anthonylegrec Posté(e) 7 juillet 2016 Signaler Share Posté(e) 7 juillet 2016 LA nouvelle version stable est sortie il y a quelque minutes. Software Changes List 4.090: Version 4.090This update features migration process from version 3.600, reconfiguring every device, adjusting it for changes which took place in the system. This will assure possibly smooth transition and continuous operation, allowing each device to work with old settings until reconfiguration is done. Please refer to message that appears in interface and Notification Center after finishing upgrade for further instructions.Important!Updating from version 3.600 may take longer than usual, up to 30 minutes, please do not restart controller during update process.Resolved issues:- #0003578 Danfoss thermostat shows unreal value- #0003883 No reports from Northq Gas Meter NQ-92021- Update progress bar stops on 30%- Virtual Device code works after device deletion- Satel sensors do not report lastBreached value- #0003605 #0003962 #0003962 Weather is not updating (weather information provider changed to yr.no)- Trigger information is brought back to the way it operated in 4.080- #0003094 Alarm panel doesn't record change of alarm state- #0003958 Virtual Device main loop hangs- #0003303 Remote Gateway synchronization moves devices to Unassigned- Protection Command Class not working on devices without template- 503 error when deleting section in some cases- Malfunction of RGBW when changing controlled device to RGB- NaN displayed in device serial number- Scene Activation not working when triggered multiple times by the same id- Mobile applications: Change of devices order not possible for non-admin users- Philips Hue plugin does not allow new user configuration. Reinstall existing plugin to enable fix- Wind speed available in weather conditions computed incorrectly - value too low- Services Restart called from 503 error page not working- Multiple Virtual Devices working simultaneously may cause 503 error- Virtual Devices hang- Scenes do not trigger when RAM usage is above 75%. Threshold moved to 90% - Device hierarchy not displaying properly for Dimmer 2 in advanced configuration- FIBARO Swipe imported by Gateway Connection not working properly- Z-Wave Weather templates lacking for devices of other manufacturersNew devices support:- #0003488 Aeon Labs Multisensor GEN 5- #0003244 Zwave.me Keyfob GEN 5- MCO MH10 PM2.5 Monitor- MCO MH9 CO2 Monitor- Aspire RF9518- Aspire RF9534- Aspire RF9536- Leviton VRI06-1L- Leviton VRI10-1L- Leviton VRE06-1L- Leviton VRF01-1L- Leviton VRS15-1L- Leviton VRS05-1L- Leviton VRCS2-MR- Leviton VRCS4-MR- Leviton VRCZ4-MR- Leviton VRCZ4-MO- Leviton VRCS1-1L- Leviton VRCZ1-1L- Vitrum Think Simple IV Scenari- Secure SWM301Other improvements:- Battery devices now work on default wake up interval when included- Serial number is now displayed in advanced configuration of devices that declare it- Setpoint thermostats capabilities are flexibly adapted when device is included- Added support for Fibaro Button- #0003844 Confirmation pop-up is now displayed when restoring or deleting backup- Favicon added- Satus bar is scrolled with page- Notification Center is available directly on the status bar- Firmware Update - wireless update of Z-Wave devices: Motion Sensor, Dimmer and Wall Plug. Availability of update for each device is showed in Notification Center and Advanced Configuration. Run update only when devices is in close range from controller (ca. 2 m). Process can take up to 30 minutes, depending on Z-Wave traffic and devices queued for update. Details on whole procedure can be found in notification displayed before every device update.- #0001660, 0003525 Shutdown and reboot actions available from Lua scene, more information can be found on developer.fibaro.com- New, configurable scenes triggering modes available in each scene advanced configuration:Automatic - scene gets triggered either by one of defined triggers (device state, global variable etc.) or manually, by 'Run' buttonManual - scene executes only manually by 'Run' buttonDisabled - scene is inactive, does not get triggered and cannot be run manuallyVisibility - scene can be hidden in all interfaces (mobile apps, web interface)In connection to this change there are new Lua API functions, more information can be found on developer.fibaro.com- Other minor fixes 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
anthonylegrec Posté(e) 7 juillet 2016 Auteur Signaler Share Posté(e) 7 juillet 2016 Par contre l'update notifier http://www.domotique-fibaro.fr/index.php/topic/698-update-notifier-gardez-votre-hc2-fibaro-%C3%A0-jour/ Ne m'a pas averti de la mise a jour... Quelqu'un d'autre a eu ce souci? 2 Lien vers le commentaire Partager sur d’autres sites More sharing options...
anthonylegrec Posté(e) 7 juillet 2016 Auteur Signaler Share Posté(e) 7 juillet 2016 Je me lance.. Qui aime sa box, me suive.. Lien vers le commentaire Partager sur d’autres sites More sharing options...
anthonylegrec Posté(e) 7 juillet 2016 Auteur Signaler Share Posté(e) 7 juillet 2016 Tout ce passe bien jusqu'a maintenant Lien vers le commentaire Partager sur d’autres sites More sharing options...
anthonylegrec Posté(e) 7 juillet 2016 Auteur Signaler Share Posté(e) 7 juillet 2016 Tout a l'air de fonctionner correctement jusqu’àmaintenant... Lien vers le commentaire Partager sur d’autres sites More sharing options...
Loizeauc Posté(e) 7 juillet 2016 Signaler Share Posté(e) 7 juillet 2016 ben pas moi ... restée bloquée à 10% j'ai tenté un simple refresh de safari et il a mis un temps dingue à redémarrer mais maintenant à première vue ça marcherait Lien vers le commentaire Partager sur d’autres sites More sharing options...
Bobobull Posté(e) 7 juillet 2016 Signaler Share Posté(e) 7 juillet 2016 Update sans soucis. Pour le moment tout roule. Lien vers le commentaire Partager sur d’autres sites More sharing options...
mprinfo Posté(e) 7 juillet 2016 Signaler Share Posté(e) 7 juillet 2016 Mise àjour en cours chez moi Envoyé de mon SM-G900F en utilisant Tapatalk Lien vers le commentaire Partager sur d’autres sites More sharing options...
ericl78 Posté(e) 7 juillet 2016 Signaler Share Posté(e) 7 juillet 2016 Hi all Mise à jour effectuée Pour moi, comme d'habitude RAS, tout est OK Bonne soirée à vous tous Lien vers le commentaire Partager sur d’autres sites More sharing options...
Krikroff Posté(e) 7 juillet 2016 Signaler Share Posté(e) 7 juillet 2016 Par contre l'update notifier http://www.domotique-fibaro.fr/index.php/topic/698-update-notifier-gardez-votre-hc2-fibaro-%C3%A0-jour/ Ne m'a pas averti de la mise a jour... Quelqu'un d'autre a eu ce souci? J'imagine un blocage du VD Tu viens de quelle version de HC2 ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
anthonylegrec Posté(e) 7 juillet 2016 Auteur Signaler Share Posté(e) 7 juillet 2016 J'imagine un blocage du VD Tu viens de quelle version de HC2 ? Je viens de la version 4.083b Lien vers le commentaire Partager sur d’autres sites More sharing options...
971jmd Posté(e) 7 juillet 2016 Signaler Share Posté(e) 7 juillet 2016 Bon comme dab, je clic et je reviens dans 1h et espèrent que le chat ne vas pas bugué Envoyé de mon iPhone en utilisant Tapatalk Lien vers le commentaire Partager sur d’autres sites More sharing options...
mprinfo Posté(e) 7 juillet 2016 Signaler Share Posté(e) 7 juillet 2016 J'imagine un blocage du VD Tu viens de quelle version de HC2 ?J'ai eu le même soucis j'étais en 4.083Envoyé de mon SM-G900F en utilisant Tapatalk Lien vers le commentaire Partager sur d’autres sites More sharing options...
domo Posté(e) 7 juillet 2016 Signaler Share Posté(e) 7 juillet 2016 alors des retours concluant Lien vers le commentaire Partager sur d’autres sites More sharing options...
fab971 Posté(e) 7 juillet 2016 Signaler Share Posté(e) 7 juillet 2016 MAJ effectuée. RAS. Lien vers le commentaire Partager sur d’autres sites More sharing options...
ikillou Posté(e) 7 juillet 2016 Signaler Share Posté(e) 7 juillet 2016 RAS chez moi aussi. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Krikroff Posté(e) 7 juillet 2016 Signaler Share Posté(e) 7 juillet 2016 J'ai eu le même soucis j'étais en 4.083 Envoyé de mon SM-G900F en utilisant Tapatalk Pas de problème de mon côté [emoji6] Mais d'une installation àl'autre ... Et sans clairement en identifier la cause ! Envoyé de mon smartphone Lien vers le commentaire Partager sur d’autres sites More sharing options...
971jmd Posté(e) 7 juillet 2016 Signaler Share Posté(e) 7 juillet 2016 tout vas bien, le chat n'a pas buggé, je repete le chat n'a pas buggé Lien vers le commentaire Partager sur d’autres sites More sharing options...
darklite44 Posté(e) 7 juillet 2016 Signaler Share Posté(e) 7 juillet 2016 Bonsoir, Je suis passé en 4.090 également. Pas de plantage lors de la MAJ. Lien vers le commentaire Partager sur d’autres sites More sharing options...
JYM Posté(e) 7 juillet 2016 Signaler Share Posté(e) 7 juillet 2016 MàJ ok, mais la météo est toujours aussi nase...encore un joli raté! Lien vers le commentaire Partager sur d’autres sites More sharing options...
pepite Posté(e) 7 juillet 2016 Signaler Share Posté(e) 7 juillet 2016 Alors alors messieurs ;-) Pendant la mi-temps ;-) 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
chrispec Posté(e) 7 juillet 2016 Signaler Share Posté(e) 7 juillet 2016 Ras pour le moment Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) 7 juillet 2016 Signaler Share Posté(e) 7 juillet 2016 Cette nouvelle stable m'a l'air d'être la v4.083 beta rebadgée en stable, je ne vois aucune nouveauté dans le changelog. Je l'installerai demain je pense. Lien vers le commentaire Partager sur d’autres sites More sharing options...
sebcbien Posté(e) 7 juillet 2016 Signaler Share Posté(e) 7 juillet 2016 installée je vais re-essayer l'inclusion Lien vers le commentaire Partager sur d’autres sites More sharing options...
mprinfo Posté(e) 7 juillet 2016 Signaler Share Posté(e) 7 juillet 2016 France 2 - Allemagne 0 Envoyé de mon SM-G900F en utilisant Tapatalk Lien vers le commentaire Partager sur d’autres sites More sharing options...
