Lazer Posté(e) le 18 mars 2021 Signaler Partager Posté(e) le 18 mars 2021 Version 5.070.42 Stable Important Notice In some cases (on large systems) update with automatic backup may fail due to the size of the database. Please create local backup manually, download it, then perform the update with "No backup before update (not recommended)" option selected. What's new: Alarm Added column with alarm scene ID. Backup Disabling backup creation button when reached the backups limit. Optional saving of the history content when creating backup manually. Storing historical data during backup creation deactivated by default. Auto-trimming to 500000*/1000000** events while creating backup for reducing backup size. Warning about not storing historical data in auto-backups created during update. Warning about possible loss of historical data before restoring backup. Dashboard Serial number displayed as a tooltip after hovering on logo. Exact value from the api displayed as a tooltip on device tile and on the right sidebar. Possibility to control com.fibaro.player devices from the right sidebar. Possibility to open video gate from the right sidebar. Thermostat preview available from the FIBARO Home Center app. Icons for opening and closing states of roller shutters. Unified text size and colour on the right sidebar. Status toasts after performing actions on devices using the right sidebar. No limit to the number of devices.* System notification after exceeding the recommended number of devices.* Devices Power consumption charts in device Advanced tab. Three new icon sets for valves. Unified content of Advanced tab for devices of the same type. Advanced tab for all types of linked devices. Current/total energy consumption view switch. Requiring confirmation before clearing the energy data. Sum function available for linked devices of the multilevel sensor type. Two possible configurations of the energy meter device. Support for FIBARO Walli Controller (FGWCEU-201). Support for FIBARO Smart Implant (FGBS-222) version 5.2. Support for Heatit Z-Smoke Detector 230V version 4.1/4.2. Support for Heatit Z-Temp2 version 1.1/1.2 Support for Heatit Z-TRM3 version 4.0. Support for Sensative Strips Guard in any version. Support for U-Fairy Valve Shut-Off Controller. Support for Steinel IS 140-2 version 1.0. Support for Steinel L810 LED iHF version 1.1. Gateway Connection** Unlocked feature of connecting two or more gateways: FIBARO Home Centers 3 may be connected only to other Home Centers 3. Slave gateway must be empty or will be restored to factory settings. All gateways must have the same version installed. Backing up connected gateways together using the master gateway. Updating connected gateways one after another starting from slave gateways. Possibility to update all gateways or master gateway only. Possibility to restore backup for all gateways or master gateway only. Possibility to access slave gateways via generated password. History Displaying events related to power consumption of devices. Improved displaying events from FIBARO RGBW Controllers. Network Possibility of adding a second Wi-Fi network for emergency auto-switching. Connecting to emergency network after losing connection to main network. Storing the credentials of added Wi-Fi networks after its disconnecting. Retrying to connect to main network each 30 minutes when connected to emergency network. Possibility of testing the connection to emergency network. Wireless network interfaces data included in system report. Added test button for networks with unknown status. Nice** Backing up Nice devices in the system configuration backup. Nice remotes available as scene triggers. Improved view of adding new device. Changes on the binding view. Support for NiceHome devices. Notifications Critical push notifications available as a new channel for life danger events. Other Beta version status displayed on the login screen and in General Settings. Tooltips on the interface menu icons. Possibility of skipping the ongoing first system configuration process at any step. Performance Optimized services performance and events handling. Optimized database write and read times. Added memory usage limit for power and temperature events to reduce overall memory load. Plugins Added Tedee lock plugin. Added Dahua camera plugin. Profiles Door locks available to open/close in any profile. Quick Apps Buttons and sliders available as actions in block scenes. Option of hiding the button. Rooms Possibility of choosing the main room energy meter. Scenes Redirection to expanded scene view from scenes dashboard. Update Notice of the necessary local connection to perform the update. Redirection to current system status after starting the update. Automatic backup during update procedure does not contain historical events data anymore. Bug fixes: Access Incorrect limit of characters when editing a user's e-mail address. No auto-logging when accessing the gateway via remote access. Alarm Possibility to add Z-Wave devices to Satel alarm zones. Cannot add alarm zones during the First Time Installation. Cannot arm the whole house if there are unconfigured alarm zones. Backup Cannot migrate cloud backups from one Home Center 3 to another. Incorrect states when creating backups. Cancellation of downloading an update stops creating/restoring the backup. Cameras No pause button on camera image preview. Complex stream paths are improperly translated. Climate Some thermostats controlled manually enter override mode despite the lack of schedule. Dashboard Unable to manually set the temperature on Fibaro Heat Controller from the right sidebar. Unable to override the temperature on third-party thermostats from the right sidebar. Devices Temperature setpoint chart is displayed incorrectly. Energy data on device Advanced tab is not cleared. No possibility to add FIBARO RGBW 2 (FGRGBW-442) in security mode. Scenes added from device Advanced tab are not displayed in this tab. Linked device of thermostat type is always equipped with all operating modes. Notifications from devices come too often and not according to selected interval. Possibility to set the ID of an icon that no longer exists. Issues with configuring parameters in devices without templates or with disabled template. Gateway Connection No central scene events from devices added to slave gateways. Scenes based on scene activation events from devices added to slave gateways do not work. Cannot change icons of devices added to slave gateways. Unable to force the removal of devices from slave gateways. Unable to change wakeup interval of battery devices added to slave gateway. Wrong message about restoring default password when removing disconnected slave gateway. No possibility to set polling time and run mesh reconfiguration on slave gateways. Error after removing a disconnected slave gateway. Restored local backup does not include slave gateways. Connect and Replace buttons available inadequately. Master gateway crashes when using Climate Panels with thermostats from Slave gateway. History Incorrect units for events from multilevel sensors. Filtering events by rooms does not work properly. Users see events from devices to which they do not have permission. Network Services do not start if there is a network connection without the Internet. Unexpected Wi-Fi connection loss.* Error 500 in some cases during connection with Wi-Fi network. Disconnected emergency network displayed as unknown after reboot. Nice** Scenes with Nice Mono and BiDi devices do not work. Notifications Critical push notifications are not sent. No notifications from BiDi Z-Wave device after rebooting the gateway. Duplicated notifications of available template after rebooting the gateway. Unexpected Nice radio protocol connection timeout notification. Other Chinese language version choice is not saved. Services do not start after leaving the stand-by mode. Power diode is not lit after leaving the stand-by mode. Numerical values are rounded incorrectly. Cannot close toast messages. Performance Significant delays in Z-Wave network communication. Few minutes after rebooting system is not available. In some cases, the gateway does not start after performing an update. Low gateway performance with MJPG stream preview.* Long gateway booting time.* Rare system crash on boot when system contains a large number of plugins/Quick Apps. Plugins Planika fireplace plugin status is refreshed too often and results in mobile app crash. Fibaro Heat Activator plugin turned off after adding by default. No data from YR Weather plugin. No support for rain state in YR Weather plugin. Profiles Scene in which the active profile is a condition does not start after rebooting. Cannot set actions in profile. Quick Apps Non-admin users get the login screen when opening the quick app on the mobile app. Non-admin users get only the custom part of quick app on the mobile app. The first letter in labels is automatically changed to a capital letter. No button for removing the device after leaving the edit mode. No family section in general device settings. Invalid support of 'secured' property for door locks. Push notifications from Quick Apps are always sent to all users. Recovery Large systems in some cases start up in recovery mode. Cannot upload beta version from local file when using Repair option. In some cases page does not load properly.* Scenes Scene Activation IDs are not displayed when creating block scene. Deactivation of a running scene does not stop the scene. Soft reconfiguration of the device is required to run scenes with Access Control Events. No protection against running the same scene at short time intervals. Value set on slider is zeroed and locked when editing existing block scene. Scenes based on sunrise and sunset do not function properly. In some cases, scenes require editing to work after creating backup. Syntax of fibaro.profile function is prompted incorrectly. Cannot select device in single device block. Inverted door lock condition states. Scene created from device settings is not filled automatically with Scene Activation Event. Update Possibility to start update before displaying auto-backup options. * - applies to Home Center 3 Lite ** - applies to Home Center 3 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
mprinfo Posté(e) le 18 mars 2021 Signaler Partager Posté(e) le 18 mars 2021 Comment tu as grillé@TonyC Envoyé de mon BLA-L29 en utilisant Tapatalk 2 Lien vers le commentaire Partager sur d’autres sites More sharing options...
TonyC Posté(e) le 18 mars 2021 Signaler Partager Posté(e) le 18 mars 2021 Petit update, après quelques frayeurs le système est de nouveau opérationnel ! il vouait juste me faire une tite peur. Lien vers le commentaire Partager sur d’autres sites More sharing options...
TonyC Posté(e) le 18 mars 2021 Signaler Partager Posté(e) le 18 mars 2021 @mprinfo même pas Lien vers le commentaire Partager sur d’autres sites More sharing options...
fredokl Posté(e) le 18 mars 2021 Signaler Partager Posté(e) le 18 mars 2021 Grosses mise à jour! Lien vers le commentaire Partager sur d’autres sites More sharing options...
jjacques68 Posté(e) le 18 mars 2021 Signaler Partager Posté(e) le 18 mars 2021 pfiou !! y en a des choses !! Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 18 mars 2021 Auteur Signaler Partager Posté(e) le 18 mars 2021 J'ai fait la mise à jour, c'est passé du premier coup Lien vers le commentaire Partager sur d’autres sites More sharing options...
971jmd Posté(e) le 18 mars 2021 Signaler Partager Posté(e) le 18 mars 2021 moi aussi Lien vers le commentaire Partager sur d’autres sites More sharing options...
971jmd Posté(e) le 18 mars 2021 Signaler Partager Posté(e) le 18 mars 2021 quelle qu'un pourrai me rapper la fonction du panneau évènement merci d'avance Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) le 19 mars 2021 Signaler Partager Posté(e) le 19 mars 2021 Ils font bien évoluer la partie gateway, mais de HC2 en vue... Lien vers le commentaire Partager sur d’autres sites More sharing options...
971jmd Posté(e) le 19 mars 2021 Signaler Partager Posté(e) le 19 mars 2021 je trouve de meilleur performances avec la 5.070.42 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Domodial Posté(e) le 19 mars 2021 Signaler Partager Posté(e) le 19 mars 2021 Je n'ai plus les poubelles pour supprimer un dispositif ! et vous ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
Cardane Posté(e) le 19 mars 2021 Signaler Partager Posté(e) le 19 mars 2021 tu as cliqué sur l'icône "-" en rouge ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
Domodial Posté(e) le 19 mars 2021 Signaler Partager Posté(e) le 19 mars 2021 (modifié) Merci ! Mais ce n'était pas comme ça avant ?? je n'ai jamais cliqué sur - Truc de fou EDIT : ou alors peut etre un fois et ça avait gardé en mémoire.. (ps ça fait 4 fois que j'y touche à cette box ) Modifié le 19 mars 2021 par Domodial Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 19 mars 2021 Auteur Signaler Partager Posté(e) le 19 mars 2021 si si, ça a toujours été comme ça je crois bien ça le garde en mémoire tant que tu restes sur la page des dispositifs, si tu la quitte et que tu y retournes, il faut à nouveau cliquer sur le bouton "-" pour faire réapparaitre la corbeille. C''est une bonne petite sécurité je trouve (en plus du popup de confirmation) 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Kana-chan Posté(e) le 19 mars 2021 Signaler Partager Posté(e) le 19 mars 2021 Bonjour, Elle est longue à se mettre à jour ? Car la dernière LED clignote mais rien ne se passe de plus. Voilà ... Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 19 mars 2021 Auteur Signaler Partager Posté(e) le 19 mars 2021 J'ai pas chronométré, mais vu l'heure, tu devrais être l'apéro, faut pas perdre les bonnes habitudes acquises avec la HC2 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Kana-chan Posté(e) le 19 mars 2021 Signaler Partager Posté(e) le 19 mars 2021 OK, mais objectivement. Est-ce long ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 19 mars 2021 Auteur Signaler Partager Posté(e) le 19 mars 2021 A la louche je dirais environ 15 minutes (hors temps de téléchargement et backup préalable) Lien vers le commentaire Partager sur d’autres sites More sharing options...
henri-allauch Posté(e) le 19 mars 2021 Signaler Partager Posté(e) le 19 mars 2021 Pour Info : dans une scene : fibaro.alert("push", {2}, "Hello Henri") ( 2 = Id User ) fonctionne sur l'ensemble des mobiles dans un QA ce mode ne fonctionne plus aucun push ( pourtant il fonctionnait dans une précédente beta ) il faut : fibaro.alert("push", {22,43}, "Hello Henri") ( 22 et 43 Id des mobiles ) 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
ericl78 Posté(e) le 19 mars 2021 Signaler Partager Posté(e) le 19 mars 2021 Mise à jour effectuée RAS pour l'instant Lien vers le commentaire Partager sur d’autres sites More sharing options...
jjacques68 Posté(e) le 19 mars 2021 Signaler Partager Posté(e) le 19 mars 2021 il y a 17 minutes, henri-allauch a dit : fibaro.alert("push", {22,43}, "Hello Henri") ( 22 et 43 Id des mobiles ) c'est pas nouveau ça, si ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
henri-allauch Posté(e) le 19 mars 2021 Signaler Partager Posté(e) le 19 mars 2021 Il y a 15 jours en faisant un QA ca fonctionnait avec 2 ce soir non Pas grave on s'adapte 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
henri-allauch Posté(e) le 19 mars 2021 Signaler Partager Posté(e) le 19 mars 2021 (modifié) IL me semble qu'on dit bien sur le userID non ? Modifié le 5 mai 2021 par henri-allauch 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
jjacques68 Posté(e) le 19 mars 2021 Signaler Partager Posté(e) le 19 mars 2021 en effet, punaise, je me souviens pas de tout ce que je dis moi 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
