Fibaro Keyfob FGKF-601 - Télécommande porte-clés Z-Wave+
d@m!Ch94
salut
voici un début de code qui fonctionne bien
et dans GEA:
GEA.add({"Global", "BUTTON_CARES", "1"},  -1, "", {{....
GEA.add({"Global", "BUTTON_CARES", "2"},  -1, "", {{...
etc
%% properties
%% events
621 CentralSceneEvent 1 Pressed
621 CentralSceneEvent 1 Released
621 CentralSceneEvent 1 HeldDown
621 CentralSceneEvent 1 Pressed2
621 CentralSceneEvent 1 Pressed3
%% globals
local fonctions = {
-- cares 1 Clic
    ["Pressed"] = function()
      fibaro:debug("cares 1 click");
   fibaro:setGlobal("cares", 1)
  end,
-- cares 2 Clic
    ["Pressed2"] = function()
      fibaro:debug("cares 2click");
    fibaro:setGlobal("cares", 2)
    end,
-- cares 3 Clic
    ["Pressed3"] = function()
      fibaro:debug("cares 3 Clic");
     fibaro:setGlobal("cares", 3)
   end,
-- cares long
    ["HeldDown"] = function()
      fibaro:debug("cares long");
fibaro:setGlobal("cares", 4)
   	end,
-- cares long relaché
    ["Released"] = function()
      fibaro:debug("cares long relaché");
fibaro:setGlobal("cares", 5)
    end,
action = startSource.event.data.keyAttribute;
fonctions[action]();
  • Upvote 2
salut
et dans GEA:
GEA.add({"Global", "BUTTON_CARES", "1"},  -1, "", {{....GEA.add({"Global", "BUTTON_CARES", "2"},  -1, "", {{...etc
--[[%% properties%% events621 CentralSceneEvent 1 Pressed621 CentralSceneEvent 1 Released621 CentralSceneEvent 1 HeldDown621 CentralSceneEvent 1 Pressed2621 CentralSceneEvent 1 Pressed3%% globals--]]local fonctions = {-- -------------------------------------------------- cares 1 Clic-- ------------------------------------------------   ["Pressed"] = function()     fibaro:debug("cares 1 click");  fibaro:setGlobal("cares", 1) end,-- -------------------------------------------------- cares 2 Clic-- ------------------------------------------------   ["Pressed2"] = function()     fibaro:debug("cares 2click");   fibaro:setGlobal("cares", 2)   end,-- -------------------------------------------------- cares 3 Clic-- ------------------------------------------------   ["Pressed3"] = function()     fibaro:debug("cares 3 Clic");    fibaro:setGlobal("cares", 3)  end,-- -------------------------------------------------- cares long -- ------------------------------------------------        ["HeldDown"] = function()      fibaro:debug("cares long");fibaro:setGlobal("cares", 4)  	end,-- -------------------------------------------------- cares long relaché-- ------------------------------------------------   ["Released"] = function()     fibaro:debug("cares long relaché");fibaro:setGlobal("cares", 5)   end,}local startSource = fibaro:getSourceTrigger();action = startSource.event.data.keyAttribute;fonctions[action]();
Merci @971jmd.
je teste ça ce soir
À plus
Envoyé de mon SM-G935F en utilisant Tapatalk
Bonne idée @971jmd de passer par une variable que tu récupères dans GEA pour faire tes scenarios.
Tu aurais pu aussi passer par une etiquette ;-) sauf si tu as beosin de la date de modfication uniquement possible avec les VGs.
Super idée tout de même, ca te permet de tout centraliser dans GEA
@Lazer
Oui j'avoue je suis repéré ;-)
En fait, je suis devenu plutot LABEL que Variable globale suite au bug connu des VGs, un jour suite à une fausse manip de ma part, un clic malencontreux au niveau du panneau de variable tout etait planté.
etant doné que je suis un boulet..ca m'evite quelques mesaventures ;-)
Pour ceux qui n'ont jamais testé : un petit save dans le panneau et vous verrez ;-)
  • Upvote 2
Des milliers de VG c'est plus lisible, car on ne les voit pas, tandis que les labels poluent l'interface des VD sur l'écran principal.
Tout est question de point de vue et d'usage.
Perso je mixe les 2, des labels uniquement si j'ai besoin de voir l'information rapidement (exemple : depuis l'application), et des VG si je n'ai pas besoin de voir cette info.
Dis autrement, les labels sont des variables "utilisateur", alors que les VG sont des variables "techniques".
Le 14/03/2017 à 09:05, pepite a dit :
salut,
juste pour comprendre, comment passer justement par une étiquette ?
Ahh met attentions Lazer, moi j'ai le tout dans un seul VD qui sert de stockeur, pas des tonnes de VD qui polluent. Mais au final j'ai fais le ménage pour en avoir le moins possible, des 2 sortes.
De même pour moi, j'ai les 2, mais je stocke tout dans un seul VD aussi pour les labels ;-)
@971jmd
Créé une etiquette dans un VD.
Dans ton code Remplace
par
fibaro:call(idduVD, "setProperty", "ui.label.value", 5)
puis dans GEA
{"Label", id_vd, nom_du_label", 5}
Il y a 6 heures, pepite a dit :
Un bouton ?
On parle d'etiquette, pourquoi un bouton ?
nous ne somme pas trop dans le sujet, mai j'ai fini par comprendre
dans 30s affecte la valeur "activé" à la label 1 id 625
Dans :  GEA.add(true, 30, "", {{"Label", 625, "Label1", "activé"}})
mai juste une autre chose, y-a-t-il la possibilités de faire le contraire
si Label1 ID625 passe a la valeur = activée alors........
GEA.add({"Label", 625, "Label1", "activé"} , -1 , "", {.........})
pour ne pas polluée le topic  Keyfob FGKF-601, tu me répondre dans le topic GEA
Hum, bon la pile de ma seconde telco vient de passer dans le rouge. Vais attendre qu'elles soient 100% vide, et je repartirai avec un jeu neuf pour juger. On va mettre ça sur le dos des piles d'origines qui étaient pourries.
Et vous ça donne quoi ?
Sinon après presque 1 mois, quel bonheur cette télécommande !
Idem, que du bonheur cette télécommande !
Concernant la pile la mienne est toujours à 50 % et n'a jamais été à 100%, soit les piles sont foireuses, soit la jauge n'est pas correctement étalonnée...
Hum, je viens de capter un truc, il y avait aussi un autocollant sous la pile... J'avais pas fais gaffe. Bon je ne vois pas trop ce que cela change qu'il y soit ou non, mais peut être que cela n'a pas aidé...
Bon, bah énorme :
Du coup j'ai enlevé cet autocollant arrière, une des 2 est passé à 100%, la seconde à 100% 1 minute puis 50%... Magique. A suivre donc. Qqun d'autre avait fait le boulet comme moi ?
Mais bon, j'avoue ne pas comprendre ce que cela change, car il n'y a aucun contact au centre à l'arrière où se trouve l'autocollant.
J'utilise cela comme code pour tous les 6 boutons dans une scène. Je n'ai pas encore activé les double et triple click des paramètres 21 à 26.
%% properties
%% globals
%% events
563 CentralSceneEvent 1
563 CentralSceneEvent 2
563 CentralSceneEvent 3
563 CentralSceneEvent 4
563 CentralSceneEvent 5
563 CentralSceneEvent 6
%% killOtherInstances
function actions(button,action)
  	if button=="1" then
    	if action=="Pressed" then
    		fibaro:debug("Appui Carre Simple")
    	elseif action=="HeldDown" then
    		fibaro:debug("Appui Carre long")
    	elseif action=="Released" then
    		fibaro:debug("Appui Carre relache")
  	elseif button=="2" then
    		fibaro:debug("Appui rond Simple")
    		fibaro:debug("Appui rong long")
    		fibaro:debug("Appui rond relache")
  	elseif button=="3" then
    		fibaro:debug("Appui Croix Simple")
    		fibaro:debug("Appui Croix long")
    		fibaro:debug("Appui Croix relache")
  	elseif button=="4" then
    		fibaro:debug("Appui triangle Simple")
    		fibaro:debug("Appui triangle long")
    		fibaro:debug("Appui triangle relache")
  	elseif button=="5" then
    		fibaro:debug("Appui Moins Simple")
    		fibaro:debug("Appui Moins long")
    		fibaro:debug("Appui Moins relache")
  	elseif button=="6" then
    		fibaro:debug("Appui Plus Simple")
    		fibaro:debug("Appui Plus long")
    		fibaro:debug("Appui Plus relache")
local trigger = fibaro:getSourceTrigger()
local action = ""
local button = ""
fibaro:debug("Source : "..trigger["type"])
if (trigger["type"] == "other") then
	action=""
else
  	local pressSource = fibaro:getSourceTrigger()
	button = tostring(pressSource.event.data.keyId)
  	action = pressSource.event.data.keyAttribute
if action ~= "" then
  	fibaro:debug("button : "..button.." / Action : "..action)
  • 4 semaines après...
On vient de m'offrir ce nouveau jouet pas mal un peu petit pour mes grosses mains :)
Voici un morceau de code pour tester la télécommande
%% events
388 CentralSceneEvent
-- trigger de la télécommade 388 CentralSceneEvent
if (sourceTrigger['type'] == 'event') then
  NomBouton = sourceTrigger.event.data.keyId
  ValeurBouton = sourceTrigger.event.data.keyAttribute
  fibaro:debug("Non Bouton "..NomBouton.." - Valeur du Bouton : "..ValeurBouton)
