cocolabombe0 9 Signaler ce message Posté(e) 3 mars 2015 Mise à jour V 4.035 This version is hot fixing version addressing some of issues reported by users. 4.035 (4.034 was an internal version) Resolved Issues: #0002335: Zipato RGBW Bulb #0002106: fibaro:call(1, "wakeUpDeadDevice", ID) has no effect #0002672: Battery drain AeonLabs DSB05xxx-ZWUS Z-Wave Multi Sensor #0001864: qees dimmer does not display power use #0002134, #0002648 NetAtmo stop to work after few hours #0002829: Events panel - Temperature not correct (decimal sepparator) #0002810: Fibaro Motion Sensors (FW2.6): Erratic Temperature (>100 & >2000 degree C) on HC2 4.032 & 4.033 #0002260, #0002124, #0002424, #0002499, #0002516, #0002633, #0002745 RGBW on/off #0002800: Consumption Reading (decimal place) #0002283: Popup description incomplete #0001671: Nomenclature - Diagnostics #0002209: FGS221 Switch 2x1,5kW (half) in wrong room after upgrade from 3.X #0002233: 4.022 and all 4.X : when converting from 3.590 2nd relay of the FGS221 device will be put into the wrong Room. Locstar Door Lock (US) - status fix Plugin for Sony TV - works with newest firmware Lack of decimal mark in Event Panel New Functionalities: Template data download for devices without template Known issues: After the update clearing browser cache could be required Power Mettering may not work properly for some devices UBS Temperature is not visivble on iPhone/iPad client RGBW Controler may not work propery when used in in/out mode Alarm Panel doesn't work in some specific configurations Plugins for TV Sets of various manufacturers may not work with its newes firmware due to restricions provided by new devices firmware. There will be added detalied information about suported firmwave versions within plugins. - Satel - adding plugin progress bar disappears during configuration. Please wait about 15 minutes before performing actions on Satel devices. Devices Polling may not work properly - devices state in UI may be refreshed only after action taken. Breached sensor with Arm Delay causes instant alarm after being armed Data range selection in event panel doesn't work properly Devices imported via Gateway Connection may have no icons Gateway Connection status of dead device between master and slave controller may be different Devices not properly configured on 3.X may not be converted properly Reconfiguration may not work properly in some cases On mobile clients devices may be visible in different categories than configured Advanced settings for some imported devices may not work properly Horstmann Thermostat HRT4-ZW higher battery usage in some cases Doorlocks some functions may not work properly Mise a jour en cours (98%). Partager ce message Lien à poster Partager sur d’autres sites
razowski 76 Signaler ce message Posté(e) 3 mars 2015 Update en cours... Partager ce message Lien à poster Partager sur d’autres sites
i-magin 864 Signaler ce message Posté(e) 3 mars 2015 J'attends que deux ou trois courageux se lancent... et je suis 1 Partager ce message Lien à poster Partager sur d’autres sites
cocolabombe0 9 Signaler ce message Posté(e) 3 mars 2015 Premier constat, on ne peut plus télécharger les templates (xml). There is no possibility to generate template data for this device. Please try to reconfigure it and generate template data again. Please remember that reconfiguration time for battery devices depends on the wakeup time. In case of any problems please contact support@fibaro.com Mon plugin hue refonctionne correctement (les anciens boutons ne fonctionnait plus quand j'ai changé d'ip). La mémoire a plus que grimpé (72% utilisé) Partager ce message Lien à poster Partager sur d’autres sites
Sakkhho 469 Signaler ce message Posté(e) 3 mars 2015 Here we go !! Rien sur le nouveau détecteur de fumée ? c'est suprenant. Partager ce message Lien à poster Partager sur d’autres sites
Zorgonaute84 46 Signaler ce message Posté(e) 3 mars 2015 Mais ce genre de probleme n'est pas leur priorité numéro 1 ??? Breached sensor with Arm Delay causes instant alarm after being armed Partager ce message Lien à poster Partager sur d’autres sites
cocolabombe0 9 Signaler ce message Posté(e) 3 mars 2015 (modifié) Non pas de changement. Il est dans "Devices without templates" mais on peut rien faire. Je vais essayé de le supprimer et le recréé pour voir. Edit: toujours en détecteur de mouvement, température, détecteur de fumée et alarme. Plugin TV Sony toujours non fonctionnel Plugin Onkyo ampli ne fonctionne plus. Modifié 3 mars 2015 par cocolabombe0 Partager ce message Lien à poster Partager sur d’autres sites
i-magin 864 Signaler ce message Posté(e) 3 mars 2015 Alors là ... je suis bluffé ! A première vue, pas de souci ! Même mes deux AEON LABS Minimote fonctionnent sans être intervenu ! J'ai juste l'alerte pour deux modules sans template : Swiidinter et Qubino fil pilote... mais ils fonctionnent bien Ok, je n'ai pas une config d'enfer et j'attends la livraison d'un Fibaro Motion Sensor FGMS-001 et d'un Fibaro FGSD-002 "Smoke Sensor 2" ... mais pour l'instant, c'est très positif Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 170 Signaler ce message Posté(e) 3 mars 2015 Mais désormais on peut créer ses propres template non : New Functionalities: Template data download for devices without template Partager ce message Lien à poster Partager sur d’autres sites
cocolabombe0 9 Signaler ce message Posté(e) 3 mars 2015 Moi, je pense plus qu'on peut le télécharger mais comment l'envoyé dans la box, je ne sais pas. J'ai deux modules sur trois que je ne peux pas télécharger: Smoke sensor V2: je peux le télécharger DSD37: je ne peux pas le télécharger ST814: Je ne peux pas le télécharger mais le module n'est plus chez moi. Il ne propose même plus le soft reconfigure. Il faut le faire maintenant depuis le module en lui même. Moi, j'attend un FGFS Flood Sensor Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 170 Signaler ce message Posté(e) 3 mars 2015 Bah le download vers le PC était déjàdispo en 4.033... Mais je ne vois pas l’intérêt. Pour moi ce qui peut servir c'est le download depuis la HC2, afin de pouvoir gérer tous les devices manquant. Sinon mise àjour encours là. Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 170 Signaler ce message Posté(e) 3 mars 2015 Bon la mise àjour àl'air ok. Regarderai en détails ce soir. Partager ce message Lien à poster Partager sur d’autres sites
Gazous 99 Signaler ce message Posté(e) 3 mars 2015 Concernant le Smoke Sensor 2, voici la réponse du support Fibaro ce jour : "SS2 has been released for contract with French company and is not compatible with our system yet. It will be in future releases. For now you can use it with Vera controller for Orange. Kind regards" Partager ce message Lien à poster Partager sur d’autres sites
i-magin 864 Signaler ce message Posté(e) 3 mars 2015 Un 1er bug ... un push notification venant d'un de mes deux Flood Sensor ? Pas de souci de détection d'eau (ma vanne se serait alors automatiquement fermée) ... et pour devancer @BenjyNet et sa remarque d'il y a quelques mois : non, je ne suis toujours pas somnambule et je n'ai pas pissé dessus Partager ce message Lien à poster Partager sur d’autres sites
i-magin 864 Signaler ce message Posté(e) 3 mars 2015 Cette fois-ci c'est le flood sensor de la cuisine : le push est effectué au moment d'une remontée d'info de température (température tout àfait normale) Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 170 Signaler ce message Posté(e) 3 mars 2015 Je ne comprends rien àleur histoire de Template, àquoi cela sert de le télécharger sur son PC ???? Partager ce message Lien à poster Partager sur d’autres sites
Gazous 99 Signaler ce message Posté(e) 3 mars 2015 Ouais pareil pour moi c'est pas clair. Partager ce message Lien à poster Partager sur d’autres sites
Titof_44 30 Signaler ce message Posté(e) 3 mars 2015 pour les templates manquant, faire un soft reconfigure et on peut alors le downloader et l'envoyer au support avec documentation du module en pdf et en anglais bien sur . Partager ce message Lien à poster Partager sur d’autres sites
i-magin 864 Signaler ce message Posté(e) 3 mars 2015 Mon Swiidinter n'a pas de template : - j'ai effectué un "soft reconfigure template" - puis un download device's template - je vais envoyer le fichier xml (que j'ai récupéré sur mon PC avec le download) au support de Fibaro Et le template sera intégré par Fibaro dans la prochaine version Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 342 Signaler ce message Posté(e) 3 mars 2015 Mise a jour en cours.... Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 170 Signaler ce message Posté(e) 3 mars 2015 Ah ok, c'est pour leur envoyé. Du coup je vais faire mon capteur Philio, le seul posant encore souci. Partager ce message Lien à poster Partager sur d’autres sites
Gazous 99 Signaler ce message Posté(e) 3 mars 2015 On va évitée le faire pour le Smoke Sensor 2... Partager ce message Lien à poster Partager sur d’autres sites
971jmd 229 Signaler ce message Posté(e) 3 mars 2015 hoho la mauvaise blague de fibaro, je n'arrive même plus àrentrée dans mes scènes pour les modifier. Partager ce message Lien à poster Partager sur d’autres sites
Gazous 99 Signaler ce message Posté(e) 3 mars 2015 Pareil, impossible d'éditer une scène. Je vais ouvrir un ticket. C'est fait : http://bugzilla.fibaro.com/view.php?id=2946 Partager ce message Lien à poster Partager sur d’autres sites
i-magin 864 Signaler ce message Posté(e) 3 mars 2015 Pas de problème pour éditer une scène Partager ce message Lien à poster Partager sur d’autres sites
