Liste Api-Lua & Api-Http Pour Hc2
pepite
Bonjour à  tous,
Comme évoqué dans un des topics du firmware avec @Lazer, j'initie un début de liste des différentes API-LUA et API-HTTP apparues suite aux évolutions de firmware.
Pour HC2 UNIQUEMENT
Cette liste est loin d'être exhaustive, je me suis basé sur les changelog des firmwares et le site https://developer.fibaro.com/.
Si vous en connaissez d'autres, n'hésitez pas (je pense à  vous les MAITRES du LUA :60::60: )
Les admins/modos, je vous laisse le soin de mettre le sujet où bon vous semble ;-), un sous-forum de HC2 peut-être.
  • These calls can be used to start increasing or decreasing Multilevel Switches (like Dimmer 2, RGBW or Roller Shutter 2 modules) value. 'x' and 'y' are optional parameters, used to set respectively time frame in which change should be applied and starting level. 'stopLevelChange' stops previously send action.
fibaro:call(ID, 'startLevelIncrease', x, y)
fibaro:call(ID, 'startLevelDecrease', x, y)
fibaro:call(ID, 'stopLevelChange')
  • Call used to get table with IDs of devices that meet requirement specified by 'x'.
fibaro:getDevicesId(x)
 -- Examples:
print('All devices with parameter visible equal to "true" and enabled equal to "true":')
ids = fibaro:getDevicesId({visible = true, enabled = true})
print(json.encode(ids))
print('ALl devices with energy interface:')
ids = fibaro:getDevicesId({interfaces ={"energy"}})
print('All devices with 'unit' property (no matter its value):')
ids = fibaro:getDevicesId({properties = {unit="nil"}})
Which will set given scene respectively to Automatic, Manual and Disabled mode. Any other value will set scene triggering mode to Automatic.
fibaro:setSceneRunConfig(sceneID, runConfig)
where runConfig is string that takes one of these three values:
          - TRIGGER_AND_MANUAL
          - MANUAL_ONLY
          - DISABLED
 fibaro:getSceneRunConfig(sceneID)
          returns currently set value.
Old functions will keep backward compatibility and continue to work without change.
- fibaro:setSceneEnabled(sceneID, enabled)
- fibaro:isSceneEnabled(sceneID)
  • Redémarrage Home Center et Arrêt Home Center
HomeCenter.SystemService.reboot() et HomeCenter.SystemService.shutdown()
Exemples :
-- Reboot system
        HomeCenter.SystemService.reboot();
    -- Shutdown system
        HomeCenter.SystemService.shutdown();
  •   Popup service
HomeCenter.PopupService.publish({title, subtitle, contentTitle, contentBody, img, type, buttons})
Parameters
    title - string containing text to be displayed as a pop-up window title (parameter required)
    subtitle - string containing text to be displayed as a pop-up window subtitle
    contentTitle - string containing text to be displayed as a pop-up content title
    contentBody - string containing text to be displayed as a pop-up content (parameter required)
    img - string containing path of an image to be displayed in the pop-up window (supported extensions: .jpg, .bmp, .png, .gif)
    type - notification type indicated with a colour, available types:
        'Info' - blue (default)
        'Success' - green
        'Warning' - yellow
        'Critical' - red
    buttons - array containing definitions of buttons to be displayed in the pop-up, single button definition must be an array containing:
        'caption' - text displayed on the button
        'sceneId' - scene id triggered after pushing the button
Exemple 1
    %% properties
    %% globals
    -- variable containing path of Motion Sensors icon
    local imgUrl =
    'http://www.fibaro.com/sites/all/themes/fibaro/images/motion-
    sensor/en/motion_sensor_manual.png'
    -- pop-up call
            -- title (required)
        title = 'No motion detected',
            -- subtitle(optional), e.g. time and date of the pop-up call
        subtitle = os.date("%I:%M:%S %p | %B %d, %Y"),
            -- content header (optional)
        contentTitle = 'No motion since last 15 minutes',
            -- content (required)
        contentBody = 'Should I run the scene "Night"?',
            -- notification image (assigned from the variable)
        img = imgUrl,
            -- type of the pop-up
        type = 'Success',
            -- buttons definition
        buttons = {
        { caption = 'Yes', sceneId = 0 },
        { caption = 'No', sceneId = 0 }
    NOTE
Please note that the example scene must be triggered manually. It just illustrates the way of creating pop-ups. Execution of this scene will not affect any device status (sceneId = 0).
NOTE
Setting an action of the button to 'sceneId = 0' means that no action will be performed.
NOTE
Created pop-up is sent to each of users and mobile devices connected with the main controller.
NOTE
There is no maximum size of image displayed in the pop-up window. However, using too large file may result in long waiting times required for downloading the image.
NOTE
Pushing one of the buttons displayed in the pop-up window may only trigger another scene.
Exemple 2
    %% properties
    3814 value
    %% globals
    if (
        ( tonumber(fibaro:getValue(3814, "value")) > 60 )
    or
    then
        title = 'Brightness level',
        subtitle = 'is too high',
        contentTitle = 'Dimmer',
        contentBody = 'Would you like to turn it off?',
        img = ' http://www.fibaro.com/images/eng/icon_osw.png',
        type = 'Critical',
        buttons = {
            { caption = 'Turn off', sceneId = 3228 },
            { caption = 'No', sceneId = 0 },
            { caption = 'Set to 100%', sceneId = 3229 }
1ère MAJ venant de @Steven concernant les fonctions fibaro :
Telecharger le tar.gz http://updatehc2.fibaro.com/4.083/
, puis dans opt/fibaro ouvrir fibaroSceneAPI.lua
HomeCenter = {
PopupService = {
publish = function(request)
local response = api.post('/popups', request)
return response
SystemService = {
reboot = function()
local client = net.HTTPClient()
client:request("http://localhost/reboot.php")
end,
shutdown = function()
client:request("http://localhost/shutdown.php")
fibaro = {}
fibaro.debug = function(self, text)
print(text)
fibaro.sleep = function(self, time)
__fibaroSleep(time)
function __convertToString(value)
if (type(value) == 'boolean') then
if (value) then
return '1'
else
return '0'
elseif (type(value) == 'number') then
return tostring(value)
elseif (type(value) == 'table') then
return json.encode(value)
return value
function __assert_type(value, typeOfValue)
if (type(value) ~= typeOfValue) then
error("Assertion failed: Expected " .. typeOfValue, 3)
function __fibaro_get_device(deviceID)
__assert_type(deviceID, "number")
return api.get("/devices/" .. deviceID)
function __fibaro_get_room(roomID)
__assert_type(roomID, "number")
return api.get("/rooms/" .. roomID)
function __fibaro_get_scene(sceneID)
__assert_type(sceneID, "number")
return api.get("/scenes/" .. sceneID)
function __fibaro_get_global_variable(varName)
__assert_type(varName, "string")
return api.get("/globalVariables/" .. varName)
function __fibaro_get_device_property(deviceId, propertyName)
return api.get("/devices/" .. deviceId .. "/properties/" .. propertyName)
-- getting device properties
fibaro.get = function(self, deviceID, propertyName)
local property = __fibaro_get_device_property(deviceID, propertyName)
if (property == nil) then
return nil
return __convertToString(property.value), property.modified
fibaro.getValue = function(self, deviceID, propertyName)
local value = fibaro:get(deviceID, propertyName)
return value
fibaro.getModificationTime = function(self, deviceID, propertyName)
local _, modified = fibaro:get(deviceID, propertyName)
return modified
-- global variables
fibaro.getGlobal = function(self, varName)
local globalVar = __fibaro_get_global_variable(varName)
if (globalVar == nil) then
return nil
return globalVar.value, globalVar.modified
fibaro.getGlobalValue = function(self, varName)
return nil
fibaro.getGlobalModificationTime = function(self, varName)
return nil
return globalVar.modified
fibaro.setGlobal = function(self, varName, value)
local data = {["value"]=tostring(value), ["invokeScenes"]=true}
api.put("/globalVariables/" .. varName, data)
-- scenes
fibaro.countScenes = function(self, sceneID)
sceneID = sceneID or __fibaroSceneId
local scene = __fibaro_get_scene(sceneID)
if (scene == nil) then
return 0
return scene.runningInstances
fibaro.isSceneEnabled = function(self, sceneID)
return nil
local enabled
if (scene.runConfig == "TRIGGER_AND_MANUAL" or scene.runConfig == "MANUAL_ONLY") then
enabled = true
else
enabled = false
return enabled
fibaro.startScene = function(self, sceneID)
api.post("/scenes/" .. sceneID .. "/action/start")
fibaro.killScenes = function(self, sceneID)
api.post("/scenes/" .. sceneID .. "/action/stop")
fibaro.setSceneEnabled = function(self, sceneID, enabled)
__assert_type(enabled, "boolean")
local runConfig
if (enabled == true) then
runConfig = "TRIGGER_AND_MANUAL"
else
runConfig = "DISABLED"
local data = {
id = sceneID,
runConfig = runConfig
api.put("/scenes/" .. sceneID, data)
fibaro.getSceneRunConfig = function(self, sceneID)
return nil
return scene.runConfig
fibaro.setSceneRunConfig = function(self, sceneID, runConfig)
__assert_type(runConfig, "string")
local data = {
id = sceneID,
-- other
fibaro.getRoomID = function(self, deviceID)
local dev = __fibaro_get_device(deviceID)
if (dev == nil) then
return nil
return dev.roomID
fibaro.getSectionID = function(self, deviceID)
return nil
if (dev.roomID ~= 0) then
return __fibaro_get_room(dev.roomID).sectionID
return 0
fibaro.getType = function(self, deviceID)
return nil
return dev.type
fibaro.abort = function(self)
os.exit()
fibaro.getSourceTrigger = function(self)
return __fibaroSceneSourceTrigger
fibaro.getSourceTriggerType = function(self)
return __fibaroSceneSourceTrigger["type"]
fibaro.calculateDistance = function(self, position1, position2)
__assert_type(position1, "string")
__assert_type(position2, "string")
return __fibaroCalculateDistance(position1, position2)
fibaro.call = function(self, deviceID, actionName, ...)
deviceID = tonumber(deviceID)
__assert_type(actionName, "string")
args=""
for i, v in ipairs({...}) do
args = args .. '&arg' .. tostring(i) .. '=' .. urlencode(tostring(v))
api.get("/callAction?deviceID=" .. deviceID .. "&name=" .. actionName .. args)
function urlencode(str)
if (str) then
str = string.gsub (str, "([^%w])",
function © return string.format ("%%%02X", string.byte©) end)
return str
fibaro.getName = function(self, deviceID)
__assert_type(deviceID, 'number')
return nil
return dev.name
fibaro.getRoomName = function(self, roomID)
__assert_type(roomID, 'number')
local room = __fibaro_get_room(roomID)
if (room == nil) then
return nil
return room.name
fibaro.getRoomNameByDeviceID = function(self, deviceID)
return nil
local room = __fibaro_get_room(dev.roomID)
if (dev.roomID == 0) then
return "unassigned"
else
return nil
return room.name
fibaro.wakeUpDeadDevice = function(self, deviceID)
fibaro:call(1, 'wakeUpDeadDevice', deviceID)
Expected input:
name: value, //: require name to be equal to value
properties: { //:
volume: "nil", //: require property volume to exist, any value
ip: "127.0.0.1" //: require property ip to equal 127.0.0.1
interface: ifname //: require device to have interface ifname
fibaro.getDevicesId = function(self, filter)
if type(filter) ~= 'table' or
(type(filter) == 'table' and next(filter) == nil)
then
return fibaro:getIds(fibaro:getAllDeviceIds())
local args = '/?'
for c, d in pairs(filter) do
if c == 'properties' and d ~= nil and type(d) == 'table' then
for a, b in pairs(d) do
if b == "nil" then
args = args .. 'property=' .. tostring(a) .. '&'
else
args = args .. 'property=[' .. tostring(a) .. ',' .. tostring(B) .. ]&'
elseif c == 'interfaces' and d ~= nil and type(d) == 'table' then
args = args .. 'interface=' .. tostring( B) .. '&'
else
args = args .. tostring© .. "=" .. tostring(d) .. '&'
args = string.sub(args, 1, -2)
return fibaro:getIds(api.get('/devices' .. args))
fibaro.getAllDeviceIds = function(self)
return api.get('/devices/')
fibaro.getIds = function(self, devices)
local ids = {}
for _, a in pairs(devices) do
if a ~= nil and type(a) == 'table' and a['id'] ~= nil and a['id'] > 3 then
table.insert(ids, a['id'])
return ids
  • Backups depuis une scène (Merci à  @Nikko)
%% properties
%% events
%% globals
local portable = 385
local message = 'Backup du '..os.date("%d/%m/%y - %HH%M")
local url = 'http://127.0.0.1:11111/api/settings/backups'
local httpClient = net.HTTPClient()
httpClient:request(url , {
        success = function(response)
                    if tonumber(response.status) == 201 then
                        print("Backup Created at " .. os.date())
                        fibaro:call(portable,'sendPush', message .. ' effectué')
                    else
                        print("Error " .. response.status)
                        fibaro:call(portable,'sendPush', 'Erreur lors de la création du Backup')
                end,
        error = function(err)
                    print('error = ' .. err)
                end,
        options = {
                method = 'POST',
                headers = {
                    ["content-type"] = 'application/x-www-form-urlencoded;'
                data = 'action=create&description='..message
 - Attention, si planification avec GEA, dans la nuit, ca relance le zwave ;-)
GEA.add(true, 30, "", {{"Scenario", id}})
ASTUCES DIVERSES
  • Affichage persistent du LOG des VDs et couleurs possibles (merci @Steven et @Berale, je ne suis que le Scrib)
- Code à  mettre dans le MAIN-LOOP
fibaro:log("Test")
fibaro:call(fibaro:getSelfId(), "setProperty", "logTemp", "TxtGray" )
 - Couleurs possibles :
.TxtGreen
.TxtRed
.TxtYellow
.TxtBlue
.TxtGray
Exemple de @Nico
--1er bouton VD
local deviceId = fibaro:getSelfId();
fibaro:call(deviceId, "setProperty", "ui.Label1.value", "Repos")
-- Second bouton du VD
fibaro:call(deviceId, "setProperty", "ui.Label1.value", "Alarme")
fibaro:call(deviceId, "setProperty", "ui.Label2.value", os.date("%m %B %Y - %H:%M:%S"))
-- Mainloop pour affichage persistent du log
local value = fibaro:getValue(deviceId, "ui.Label2.value")
fibaro:log(value)
Affichage persistent HORS MAIN-LOOP
fibaro:call(fibaro:getSelfId(), "setProperty", "log", "blablabla" )
MISE à  jour suite à  la version stable 4.10 :
Merci à  @Steven
fibaro:callGroupAction(action, filters)
      "filter": "hasProperty",
      "value": ["configured", "dead", "model"]
      "filter": "interface",
      "value": ["Z-Wave", "levelChange"]
      "filter": "parentId",
      "value": [664]
      "filter": "type",
      "value": ["com.fibaro.multilevelSwitch"]
      "filter": "roomID",
      "value": [2, 3]
      "filter": "baseType",
      "value": ["com.fibaro.binarySwitch"]
      "filter": "isTypeOf",
      "filter": "isPlugin",
      "value": [true]
      "filter": "propertyEquals",
      "value":
          "propertyName": "configured",
          "propertyValue": [true]
          "propertyName": "dead",
          "propertyValue": [false]
          "propertyName": "deviceIcon",
          "propertyValue": [15]
          "propertyName": "deviceControlType",
          "propertyValue": [15,20,25]
      "filter": "deviceID",
      "value": [55,120,902]
    Parameters
action: action name
filters: filters object
Returned values
devices: array of device id's filtered by given rule.
Code example
    %% properties
    %% events
    %% globals
    local data =
      args = { 1 },
      filters =
          filter = "roomID",
          value = { 2 }
          filter = "type",
          value = { "com.fibaro.motionSensor" }
    local devices = fibaro:callGroupAction("setArmed", data)
    for k,v in ipairs(devices) do
      print (v)
HomeCenter.NotificationService.publish(payload)
Name
Function name must be always the same: HomeCenter.NotificationService.publish
Application
Publishes notification.
Parameters
request: request object
Code example
    HomeCenter.NotificationService.publish({
        type = "GenericDeviceNotification",
        priority = "warning",
        data =
            deviceId = 2643,
            title = "foo",
            text =  "bar"
HomeCenter.NotificationService.update(id, payload)
Name
Function name must be always the same: HomeCenter.NotificationService.update
Application
Updates notification.
Parameters
Code example
    HomeCenter.NotificationService.update(7, {
        canBeDeleted = true,
        data =
            title = "udapted foo",
            text =  "udapted bar"
HomeCenter.NotificationService.remove(id)
Name
Function name must be always the same: HomeCenter.NotificationService.remove
Application
Removes notification.
Parameters
Code example
    HomeCenter.NotificationService.remove(7)
Info du jour concernant le centre de notification de la HC2, merci @tinman,
c'est ici :
 - Pour utiliser le centre de notification avec des infos "perso" :
Tester et aprouvé en 4.10
function doNotify(text, devid)
  api.post('/notificationCenter', {
        type = 'GenericDeviceNotification',
        -- priority can be
        -- alert -- red alert sign
        -- warning -- yellow warning sign
        -- info -- same as warning
        priority = 'alert',
        data = {
               deviceId = devid,
               text = text,
               title = text
doNotify('Test notif HC2', 12 )
Modifié par pepite
  • Upvote 13
bien ça :)
je pense que j'aurais plutôt séparé les API LUA et HTTP en 2 topics distincts, non ?
En plus l'API HTTP est dispo aussi bien pour HC2 que HCL, tandis que l'API LUA c'est uniquement sur HC2.
je ne peux pas diviser un post en 2.
Tu peux juste le modifier pour couper la partie API HTTP, et créer un nouveau topic.
Enfin ça je peux le faire, mais autant que tu le fasses, c'est ton post ;)
Pas dans "Firmware" déjà  (je vais déplacer ce topic-ci) car c'est réservé aux firmwares.
Met le dans le dossier parent "Home Center 2 & Lite", je pense que c'est le mieux.
C'est pas bête ça !
Mais je crois que seul Yohan peut modifier ces pages, et il n'est pas très dispo.
Sans compter que ce topic va évoluer, avec les découvertes de nouvelles Api
dites, chez moi, je met ça derrière un bouton, mais ça ne fonctionne pas...
J'ai cette rerreur dans le debug:
[ERROR] 20:50:24: line 14: attempt to index global 'net' (a nil value)
suis en 4.090 une idée ?
  • 1 month later...
hello ! Est ce que code fonctionne pour l'affichage persistant ?
fibaro:log("Test")
parce que chez moi non.
Lorsque je clique sur les bouton du VD "Test" apparait bien en gris, mais finit quand même par disparaitre...
voilàexactement mon mainloop :
if response.OUT3 == 1 then
	fibaro:call(fibaro:getSelfId(), "setProperty", "currentIcon", 145)
  	fibaro:call(fibaro:getSelfId(), "setProperty", "log", "42.00W")
else
	fibaro:call(fibaro:getSelfId(), "setProperty", "currentIcon", 146)
  	fibaro:call(fibaro:getSelfId(), "setProperty", "log", "0.00W")
  • Upvote 2
  • 1 month later...
