HANSOLO 381 Signaler ce message Posté(e) 24 juillet 2015 héhé 4.053> New Features:- Fibaro Dimmer 2 support- Multichannel Associations support - to use that feature reinclusion or soft reconfiguration is required- Notification Center in web interface - basic set of notifications is currently available, this feature will be developed- It is possible to choose whether the device should be added in secure mode - for devices other than door locks, sirens, roller blinds it is strongly advised to use non secure mode due to Z-Wave protocol performance- Secure update availability check via https- It is possible to interrupt the process of device reconfiguration- Reworded notification messages> New Plugins:- Planika - Bio Fireplace- New video cameras support (check on plugin list)> Resolved Issues:#0003316 Z-Wave communication breakdown after sending an empty argument#0002493 FortrezZ SSA2 siren no template#0002622 Home Center 2 is not supporting multichannel associations#0002706 Cant set parameters on Fibaro Sensor (FGMS)#0001705 POP_123665 Z-Wave UK Plug-in Switch plus Power Meter does not display measured power#0002052 MCOHOME touch panel switch#0002227 Association to Vitrum's slave button is not working#0002276 FGS-221 + WCD2 - cannot associate the second channel#0001771 Metering Report#0002432 unable to change any parameters on Home Energy Meter DSB28-ZWEU E2#0003345 Display truncated in 4.048Satel alarm disarming> Other changes:- Z-Wave Stability Improvements- Z-Wave Network Reconfiguration Improvement- Many other system improvements > Known issues: Using multichanel assocations requires soft reconfiguration of devices Android version of the Fibaro mobile app does not display icons for following devices properly:- NetAtmo Thermostat- NetAtmo Weather Station- Sonos Global polling interval is set to a fixed value (120s), this may cause a delay in operation of large Z-Wave networks. Inconsistencies in Satel interface. Power Mettering may not work properly for some devices Alarm Panel doesn't work in some specific configurations Plugins for TV Sets of various manufacturers may not work with its newes firmware due to restricions provided by new devices firmware. There will be added detalied information about suported firmwave versions within plugins. Breached sensor with Arm Delay causes instant alarm after being armed Data range selection in event panel doesn't work properly Devices imported via Gateway Connection may have no icons Gateway Connection status of dead device between master and slave controller may be different Devices not properly configured on 3.X may not be converted properly On mobile clients devices may be visible in different categories than configured Horstmann Thermostat HRT4-ZW higher battery usage in some cases Doorlocks some functions may not work properly 1 Partager ce message Lien à poster Partager sur d’autres sites
HANSOLO 381 Signaler ce message Posté(e) 24 juillet 2015 Comme une lettre àla poste... Partager ce message Lien à poster Partager sur d’autres sites
Moicphil 1 117 Signaler ce message Posté(e) 24 juillet 2015 Fait ! Ras Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 336 Signaler ce message Posté(e) 24 juillet 2015 Mise a jour en cours... Envoyé de mon SM-G900F en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
GEPETOS 0 Signaler ce message Posté(e) 24 juillet 2015 Installé sans problème et toujours pas de possibilité d'installer des plugins persos.Cela commence a être long cette attente ! Partager ce message Lien à poster Partager sur d’autres sites
quadal 21 Signaler ce message Posté(e) 24 juillet 2015 RAS pour le moment Partager ce message Lien à poster Partager sur d’autres sites
Sakkhho 469 Signaler ce message Posté(e) 24 juillet 2015 pas une beta cette fois. On fera ca après les vacances ... au cas ou Sauf si on me dit que la sirène ZW080 fonctionne maintenant Partager ce message Lien à poster Partager sur d’autres sites
Icek 3 Signaler ce message Posté(e) 24 juillet 2015 J'ai fait le saut 3.6 -> 4.0.53. Suis en train de refaire des config douces de mes HRT4-ZW. Pas de template pour le ZWave repeater de Aeon... de tte façon, je ne sais pas s'il marche vu que mon module dans le garage reste inaccessible Enfin, sinon, tout va bien. Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 157 Signaler ce message Posté(e) 24 juillet 2015 Hum, vais voir pour faire ça du coup semaine prochaine, car pas envie de me retaper mes plugins VS ce soir Partager ce message Lien à poster Partager sur d’autres sites
HANSOLO 381 Signaler ce message Posté(e) 24 juillet 2015 Un petit soucis: dans configuration, général la sélection des capteurs pour les lignes température, humidité et luminosité n'est pas possible. Un coup de Save et ils reviennent. Mais pas possible de définir les seuils de température Partager ce message Lien à poster Partager sur d’autres sites
Peter 68 Signaler ce message Posté(e) 24 juillet 2015 Bonjour mise a jour effectué ras pour le moment mais j'ai p as compri le fonctionnement des nouvelles notifications Et j'attend de voir si mes scene en lua fonctionne toutes Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 157 Signaler ce message Posté(e) 24 juillet 2015 HANSOLO j'avais déjàce bug en 4.049 de mémoire, je ne sais plus comment je l'ai résolu... Partager ce message Lien à poster Partager sur d’autres sites
matthieu 1 Signaler ce message Posté(e) 24 juillet 2015 Idem que Han Solo pour le petit souci. Questions : Pour la nouvelle option "Multichannel Associations support" est en rapport avec l'option Réseau Maillé dans le panneau Zwave ? Concernant la nouvelle option 'secure mode', comment on le paramètre sur le motion sensor ou les détecteurs d'ouvertures de port de fibaro par exemple ? Merci par avance pour vos réponses Partager ce message Lien à poster Partager sur d’autres sites
Icek 3 Signaler ce message Posté(e) 24 juillet 2015 Pas possible d'ajouter mes modules FGS 211 3Kw.. Ah si, ça y est après restart. Tout est OK. Partager ce message Lien à poster Partager sur d’autres sites
Fredric 297 Signaler ce message Posté(e) 24 juillet 2015 (modifié) Un petit soucis: dans configuration, général la sélection des capteurs pour les lignes température, humidité et luminosité n'est pas possible. Un coup de Save et ils reviennent. Mais pas possible de définir les seuils de température je viens de la 4.049 et je n'avais pas ce souci, maintenant, le j'ai!! @Nico, je suis preneur de l'info si tu te souviens.... ps: par contre, cette mise à jour m'a corrigé plein de petit bug, comme les "W" qui s'affichaient tout le temps sur certain device, m'a sirène disparu est réapparue.... Modifié 24 juillet 2015 par Fredric Partager ce message Lien à poster Partager sur d’autres sites
razowski 76 Signaler ce message Posté(e) 24 juillet 2015 Le secure mode est dispo que sur certains modèles uniquement, mais Fibaro door et Motion pas supportés actuellement Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 157 Signaler ce message Posté(e) 24 juillet 2015 Je cherche Fred, je ne sais plus... 1 Partager ce message Lien à poster Partager sur d’autres sites
neliger 35 Signaler ce message Posté(e) 24 juillet 2015 J'ai du mal àtrouver des informations concrètes àpropos du secure mode. Partager ce message Lien à poster Partager sur d’autres sites
matthieu 1 Signaler ce message Posté(e) 24 juillet 2015 Merci razowski pour ta réponse Partager ce message Lien à poster Partager sur d’autres sites
Shad 315 Signaler ce message Posté(e) 24 juillet 2015 Mouais vu les travaux que je vais faire chez moi, je verrais les MAJ au retour de mes vacances et ainsi refaire tous les scripts. Partager ce message Lien à poster Partager sur d’autres sites
ctve 15 Signaler ce message Posté(e) 25 juillet 2015 Ils commencent àme gaver chez Fibaro. Cette nième mise àjour ne comporte toujours pas les templates Qubino qui, si j'en crois la réponse que m'avait faite le support lors de ma demande, sont pourtant prêts de puis plusieurs mois. Bien sûr, Qubino est un concurrent pour ce qui est des modules Zwave mais ce n'est pas en essayant d'étouffer la concurrence qu'on progresse. Parfois je me prends àrêver d'un HC 2 àla sauce Qubino pour secouer un peu les gens de chez Fibaro 1 Partager ce message Lien à poster Partager sur d’autres sites
jojo 2 612 Signaler ce message Posté(e) 25 juillet 2015 fait un petit mail au support fibaro en leur rappelant qu'ils avaient dit qu'ils étaient prêts Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 157 Signaler ce message Posté(e) 25 juillet 2015 Moi j'aimerai surtout voir ces plugins venir... Partager ce message Lien à poster Partager sur d’autres sites
Kana-chan 66 Signaler ce message Posté(e) 25 juillet 2015 Bonjour, Un petit soucis: dans configuration, général la sélection des capteurs pour les lignes température, humidité et luminosité n'est pas possible. Un coup de Save et ils reviennent. Mais pas possible de définir les seuils de température De même, pas de problème en 4.049 et maintenant je l'ai en 4.053... Je pense que c'est un problème de rafraichissement d'affichage, car je mets les seuils, j'enregistre et cela reste. Je sors et reviens, tout est à zéro. Voilà . Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 157 Signaler ce message Posté(e) 25 juillet 2015 Yes, c'est exactement ce que je n'avais... Partager ce message Lien à poster Partager sur d’autres sites
