HC2 & HCL - 4.570 - Stable - 17/12/2019
flacon030
Liste des modifications logicielles 4.570:
Version 4.570
New improvements:
- Added possibility of grouping devices for FIBARO RGBW Controllers 2 FGRGBW-442.
- Added sending push notification after receiving system notification.
- Added sending push notification after running scene triggering mobile popup notification.
- Added support for FIBARO Heat Controller FGT-001 v4.7.
- Added support for FIBARO Wall Plug UK FGWPG-111 v4.2.
- Added Russound MBX-AMP plugin.
Resolved issues:
- After transferring the configuration from HCL to HC2 gateway does not start or backup cannot be restored.
- Temperature measured by FIBARO Heat Controller itself is not displayed as the main room temperature sensor.
- Alarm cannot be fully disarmed if armed and disarmed the whole house.
- Alarm cannot be fully disarmed if the room with the armed device was disarmed.
- Alarm does not work properly for unconfigured or dead devices.
- Scene Controller's endpoint of FIBARO Smart Implant is hidden.
- User's password cannot be changed via remote access.
- Scenes based on user's location do not work properly.
- Samsung Smart Appliances plugin rejects authorization token.
- Other minor fixes.
