Fibaro FGBS-222 Smart Implant - Détecteur Universel Z-Wave+
Lazer
Description
FIBARO Smart Implant allows to enhance the functionality of wired sensors and other devices by adding Z-Wave network communication.
You can connect binary sensors, analog sensors, DS18B20 temperature sensors or DHT22 humidity and temperature sensor to report their readings to the Z-Wave controller.
It can also control devices by opening/closing output contacts independently of the inputs. :60:
Features
  • Compatible with any certified Z-Wave or Z-Wave Plus controller.
  • Supports Z-Wave network Security Modes: S0 with AES-128 encryption and S2 Authenticated with PRNG-based encryption.
  • Works as a Z-Wave signal repeater.
  • Allows for connecting sensors:
    • 6 DS18B20 sensors,
    • 1 DHT sensor,
    • 2 2-wire analog sensor,
    • 2 3-wire analog sensor,
    • 2 binary sensors.
  • Built-in temperature sensor.
Technical data
Power supply 9-30V DC ±10%
Inputs 2 0-10V or digital inputs 1 serial 1-wire input
Outputs 2 potential-free outputs
Supported digital sensors 6 DS18B20 or 1 DHT22
Maximum current on outputs 150mA
Maximum voltage on outputs 30V DC / 20V AC ±5%
Built-in temperature sensor measurement range -55°C–126°C
(-67°F–259°F)
Operating temperature 0–40°C (32–104°F)
Radio protocol Z-Wave (500 series chip)
Radio frequency 868.4 or 869.8 MHz EU;
908.4, 908.42 or 916.0 MHz US;
921.4 or 919.8 MHz ANZ;
869.0 MHz RU;
Radio ransmit power max. 7 dBm (EIRP)
Range up to 50m (164 ft) outdoors
up to 40m (131 ft) indoors
(depending on terrain and building structure)
Dimensions
(Length x Width x Height)
29 x 18 x 13 mm
(1.14” x 0.71” x 0.51”)
Compliance with EU directives RoHS 2011/65/EU
RED 2014/53/EU
Clair que le fait de pouvoir contrôler les sorties indépendamment est juste énorme, argh top. Si le prix reste contenu comme le premier, c'est juste top, cela remplace 2 FGS au niveau contact sec, c'est top de chez top ça !
le tout premier FGBS que j'ai acheté, j'avais mal lu la notice, et je croyais qu'on pouvait piloter les sorties indépendamment.
Maintenant c'est ok.
Et c'est super, car comme Fibaro ne fait plus que des FGS sans possibilité de commander autre chose que du 220V (avant il y avait les 221 et 222), ceci pourra les remplacer avantageusement ?
il y a 3 minutes, PITP2 a dit :
@jojo ATTENTION
30V DC / 20V AC ±5%
Pas de 230V sur les sorties et de plus les FGS2221 et 22 sont tjrs dispos
oui, mais pour les contacts secs, c'est super, sauf qu'il faut également une alim
 Pratique quand même, par exemple sur un portail, le contact d'ouverture et les deux sorties pour l'état sur le même module: parfait (mais je pense qu'il va augmenter).
Sur le papier c'est impec (possibilité de mesurer un taux d'humidité), mais espérons qu'ils soient mieux "terminés" que les robinets thermostatiques ou le portier vidéo.
Invité chris6783
que de bonnes évolutions sur ce module ! bravo
j'aime bien aussi le nouveau form factor avec un habillage plastique. C plus pratique pour un montage volant sur un automatisme de portail ou dans une centrale d'alarme ou un peu partout...
Je viens de lire l'article de Domadoo sur le smart implant
et cette phrase m'interpellle :
Un seul module Smart Implant peut fonctionner comme (ou commander) deux boutons physiques, et il est possible de connecter plusieurs modules à un seul périphérique.
Pourrais-je avoir 2 inputs ET 2 outputs (=> 4 "modules") ou il sera limité à 2 "modules". Donc si on a 2 outputs, il n'y a plus d'input dispo.
J'ai peur de la réponse ...
D'après ce que je comprends de la doc (en attendant d'avoir le PDF complet) :
- les Sorties peuvent être pilotées indépendamment des entrées
- mais si une entrée change, alors la sortie change immédiatement
Donc si on veut utiliser les Sorties en totale autonomie, il ne faut pas brancher les 2 entrées numériques (pas de souci avec les entrées analogiques qui sont indépendantes)
c'est ce que je craignais.
Donc pour mes portes de garage, où j'utilise les deux contacts en entrée, je n'ai plus de possibilité d'utiliser la sortie indépendemment ... (en fait si on regarde les fils dispos pour les connexions, c'est (malheureusement) évident)
Les FGBS actuels ont une réputation de faible portée z-wave. Les nouveaux seraient-ils plus performants ?
