Peter Posté(e) 31 mars 2016 Signaler Share Posté(e) 31 mars 2016 ATTENTION NE PAS FAIRE CETTE MISE À JOUR CAR GEA HS ET LES SCÈNES AVEC TRIGGER PROPERTIES NE FONCTIONNE PAS ET PLUSIEUR AUTRE BUG Vous pouvez revenir a la version 4.80 en faisant http://ip/services/startUpgrade.php (Merci àNico) Pour cette astuce sans recovery ou perte d'icône Mise àJour déconseillé àvos risques et péril ou si vous voulez remonter les BUG àfibaro Version 4.081 Beta This update features migration process from version 3.600, reconfiguring every device, adjusting it for changes which took place in the system. This will assure possibly smooth transition and continuous operation, allowing each device to work with old settings until reconfiguration is done. Please refer to message that appears in interface and Notification Center after finishing upgrade for further instructions. Important! Updating from version 3.600 may take longer than usual, up to 30 minutes, please do not restart controller during update process. Resolved issues: - #0003578 Danfoss thermostat shows unreal value - #0003883 No reports from Northq Gas Meter NQ-92021 - Update progress bar stops on 30% - Virtual Device code works after device deletion - Satel sensors do not report lastBreached value New devices support: - #0003488 Aeon Labs Multisensor GEN 5 - #0003244 Zwave.me Keyfob GEN 5 - MCO MH10 PM2.5 Monitor - MCO MH9 CO2 Monitor - Aspire RF9518 - Aspire RF9534 - Aspire RF9536 - Leviton VRI06-1L - Leviton VRI10-1L - Leviton VRE06-1L - Leviton VRF01-1L - Leviton VRS15-1L - Leviton VRS05-1L - Leviton VRCS2-MR - Leviton VRCS4-MR - Leviton VRCZ4-MR - Leviton VRCZ4-MO - Leviton VRCS1-1L - Leviton VRCZ1-1L - Vitrum Think Simple IV Scenari - Secure SWM301 Other improvements: - Battery devices now work on default wake up interval when included - Serial number is now displayed in advanced configuration of devices that declare it - Setpoint thermostats capabilities are flexibly adapted when device is included - #0001660, 0003525 Shutdown and reboot actions available from Lua scene, more information can be found on developer.fibaro.com Allez je la tente sa vas peut être résoudre mon problème de latence sur les ordres zwave et je vous dirais si je vois une différence Update en court on Véra bien apres le reboot 2 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Peter Posté(e) 31 mars 2016 Auteur Signaler Share Posté(e) 31 mars 2016 Et pour mprinfo en francais Version 4.081 Beta Cette mise àjour comprend processus de migration de la version 3.600, la reconfiguration de chaque appareil, en l'ajustant pour les changements qui ont eu lieu dans le système. Ceci assurera la transition éventuellement lisse et un fonctionnement en continu, permettant àchaque dispositif de travailler avec les anciens paramètres jusqu'àce que la reconfiguration se fait. S'il vous plaît se référer àun message qui apparaît dans l'interface et centre de notification après avoir terminé la mise àniveau pour plus d'instructions. Important! Mise àjour de la version 3.600 peut prendre plus de temps que d'habitude, jusqu'à30 minutes, s'il vous plaît ne pas redémarrer le contrôleur au cours du processus de mise àjour. Problèmes résolus: - # 0003578 thermostat Danfoss montre la valeur irréelle - # 0003883 Aucun rapport de NorthQ Compteur de gaz NQ-92021 - Mise àjour barre de progression s'arrête sur 30% - Le code de périphérique virtuel fonctionne après la suppression de l'appareil - Capteurs Satel ne signalent pas la valeur lastBreached Les nouveaux appareils prennent en charge: - # 0003488 Aeon Labs Multisensor GEN 5 - # 0003244 Zwave.me Keyfob GEN 5 - MCO MH10 PM2.5 Moniteur - Moniteur de CO2 MCO MH9 - Aspire RF9518 - Aspire RF9534 - Aspire RF9536 - Leviton VRI06-1L - Leviton VRI10-1L - Leviton VRE06-1L - Leviton VRF01-1L - Leviton VRS15-1L - Leviton VRS05-1L - Leviton VRCS2-MR - Leviton VRCS4-MR - Leviton VRCZ4-MR - Leviton VRCZ4-MO - Leviton VRCS1-1L - Leviton VRCZ1-1L - Vitrum Pensez Simple IV Scenari - SWM301 sécurisé Autres améliorations: - Les dispositifs de batterie fonctionnent désormais réveil intervalle par défaut lorsqu'il est inclus - Le numéro de série est maintenant affiché dans la configuration avancée de dispositifs qui la déclarer - Thermostats de consigne capacités sont adaptées avec souplesse lorsque le dispositif est inclus - # 0001660, 0003525 Arrêt et redémarrage des actions disponibles àpartir de Lua scène, plus d'informations peuvent être trouvées sur developer.fibaro.com 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) 31 mars 2016 Signaler Share Posté(e) 31 mars 2016 - #0001660, 0003525 Shutdown and reboot actions available from Lua scene, more information can be found on developer.fibaro.com je lance sur la box de test Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) 31 mars 2016 Signaler Share Posté(e) 31 mars 2016 - Virtual Device code works after device deletion Je l'avais raté ce bug , mais c'est encore un collector celui là 3 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Peter Posté(e) 31 mars 2016 Auteur Signaler Share Posté(e) 31 mars 2016 Salut Lazer moi je suis joueur en ce moment elle est en court sur ma box principal Comme je le disais on verra bien....' Elle est peut être plus stable que la stable ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) 31 mars 2016 Signaler Share Posté(e) 31 mars 2016 c'est une beta, aucun risque © 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jayce74 Posté(e) 31 mars 2016 Signaler Share Posté(e) 31 mars 2016 J'ai lancé aussi ! ;-) Envoyé de mon iPhone en utilisant Tapatalk Lien vers le commentaire Partager sur d’autres sites More sharing options...
sebcbien Posté(e) 31 mars 2016 Signaler Share Posté(e) 31 mars 2016 Capteurs Satel ne signalent pas la valeur lastBreached cool ça maiiiissss Et les QUBINO ??? plutôt... Lien vers le commentaire Partager sur d’autres sites More sharing options...
razowski Posté(e) 31 mars 2016 Signaler Share Posté(e) 31 mars 2016 S'il pouvait nous filer un changelog non seulement des corrections mais aussi des nouveaux bugs ça serait plus pratique de décider si on se lance ou pas... lol Je suis tenté avec l'histoire des capteurs satel, mais je vois bien le truc venir après ils remonteront plus leur status du tout ;-) Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jayce74 Posté(e) 31 mars 2016 Signaler Share Posté(e) 31 mars 2016 Bah voila pour moi c'est up and running et le vd freeram remit à0 la suite au prochain bug! ;-) Envoyé de mon iPhone en utilisant Tapatalk Lien vers le commentaire Partager sur d’autres sites More sharing options...
Peter Posté(e) 31 mars 2016 Auteur Signaler Share Posté(e) 31 mars 2016 Bon alors mise àjour faite et reboot ok et aucune remontée d'état toujours le probleme de latence entre les ordres Plus de météo et je n'ai pas tout vérifier Je vais lui faire un autre reboot pour voir si sa continu ou,pas Sinon recovery dès demain. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) 31 mars 2016 Signaler Share Posté(e) 31 mars 2016 Bon je tente... Lien vers le commentaire Partager sur d’autres sites More sharing options...
BenjyNet Posté(e) 31 mars 2016 Signaler Share Posté(e) 31 mars 2016 Bah moi ras pour le moment. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) 31 mars 2016 Signaler Share Posté(e) 31 mars 2016 Peter, j'ai cru avoir pareil, pas de remonté, plus de météo mais en fait... Non. Comme d'habitude, il faut bien attendre après l'update, car elle n'a pas fini de suite, même si elle nous laisse nous connecter. Et je crais que beaucoup de personne ne reboot bien trop vite, et là on risque de bousiller des trucs. Donc je le répète encore et toujours : Bien attendre après la mise à jour (Et vider son cache), c'est primordiale. Sinon, tout semble ok désormais. Lazer, j'attends avec impatience un code lua propre pour shudown et restart depuis du lua !!! 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) 31 mars 2016 Signaler Share Posté(e) 31 mars 2016 Depuis une scène uniquement : -- Reboot system HomeCenter.SystemService.reboot(); et : -- Shutdown system HomeCenter.SystemService.shutdown(); Je n'ai pas l'impression que ça soit disponible depuis l'API ni les Virtual Devices.... dommage EDIT : une seule ligne de code LUA, ça va c'est propre j'espère Lien vers le commentaire Partager sur d’autres sites More sharing options...
Shad Posté(e) 31 mars 2016 Signaler Share Posté(e) 31 mars 2016 cool avec la remontée de mes onduleurs je vais pouvoir l'éteindre. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Peter Posté(e) 31 mars 2016 Auteur Signaler Share Posté(e) 31 mars 2016 @Nico merci j'avais deja lu àplusieur reprise t'est recommandation Mais je lui est lasser assez de temps car j'ai fait la mise àjour depuis le boulot Et j'ai même pris le temps de manger il a quand même fallut que je la redémarre un autre fois pour que sa rentre en orde Mais en testant GEA a l'instant je n'ai plus de notifications qui fonctionnent Il n'est toujours pas possible de faire une scene en mode bloc avec un iPad tandis qu'avec une tablette Android c'est possible Je vais refaire une demande sur le bug tracker pour ce probleme qui date de plus de 9 mois Je vous souhaite une bonne soirée àtous car au dodo je bosse pas demain je jouerai avec on verra bien Bonne soirée àtous Lien vers le commentaire Partager sur d’autres sites More sharing options...
jojo Posté(e) 31 mars 2016 Signaler Share Posté(e) 31 mars 2016 et mprinfo est aux abonnés absents ? Pascal, réveille-toi, il s'agit d'une beta Lien vers le commentaire Partager sur d’autres sites More sharing options...
jojo Posté(e) 31 mars 2016 Signaler Share Posté(e) 31 mars 2016 Peter, Pourrais-tu modifier le titre et/ou le post 1 pour préciser que cette beta ne concerne que la HC2, PAS la HCL. Merci pour les HCLiens Lien vers le commentaire Partager sur d’autres sites More sharing options...
Peter Posté(e) 31 mars 2016 Auteur Signaler Share Posté(e) 31 mars 2016 Merci Jojo j'ai pas fait gaffe C'est fait Lien vers le commentaire Partager sur d’autres sites More sharing options...
pepite Posté(e) 31 mars 2016 Signaler Share Posté(e) 31 mars 2016 personne d'autre n'a clique encore ? allez ;-) j'hesite je vais attendre lol Tres sympa le shutdown et le reboot ;-), tu as testé Lazer ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
CASINOS Posté(e) 31 mars 2016 Signaler Share Posté(e) 31 mars 2016 Bonjour Quelqu'un a t-il fait cette mise a jour depuis une v3.6 ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) 31 mars 2016 Signaler Share Posté(e) 31 mars 2016 Non Mais attention, il se peut que cela bloque pour une question de taille (En fonction de ton installation), tu devras dans ce pas passer par le support. Bon, de mon côté stable pour le moment, rien à dire. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) 31 mars 2016 Signaler Share Posté(e) 31 mars 2016 @pepite : ouaip testé à l'instant le shutdown dans une scène, ça lance immédiatement l'arrêt propre de la box. @CASINOS : tu as surement une DB énorme qu'il va avoir du mal à migrer, mais il me semble que dans les v4 récentes ça ne plante plus et il arrive au bout. Par contre il me semble avoir lu des retours d'expériences comme quoi ça prend plus de 30 minutes, voire plus. 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
jmg38 Posté(e) 1 avril 2016 Signaler Share Posté(e) 1 avril 2016 De 4.080 à 4.081 gros plantage 503. C'est la première fois qu'une nouvelle version plante comme ça. J'ai tenté de revenir en 4,08 mais impossible. Donc reboot plusieurs fois mais tous les instantanés (-1) de GEA ne fonctionne plus! Curieusement tout le reste des commandes marche ! J'ai tenté de réintroduire ligne par ligne mais négatif! Un détail sans lien avec la nouvelle version j'ai la météo yahoo bloqué depuis plusieurs jours. Lien vers le commentaire Partager sur d’autres sites More sharing options...
