mprinfo
V4.042 Hot Fix - 20-04-2015
Nouvelle version logicielle:4.042
Liste des modifications logicielles 4.042:
This version is hot fixing version addressing some of issues reported by users.
4.042
> Resolved Issues:
#0002091: Unable to change "Devices polling time interval"
#0002958: Excluded devices in HC2 reappear again. Unable to delete them.
#0002523: v4.031 - Fibaro FGRM-221/222 - Venetian mode - Lamellas
#0002558: Not possible to set polling time interval Duwi and Zwave.ME modules.
#0001809: Aeon labs Z-Wave Home Energy Monitor HEM (Single Phase) E2 Not reporting energy usage
#0002556: Description of all plugins
#0002555: Problems with virtual device interface
#0002529: Uninstall of default plugins/panels failed
#0002515: Text is out of the device view
#0002595: Language Russian (incorrect characters occured)
#0002887: Expand button is not shown for virtual device with only labels
#0002385: Dashboard sensors view.
#0002270: zwave.me products not working
#0002755: Block programming with dances is empty
#0002330: Fibaro Door Sensor, Icon Save Bug
#0003166: Icons for windows / door contact FGK101 can not be changed.
#0002182: Seismometer Icon Missing
#0002733: Cant get the Seismometer to be shown and icon is wrong
#0002496: 4.031 Problems changing icon's for devices
#0003042: Fgms001 Not correctly reporting lux
#0002517: 4.031 doesn't show events history
#0002532: No updates in eventpanel anymore
#0002624: Events history
#0002739: Event Log with period of Blank or No Event state
#0002742: Temperature panel only showing the last 30 minutes
#0002858: Temperature data from UBS gets lost
#0003086: Remote access doesn't reconnect if internet connection fail or is not available on boot
#0002826: Battery drain on Danfoss LC12
#0003124: Aeon Labs smart switches marked as dead often
#0003123: Aeon Labs DSB05xxx Multi Sensor goes dead randomly
#0003126: FGRGBW 441M EU - marked as dead
#0003064: Not possible to delete device parameter in 4.037
#0001764: Aeon Labs Aeotec wall switch Z-Wave ZW075
#0003062: KFOB2 Remote controller is partially working. Only first click of a (same) button triggers sceneActivation
#0002751: Email: Newline "\n" does not work in LUA
- Invisible devices after update
- Resolved Known Issue: "Global polling interval is set to a fixed value (120s), this may cause a delay in operation of large Z-Wave networks."
- Minor bug fixes.
> We advise:
Avoiding local polling interval smaller than 30s. This may cause high network traffic and block communication.
Change in Z-Wave Settings the value of global polling interval to recommended.
Note that high RAM memory usage indication in the diagnostic interface might not always mean that the amount of available memory is low. Excess memory is used to speed up the operation.
> Known Issues
In some configurations with multichannel devices (e.g. Aeon Labs, Greenwave) there may still occur higher memory usage which can cause freezes of Home Center. It will be comprehensively fixed in the next version.
Android version of the Fibaro mobile app does not display icons for following devices properly:
- NetAtmo Thermostat
- NetAtmo Weather Station
- Sonos
Inconsistencies in Satel interface.
Power Metering may not work properly for some deviceswhich have no Z-Wave template
RGBW Controler may not work properly when used in in/out mode
Alarm Panel doesn't work in some specific configurations
Plugins for TV Sets of various manufacturers may not work with its newest firmware due to restrictions provided by new devices' firmware. Detailed information about supported firmware versions within plugins will be added.
Breached sensor with Arm Delay causes instant alarm after being armed
Data range selection in event panel doesn't work properly
Devices imported via Gateway Connection may have no icons
Gateway Connection status of dead device between master and slave controller may be different
Devices not properly configured on 3.X may not be converted properly
On mobile clients devices may be visible in different categories than configured
Horstmann Thermostat HRT4-ZW higher battery usage in some cases
In door locks some functions may not work properly
  • Upvote 2
Et la note de mise àjour alors :D
Pas encore publié sur le fofo officiel. D'ailleurs moi je ne la vois même pas encore...
 Rien de parti, toujours la 4.040!
mprinfo, arrête de donner de faux espoirs  :D
tu veux faire le buzz ? :2:
C'était son poisson d'avril :)
 Mais c'est raté.
Non la mise a jour arrive il faut attendre encore quelques minutes mais ça arrive
Non ce n'est pas un poisson, la mise àjour est bien disponible sur les serveurs Fibaro :)
 Une bouteille de rhum par heure passée depuis ton annonce et par personne qui comptait faire cette mise à  jour (déjà  une demi). :P
  • Upvote 3
j'ai dis disponible pas en ligne :D je metterai le change log des que cela arrive
Did, tu étais donc "chand baraque" comme on dit chez nous. J'attendrai ton retour ...
Je soutiens Did :lol:
 Pourquoi chaud baraque? Pour faire la mise à  jour? Non merci, je vais bien en 3.6.
parce que la bouteille de rhum que mprinfo a proposée, n'est que pour ceux qui font l'upgrade de 3.6 vers 4.042
 Non non, je reste en 3.6 (tant pis pour le rhum).
moi aussi je suis chaud des quel arrive vue les bug que j'ai en 4.40 je risque rien sa peut pas être pire
Bon c'est dispo maintenant le release note :) hop hop Pascal :)
Pour attendre mise a jour dispo sur le play store
Envoyé avec mon SmartPhone
Software Changes List 4.042:This version is hot fixing version addressing some of issues reported by users.
4.042
> Resolved Issues:
- Minor bug fixes.
> We advise:
> Known Issues
- Sonos
Release notes for previous versions
