HC2 & HCL - 4.131 - BETA - 08/06/2017
Et sinon ce bug de chaine est pris en compte, la prochaine beta devrait corriger.
ok merci a vous
mai en attendant, serait-il possible de via une scene de fair fonctionné un code hexa (IR code) ?
merci Nico pour l'info
pour ceux qui ont un orange décodeur voici le code
ORANGE=Net.FHttp("ip decodeur",port);
reponse=ORANGE:GET("/remoteControl/cmd?operation=01&key=513&mode=0");
fibaro:sleep(100);
pour kira128
KIRA=Net.FHttp("ip kira",80);
reponse=KIRA:GET("/remote2.htm?button014");
fibaro:sleep(100);
pour global cache essai ca je suis pas sur
local me = fibaro:getSelfId()
local ip = fibaro:getValue(me, 'IPAddress')
local port = fibaro:getValue(me, 'TCPPort')
tcpSocket = Net.FTcpSocket(ip, port)
tcpSocket:setReadTimeout(2000)
tcpSocket:write("sendir,1:1,1,37735,1,1,171,171,21,64,21,64,21,64,21,21,21,21,21,21,21,21,21,21,21,64,21,64,21,64,21,21,21,21,21,21,21,21,21,21,21,21,21,64,21,21,21,21,21,21,21,21,21,21,21,21,21,64,21,21,21,64,21,64,21,64,21,64,21,64,21,64,21,1776\r")
tcpSocket:disconnect()
voila pour moi c'est ok
local selfId   = fibaro:getSelfId();
local selfIp   = fibaro:get(selfId, 'IPAddress');
local selfPort = fibaro:get(selfId, 'TCPPort');
local enter = string.char(0x0d, 0x0a);
local sendCommand = "sendir,2:1,1,40192,1,1,32,24,48,24,24,24,48,24,24,24,48,24,24,24,24,24,48,24,24,24,24,24,24,24,24,1034,96,24,48,24,24,24,48,24,24,24,48,24,24,24,24,24,48,24,24,24,24,24,24,24,24,1033,96,24,48,24,24,24,48,24,24,24,48,24,24,24,24,24,48,24,24,24,24,24,24,24,24,1034,96,24,48,24,24,24,48,24,24,24,48,24,24,24,24,24,48,24,24,24,24,24,24,24,24,1033,96,24,48,24,24,24,48,24,24,24,48,24,24,24,24,24,48,24,24,24,24,24,24,24,24,4019"..enter;
--To initialise the TCP-port:
-- Initialising TCP-port
if (tcpSocket == nil) then
  tcpSocket = Net.FTcpSocket(selfIp, selfPort);
  tcpSocket:setReadTimeout(1000);
-- Writing (send) command:
bytes, errorCodeWrite = tcpSocket:write(sendCommand);
fibaro:sleep(250);
response, errorCode = tcpSocket:read();
-- Close socket:
tcpSocket:disconnect();
Après la mise à jour sur ma HCL je devais lancer la reconfiguration de la plupart de mes modules.
Suite à cette étape j'ai un comportement assez étrange sur les 10 modules roller shutter et le contact de port Fibaro. En effet, un appareil supplémentaire a apparu dans ces modules sous forme d'une télécommande ?!?! Avec la 4.130 j'ai perdu le lien avec ma télécommande Nodon Remote
J'ai contacté le support Fibaro mais ils ne sont pas très réactifs ces temps.
La réponse de Fibaro c'est que ces modules supplémentaires sont normaux pour les nouvelles fonctionnalités Central Scene:
These “remotes” comes when the Central Scene feature comes live for our modules. With this function you can trigger your scene directly from your module with double click for example or when other event occur.
This function is completely normal feature.
Pour l'instant je n'en vois pas l'utilité. Si quelqu'un est mieux informé, je suis preneur.
Belle après-midi
Modifié par krastavac
Mais ce n'est pas gênant, tu caches ceux que tu n'utilises pas tout simplement.
Mais c'est vrai que Fib manque de com sur certaines choses.. heureusement que les users s'entraident.. ;)
Envoyé via Tapatalk
Il y a 6 heures, BenjyNet a dit :
Putain ça c'est de l'update !!!
Hello
Mise à jour effectuée mais problème reste identique
Une petite larme :=)
A vous lire
Salut à tous,
J'ai un souci de fuite mémoire violente sur ma HC2 depuis que je suis passé 4.131b. Je dois la rebooter tous les ou 4 jours faute de quoi je me retrouve avec une mémoire libre à 1 ou 2%. Je n'ai rien touché de ma config depuis plusieurs mois. Je ne comprends pas trop ce qui se passe.
Vous pouvez m'éclairer
Bonjour, c'est très bizarre les fuites mémoires sont résilles depuis plusieurs versions. As tu essayé d upgrader ? Il y a 4.132 beta et 4.133 beta depuis.
Envoyé de mon Nexus 5X en utilisant Tapatalk
Il est étrange ton VD, déjà je ne vois pas comment tu peux monitorer le Swap vu que l'info n'est pas dans l'API mais disponible uniquement via Linux (donc en root).
Une demande d'ajout avait été faite sur le bugtracker à l'époque des fuites mémoires, à laquelle Fibaro n'a jamais répondu....
