Hc2 Et Hc Lite - V4.071 Beta - 02/02/2016
nickrdtp
il l'a déjàpartagé dans un autre fil de firmware.
le voici:
il faut créer un VG non prédéfinie: Benchmark
Et spécifier un id qui existe: dans mon cas: Cellier
%% properties
%% globals
-- Parameters --
local id_exist = 56 --cellier
local global_exist = "Benchmark"
local nbIteration = 1000
-- Do not touch please ---
local id_not_exist = 100056
local global_not_exist = "AABBCCDDEEFFGGHHIIFFF"
function log(name, start, cpu)
   if (start) then
fibaro:debug(string.format("<span style=\"font-family:monospace; white-space:pre; clear:both; float:right\">  %s instruction time : %ds | cpu time : %gs </span>", name, os.time()-start, os.clock()-cpu))
else
fibaro:debug(string.format("<span style=\"font-family:monospace; white-space:pre; clear:both; float:right\">  %s </span>", name))
function execute(name, func)
  if (not pcall(function()
        local start = os.time()
        local cpu = os.clock()
        for i= 1,nbIteration do
            func()
    end)) then
   fibaro:debug("ERROR : " .. name)
log("Nb runs : " .. nbIteration .. " | id : " .. id_exist .. " | G.Variable : " .. global_exist)
log("----------------------------------------------")
log("")
-- Tests ---
execute("getValue Exist      :", function() fibaro:getValue(id_exist, "value") end)
execute("getValue Not Exist  :", function() fibaro:getValue(id_not_exist, "value") end)
execute("setValue            :", function() fibaro:call(id_exist, "setValue", fibaro:getValue(id_exist, "value")) end)
execute("getGlobal Exist     :", function() fibaro:getGlobalValue(global_exist) end)
execute("getGlobal Not Exist :", function() fibaro:getGlobalValue(global_not_exist) end)
execute("setGlobal           :", function() fibaro:setGlobal(global_exist, fibaro:getGlobalValue(global_exist)) end)
execute("getType             :", function() fibaro:getType(id_exist) end)
execute("getName             :", function() fibaro:getName(id_exist) end)
execute("getRoomID           :", function() fibaro:getRoomID(id_exist) end)
execute("getRoomName         :", function() fibaro:getRoomName(fibaro:getRoomID(id_exist)) end)
execute("getSunrise          :", function() fibaro:getValue(1, "sunsetHour") end)
execute("boucle 1000         :", function() for j=1,1000 do k=j end end)
log("")
log("ALL DONE")
Bon pas cool, je suis resté en 4.070 et j'ai remarqué aussi des pic du CPU jusqu'a 30% et la ram qui monte un peu chaque jour. C'est pas méchant mais il y'a 2 jours j'étais à  57 et là  je suis à  59 % :( , j'ai pas encore fait la sauvegarde de la clé mais je vais le faire ce week car je le sent pas trop :(
Bon pas cool, je suis resté en 4.070 et j'ai remarqué aussi des pic du CPU jusqu'a 30% et la ram qui monte un peu chaque jour. C'est pas méchant mais il y'a 2 jours j'étais à57 et làje suis à59 % :( , j'ai pas encore fait la sauvegarde de la clé mais je vais le faire ce week car je le sent pas trop :(
lol.
Allez le fofo.
On se reprends.
On prends 2 dolipramme
On boit 1 bonne bière
On arrête de se plaindre
On aime sa box
Ou on la jette àla poubelle
Mais bon des pics de 30% ... Faut pas deconner
