Lazer 8 486 Signaler ce message Posté(e) 10 août 2022 HC3 & HC3L 5.112.27 BETA Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. Main features: 1. Redesigned Settings page for better user experience. Changed the tabs order in settings. The possibility to easily manage devices using new filtering options in Devices tab. Easier removal process for all device types. Settings of main devices moved from General settings to Devices settings.2. Factory reset feature available in web interface. Perform factory reset of the hub from General settings. Now it is possible to enable additional actions which should be performed during the process, like removing cloud backups or removing connection to remote access. 3. New approach to configuration of Electric meters for Energy Panel. Configuration moved from General settings to Energy Panel settings. Now it is possible to choose how energy and power should be measured.4. Changed Scenes and QuickApps limits for Yubii Home and Home Center 3 Lite gateways. Due to performance improvements, the limit for scenes has been raised to 30, and for QuickApps to 10. What's new: Alarm Non-admin user gets logged out from the interface when enters wrong PIN during arming a zone. Dashboard Improved handling of set-points step for control of thermostat from sidebar. Devices Added device roles to sensors and meters. Support for Z-Wave parameters translations in languages other than PL and EN. Consistent device removal processes for Z-Wave engines. Device icons service improvements. Support for Aeotec Home Energy Meter Gen5. Support for Qubino 1Phase Meters. Support for Popp Outdoor Siren. Support for Fibaro RGBW Controller (FGRGBW-441)**. Elero* Revio SW device support. Improved marking as dead function. Improvements in pairing process. Energy Improved support for data from removed devices. Nice* Improved support for PLN2+ (BiDi) devices. Improved marking as dead function. Added parameters queue for battery operated devices. Improved error handling during pairing process. Simplified binding process. Other Added system notification about available migration from HC2/HCL systems. Added possibility to skip network configuration during FTI process. Added possibility to set the gateway name during FTI process. First Time Installation (FTI) process improvements. Plugins Thermostat & Heating Zone plugin - added additional two options to override time. Support for "Partly cloudy" weather condition in weather provider. Rooms Improvements for rooms and sections management. Scenes Possibility to change the scene name in opened edit page. Silent movement mode used in Simple Scenarios for blinds and shutters if supported. Added additional weather condition support (partly cloudy). Support for thermostat fan modes in Block Scenes. Added skipping actions to hidden devices in Simple Scenarios. Security Disabled support for TLS version lower than 1.2. Settings Gateway Connection tab removed for YH and HC3L gateways and moved to General settings. Devices counter/limits moved to General settings. Z-Wave Improved support for remotes. Zigbee Minor changes in Zigbee settings page. Improved generic device support. Bug fixes: Alarm Setting a new PIN requires typing each digit twice. Dashboard Devices order may be incorrect after using a drag & drop function on device tiles. Non-admin user can click "settings" icon on device tile which results in 404 errors. Devices Separating inputs from outputs for Smart Implant. Wrong set-point limits for some thermostats. Gerber GP-2000 does not report states correctly. Not possible to edit a previously created Linked device if no master device was chosen. Removed duplicated control buttons for blinds and shutters from the mobile app control dialog. Heatit Z-Temp2 does not work correctly when using secure mode. Issues with listing associations in Z-Wave devices if more than 2 targets are set in one group. Overlapped associations groups description in some languages. OFF/MAX modes not showing on FGT-001 history graph. Created sprinkler (linked device) has a role "light". Elero* Issues with displaying states and control of awnings. Energy Issue with displaying summary consumption when the main meter exists in some configurations. Issues with loading graphs in some languages. Decreased performance in panel settings when changing tariffs in some cases. Gateway Connection Not possible to request neighbors update for Z-Wave devices from Slave gateway. Not possible to set temperature offset for devices from Slave gateway. Not possible to change "Mark if unavailable" option for devices from Slave gateway. Rare Master gateway crash during synchronization of devices. Impossible to add a new Slave if it was configured using new FTI process (introduced in 5.111 Beta). History Wrong temperature units in panel after changing temperature unit. Network In some cases HC3 fails to boot if there is no network configured. (issue introduced in 5.111 Beta). Nice* Not possible to read Nice device parameter value on demand. Not possible to pair a device by authorization via remote when using ON3EBD. Other Unable to finish FTI process when changing the superuser login (issue introduced in 5.111 Beta). Plugins Read-only Satel outputs trigger the scenes after user interaction. 2N Helios plugin does not work correctly. Quick Apps Issue with refreshing views for QuickApps after user interaction. Scenes Simple scenarios not available in voice assistants. Not showing saved value in block scenes condition for multilevel switches in some cases. Not showing saved Time interval value in block scenes conditions. Impossible to create a new Simple Scenario when Scenes limit is reached. Scene with group action - active Save button when no changes were made. Global variables are not being refreshed in scenes engine after creation and removal. Update FGT-001 update fails in some cases.** Z-Wave Issue with displaying queued configuration parameter values for sleeping devices.** The Z-Wave engine on rare cases crashes during the process of adding devices. Known issues: Z-Wave Engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. Gateway connection is not available in the new Z-Wave engine version. * - does not apply to HC3L (Home Center 3 Lite) ** - applies only to Z-Wave Engine 3.0 Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 486 Signaler ce message Posté(e) 10 août 2022 il y a 9 minutes, Lazer a dit : Support for Qubino Je me sens tout chose en lisant cela.... ceux qui connaissent Fibaro depuis quelques années comprendront ! 2 3 1 Partager ce message Lien à poster Partager sur d’autres sites
jjacques68 603 Signaler ce message Posté(e) 10 août 2022 bon c'est toujours pas le fil pilote... Partager ce message Lien à poster Partager sur d’autres sites
Dragoniacs 436 Signaler ce message Posté(e) 10 août 2022 On va y arriver, on garde espoir Envoyé de mon M2012K11AG en utilisant Tapatalk 1 Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 486 Signaler ce message Posté(e) 10 août 2022 Je crains que ça ne soit définitivement mort pour le fil pilote, d'une part l'inclusion passe très mal car son firmware est buggué (du moins dans la dernière version disponible du module... et Qubino refuse de le corriger, j'avais essayé de les contacter), et d'autre part du fait de la spécificité bien française du fil pilote, le Z-Wave ne propose aucune classe pour gérer les 6 ordres.... donc le module lui-même se présente comme un dimmer pour émuler au mieux les ordres. Sinon la solution c'est un module de type multiposition, mais je trouve qu'à l'heure actuelle l'implémentation est super mal foutue (dans les QuickApp), pourtant l'idée est bonne. 1 Partager ce message Lien à poster Partager sur d’autres sites
jjacques68 603 Signaler ce message Posté(e) 10 août 2022 (modifié) j'ai la chance d'en avoir 2 qui fonctionnent comme je le souhaite (via 1 QA de gestion). après c'est que pour du on/off des sèches serviettes... Modifié 10 août 2022 par jjacques68 Partager ce message Lien à poster Partager sur d’autres sites
Manech 12 Signaler ce message Posté(e) 10 août 2022 La MAJ semble stable ? Partager ce message Lien à poster Partager sur d’autres sites
jjacques68 603 Signaler ce message Posté(e) 10 août 2022 à l’instant, Manech a dit : La MAJ semble stable ? je teste demain... 1 Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 486 Signaler ce message Posté(e) 10 août 2022 La mise à jour est passée sur ma box de test, après, est-ce qu'elle est stable, on saura dans plusieurs jours/semaines/mois le temps de découvrir les nouveaux bugs cachés tels des œufs de Pâques... @jjacques68 j'ai mes 4 Qubino fil pilote de dernière génération (ceux qui sont buggés justement) qui sont inclus sur ma box de prod depuis plus d'un an et qui fonctionnent au poil, tellement bien que ça chauffe non stop depuis tout ce temps, tu comprends maintenant pourquoi il faut si chaud cet été Sérieusement, malgré le fait que j'ai dû appliquer la procédure d'inclusion "en force" comme décrit sur le topic idoine, les modules son "non configurés", mais fonctionnent très bien quand même. Seul truc qui ne passe pas, en cas de coupure secteur, ils ne passent jamais en nœud mort, contrairement aux autres modules du réseau.... bon c'est pas trop gênant. 2 Partager ce message Lien à poster Partager sur d’autres sites
jjacques68 603 Signaler ce message Posté(e) 10 août 2022 il y a 2 minutes, Lazer a dit : tellement bien que ça chauffe non stop depuis tout ce temps qu'est ce qui chauffe ? les modules ou la box ? concernant cette mise à jour, rien sur la suppression des modules zigbee HS... Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 486 Signaler ce message Posté(e) 10 août 2022 C'est le 7ème ordre fil pilote caché, non documenté : le mode caliente 1 Partager ce message Lien à poster Partager sur d’autres sites
ericl78 74 Signaler ce message Posté(e) 10 août 2022 Hi Mise à jour effectuée ! Il y a du changement dans la présentation, pour retrouver ses QA facilement, obligé d'utiliser les filtres. Mais bien en globalité. Le problème de refresh des QA est résolu A suivre 1 Partager ce message Lien à poster Partager sur d’autres sites
flacon030 153 Signaler ce message Posté(e) 11 août 2022 perso pour le sèche serviette j'ai utilisé un relais fibaro et des diodes pour simuler le signal du fil pilot pour déclencher la mise en marche du dit sèche serviette Et cela fonctionne depuis 4 ans 1 Partager ce message Lien à poster Partager sur d’autres sites
jjacques68 603 Signaler ce message Posté(e) 11 août 2022 MAJ faite. RAS pour le moment. Étrange leur filtres pour la liste des device... et on peut plus filtrer selon le protocole ou alors j'ai pas trouvé. Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 486 Signaler ce message Posté(e) 11 août 2022 Il y a 3 heures, flacon030 a dit : perso pour le sèche serviette j'ai utilisé un relais fibaro et des diodes pour simuler le signal du fil pilot pour déclencher la mise en marche du dit sèche serviette Et cela fonctionne depuis 4 ans C'est ce que j'avais mis en place en 2013, lorsque les modules Qubino n'existaient pas. Mais je suis passé sur les Qubino dès la sortie de la 1ère génération, c'est quand même bien propre, pas de diode, circuit plus simple, moins encombrant, plus sécurisant je trouve. Partager ce message Lien à poster Partager sur d’autres sites
Dragoniacs 436 Signaler ce message Posté(e) 11 août 2022 Est-ce que cette beta corrige les ZigBee qui se mettent en dead régulièrement ?Envoyé de mon M2012K11AG en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
jjacques68 603 Signaler ce message Posté(e) 11 août 2022 il y a 4 minutes, Dragoniacs a dit : Est-ce que cette beta corrige les ZigBee qui se mettent en dead rien est dit là dessus... mais j'ai remarqué ça aussi. Je m'était dis que c'était un soucis de porté de signal, parce que dans mon cas, ça pourrait l'être... Partager ce message Lien à poster Partager sur d’autres sites
Dragoniacs 436 Signaler ce message Posté(e) 11 août 2022 Hum non j'y ai pensé aussi, mais j'ai 2 modules à quelques mètres de la box qui plantent aussi souvent que ceux qui sont loinEnvoyé de mon M2012K11AG en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
jjacques68 603 Signaler ce message Posté(e) 11 août 2022 super donc ça semble pas fiable quoi... Partager ce message Lien à poster Partager sur d’autres sites
Bloug 280 Signaler ce message Posté(e) 12 août 2022 Pas d'améliorations sur de multiples séquences dans le panneau d'arrosage... Partager ce message Lien à poster Partager sur d’autres sites
Stillwatter 2 Signaler ce message Posté(e) 12 août 2022 GEA ne fonctionne plus chez moi... Partager ce message Lien à poster Partager sur d’autres sites
Sakkhho 469 Signaler ce message Posté(e) 1 septembre 2022 voilà mon HC3 vient de s'allumer de me propose immédiatement une mise à jour en BETA ! et oh ! je sais ce que veux dire BETA Fibaro moi, donc NO WAY tout ca pour vous dire , que j'ai basculé ... mais bon la migration est encore loin tellement ca va demander du boulot 2 Partager ce message Lien à poster Partager sur d’autres sites
flamalex 77 Signaler ce message Posté(e) 19 novembre 2022 Le 10/08/2022 à 21:12, Lazer a dit : La mise à jour est passée sur ma box de test, après, est-ce qu'elle est stable, on saura dans plusieurs jours/semaines/mois le temps de découvrir les nouveaux bugs cachés tels des œufs de Pâques... @jjacques68 j'ai mes 4 Qubino fil pilote de dernière génération (ceux qui sont buggés justement) qui sont inclus sur ma box de prod depuis plus d'un an et qui fonctionnent au poil, tellement bien que ça chauffe non stop depuis tout ce temps, tu comprends maintenant pourquoi il faut si chaud cet été Sérieusement, malgré le fait que j'ai dû appliquer la procédure d'inclusion "en force" comme décrit sur le topic idoine, les modules son "non configurés", mais fonctionnent très bien quand même. Seul truc qui ne passe pas, en cas de coupure secteur, ils ne passent jamais en nœud mort, contrairement aux autres modules du réseau.... bon c'est pas trop gênant. ça fonctionne au poil egalement, as tu des sondes de temperatures sur les qubino? si oui, le refresh est ok? Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 353 Signaler ce message Posté(e) 19 novembre 2022 voilà mon HC3 vient de s'allumer de me propose immédiatement une mise à jour en BETA ! et oh ! je sais ce que veux dire BETA Fibaro moi, donc NO WAY tout ca pour vous dire , que j'ai basculé ... mais bon la migration est encore loin tellement ca va demander du boulot Moi c'est terminé j'ai tout basculerJ'ai débranché ma hc2 hierCela a été vite environ 4h pour les modulesPour les QA tout était déjà prêt depuis plusieurs mois voir annéesJ'ai juste a faire un QA pour mon ipx800 v5Pour mes volets je suis en scène blocs Envoyé de mon BLA-L29 en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 486 Signaler ce message Posté(e) 20 novembre 2022 Il y a 12 heures, flamalex a dit : as tu des sondes de temperatures sur les qubino? si oui, le refresh est ok? Non, pas de sondes sur les Qubino. Et ça serait totalement inutile, des sondes dans des boites d'encastrement fermées, dans un mur, derrière un radiateur, je ne vois pas bien quelle information de température utile ça pourrait donner ? Il faudrait faire passer une gaine qui fait le tour de la pièce, pour aller prendre la température sur un mur opposé au radiateur, à 1 ou 1.5m de hauteur. Pas simple... Je l'ai fait dans 2 chambres quand je les ai rénové, mais les sondes ne sont pas branchées sur un Qubino, mais sur un FGBS. Et ça fonctionne très bien ainsi. Partager ce message Lien à poster Partager sur d’autres sites
