jojo
    15280
    216
  1. jojo
    Gestion Panneau De Chauffage
    Lzaer, tu es un champion : http://adresse_ip/api/panels/heating me retourne les id des heating panels : [{"id":14,"name":"SdB_Etage","properties":{"handTemperature":0,"handTimestamp":0,"vacationTemperature":0}},{"id":15,"name":"SdB_Rez","properties":{"handTemperature":0,"handTimestamp":0,"vacationTemperature":0}}] et ensuite http://adresse_ip/api/panels/heating?id=14 me retourne le détail : {"id":14,"name":"SdB_Etage","properties":{"monday":{"morning":{"hour":6,"minute":0,"temperature":21},"day":{"hour":7,"minute":0,"temperature":15},"evening":{"hour":18,"minute":0,"temperature":21},"night":{"hour":19,"minute":30,"temperature":15}},"tuesday":{"morning":{"hour":6,"minute":0,"temperature":21},"day":{"hour":7,"minute":0,"temperature":15},"evening":{"hour":18,"minute":0,"temperature":21},"night":{"hour":19,"minute":30,"temperature":15}},"wednesday":{"morning":{"hour":6,"minute":0,"temperature":21},"day":{"hour":7,"minute":0,"temperature":15},"evening":{"hour":18,"minute":0,"temperature":21},"night":{"hour":19,"minute":30,"temperature":15}},"thursday":{"morning":{"hour":6,"minute":0,"temperature":21},"day":{"hour":7,"minute":0,"temperature":15},"evening":{"hour":18,"minute":0,"temperature":21},"night":{"hour":19,"minute":30,"temperature":15}},"friday":{"morning":{"hour":6,"minute":0,"temperature":21},"day":{"hour":7,"minute":0,"temperature":15},"evening":{"hour":18,"minute":0,"temperature":21},"night":{"hour":19,"minute":30,"temperature":15}},"saturday":{"morning":{"hour":8,"minute":0,"temperature":21},"day":{"hour":9,"minute":0,"temperature":15},"evening":{"hour":18,"minute":0,"temperature":21},"night":{"hour":19,"minute":30,"temperature":15}},"sunday":{"morning":{"hour":8,"minute":0,"temperature":21},"day":{"hour":9,"minute":0,"temperature":15},"evening":{"hour":18,"minute":0,"temperature":21},"night":{"hour":19,"minute":30,"temperature":15}},"handTemperature":0,"handTimestamp":0,"vacationTemperature":0,"rooms":[20]},"created":1414622603,"modified":1414622603} et cerise sur le gateau, y aurait-il une commande GET qui me permetterait de définir la rooms (comme ça je créerais une device virtuelle et je pourrais gérer mon chauffage en fonction de la valeur d'une variable globale pour les vacances)
  2. Alvea, Pour être sûr quel est le schéma ACTUEL (=> sans Fibaro) pour la commande de tes velux (avec si possible le schéma logique des contacts)
  3. jojo
    Lenteur Forum
    En y faisant attention, je constate également de fortes lenteurs, surtout pour accéder à la page Portail. Est-ce que la femme de ménage n'est pas venue dernièrement et aurait retiré la prise d'un serveur pour brancher son aspirateur ?
  4. jojo
    Merci Lazer, mais comment puis connaitre l'id de mon panel (sur HCL)
  5. jojo
    Lenteur Forum
    Lent du point de vue réactivité des membres, ou lent au niveau des serveurs ? Moi, perso, je n'ai rien remarqué. C'est peut-être ta connection internet : as-tu vérifié qu'il n'y a pas de noeud dans ton cable ? n'est-ce pas tes enfants qui te piquent toute la bande passante ? peut-être est ce que c'est parce que tu n'est pas en ville (lol)
  6. Alvea, Pour moi ce schéma tient la route. Fait attention que sur le Fibaro tu as montré 2 sorties O, alors que l'ordre c'est S1 - S2 - O2 - O1 - I - N - L Donc le DOWN est connecté au S1, et le O1 est connecté àla borne down de ton KLF100. idem pour le UP Sur le schéma du KLF100 quel est le fil pour le UP (le clair ou le foncé) ? je n'y vois que des connections pour 1 volet. Pour un second volet, tu auras évidemment besoin d'un deuxième Fibaro
  7. Bonjour, Il est temps de commencer à se chauffer .... Avec le Heating Panel je peux programmer la température désirée pour chaque jour de la semaine . Je suis maintenant en congés à la maison et j'aimerais bien que la période de chauffe corresponde plus au WE qu'à celle de la semaine. Mon idée était : je crée une variable globale : CONGE : oui / non ensuite scène : si CONGE = oui, alors activer le heating panel "heat_conge" si CONGE = non, alors activer le heating panel "heat_travail" Pour activer le heating panel, je pensais à lui associer la pièce correspondante. On pourrait faire la même chose avec les vacances : j'ai déjà toutes des scènes pour la gestion de mon éclairage en fonction de la variable VACANCES (oui / non), on pourrait ainsi également activer / désactiver automatiquement (c'est le principe de la domotique) le chauffage. Dans le même ordre d'idée on pourrait également imaginer qu'on ne chauffe pas une pièce si la fenêtre est ouverte. Evidemment, pour faire compliqué, je n'ai qu'une HCL (=> pas de lua), et j'aimerais éviter de devoir faire des scènes complexes pour gérer mon chauffage en me passant des heating panels. J'espère que vous avez de bonnes idées. Merci Vincent
  8. @ Alvea Si tu as un KLF 050, d'après sa doc postée ci-dessus, c'est super simple : Tu utilises un Fibaro FGS-221 (2x1,5 kW) tu alimentes L & N avec le même 220V que ton KLF 050 (tu le mets à côté) Tu branches le cable C (Bleu) sur le I du Fibaro Cable jaune (actionneur vers le haut) : la sortie de l'interrupteur sur le S1 du Fibaro. Sur O1 du Fibaro tu branches le cable jaune vers le KLF 050. Idem avec le cable rouge (actionneur vers le bas) : la sortie de l'interrupteur sur le S2 du Fibaro. Sur O2 du Fibaro tu branches le cable rouge vers le KLF 050. Ca DOIT marcher
  9. Je ne connais pas du tout les accessoires électriques Velux, mais il y a moyen d'utiliser un module Fibaro FGS-221 (2x1,5 kW) alimenté en 220V sans injecter du 220V dans le circuit : Les bornes L & N sont l'alimentation en 220V du module. Le module fait ensuite un contact entre I et O1 (ou I et O2) : tu peux y mettre la tension que tu veux, tant que tu ne dépasse pas 1500 W par sortie. Maintenant si ton électronique Velux sort un contact, tu le branche sur S1 (la commande) et le départ vers le Vélux sort du O1. Si c'est pas clair, envoie-moi le principe de fonctionnement actuel et j'essayerai de trouver une solution (sans garantie)
  10. pourrait-on imaginer un montage identique pour une citerne àmazout ?
  11. jojo
    Cameras Ip Poe
    Merci KriKoff, Je ne suis pas sà»r d'avoir compris toutes tes explications ... Mais je peux te confirmer que : je rentre l'IP (interne) et le port de la caméra dans le HCL => tu proposes de mettre l'IP externe avec une redirection de port au niveau de mon routeur, ce qui voudrait dire que mon HCL sort de chez moi, pour rerentrer chercher l'info des caméras ? depuis que les 2 Dahua ne sont plus connectées, mon HCL ne plante plus, avant c'était systématique. Quand je dis plante, c'est bien planté ! : plus possible de s'y connecter, même en IP locale, les scènes ne fonctionnent plus. Je suis obligé de faire un reboot physique (dans le meilleur des cas) et parfois même un recovery et un restore de backup. C'est lourd. Si tu as d'autres bonnes idées, je suis preneur.
  12. jojo
    Cameras Ip Poe
    @Shad : merci pour le tuyau le problème que j'ai avec mes caméra PoE et mon HCL provient peut-être du fait que je récupère un flux h264 au lieu de mjeg. Une bonne piste pour mes investigations futures
  13. jojo
    Cameras Ip Poe
    J'ai 2 cameras PoE Dahua (voir fiche technique jointe) Mon expérience actuellement avec la HCL est mitigée : lorsque je les connecte toutes les deux, avec l'affichage de la video, mon HCL plante (uniquement lorsque je me connecte via fibaro-home). C'est TRES TRES TRES bizarre, mais je continuerai mes investigations, car le support Fibaro qui s'est connecté chez moi, n'a rien trouvé Sinon, l'image est de très bonne qualité (même la nuit). Je les ai achetées sur aliexpress.com, et elles y sont bcp moins chères. Pour l'injecteur j'ai pris un switch, à peine plus cher qu'un injecteur, mais ok pour 4 PoE et 4 non PoE http://www.amazon.fr/gp/product/B0031KMSVA/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1 ou http://www.amazon.fr/TP-Link-TL-SF1008P-Switch-RJ45-8ports/dp/B001PS4NRM/ref=fallbacksessionReftagcomputers_3?ie=UTF8&refRID=00GV00W35YC42GAR2PAW
  14. jojo
    Vitual Device
    alors, il ne reste plus que tes yeux pour pleurer
  15. jojo
    Vitual Device
    ce brol est fort sensible aux espaces. Essaye ceci : GET /?sn=0013XXXXXb8&token=e946383cdXXXXXf00e19fd4530b&server=openjabnab.fr&tts=alarme+armer&voice=fr HTTP/1.10x0D0x0AHost: 192.168.1.13:80<space>0x0D0x0A0x0D0x0A
  16. jojo
    Vitual Device
    En fait avec les Virtual Devices, tu peux lancer des commandes GET. Mais je ne suis pas un pro de ces bidules ... Donc si tu a l'àŒP et le port interne de ton lapin (tu devrais l'avoir ???), j'essayerais ceci GET /?sn=0013d3XX23b8&tokene946383cdXXXXXXXX00e19fd4530b&server=openjabnab.fr&tts=alarme+armer&voice=fr HTTP/1.10x0D0x0AHost:<space><IP:port>0x0D0x0A0x0D0x0A avec IP:Port : celle de ton cher lapin
  17. jojo
    Vitual Device
    en fait, tu te connectes via un lien externe ? Comme si tu te connectais sur ton HCL via Fiabor-Home.com au lieu de rentrer l'IP directe de ton HCL ? si oui, je n'ai pas d'expérience. Essaye de voir si tu peux te connecter àton lapin en direct, sans sortir
  18. jojo
    Vitual Device
    quelle est l'url qui fonctionne correctement depuis ton browser ? (ne la met pas sur le site en hyperlien, car elle sera tronquée au milieu, mais juste un copier coller sous forme de texte)
  19. jojo
    Vitual Device
    "Nabaztag, connecté à openjabnab, j'ai déjà essayé en codant mes id d'openjabnab" tu sais parler français SVP ?
  20. jojo
    Vitual Device
    je vois 2 choses qui clocheraient : tu as 1 fois de trop "0x0D0x0A0x0D0x0A" à la fin le <user:pwd in Base64> est celui du device à commander, pas celui du Fibaro. S'il ne requiert pas d'autentification, essaie en oubliant la partie du string depuis Authorization : ...
  21. jojo
    Vitual Device
    ferecoch, regarde mon post précédent, GET<space><command><space>HTTP/1.10x0D0x0AHost:<space><IP:port>0x0D0x0AAuthorization:<space>Basic<space><user:pwd inBase64><space>0x0D0x0A0x0D0x0A ça devrait marcher
  22. Le bug est passé en "accepté" chez Fibaro
  23. jojo
    Ne Pas Oublier La Poubelle !
    Pourquoi ne pas imaginer qqch comme ce qui suit : tu appuyes sur le bouton quand la poubelle est pleine il passe en alarme tant que la poubelle n'est pas changée / vidée (pourquoi se limiter à48h ?) chaque fois que tu mets l'alarme tu reçois une alerte si le FBGS est en alarme. Quand tu sorts la poublelle, tu réappuyes sur le bouton, ce qui désactive l'alarme. Tu pourrais également imaginer un contact qui réagit au poids sous la poubelle, pour automatiser cela : si le poids est sous une certaine limite, alors contact => cela voudrait dire que tu as sorti la poubelle
  24. Je viens de créer un ticke't sur bug tracker http://bugzilla.fibaro.com/view.php?id=1923
  25. GGEENNIIAALL Un tout grand merci Berale24 pour ce lien ;-)
