TonyC 457 Signaler ce message Posté(e) 28 février 2020 (modifié) Désolé pour la présentation c'est un copier coller du change log sur la hc3, j'essaierai de le mettre en forme ce soir ! On ne voit plus (en tout cas je ne vois pas) de notion de beta ou stable d'ou le titre qui ne le précise pas... EDIT: Un peu de rework sur la présentation que je viens de pompé sur le fofo officiel et qui apporte plus de lisibilité au changelog. Thank you for using the FIBARO Home Center 3! Our constant improvements are to better your experience. Be sure to update to the latest version to enjoy new features. What's new: Block Scenes Actions on the LED ring for FIBARO Walli series devices. Actions for Z-Wave thermostats. Cameras Redirect to camera configuration after adding. Setting up a custom icon. Climate Indicating the active mode of climate schedule. Dashboard Controlling the binarySwitch, multilevelSwitch and rollerShutter devices from the right sidebar. Displaying the currently set temperature on the thermostat icon. Collapsing/expanding the rooms side menu. Devices Z-Wave removal mode available from the list of all devices. Displaying the battery level under the battery icon on the device list. Default humidity range changed to 40-50%. Unified configuration of various types of linked devices. Support for pending and failed associations. Support for the black box of FIBARO Heat Controller (FGT-001). Support for FIBARO RGBW Controller 2 (FGRGBW-442). Support for Z-Wave locks. Support for Z-Wave thermostats. Support for wind and rain sensors. General Downloading the current location of the gateway in https connection mode. Lua Scenes Possibility to download a scene trigger using the sourceTrigger object that triggered the scene. Values retrieved from the api are typed. Os.time, os.date and fibaro.sleep functions. Migration from HC2/HCL "Finish migration" button on the welcome screen to restore backup transferred from HC2/HCL. Network Disabled switching off Wi-Fi during the first configuration. Other Shorter loading time of device and room lists. Added loaders for loading lists in settings. Unified display of entries in the debugger (Lua, Quick Apps) and the Z-Wave console. Collapsing/expanding the settings side menu. Added Czech language. Plugins Satel plugin fixes and improvements.. Integration of Satel alarm partitions with the FIBARO alarm. Profiles Display and control of climate zones. Display and control of alarm zones. New icons related to weather and temperature. Quick Apps New device types: com.fibaro.genericDevice and com.fibaro.weather. Values retrieved from the api are typed. Recovery Mode Displaying inactive system version. Progress bar when uploading a local file. Displaying the time remaining to automatic reboot of the gateway. Rooms Indicating the default room on the list of rooms. VoIP Added the functionality description. Bug fixes: Access No refresh after synchronizing users. Remote support cannot be enabled via remote access. Backup The "restore with version" feature does not download the correct software version. Instead of restoring the selected local backup, the latest local backup is always restored. Number of scenes in backup is always equal 0. Block Scenes Unable to enter the time in the delay block. Lists of rooms and sections do not load. Active "run scene" button despite unsaved changes. Selected triggers disappear after reloading page. No suitable options for the type com.fibaro.barrier. Redundant fields in blocks for RGBW devices. No condition values displayed for Central Scene controllers. Forcing the watering from the scene causes a system error. Missing translations. Cameras Cannot display the advanced tab. Incorrect image path causing no camera image. Invalid default image refresh time. Climate Incorrect limits of minimum and maximum temperature. Zone temperature is not displayed in manual mode. Restarting the gateway when any partition is in Hold mode causes a system error. Dashboard Search does not work properly if entered a dot in the search box. Devices No device polling button if polling is globally enabled. Double message about unsaved changes in device parameters. Errors in displaying the energy consumption of the device. No advanced settings section for Z-Wave locks supporting pin codes. Changing the role of RGBW device requires reloading the page to display properly. No icons for several types of sensors connected to the FIBARO Smart Implant. Cannot set the minimum and maximum RGBW slider value. Cannot reset advanced parameters to the default values. Invalid redirection to associated device. The Advanced tab is not displayed when added a scene with Central Scene event. USB powered device is marked as a battery device. The user added icon has an invalid path. Changing the device name is not applied in the notifications. Lack of support for the FIBARO Smart Implant device. Incorrect support of the Danfoss RS device. Diagnostics Unable to download the device template. Garden Setting is not displayed correctly on the days that the schedule does not apply to. Incorrect operation of sprinklers in a sequence. Lua Scenes Incorrect loading of the scene editor view. Errors in displaying the debugger. Network Changing the IP address or addressing mode does not work properly. Access Point is inactive after the recovery procedure. Notifications Lack of filtering by type and priority. Notifications for linked devices do not work. Other Displaying incorrect checkboxes when using a tablet. Inconsistent icons and buttons on warning popups. Plugins Philips Hue devices are set to default light values after switching off and on. No weather data displayed on the YR Weather plugin preview tab. Quick Apps New device is always assigned to the default room. The ID of an existing item changes when adding a new item. The device view is not updating. Lack of code scrolling. Importing an unassigned device results in an error. Visual fixes. Recovery Mode The restore, repair and switch actions do not display statuses. Visual fixes. Rooms The section name does not change when closing the window. Update Retrying to download the update returns an error. Z-Wave Unable to close the adding controller window. The mesh reconfiguration for the Z-Wave devices does not work. Modifié 28 février 2020 par TonyC Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 497 Signaler ce message Posté(e) 28 février 2020 Il n'y a plus que des stables Fibaro reprend ses bonnes vieilles habitude de firmware la veille d'un week-end.... Mais est-elle vraiment disponible cette fois-ci ? PS : sujet déplacé dans la section Firmwares. Partager ce message Lien à poster Partager sur d’autres sites
couillerot 749 Signaler ce message Posté(e) 28 février 2020 oui complètement dispo et en cours de téléchargement ! Stef Partager ce message Lien à poster Partager sur d’autres sites
TonyC 457 Signaler ce message Posté(e) 28 février 2020 il y a 8 minutes, Lazer a dit : PS : sujet déplacé dans la section Firmwares. Désolé @Lazer, je pensais y être lorsque j'ai ouvert le topic. Sorry ! et oui que des stables on dirait 1 Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 357 Signaler ce message Posté(e) 28 février 2020 Alors ça donne quoi la migration des modules ? Envoyé de mon BLA-L29 en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
couillerot 749 Signaler ce message Posté(e) 28 février 2020 moi j'attends la semaine prochaine je suis en CP (je préfère prévoir le coup!) Stef Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 357 Signaler ce message Posté(e) 28 février 2020 HC2 à HC30 90 dispositifs physiques "Big Bang Migration" https://forum.fibaro.com/topic/49350-hc2-to-hc30-90-physical-devices-big-bang-migration/ 2 Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 170 Signaler ce message Posté(e) 28 février 2020 Et migration réussi sans aucun souci des 90 modules, et à priori c'est pas le seul... Donc GG Fibaro ! Partager ce message Lien à poster Partager sur d’autres sites
ericl78 74 Signaler ce message Posté(e) 28 février 2020 Je viens de recevoir ma HC3 et de la mettre à jour, donc RAS :=) Question: si je migre ma HC2 avec mes 65 modules, il me restera à réécrire mes 100 scripts! Lors de la migration, la HC2 est effacée au niveau conf Zwave, vrai ? Si je réinstalle sur la hc2 une configuration qui a été sauvegardée sur mon pc, ma HC2 refonctionne t'elle ? Merci à vous Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 357 Signaler ce message Posté(e) 28 février 2020 Non le retour en arrière n'est pas possible Envoyé de mon BLA-L29 en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 170 Signaler ce message Posté(e) 28 février 2020 A priori, mais clairement je ne ne comprend pas le pourquoi... Partager ce message Lien à poster Partager sur d’autres sites
ericl78 74 Signaler ce message Posté(e) 28 février 2020 oui, dans le même cas que toi, je ne comprends pas le pourquoi Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 357 Signaler ce message Posté(e) 28 février 2020 Non Pascal, on en a déjà parlé sur 2 autres topics. Ils utilisent le bascule de controleur principalEnvoyé de mon BLA-L29 en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
Krikroff 1 924 Signaler ce message Posté(e) 28 février 2020 Et migration réussi sans aucun souci des 90 modules, et à priori c'est pas le seul... Donc GG Fibaro ! Oui très très bonne surprise vu de mes yeux et pas que des modules Fibaro ayant poussé le vice sur le HC2 avec du Qubino SmartMeter, Fil Pilote et de l’Aeotec également. Tout est parfaitement fonctionnel et configuré à l’identique ! Après il y a du Taff pour refaire scènes et Cie . Pour les impatients avec 1 semaine de vacances c’est parfait, personnellement le jour où je bascule je le ferai progressivement. Dans tous les cas un grand bravo à Fibaro 1 Partager ce message Lien à poster Partager sur d’autres sites
Dragoniacs 436 Signaler ce message Posté(e) 3 mars 2020 Beau changelog et beaucoup d'évolutions !!!Moi, tant qu'il n'y a pas GEA, je peux pas passer a la HC3...Envoyé de mon SM-A530F en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
pepite 1 272 Signaler ce message Posté(e) 3 mars 2020 il y a une heure, Dragoniacs a dit : Moi, tant qu'il n'y a pas GEA, je peux pas passer a la HC3... Tu ne verras jamais GEA intégré par FIBARO ;-) 1 Partager ce message Lien à poster Partager sur d’autres sites
Krikroff 1 924 Signaler ce message Posté(e) 3 mars 2020 Ça nous sommes d’accord ! Partager ce message Lien à poster Partager sur d’autres sites
Dragoniacs 436 Signaler ce message Posté(e) 3 mars 2020 Bah non, mais je compte sur notre belle communauté de développeurs barbus Envoyé de mon SM-A530F en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
pepite 1 272 Signaler ce message Posté(e) 3 mars 2020 il faut que la barbe soit très longue ... Partager ce message Lien à poster Partager sur d’autres sites
Did 1 722 Signaler ce message Posté(e) 3 mars 2020 ZZ Top? 1 Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 357 Signaler ce message Posté(e) 3 mars 2020 @did tes gouts musicaux me font penser que tu n'es pas loin de la maison de retraite 2 2 Partager ce message Lien à poster Partager sur d’autres sites
Did 1 722 Signaler ce message Posté(e) 3 mars 2020 Ils assurent encore les papys. 1 Partager ce message Lien à poster Partager sur d’autres sites
Krikroff 1 924 Signaler ce message Posté(e) 3 mars 2020 Les poignets bougent encore bien mais ils font du surplace sur scène 1 2 Partager ce message Lien à poster Partager sur d’autres sites
ericl78 74 Signaler ce message Posté(e) 3 mars 2020 Hi Pour les personnes que cela intéresse, il y a un site qui possède des HC3 en stock, livrée en 72h Je ne désire pas faire de pub pour ce site sur le forum, mais recherche sur google de "achat fibaro home center 3" et vous trouverez le site sur la première page affichée Voilà, juste pour info Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 357 Signaler ce message Posté(e) 3 mars 2020 Il n'y a aucune interdiction de donner ce genre d'informationHC3 disponible icihttps://www.domotec-services.com/Domotique/Domotique-Fibaro/Box-Domotiques/12937-Home-Center-3.htmlEnvoyé de mon BLA-L29 en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
