3525 -
10
ha j'ai trouver le prob il manque: function QuickApp:OFF_S1_C1() je continue
j'ai tester avec un lampe pour voir et j'ai une erreur [14.11.2021] [12:34:29] [ AVERTISSEMENT ] [QUICKAPP416] : la classe n'a pas de fonction ON24_S1_C1 définie - action ignorée function ON24_S1_C1() print("allumage clim") fibaro.call(89, 'turnOn') -- ici ton code pour allumer la clim. D'ailleurs ton bouton ON24 aussi devrait activer cette même fonction end function OFF_S1_C1() print("arret clim") -- ici ton code pour eteindre la clim. D'ailleurs ton bouton OFF devrait activer cette même fonction fibaro.call(89, "turnOff") end
Le QA ce Rebischung _IR.fqa ce conecte à un module IR
avant tout chose merci pour ton aide si tu est debutant bin tu debut super bien je comprend certaine chose mai pas tout le code complet: _Rebischung _IR.fqa je suppose qui coler mon code HEX entre les parenthèses de test le bonton ON function QuickApp:ON24_S1_C1(event) self:send("sendir,1:3,1,36656,1,1,129,63,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,48,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,16,16,16,16,16,16,16,16,16,16,366,129,63,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,48,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,16,16,48,16,48,16,48,16,16,16,16,16,48,16,16,16,48,16,48,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,48,16,16,16,16,16,48,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,16,16,48,16,16,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,48,16,16,16,48,16,16,16,16,16,48,16,46920x0D0x0A",true) et le OFF ---OFF function QuickApp:OFF_S1_C1(event) self:send("sendir,1:3,1,36656,1,1,129,63,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,48,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,16,16,16,16,16,16,16,16,16,16,366,129,63,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,48,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,48,16,16,16,16,16,48,16,16,16,48,16,48,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,48,16,16,16,16,16,48,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,16,16,48,16,16,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,48,16,16,16,16,16,48,16,46920x0D0x0A",true)
Salut @Fredmas alors oui pour le moment ça fonctionne mais avec GEA. mais je pense qu’il aurait été peut-être plus simple de passer directement par le Quick app.
Salut Si on appuie sur 4H je lance la clime et au bout de quatre heures elle doit s’éteindre appuyer sur le bouton off mais si entre-temps avant la fin des quatre heures j'appuie sur 2H il faut qu'il stoppe le décompte du 4H et commencer à décompter les deux heures. je n’arrive pas à le faire
Salut à tous Est il possible de réaliser vas et viens entre deux inters switch WALLI ? Et autre chose, est-il possible ou de trouver un kit Pour enjoliver à la mode Walli, un interrupteur de marque Legrand.
bonjour à tous Je recherche désespérément comment récupérer une valeur dans une partie d'un API Ce que je souhaite récupérer : updateVersion Dans mon Quick app j'ai essayé comme ça mais ça fonctionne pas, et j'ai essayé bien d'autres solutions mais toujours aucun résultat QuickApp.clima2 = tostring(fibaro.getValue(clim, "properties", firmwareUpdate: "updateVersion")) QuickApp.clima2 = tostring(fibaro.getValue(clim, "firmwareUpdate", "updateVersion")) etc j'ai tester comme ca et ça commence à bouger : QuickApp.clima2 = tostring(fibaro.getValue(clim, "firmwareUpdate")) et comme résultat : table: 0xf3a8a50 }, "dead": false, "deadReason": "", "deviceControlType": 0, "deviceIcon": 70, "endPointId": 0, "firmwareUpdate": { "info": "", "progress": 0, "status": "UpToDate", "updateVersion": "1.7" }, local clim = 375 QuickApp.clima = tostring(fibaro.getValue(clim, "coolingThermostatSetpoint")) QuickApp.clima2 = tostring(fibaro.getValue(clim, "properties", firmwareUpdate: "updateVersion")) function QuickApp:onInit() self:debug(self.clima) self:debug(self.clima2) self:updateView("label1", "text", self.clima.. " °") self:updateView("label20", "text", self.clima2.. " °") end merci d'avance pour votre aide
enfin si tu à un lien pour m'emmener vers le bon tuto je suis preneur
oui tu as raison ça prend des proportions qui vont pas dans le sens du sujet Je vais chercher merci encore
Je cherche à comprendre comment récupérer des informations, une fois que j'aurais compris et quand j'aurai le temps je vais me mettre sur le développement firmware update est juste un exemple Récupérer dead pas de problème, mai updateVersion qui dans la table firmwareUpdate la je sèche. }, "dead": false, "deadReason": "", "deviceControlType": 0, "deviceIcon": 70, "endPointId": 0, "firmwareUpdate": { "info": "", "progress": 0, "status": "UpToDate", "updateVersion": "1.7" },
oui et non En fait je cherche à développer un QA pour controlée ZXT
Les questions de comprendre comment fonctionne avec tes à son information on a les tables Je voudrais essayer de récupérer la valeur de updateVersion qui est placé si je me trompe pas dans la table firmwareUpdate J'ai essayé comme ça "firmwareUpdate:updateVersion")) mais je reçois NIL QuickApp.clima = tostring(fibaro.getValue(clim, "?????????")) }, "dead": false, "deadReason": "", "deviceControlType": 0, "deviceIcon": 70, "endPointId": 0, "firmwareUpdate": { "info": "", "progress": 0, "status": "UpToDate", "updateVersion": "1.7" },
salut effectivement merci pour l'info, surtout que je débute dans le QA alors ça fonctionne, mais je n'arrive pas à l'actualiser ou le rafraîchir automatiquement local clim = 375 QuickApp.clima = tostring(fibaro.getValue(clim, "coolingThermostatSetpoint")) function QuickApp:onInit() self:debug(self.clima) self:updateView("label1", "text", self.clima.. " °") setInterval(function() self:onInit() end,5) end
Je suis en train de créer un Quick app afin de prendre le contrôle sur le QA ZXT Je cherche à récupérer la valeur de setCoolingThermostatSetpoint du ZXT ---local clima = fibaro.call(deviceid, "setCoolingThermostatSetpoint", 20) QuickApp.clima = tostring fibaro.call(deviceid, "setCoolingThermostatSetpoint")) function QuickApp:onInit() self:debug(self.clima) self:updateView("label1", "text", self.clima.. " ° ") end "climateZoneId": 3, "configured": true, "coolingThermostatSetpoint": 24, "coolingThermostatSetpointCapabilitiesMax": 31, "coolingThermostatSetpointCapabilitiesMin": 16, "coolingThermostatSetpointFuture": 24, "coolingThermostatSetpointStep": { "C": 0.5, "F": 1
ok je comprend mieux, moi bien sûr je n'utilise pas le chaud Donc si je comprends bien, si je mets une consigne de 24° et que la température ambiante de la pièce et deux 22 normalement la clim s'arrête. Et ça c'est uniquement en mode auto. effectivement le panneau est rigide, tu pourrais me donner un exemple de lignes de code GEA stp Oui avec plaisir dès que j'aurais maîtriser le principe je vous ferai un retour
salut c'est la quel la température de consigne 25 ou 24 ? pour le moment depuis le panneau climatiseur de fibaro ça fonctionne comme ça par tranche horaire un temperature, mai dommage qu'il n y a pas une moyen de réalisée un OFF dans une tranche horaire mai c'est le mode auto que je ne comprend pas son fonctionnement
salut à tous Je suis en train de tester ZXT 600 sur mon climatiseur Panasonic Question fibaro comme malheureusement je n'ai pas trouvé mon modèle de climatiseurs référencé j'ai dû faire l'apprentissage, jusque-là pas de problème tout s'est bien passé le climatiseur réagit très bien au changement d'état On, Off, 19°, 23 etc sauf le paramètre 32 (FAN MODE) qui ne réagir pas Mais voilà je souhaite utiliser le panneau de contrôle CLIMA Fibaro, mais je sais pas s'il faut placer le ZXT sur auto ou pas. En gros je cherche à configurer le ZXT de façon à ce que mon panneau de contrôle Fibaro puisse fonctionner. Merci pour votre aide
j'ai fait comme ça : ---Au couche soleil GEA.add({"Time", "Sunset-15", "Sunset-14"} , 30, "", {{"VariableCache", "couchesoleil", false} }) --- Au Lever soleil GEA.add({"Time", "Sunrise-15", "Sunrise-14"} , 30, "", {{"VariableCache", "couchesoleil", true} }) --- quand le soleil se lève impossibilité d'allumer la lampe juqu'au coucher GEA.add( {{id["LP_FACADE_EXT"]}, {"VariableCache", "couchesoleil", true}} , -1, "", {{"turnOff", id["LP_FACADE_EXT"]}}) ---au lever du soleil éteindre la lampe GEA.add( {"VariableCache", "couchesoleil", true} , -1, "", {{"turnOff", id["LP_FACADE_EXT"]}})
- 12539 réponses
ok merci a vous, je teste quand je rentre
- 12539 réponses
salut tout le monde J'essaye de réaliser la fonction suivante: au coucher du soleil active la variable couchesoleil = true GEA.add( {"Time", "Sunset-15"} , 30, "", {{"VariableCache", "couchesoleil", true}}) Mais visiblement ça fonctionne pas Merci d'avance pour votre aide
- 12539 réponses
j'ai crée mon tout premier QA il permet QA sur HC3 , il fonction mai c'est un peut l'usine à gaz C'est dernier fonctionne grâce à un module infrarouge IP d'envoyer des codes à une clim il fonctionne surtout grâce à GEA Question d'apprendre j'aurais souhaité de l'aide pour faire la même chose mais uniquement dans le QA Là où j'ai pris plus de gaz, c'est avec la Tampo de 4 heures et 2 heures. Si on appuie sur 4H le décompte avant le OFF mais si entre-temps j'appuie sur 2H il faut qu'il stoppe le décompte du 4H Le Reset permet de stopper le 4H ou 2H ci-dessous le QA: qa.pdf
salut j'ai ouvert mon fichier avec un éditeur et je vois bien effectivement le type de mon QA : "type":"com.fibaro.clima" Est-ce bien cela qu'il faut modifier pour pouvoir après ajouter les icônes au bon vouloir ? Quel type que je dois remplacer ?
Salut J'ai essayé j'ai cherché un petit peu partout mais je n'y arrive pas à changer l'icône de mon QA Où pourrais-je trouver un tuto ou avez-vous eu un début de solution merci d'avance votre aide
pour comprend le code, le SELF devant certaine ligne veux dir quoi ?
- 5 réponses
