HC2 & HCL - 4.511 - BETA - 11/10/2018
speedoxx007
Version 4.511 BETA
New improvements:
  • Added support for Fakro ZWS12.
  • Added support for Remotec ZXT-600.
  • Added support for Heiman/Zipato HS1CG Gas Sensor.
  • Added the popup notification while trying to disable Remote Access with active installer access.
  • Added the button for rebooting in recovery mode.
  • Improved communication security of plugins.
Resolved issues:
  • System hangs on starting services.
  • Unable to reboot or turn off the gateway using a scene.
  • Unable to transfer configuration via id.cloud.fibaro.com between gateways linked to Fibaro ID account.
  • Gateway does not start after restoring cloud backup.
  • 'API: Host not found' error.
  • Incorrect icon for Roller Shutter which controls a garage gateway.
  • Alarm events disappear after refreshing the page.
  • No data in LAN Settings after rebooting.
  • Lists of scenes and rooms do not update correctly.
  • Scene based on weather does not start.
  • Removed dashboard.
  • Other minor fixes.
@NicoDepuis la 4.50X  sur la HC2 maître à chaque install, ça bloquait sur starting services  donc au bout de trente minutes de l'autre HC je la redémarrais avec un wallplug. Maintenant c'est bon.
Attention avec les fonctions netatmo dans les scènes j'ai un problème :
[DEBUG] 21:31:45: Debug: english
[DEBUG] 21:31:45: 2018-10-11 21:31:45.195583 [ error] Handshake error: certificate verify failed
[DEBUG] 21:31:45: 2018-10-11 21:31:45.196653 [ error] Handshake error: bad message type
Moi aussi j'ai des problèmes avec une scène Netatmo depuis V4.511
[DEBUG] 22:01:03: MANUAL START - Netatmo Weather station Integration scene version: 2.0.1.
[DEBUG] 21:43:03: Global table data for station: 70:ee:50:1b:0e:ee read sucessfuly
[DEBUG] 21:43:03: Get token
[DEBUG] 21:43:04: 2018-10-11 21:43:04.051078 [ error] Handshake error: certificate verify failed
[DEBUG] 21:43:04: 2018-10-11 21:43:04.052146 [ error] Handshake error: bad message type
Je pense que c'est du au:
Improved communication security of plugins. :-(
Modifié par speedoxx007
Tristounette cette mise à jour ...
Tout cela va globalement dans le bon sens, mais on ne peut pas dire que les choses avancent rapidement.
On se fait une raison pour les Qubino et les plugins, mais bon….
A quand un vrai support de Hue, un Dashboard digne de ce nom, et une application mobile moins rigide, et j'en oublie surement….
Bref, trop de Chianti dans la vodka.
