2241 -
19
pas bête
Merci @Lazer, la direction que tu m'as donné était la bonne http://www.domotique-fibaro.fr/index.php/topic/3974-changement-ic%C3%B4nes-d%E2%80%99apr%C3%A8s-l%C3%A9tat/
bon, je progresse... local Watts = fibaro:getGlobalValue("CONSO") Watts = Watts/1000 fibaro:debug(Watts) if Watts <= 1 then fibaro:call(228, "setProperty","currentIcon", 1118) elseif Watts > 1 then fibaro:call(228, "setProperty", "currentIcon", 1119) elseif Watts >= 2 then fibaro:call(228, "setProperty", "currentIcon", 1119) elseif Watts >= 3 then fibaro:call(228, "setProperty", "currentIcon", 1120) elseif Watts >= 4 then fibaro:call(228, "setProperty", "currentIcon", 1120) elseif Watts >= 5 then fibaro:call(228, "setProperty", "currentIcon", 1121) elseif Watts >= 6 then fibaro:call(228, "setProperty", "currentIcon", 1122) elseif Watts >= 7 then fibaro:call(228, "setProperty", "currentIcon", 1122) elseif Watts >= 8 then fibaro:call(228, "setProperty", "currentIcon", 1122) elseif Watts >= 9 then fibaro:call(228, "setProperty", "currentIcon", 1122) elseif Watts >= 10 then fibaro:call(228, "setProperty", "currentIcon", 1122) elseif Watts >= 11 then fibaro:call(228, "setProperty", "currentIcon", 1123) end fibaro:sleep(6*1000) le problème, c'est que cela s’arrête à 1, je vois pourquoi, mais ne trouve pas la solution j'ai fait ça: local Watts = fibaro:getGlobalValue("CONSO") Watts = Watts/1000 fibaro:debug(Watts) if Watts <= 1 then fibaro:call(228, "setProperty","currentIcon", 1118) elseif Watts > 1 then fibaro:call(228, "setProperty", "currentIcon", 1119) end if Watts >= 2 then fibaro:call(228, "setProperty", "currentIcon", 1119) end if Watts >= 3 then fibaro:call(228, "setProperty", "currentIcon", 1120) end if Watts >= 4 then fibaro:call(228, "setProperty", "currentIcon", 1120) end if Watts >= 5 then fibaro:call(228, "setProperty", "currentIcon", 1121) end if Watts >= 6 then fibaro:call(228, "setProperty", "currentIcon", 1122) end if Watts >= 7 then fibaro:call(228, "setProperty", "currentIcon", 1122) end if Watts >= 8 then fibaro:call(228, "setProperty", "currentIcon", 1122) end if Watts >= 9 then fibaro:call(228, "setProperty", "currentIcon", 1122) end if Watts >= 10 then fibaro:call(228, "setProperty", "currentIcon", 1122) end if Watts >= 11 then fibaro:call(228, "setProperty", "currentIcon", 1123) end fibaro:sleep(6*1000) ça fonctionne mais je ne suis pas sur que ce soit très optimisé.
@Did, c'est l'idée, mais pour le moment j'ai un petit souci avec le delta, Frédo l'a fait un petit moment je vais essayer voir avec lui. À part que tu saches comment donner un delta, par exemple entre 2000 et 3000. ?
j'ai un petit soucis surement tout bête mais je ne trouve pas mon bonheur. j'arrive sans problème à faire changer les icônes d'un vd selon sont état mais je n'arrive pas à donner un delta pour le changement de l'eco-device. par exemple, changer l'icone si la valeur de la variable "CONSO" est entre 2000 et 3000. if tonumber(fibaro:getGlobalValue("CONSO")) <= tonumber("1000") then fibaro:call(440, "setProperty", "currentIcon", 1089) merci de votre aide
si cela intéresse quelqu'un, j'ai fait ça pour mon Eco-device.
ça fonctionne pour moi, sauf que les message sont vide oups, j'avais oublié de créer une variable "SMS" merci pour ce tuto Cela nous dégage des push Fibaro.
je cherche des icônes pour mettre sur mon Eco-device avec une graduation de 0w à 11000w. de ce genre là : est ce que quelqu'un en aurai à partager? merci d'avance
Besoin daide Je Ne Reçois Plus Les Notifications
Fredric a répondu à un(e) sujet de mikael2235 dans Support
Eh bien, ça n'aura pas marché longtemps ! Sur l'iPad, ça ne fonctionne deja plus. Depuis hier soir ! Bye-bye push… -
Désolée @lolomail, je n'avais pas vu ton post. super si ça marche pour toi, effectivement il suffit de faire une scène comme ça et après tu peux vraiment donner libre cours àton imagination. Moi je pense commander celle àquatre boutons de façon àpouvoir allumer le projecteur extérieur ou l'éteindre par exemple sans être obligé de temporiser ou de me connecter avec mon Smartphone. Et je ne sais pas si tu as fait l'essai, mais normalement ça apporte quand même bien assez loin.
Ils sont conscients du problème, c'est déjàça ! Chez moi, tout fonctionne àl'exception de mon iPhone 5S. l'iPad 4, l'iPhone 4S de mon épouse et les tablettes Android fonctionne Au niveau des push. mon iPhone 5s ne les reçoit plus, dès que je me connecte en wi-fi en local, tant que je me suis pas reconnecter par le serveur Fibaro, je ne reçois plus les push sur l'iPhone, donc, je ne me connecte plus en wi-fi chez moi en attendant. -
Oui, moi aussi, depuis hier soir exactement, c'est revenu àla normale sur mon iPad, j'avais laissé de côté depuis longtemps. Donc j'imagine que Fibaro a du lui faire quelque chose. -
oui, fonctionne très bien Pushover. les push ont ponctionnés tous se week-end, je me suis connecté en 3g puis en wifi chez mes beau parent ou j'ai passé le week-end et tout est arrivé. -
L'appli en fond de tache n'empeché pas les push, la preuve, sur le 4s de ma femme qui a toujours fonctionné, les push arrivent appli en fond de tache, alors que sur le mien, si elle reste en fond de tache, pas de push. -
oui, en Edge, 3G ou 4G, le résulta est le même, c'est bluffant, je suis en Wifi chez moi, je me connecte sur la box, les push ne fonctionne pas, de coupe le wifi et je me connecte par le serveur fibaro en 3G et les push reviennent instantanément, appli fermée. si l'appli est ouverte, j'ai les notifications qui s’affichent sur l'icone fibaro en chiffre mes pas les textes. dés que je me reconnecte en direct en wifi, plus rien... bravo pour avoir vu ça -
bien-vu @i-magin, effectivement, si on est en wifi local ou que l'appli est ouverte, pas de push, si on ce connecte en 3G ou autre que local et que l'appli est fermé, ça fonctionne. c'est ça le coté aléatoire!!! -
le récepteur et dans un placard à 2m de la porte d'entrée, ça porte environ 30m/40m de l’intérieur de la voiture. ça commande des relais, alors tout est envisageable
oui pour le contact, deux par bouton et j'ai choisi un FGBS-001 vu que le récepteur des Satel doit être alimenté, ça l'alimente en même temps, tout ça branché sur une ligne ondulé. et aussi pour WAF, rouge, désactivé, vert activé, simple et solide était le contrat, par ce qu'un seul bouton aurait suffit mais ce que femme veux.... (tu le fais!!! )
Alors, oui, ce sont des télécommandes sécurisées, si tu en perds une, tu la désactive du boitier et tu ne peux pas la ré-associer sans accéder au boitier à l’intérieur de chez toi. http://www.planete-domotique.com/systeme-telecommande-2-canaux-satel.html je les avais acheté l'an dernier en solde et je vais certainement passer à la 4 bouton pour plus d'option. je connais le point de vu sur "Alarme" et "vrai alarme", j'ai fais au mieux de mes possibilité et de mes moyen, j'habite pas une région trop mal famé et surtout, j'avais rien, donc c'est mieux que rien donc moi aussi la HC2 me sert d'alarme, mais vraiment poussé à l’extrême. Donc ces télécommandes active un FGBS-001, à toi d'écrire tes scénarios avec, par exemple: je sort de chez moi pour aller bosser, le matin très tôt, il fait nuit, j'allume mes lumières extérieure avant de sortir le temps d'aller à la voiture (le temps que je veux et pas minuté) et quand je suis dans la voiture et que je le décide, j'active l'alarme qui éteint en même temps les lumières et effet inverse les soir ou je rentre qu'il fait nuit, avant même l'ouverture du portail (qui et pour le moment manuel ), je désactive l'alarme qui allume mes lumières extérieur et je peux me garer et rentrer a la maison sans marcher dans la boue (ou pire, vilain le chien!! ). tu peux bien entendu donner libre cours à ton imagination...
j'utilisais la DSA22 mais, le fonctionnement était trop aléatoire et la distance trop court, il fallait que je colle la télécommande au vitre de la porte d'entrée ou que je fasse le tour de la maison pour qu'elle capte mieux. je pense que malheureusement, cette télécommande ne va pas pour toutes les maison. donc, j'ai pris des télécommande SATEL jumelées avec un FGBS-001. déjà , le coup est raisonnable, 35€ pour deux télécommande + leur boitier, résistante,sécurisées, qui portent et consommant très peux. un FGBS-001 qui coà»te 39€ pour les ordre à la HC2. un bouton rouge, un bouton vert, on et off, quoi de plus WAF!! et vraiment prévu pour être accroché au clé, pas fragile.
Désolé pour toi @Domodial mais bienvenue au club des "sans notifications". j'ai ouvert un ticket il y a 15 jours, j'ai reçu un mail comme quoi un tech était chargé du problème et stand-by depuis. si je fais la manip de @KriKroff , ça marche aléatoirement un ou deux jour et ça marche plus, je l'ai fait trois fois, vraiment marre de changer les ID partout!! -
encore un produit qui nous pousse àpasser en V4, je peux me passer de la remonté de conso (même si c'est dommage), je peux me passer de la remonté d'information de la prise vers la HC2 lorsque l'on manipule la multiprise manuellement (ça, c'est encore dommage) mais que suite àune coupure de courant, toutes les prises passent au "ON" et la HC2 ne le voit même pas, c'est rédhibitoire, elle reste dans sont carton cette multiprise, au moins le temps que le V4... soit stable, enfin.....ça , c'est une autre histoire, et pas drôle en plus!
il te manque la notion des jours sur ton "teasing" @Steven, mais pour le coup, je vous faire un trou au fond du jardin pour enterrer feux Scheduler
- 12510 réponses
Ben oui @Steven, ça fait longtemps que tu aurais du y penser, mais qu'est-ce que tu fous !!!
- 186 réponses
- Script Lua
- Agenda
il faut aller sur le site du fabriquant j'imagine mais, attention, il y a des risques! toutes mes cam sont en RJ45, pas de wifi et sans problème.
