TonyC Posté(e) 20 janvier 2022 Signaler Share Posté(e) 20 janvier 2022 What's new: Dashboard Device state is now displayed on dashboard tile and sidebar for Base Shutter type devices. Devices Modified descriptions for device reconfiguration.** Added info about needed waking up battery devices after requesting reconfiguration.** Elero* Possibility to use "Silent movement" in Scenes and Profiles for Elero RolMotion. Nice* Modified descriptions for device pairing process. Reset/Reset all option added for device parameters configuration. Adjusted list of supported notifications in device advanced configuration. Changed model names of BiDi-Interface series devices. Scenes Creating scenes based on devices categories in Energy scenes. Update "Check for updates" button forces checking firmware update availability for devices.**Bug fixes: Cameras Page refresh needed after saving camera configuration. Dashboard Unnecessary label "unknown" on Z-Wave shutters tiles. Time does not update correctly in interface clock. Devices Disabling "Saving energy data to database" does not disable "Use stored energy". Incorrect handling of "Save energy to database" and "Use stored energy in Energy Panel". Possibility to disable "Saving energy data to database" for main energy meter. Devices not visible currently on Settings page do not update their states correctly. Graphs for FIBARO Thermostats (FGT-001) display incorrect setpoint values. Cannot configure FGRGBWM-441 module in Input/Output mode. Elero* Device icon for Dimmer and Heater is not updated correctly. Energy Cannot remove data from main energy meter. Energy cost calculation based on configured tariff works incorrectly. Currency settings do not take effect without system reboot. General Setting the main energy meter does not enable saving energy data and using stored energy. Network Cannot connect to unprotected Wi-Fi network. Other Stability improvements related to "Serious problem detected" notification. Changed translation for "Serious problem detected" notification. Boot loop after updating to 5.092 Beta in some cases. Plugins In some cases Tedee Lock plugin loses connection with the device. Profiles Cannot set slider value for Quick Apps. Quick Apps Error 401 in the Mobile Application after opening a Quick App.** fibaro.alert function does not work correctly. Scenes Average Consumption condition in Energy category does not work correctly. Limits for Summary Balance conditions in Energy category are defined incorrectly. Update Cannot cancel Firmware Update process for battery device during "Waiting for wakeup".** Voice Assistants Issue with controlling thermostats from Alexa.Known issues: Z-Wave Engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. Gateway connection is not available in the new Z-Wave engine version. * - does not apply to HC3L (Home Center 3 Lite) ** - applies only to Z-Wave Engine 3.0 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) 20 janvier 2022 Signaler Share Posté(e) 20 janvier 2022 Mise à jour passée sans encombre sur ma box de test, reste à voir sur la durée. Je n'ai jamais eu le message " Serious problem detected " dont tout le monde se plaint. il y a 23 minutes, TonyC a dit : Time does not update correctly in interface clock. Ce vieux bug, je l'avais oublié ! ça doit faire plus d'un an qu'il trainait. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Dragoniacs Posté(e) 20 janvier 2022 Signaler Share Posté(e) 20 janvier 2022 Ils enchaînent les beta.... Bientôt une version stable ?Envoyé de mon M2012K11AG en utilisant Tapatalk Lien vers le commentaire Partager sur d’autres sites More sharing options...
mprinfo Posté(e) 21 janvier 2022 Signaler Share Posté(e) 21 janvier 2022 Oui vivement une stable car je sais pas ce que j'ai fais lors de mes recovery. Mais j'ai plus de système B. Donc condamné à utiliser une bêta [emoji24]Envoyé de mon BLA-L29 en utilisant Tapatalk Lien vers le commentaire Partager sur d’autres sites More sharing options...
ericl78 Posté(e) 21 janvier 2022 Signaler Share Posté(e) 21 janvier 2022 Mise à jour effectuée, RAS pour l'instant, à suivre ... Lien vers le commentaire Partager sur d’autres sites More sharing options...
ROBBEJP Posté(e) 22 janvier 2022 Signaler Share Posté(e) 22 janvier 2022 (modifié) Le 20/01/2022 à 22:12, TonyC a dit : Stability improvements related to "Serious problem detected" notification. Changed translation for "Serious problem detected" notification. J'adore, en fait ils ont corrigé le problème en changeant le message d'erreur ? Donc le nouveau message d'erreur pourrait etre : "Votre HC3 a eu le covid, nous l'avons redémarré" Modifié 22 janvier 2022 par ROBBEJP Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) 22 janvier 2022 Signaler Share Posté(e) 22 janvier 2022 (modifié) En tout cas il y a eu une baisse significative du CPU utilisé. On voit clairement le avant/après (sur ma box de test, donc peu d'activité, 1 seul module Z-Wave actuellement, surtout des QuickApps qui tournent en boucle) : C'est à se demander si la box fait encore quelque chose tellement le CPU est bas !! Modifié 22 janvier 2022 par Lazer 3 Lien vers le commentaire Partager sur d’autres sites More sharing options...
ericl78 Posté(e) 22 janvier 2022 Signaler Share Posté(e) 22 janvier 2022 (modifié) il y a une heure, Lazer a dit : En tout cas il y a eu une baisse significative du CPU utilisé. On voit clairement le avant/après (sur ma box de test, donc peu d'activité, 1 seul module Z-Wave actuellement, surtout des QuickApps qui tournent en boucle) : C'est à se demander si la box fait encore quelque chose tellement le CPU est bas !! Voilà pour moi, idem avec 69 modules connectés plus 15 scènes, des QAsss et cnx Jeedom Modifié 22 janvier 2022 par ericl78 Lien vers le commentaire Partager sur d’autres sites More sharing options...
flacon030 Posté(e) 22 janvier 2022 Signaler Share Posté(e) 22 janvier 2022 idem avec 80 modules Lien vers le commentaire Partager sur d’autres sites More sharing options...
Dragoniacs Posté(e) 22 janvier 2022 Signaler Share Posté(e) 22 janvier 2022 Mise à jour faite, ça ronronne....Envoyé de mon M2012K11AG en utilisant Tapatalk Lien vers le commentaire Partager sur d’autres sites More sharing options...
couillerot Posté(e) 23 janvier 2022 Signaler Share Posté(e) 23 janvier 2022 RAS également de mon côté ! Stef Lien vers le commentaire Partager sur d’autres sites More sharing options...
jjacques68 Posté(e) 23 janvier 2022 Signaler Share Posté(e) 23 janvier 2022 Idem, RAS de mon côté... Et CPU divisé par 2 alors qu'elle bosse... plutôt beaucoup Lien vers le commentaire Partager sur d’autres sites More sharing options...
