HC3 & HCL3 - 5.093.21 - BETA - 20/01/2022
TonyC
What's new:
Dashboard
Device state is now displayed on dashboard tile and sidebar for Base Shutter type devices.
Devices
Modified descriptions for device reconfiguration.**
Added info about needed waking up battery devices after requesting reconfiguration.**
Elero*
Possibility to use "Silent movement" in Scenes and Profiles for Elero RolMotion.
Nice*
Modified descriptions for device pairing process.
Reset/Reset all option added for device parameters configuration.
Adjusted list of supported notifications in device advanced configuration.
Changed model names of BiDi-Interface series devices.
Scenes
Creating scenes based on devices categories in Energy scenes.
Update
"Check for updates" button forces checking firmware update availability for devices.**
Bug fixes:
Cameras
Page refresh needed after saving camera configuration.
Dashboard
Unnecessary label "unknown" on Z-Wave shutters tiles.
Time does not update correctly in interface clock.
Devices
Disabling "Saving energy data to database" does not disable "Use stored energy".
Incorrect handling of "Save energy to database" and "Use stored energy in Energy Panel".
Possibility to disable "Saving energy data to database" for main energy meter.
Devices not visible currently on Settings page do not update their states correctly.
Graphs for FIBARO Thermostats (FGT-001) display incorrect setpoint values.
Cannot configure FGRGBWM-441 module in Input/Output mode.
Elero*
Device icon for Dimmer and Heater is not updated correctly.
Energy
Cannot remove data from main energy meter.
Energy cost calculation based on configured tariff works incorrectly.
Currency settings do not take effect without system reboot.
General
Setting the main energy meter does not enable saving energy data and using stored energy.
Network
Cannot connect to unprotected Wi-Fi network.
Other
Stability improvements related to "Serious problem detected" notification.
Changed translation for "Serious problem detected" notification.
Boot loop after updating to 5.092 Beta in some cases.
Plugins
In some cases Tedee Lock plugin loses connection with the device.
Profiles
Cannot set slider value for Quick Apps.
Quick Apps
Error 401 in the Mobile Application after opening a Quick App.**
fibaro.alert function does not work correctly.
Scenes
Average Consumption condition in Energy category does not work correctly.
Limits for Summary Balance conditions in Energy category are defined incorrectly.
Update
Cannot cancel Firmware Update process for battery device during "Waiting for wakeup".**
Voice Assistants
Issue with controlling thermostats from Alexa.
Known issues:
Z-Wave Engine 3.0
Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
Gateway connection is not available in the new Z-Wave engine version.
* - does not apply to HC3L (Home Center 3 Lite)
** - applies only to Z-Wave Engine 3.0
Mise à jour passée sans encombre sur ma box de test, reste à voir sur la durée.
Je n'ai jamais eu le message " Serious problem detected " dont tout le monde se plaint.
il y a 23 minutes, TonyC a dit :
Ce vieux bug, je l'avais oublié !
ça doit faire plus d'un an qu'il trainait.
Le 20/01/2022 à 22:12, TonyC a dit :
J'adore, en fait ils ont corrigé le problème en changeant le message d'erreur ?
:D
Donc le nouveau message d'erreur pourrait etre : "Votre HC3 a eu le covid, nous l'avons redémarré"
Modifié par ROBBEJP
En tout cas il y a eu une baisse significative du CPU utilisé.
On voit clairement le avant/après (sur ma box de test, donc peu d'activité, 1 seul module Z-Wave actuellement, surtout des QuickApps qui tournent en boucle) :
C'est à se demander si la box fait encore quelque chose tellement le CPU est bas !!
Modifié par Lazer
  • Like 3
il y a une heure, Lazer a dit :
Voilà pour moi, idem avec 69 modules connectés plus 15 scènes, des QAsss et cnx Jeedom
532936996_Capturedecran2022-01-22a13_13_18.thumb.png.18bf793adbf79faa3a4a9df9c30e85cd.png
Modifié par ericl78
