Nvince76 Posté(e) le 19 novembre 2015 Signaler Partager Posté(e) le 19 novembre 2015 Beta software changes list 4.058:Version 4.058 Beta WARNING: Beta version is designed for user testing and soon should be released as official. This update includes new migration process from version 3.600, featuring configuration for every device, adjusting it for changes which took place in the system. This will assure possibly smooth transition and continuous operation, allowing each device to work with old settings until reconfiguration is done. Please refer to message that appears in interface and Notification Center after finishing upgrade for further instructions. Important! Updating from version 3.600 may take longer than usual, up to 30 minutes, please do not restart controller during update process. Resolved issues: - #0003538 Status Off after Soft Reconfiguration - #0003208 AEOTEC GEN 5 Siren doesn't work - #0003557 Template misssing for Zwave.ME WIN ITEMP - #0003560: PHI_PAN06 Relay Insert 2 * Template - #0003628: Can't select devices as actors into alarm actions like panic, lights on - #0003530: many problems with HRT4 ASR-ZW - Settings page for Polylock device do not load - There is no "controlled device" after soft reconfiguration - Problem with authentication to cameras under IE, Safari and Chrome browsers - Breached sensor with Arm Delay causes instant alarm after being armed Other improvements: - Due to multiple requests we introduced mechanism of limiting number of single scene instances running simultaneously. Maximum number is 10 instances active at the same time. It is available in all types of scenes. In case of exceeding given number the additional scene will not be started and proper notification will appear in Notification center. Remember, that all block and magic scenes based on time have always once instance running in loop, so if there is only single instance allowed, clicking "Run" button will have no effect. - In case of exceeding 95% of RAM's "used space", no new scenes will be triggered until that value drops again - New devices support: - HEATIT Z-Wave Thermostat - Evolve LDM-15 - Evolve LPM-15 - Evolve LFM-20 - Evolve LRM-AS-W - Evolve LOM-15 - Evolve LTM-5 - Evolve LSM-15 - Evolve LRM-1000 - Ecolink Z-Wave Garage Door Tilt Sensor - Linear/ GoControl WAPIRZ-1 PIR Motion Detector - Danfoss RS Room Sensor - FortrezZ WWA01AA - FortrezZ WWA-02 - Philio PAN06 - Everspring SF813-2 - Following devices received generic templates that cover devices in various versions: - Philio D/W Sensor PST02-1C Generic templates guarantee compatibility of all devices of given kind, regardless the version, as long as device has the same product ID (which depends on its manufacturer) - New plug-ins: - DENON HEOS 3/link - Russound X5 Controller - Nuvo Gateway/NV-P3100/NV-P3500/P100/P200 - Adding devices with mobile app no longer includes them in secure mode. Non-secure inclusion is default mode now - Improved camera streams performance both in remote and local access - Time from last breach is now displayed in logs underneath each sensor - Logs are now displayed and refreshed properly Known issues: - Inconsistencies in Satel interface - Plugins for TV Sets of various manufacturers may not work with its newer firmware due to restrictions provided by new devices firmware - Data range selection in event panel doesn't work properly - Devices imported via Gateway Connection may have no icons - On mobile clients devices may be visible in different categories than configured - Horstmann Thermostat HRT4-ZW higher battery usage in some cases - Doorlocks some functions may not work properly Important! Due to changes that took place in Logitech API, Harmony plug-in must have been adjusted. Because of manufacturer's restrictions new Harmony plug-in no longer polls Logitech service for changes, meaning, that plug-in values will not be updated when activity state is changed with some other device. This way of operation will maintain until Logitech establishes new way of requesting such data. Important! This version introduces new Privacy Policy, which will help us to provide even better service and software for your use. Please refer to pre-update message for more details. CHANGES INTRODUCED IN VERSION 4.X: - Drag & Drop for devices and scenes - available on home, devices and rooms screens. Assigning devices to rooms and changing its order is now much easier and faster. - Temperature Panel - allows to see history of temperature changes in rooms and on each device. - Diagnostic Panel - general information about HC working condition like CPU & RAM usage, free space on hard drive. Will be extended in future versions. - Soft Device Reconfiguration - option allows to save settings, parameters and device ID. Thanks to that scenes with reconfigurable device will not require editing. Full reconfiguration will remove and add the device to the Z-Wave network, resulting in the loss of its settings, parameters and change the device ID.. - Mesh Network Reconfiguration - available on Configuration -> Z-Wave Network - New Z-Wave engine - redesigned and rewritten from the scratch. Now is faster and has better support for devices. - Z-Wave Door Locks support - controlling and PIN settings. - Thermostats - extended controlling for thermostats from manufacturers like: Honeywell, Trane Corporation. - Extended tamper for sensors - exclusive information for motion detection and violation of sensors. - Fibaro Smoke Sensor extended support - level of smoke and gap to alarm level is reported and visible on charts. Sensitivity level is now easier to set. - Fibro Motion Sensor new device - when seismometer mode is turned on new device reporting tremors is available. Charts for temperature and illuminance. Additionally information about sensor violation. - Device hiding - device that is not in use can be hide without removing it. - Device deactivation - deactivated device is visible in UI but can't be controlled. - Multithreading added for HC (server and z-wave) - now engines work much faster. - Event panel moved - for better usability now is available in menu on right side of screen. - Pre-Update Confirmation - installing update will prompt user additional confirmation. - Added support for American English (EN-US) - User rights management - moved to Configuration. - Recovery Memory Health - can be checked on Backup & Recovery - Backups has information about compatibility with current HC version - Block scenes improvements - for device only available actions are visible, scene activation block added and logical conditions grouping using brackets. - Lua Scenes - updated tool-tips for devices. - Rest API Active Documentation - documentation and ability to test REST API requests, access at HOME_CENTER_IP/docs Plugins: - Plugins are grouped in categories: Safety, Cameras, Climate, Multimedia, Others - Plugins search - Network devices search via ARP Plugins category Safety: - DSC Alarm - for DSC Alarms, - Helios Basic - integration using Basic license, - Helios Gold - integration using Gold license - Mobotix - for Mobotix videophone, - Satel Alarm - for SATEL - Modular Alarm Plugins category Cameras - more than 130 devices from various manufacturers Plugin category Climate - Carrier Furance - WS Davis Vantage - Nest - plugin for well-known thermostat - Netatmo - plugin for thermostat and weather station from netatmo Plugins category Multimedia - LG Bluray - LG TV* - NC + mediabox - XBMC Remote Control - Denon Amplifier - LG Bluray - Onkyo Amplifier - Philips Bluray - Pioneer Amplifier - Samsung TV* - Sonos - Sony Bluray - Sony TV* - Logitech Harmony * some TV Sets firmware version may not be supported Plugins category Other - Philips Hue - Wake on LAN - Planika Fireplace Other changes, many other improvements to the system 2 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nvince76 Posté(e) le 19 novembre 2015 Auteur Signaler Partager Posté(e) le 19 novembre 2015 elle date la dernière beta.. en cours d'installation Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nvince76 Posté(e) le 19 novembre 2015 Auteur Signaler Partager Posté(e) le 19 novembre 2015 aprés le reboot de la HC2, le bouton de login ne fonctionne plus, impossible se reconnecter je m'en vais la rebooter Lien vers le commentaire Partager sur d’autres sites More sharing options...
BenjyNet Posté(e) le 19 novembre 2015 Signaler Partager Posté(e) le 19 novembre 2015 Bon, est-ce que ça va virer ces erreurs 503 parce qu'elles me gonflent au possible ! Lien vers le commentaire Partager sur d’autres sites More sharing options...
tibahut Posté(e) le 19 novembre 2015 Signaler Partager Posté(e) le 19 novembre 2015 A noter que la mise àjour est dispo pour la HC2 et la HCLite. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 19 novembre 2015 Signaler Partager Posté(e) le 19 novembre 2015 M'a l'air pas mal cette version. Par contre : - In case of exceeding 95% of RAM's "used space", no new scenes will be triggered until that value drops again => ça veut dire qu'ils n'ont fait aucun effort sur l'optimisation de leur code, et qu'ils cherchent des moyens de contournement pour éviter les plantages. Donc en gros, va falloir investir dans une barrette RAM de 1 Go supplémentaire :/ 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) le 19 novembre 2015 Signaler Partager Posté(e) le 19 novembre 2015 Nvince, c'est que tu n'as pas du attendre assez longtemps, au départ aussi je rebootais, puis j'ai remarqué qu'en attendant plus longtemps après l'update, cela venait tout seul. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nvince76 Posté(e) le 19 novembre 2015 Auteur Signaler Partager Posté(e) le 19 novembre 2015 plus de 10-15 min, ça fait long. J'ai bien la page d'accueil je rentre user et psw, mais le bouton LOGIN n'est pas accessible je viens juste de rebooter, on va voir Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nvince76 Posté(e) le 19 novembre 2015 Auteur Signaler Partager Posté(e) le 19 novembre 2015 toujours rien, cela vient de Chrome, car cela fonctionne avec edge Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 19 novembre 2015 Signaler Partager Posté(e) le 19 novembre 2015 t'as vidé le cache je suppose ? c'est le premier truc àfaire. 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Rocketlud Posté(e) le 19 novembre 2015 Signaler Partager Posté(e) le 19 novembre 2015 Pas mal cette Beta c'est cool que ce soit dispo sur HC2 et Hclite , ça promet de belle évolution prochaine Lien vers le commentaire Partager sur d’autres sites More sharing options...
BenjyNet Posté(e) le 19 novembre 2015 Signaler Partager Posté(e) le 19 novembre 2015 Bon moi j'ai le message comme quoi j'ai une scene qui se lance trop souvent. C'est celle de l'IPX sur laquelle j'ai le capteur de porte de garage et avec le vent ça envoie des pushs tres souvent. Lien vers le commentaire Partager sur d’autres sites More sharing options...
HANSOLO Posté(e) le 19 novembre 2015 Signaler Partager Posté(e) le 19 novembre 2015 C'est parti...... Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) le 19 novembre 2015 Signaler Partager Posté(e) le 19 novembre 2015 Ils envoient des messages pour ça maintenant, bonne idée. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Rocketlud Posté(e) le 19 novembre 2015 Signaler Partager Posté(e) le 19 novembre 2015 Je vais attendre demain pour la faire, histoire d'avoir un peu plus de retour Lien vers le commentaire Partager sur d’autres sites More sharing options...
HANSOLO Posté(e) le 19 novembre 2015 Signaler Partager Posté(e) le 19 novembre 2015 J'ai une instance GEA (la directe) qui est bloquée. Du fait de la limitation à 10 instances par scène, je suis en train de dupliquer ma scène GEA Instantanée avec 2 à 3 commandes instantanées max Lien vers le commentaire Partager sur d’autres sites More sharing options...
sebcbien Posté(e) le 19 novembre 2015 Signaler Partager Posté(e) le 19 novembre 2015 Pfffff.... Que de temps perdu en perspective... Et au final ça ne changera rien... Sent from my Note4 Lien vers le commentaire Partager sur d’autres sites More sharing options...
mprinfo Posté(e) le 19 novembre 2015 Signaler Partager Posté(e) le 19 novembre 2015 Mise a jour en cours chez moi Et comme dab on vide la cache du navigateur Envoyé de mon SM-G900F en utilisant Tapatalk Lien vers le commentaire Partager sur d’autres sites More sharing options...
BenjyNet Posté(e) le 19 novembre 2015 Signaler Partager Posté(e) le 19 novembre 2015 Bon ici, ça marche bien, ça me bride ma scène àla con mais sinon ça va Lien vers le commentaire Partager sur d’autres sites More sharing options...
Sakkhho Posté(e) le 19 novembre 2015 Signaler Partager Posté(e) le 19 novembre 2015 mauvaise nouvelle pour GEA ... Lien vers le commentaire Partager sur d’autres sites More sharing options...
sebcbien Posté(e) le 19 novembre 2015 Signaler Partager Posté(e) le 19 novembre 2015 Je ne pense pas. Pour avoir 10 gea en parallèle je ne vois pas comment je m'y prendrais.... Sent from my Note4 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
mprinfo Posté(e) le 19 novembre 2015 Signaler Partager Posté(e) le 19 novembre 2015 Pour les pb de pwd il faut attendre un moment environ 10 mn et cela fonctionne Pour GEA je peux rien dire car je n utilise pas lol Je jeterai un oeil demain après 24h de fonctionnement Envoyé de mon SM-G900F en utilisant Tapatalk Lien vers le commentaire Partager sur d’autres sites More sharing options...
HANSOLO Posté(e) le 19 novembre 2015 Signaler Partager Posté(e) le 19 novembre 2015 J'ai l'impression que les déclenchements instantanés sous GEA avec un détecteur de mouvement la 4.58 n'aime pas! Lien vers le commentaire Partager sur d’autres sites More sharing options...
sebcbien Posté(e) le 19 novembre 2015 Signaler Partager Posté(e) le 19 novembre 2015 Quels symptômes ? Sent from my Note4 Lien vers le commentaire Partager sur d’autres sites More sharing options...
HANSOLO Posté(e) le 19 novembre 2015 Signaler Partager Posté(e) le 19 novembre 2015 Pas de déclenchement et message dans les notifications: Too many instances | scene : GEA XXXXXXX Lien vers le commentaire Partager sur d’autres sites More sharing options...
