ericl78 74 Signaler ce message Posté(e) 22 février 2021 (modifié) Hi Elle est arrivée, désolé oublié de copier les modifs Mise en place effectuée RAS sauf reboot long 4 minutes A+ What's new: Dashboard Unified text size and colour on the right sidebar. Status toasts after performing actions on devices using the right sidebar. No limit to the number of devices. * System notification after exceeding the recommended number of devices. * Devices Unified content of Advanced tab for devices of the same type. Advanced tab for all types of linked devices. Current/total energy consumption view switch. Critical push notifications available only for life danger events. Requiring confirmation before clearing the energy data. Sum function available for linked devices of the multilevel sensor type. Two possible configurations of the energy meter device. Support for Heatit Z-Smoke Detector 230V version 4.2. Support for Heatit Z-Temp2 version 1.2. Network Possibility of adding a second Wi-Fi network for emergency auto-switching. Connecting to emergency network after losing connection to main network. Storing the credentials of added Wi-Fi networks after its disconnecting. Retrying to connect to main network each 30 minutes when connected to emergency network. Possibility of testing the connection to emergency network. Nice ** Backing up Nice devices in the system configuration backup. Nice remotes available as scene triggers. Improved view of adding new device. Changes on the binding view. Support for NiceHome devices. Other Tooltips on the interface menu icons. Possibility of skipping the ongoing first system configuration process at any step. Profiles Door locks available to open/close in any profile. Quick Apps Option of hiding the button. Rooms Possibility of choosing the main room energy meter. Scenes Redirection to expanded scene view from scenes dashboard. Bug fixes: Access Incorrect limit of characters when editing a user's e-mail address. No auto-logging when accessing the gateway via remote access. Alarm Cannot arm the whole house if there are unconfigured alarm zones. Dashboard Unable to manually set the temperature on Fibaro Heat Controller from the right sidebar. Unable to override the temperature on third-party thermostats from the right sidebar. Devices Scenes added from device Advanced tab are not displayed in this tab. Linked device of thermostat type is always equipped with all operating modes. Notifications from devices come too often and not according to selected interval. Possibility to set the ID of an icon that no longer exists. Gateway Connection No central scene events from devices added to slave gateways. Scenes based on scene activation events from devices added to slave gateways do not work. Cannot change icons of devices added to slave gateways. Unable to force the removal of devices from slave gateways. Unable to change wakeup interval of battery devices added to slave gateway. Wrong message about restoring default password when removing disconnected slave gateway. No possibility to set polling time and run mesh reconfiguration on slave gateways. Error after removing a disconnected slave gateway. Restored local backup does not include slave gateways. Connect and Replace buttons available inadequately. History Users see events from devices to which they do not have permission. Network Unexpected Wi-Fi connection loss. * Nice ** Scenes with Nice Mono and BiDi devices do not work. Notifications Duplicated notifications of available template after rebooting the gateway. Unexpected Nice radio protocol connection timeout notification. Other Numerical values are rounded incorrectly. Cannot close toast messages. Performance Significant delays in Z-Wave network communication. Few minutes after rebooting system is not available. In some cases, the gateway does not start after performing an update. Low gateway performance with MJPG stream preview. * Long gateway booting time. * Profiles Cannot set actions in profile. Quick Apps Invalid support of 'secured' property for door locks. Recovery Cannot upload beta version from local file when using Repair option. In some cases page does not load properly. * Scenes Value set on slider is zeroed and locked when editing existing block scene. Scenes based on sunrise and sunset do not function properly. In some cases, scenes require editing to work after creating backup. Syntax of fibaro.profile function is prompted incorrectly. Cannot select device in single device block. Inverted door lock condition states. * - applies only to Home Center 3 Lite ** - not available for Home Center 3 Lite Modifié 22 février 2021 par Lazer 2 Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 496 Signaler ce message Posté(e) 22 février 2021 J'ai ajouté le changelog à ton post 1 Partager ce message Lien à poster Partager sur d’autres sites
ericl78 74 Signaler ce message Posté(e) 22 février 2021 Merci à toi Partager ce message Lien à poster Partager sur d’autres sites
Dragoniacs 436 Signaler ce message Posté(e) 23 février 2021 Hé ben, y a beaucoup de choses !Et où sont les "other minor fixes" ???? En tous cas, ils ont corrigé un truc que j'avais demandé : Notifications from devices come too often and not according to selected interval.Envoyé de mon RMX1993 en utilisant Tapatalk 1 Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 496 Signaler ce message Posté(e) 23 février 2021 Je me faisais la même remarque Sinon je n'ai pas compris ce que c'était que cette histoire de notification ? Partager ce message Lien à poster Partager sur d’autres sites
Dragoniacs 436 Signaler ce message Posté(e) 23 février 2021 Dans les modules tu peux choisir un type de notification et la fréquence associée. Typiquement, j'avais mis les caméras de surveillance station en notification si pas disponible, a la fréquence de 1 mail par jour. Et a chaque déconnexion réseau, j'avais 1 mail par minute....Envoyé de mon RMX1993 en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 496 Signaler ce message Posté(e) 23 février 2021 Ah oui OK c'est clair, merci Partager ce message Lien à poster Partager sur d’autres sites
jjacques68 607 Signaler ce message Posté(e) 23 février 2021 MAJ effectuée, RAS pour le moment... J'ai l'impression que la CPU est encore moins sollicitée... Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 496 Signaler ce message Posté(e) 23 février 2021 C'est possible qu'ils aient encore travaillé sur ce point. De mon coté je suis encore sur la dernière stable 5.050 (octobre 2020), et déjà il y a eu des améliorations par rapport aux versions de mai 2020, justement en ce qui concerne le CPU. En effet, il se trouve que cet après-midi j'ai fait un test de charge (un QuickApp qui consomme pas mal de mémoire avec manipulation d'un gros tableau pendant 3 heures). Au mois de mai, cela faisait s'envoler la consommation de CPU. Et bien là, presque rien 2 Partager ce message Lien à poster Partager sur d’autres sites
Krikroff 1 924 Signaler ce message Posté(e) 23 février 2021 https://products.z-wavealliance.org/products/4086?selectedFrequencyId=1 Brand Name: FIBARO Product Identifier: FGHC3-001 Product Line: Home Center Product Version: HW: 1 FW: 6.09 Z-Wave Certification Number: ZC12-21010173 Z-Wave Certification Date: 1/29/2021 Citation A.Socha: "From hardware there is no difference. On HC2 and HC3 we use that same z-wave engine, who was dedicate on zw 300 and later we added support zw 500 and zw 700 and some new functions But we meet limitation one of them was security S2 or smart start, support of some new z-wave functions. In this time role of hub have been change, in older times hub was a controller for z-wave network but for working was not needed. Today hub is center of z-wave network, there is one standard method how to get report or how to presence device in interface. So we wrote new z-wave engine. Why we don't give you it? Because we need do a migration from old to new. We must add templates for old devices, because if device was working on HC3 with old you will want to work on HC3 with new engine. All new device with z-wave plus should* work without templates (you will don't need wait for update Fibaro with support of device (if it meet standard good)) I hope it is more clear now" 2 Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 496 Signaler ce message Posté(e) 23 février 2021 Est-ce que ça veut dire que le Qubino Fil Pilote Z-Wave+ s'intègrera sans évoquer les esprits ? Par contre je ne suis pas sûr de bien comprendre.... la fiche technique que tu nous partages, c'est bien celle de la HC3 sortie il y a 1 an ? Ce n'est pas un nouveau modèle sorti en douce sous la même référence commerciale j'espère ? J'ai peur quand je vois la date du 29 janvier 2021.... au moins j'espère qu'on pourra faire la mise à jour du firmware ce qui nous amèneras les HC3 existantes à la même version que les nouvelles box commercialisée !!! Partager ce message Lien à poster Partager sur d’autres sites
Krikroff 1 924 Signaler ce message Posté(e) 23 février 2021 Je te confirme qu'il s'agit bien de la même HC3 (FGHC3-001 & HW: 1) il s'agit vraiment d'une évolution logicielle majeur. il y a 12 minutes, Lazer a dit : Est-ce que ça veut dire que le Qubino Fil Pilote Z-Wave+ s'intègrera sans évoquer les esprits ? J'ai pensé exactement la même chose 1 Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 496 Signaler ce message Posté(e) 23 février 2021 OK, bien, alors c'est super tout ça Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 170 Signaler ce message Posté(e) 23 février 2021 Toujours pas de HC2 en fille... Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 496 Signaler ce message Posté(e) 23 février 2021 J'ai cru comprendre qu'il y aurait assez peu de chance pour que ça arrive... en tout cas c'est relégué au dernier rang de leurs priorités Partager ce message Lien à poster Partager sur d’autres sites
jjacques68 607 Signaler ce message Posté(e) 23 février 2021 @Krikroff, @Lazer, vous parlez de quoi là ? Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 496 Signaler ce message Posté(e) 23 février 2021 Juste du nouveau moteur Z-Wave tant attendu, qui arrivera sur HC3 prochainement. Partager ce message Lien à poster Partager sur d’autres sites
jjacques68 607 Signaler ce message Posté(e) 23 février 2021 elles sont physiquement compatible ? Partager ce message Lien à poster Partager sur d’autres sites
Krikroff 1 924 Signaler ce message Posté(e) 23 février 2021 Pas compris Envoyé de mon iPhone en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
Dragoniacs 436 Signaler ce message Posté(e) 23 février 2021 Ça va être du lourd !J'espère que ça va pas planter nos QA...Envoyé de mon RMX1993 en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
Krikroff 1 924 Signaler ce message Posté(e) 23 février 2021 Cela ne devrait concerner que le moteur zwaveEnvoyé de mon iPhone en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
jjacques68 607 Signaler ce message Posté(e) 24 février 2021 Il y a 6 heures, Krikroff a dit : Pas compris euh... moi-meme je me suis pas compris Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 356 Signaler ce message Posté(e) 24 février 2021 Ils vont mettre openzwave sur hc3 Envoyé de mon BLA-L29 en utilisant Tapatalk 1 Partager ce message Lien à poster Partager sur d’autres sites
Bloug 280 Signaler ce message Posté(e) 24 février 2021 Belle mise à jour, elle commence à briller cette HC3 !!! Qs :Toujours pas de zigbee dans la roadmap ? Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 496 Signaler ce message Posté(e) 24 février 2021 @Bloug non Zigbee on en parlait sur un autre topic récemment, c'est repoussé à la saint glinglin (annulé ???) Ils attendent de voir CHIP sortir pour voir ce qui en sort, et si ça vaut pas plus le coup. En attendant ils vont améliorer Z-Wave, le support du protocole Nice, le mode passerelle entre HC3/HC3L, et les différents panneaux de climat/arrosage/énergie. Partager ce message Lien à poster Partager sur d’autres sites
