share Posté(e) 2 septembre 2014 Bon il y a encore du taf Déjàj'ai mes fibaro:log qui s'affichent plus et ça m'énerve ! Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) 2 septembre 2014 Signaler Share Posté(e) 2 septembre 2014 Hum... Et tout le reste a fonctionné ? Car je vois sur le forum officiel que plusieurs ont perdu tout ou une partie de leur device... Lien vers le commentaire Partager sur d’autres sites More sharing options...
Shad Posté(e) 2 septembre 2014 Signaler Share Posté(e) 2 septembre 2014 Bon attention apparemment il y a un problème avec le fibaro:CountScene. Toute les scènes qui ont ce code chez moi ont une erreur àcette ligne. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Shad Posté(e) 2 septembre 2014 Signaler Share Posté(e) 2 septembre 2014 Bon gros problème chez moi, j'ai voulue reconfigurer tout mes modules pour être sur que tout soit bon. Et il m'a tout dégagé et changé les ID. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) 2 septembre 2014 Signaler Share Posté(e) 2 septembre 2014 Euh.... Vraiment pas cool quoi... Finalement ce ne sera pas ce soir on dirait... Lien vers le commentaire Partager sur d’autres sites More sharing options...
BenjyNet Posté(e) 2 septembre 2014 Signaler Share Posté(e) 2 septembre 2014 Alors moi dans l'outil de Krikri j'ai ça : Soft Version:4.016 Beta alors que dans la page d'administration j'ai bien 3.907 (sans beta) Punaise je crois bien que c'est la 1ere fois qu'une beta passe aussi mal ! Une bonne chose, l'apparition du drag & drop, je peux foutre mes scènes en queue de peloton. Par contre, quand ils veulent pour faire un site en responsive design. Même leurs intitulés ne rentrent plus dans les cases (HAVC....). [ben en mode grognon] Hey Mr Fibaro, va falloir un peu accélérer là , vous êtes en perte de vitesse sur les 6 derniers mois par rapport aux concurrents. Et j'attends toujours mon dimmerplug et une prise en charge du h264 au passage... ! Et j'attends aussi... arf je vais en rester là .... [mode grognon off mais normal c'est la rentrée] Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) 2 septembre 2014 Signaler Share Posté(e) 2 septembre 2014 Benjy, et tout le reste fonctionne ? Tu es parti de la 590 ou de la 591 ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
Shad Posté(e) 2 septembre 2014 Signaler Share Posté(e) 2 septembre 2014 H264 oublie pour le moment car ils n'arrivent pas à l'inclure. Bon je tente un restaure, j'espère évité le recovery -_-'. Lien vers le commentaire Partager sur d’autres sites More sharing options...
BenjyNet Posté(e) 2 septembre 2014 Signaler Share Posté(e) 2 septembre 2014 @Nico de la 591. Pour le moment tout le reste fonctionne.... enfin je dis ça, j'ai pas mis le chauffage en route encore, je risque d'avoir des surprises (heureusement que les boutons physiques existent !). Lien vers le commentaire Partager sur d’autres sites More sharing options...
Shad Posté(e) 2 septembre 2014 Signaler Share Posté(e) 2 septembre 2014 Bon le restaure a fonctionne Par contre j'attend une réponse pour le countscene car les 3/4 de mes scènes sont HS maintenant. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) 2 septembre 2014 Signaler Share Posté(e) 2 septembre 2014 Moi je suis en 590 du coup, mais cela devrait être pareil... J'attends que Shad me dise que le restore fonctionne, car en recovery j'ai pas envie. 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Shad Posté(e) 2 septembre 2014 Signaler Share Posté(e) 2 septembre 2014 Be toujours en 3.907 mais le restaure a fonctionné et j'ai récupéré tout mes ID. Et perso j'ai pas de noeud mort à première vue. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) 2 septembre 2014 Signaler Share Posté(e) 2 septembre 2014 Ahh le restore fonctionne, du coup je vais peut être tout de même tester. GEA fonctionne dessus ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
