HC3 & HCL3 - 5.100.22 - Stable - 01/02/2022
HC3 & HCL3 - v 5:100:22 stable- 22/12/2021
Main features:
1. Improvements for Energy Panel
2. Block Scenes related to Energy Panel
3. Bug fixes and improvements for Elero and Nice devices
4. A new, user-friendly wizard for adding Elero devices
5. Configuration of favourite positions in device settings Advanced tab
What's new:
Access
- Possibility of setting another PIN to be used for integrations in user's alarm settings.
- Mobile device status indication.
Dashboard
- Device state is now displayed on dashboard tile and sidebar for Base Shutter type devices.
- Distinction of actions sent on click and hold & release of open/close buttons.
- New icon of unavailable device.
- Distinction of actions sent on click and hold of the slat rotation button.
- Support for holding the level change button on device sidebar.
- Favourite positions buttons available on device sidebar.
Devices
- Modified descriptions for device reconfiguration.**
- Added info about needed waking up battery devices after requesting reconfiguration.**
- Disabled logging energy consumption for hidden root endpoints of the device.
- Separated configuration of saving energy to database from using data in energy panel.
- New com.fibaro.multiPositionSwitch device type support.
- Support for MCO MH3901-Z version 2.1.
- Support for Heiman Gas Sensor (HS1CG) version 1.1 & 1.2.
- Possibility of enabling inversion in device Advanced tab for blinds/shutters/gates etc.
- Improved and unified support of device control types.
- New default icons for switches, dimmers, shutters, gates, and garage doors.
- Added icons for missing device states (favourite positions, brightening, dimming, etc.).
- Devices of the com.fibaro.baseShutter type available in the Blinds linked device.
- Improved detecting if device is awake and checking its wake-up interval.**
- Added missing support for FIBARO Roller Shutter 2 FGRM-222.**
- Support for Donexon Pro Z-Wave thermostat.
- Reinterview process optimisation.**
Elero*
- Possibility to use "Silent movement" in Scenes and Profiles for Elero RolMotion.
- Possibility to skip waiting for limit switch report when setting the favourite position.
- Possibility to retry configuration of favourite position after passing the desired level.
- Possibility of re-editing the device configuration during the adding wizard.
- Forced polling of added device after finishing its configuration.
- Forced polling of the device after setting favourite position.
- Synchronous pairing of Elero devices in Nice/Elero settings.
- Displaying manufacturer, model, and version in device settings.
- Silent move feature when used in scenes for Elero RolMotion device.
- Configuration of device name, assignment, and its type as a part of pairing process.
- Possibility of pairing multiple devices of different types in one process.
- Testing the device detected during the pairing process to allow its identification.
- Inversion feature enabled by default for devices detected as awnings.
- Support for controlling the slats position.
- Support for alarms and notifications.
- Possibility of configuring favourite positions.
- Possibility of changing the device role.
- Possibility of forcing the device polling.
- Support for Elero Unio-868, Combio-868 HE, and Combio-868 LI.
Energy
- History tab in Panel Settings allowing to remove energy data.
- Possibility of adding additional costs in Expenses tab of Panel Settings.
- Redesigned interface of setting the installation cost in Panel Settings.
- Overall costs added in Expenses tab are considered when calculating returns.
- Graphical representation of configured rates in Tariff tab of Panel Settings.
- Marking the same time ranges when comparing two periods in Savings tab.
- Improvements for displaying charts in Savings tab.
- New Ecology tab for ecu-enthusiasts and everyone who produces energy.
- Displaying self-sufficiency level, equivalent trees planted, and CO2 reduction.
- Animated graphs of achievements and their impact on the environment.
- Possibility of setting the return rate in Panel Settings.
- Calculation of already returned installation cost including set return rate.
- Redesigned interface for configuring additional rates in Tariffs.
Network
- Access Point remains enabled after finishing FTI if no network is connected.
Nice*
- Modified descriptions for device pairing process.
- Reset/Reset all option added for device parameters configuration.
- Adjusted list of supported notifications in device advanced configuration.
- Changed model names of BiDi-Interface series devices.
- User-friendly names and tooltips for Nice device adding mode configuration dialog.
- Displaying manufacturer and model in device settings.
- Improved and unified support of Nice Mono devices.
- Global abort for all types of binding procedures.
Notifications
- Notifications set in device settings may be sent only to specified users.
Other
- Ability to call device actions, scenes and emit custom events via GET method of HTTP API.
- Updated translations.
Quick Apps
- Expanded list of available binary sensors.
- Added os.clock library.
- Possibility of adding custom icon for all single-state devices (players, remotes, etc.).
Scenes
- New category of block scenes - Energy.
- Creating scenes based on devices categories in Energy scenes.
- Creating scenes based on summary consumption/production/balance of energy.
- Creating scenes based on energy consumed by given device/room/category.
- Creating scenes based on active rate of tariff.
- Support for os.clock function that returns the time of CPU required for the program.
Update
- "Check for updates" button forces checking firmware update availability for devices.**
- Expanded view of available device firmware update.**
- Displaying detailed device update process status.**
Bug fixes:
Alarm
- Alarm partitions (com.fibaro.alarmPartition) are not available as zones in alarm panel.
Cameras
- Page refresh needed after saving camera configuration.
Dashboard
- Unnecessary label "unknown" on Z-Wave shutters tiles.
- Time does not update correctly in interface clock.
- Holding the button on device sidebar does not work in mobile app.
Devices
- Disabling "Saving energy data to database" does not disable "Use stored energy".
- Incorrect handling of "Save energy to database" and "Use stored energy in Energy Panel".
- Possibility to disable "Saving energy data to database" for main energy meter.
- Devices not visible currently on Settings page do not update their states correctly.
- Graphs for FIBARO Thermostats (FGT-001) display incorrect setpoint values.
- Cannot configure FGRGBWM-441 module in Input/Output mode.
- Device polling time interval displays incorrectly.
- Main energy meter energy consumption is not displayed in device advanced tab.
- FIBARO Smart Implant central scene support does not work correctly.
- Removed the polling interface where not applicable.
- Possibility to run multiple times an active device update process.**
- Cannot save value of parameter added manually.**
- Incorrect inputs support of FIBARO RGBW Controller.
- Device icons do not update properly when switching tabs.
- Icon of gate with positioning is not set automatically.
- Cannot download device template.
- Device properties and its interfaces are removed after the soft reconfiguration.
- Soft reconfiguration of the device removes it from the linked device.
- Maximum value reported by the sensor connected to analog input is limited to 4 digits.
- In some cases, com.fibaro.baseShutter type device lose its configuration.
- Incorrect setpoint temperature range for some thermostats.
- Attempt to update firmware of some battery devices always fails.
- Node provisioning list is not available.**
- No power charts for power meters (com.fibaro.powerMeter).
Elero*
- Device icon for Dimmer and Heater is not updated correctly.
- In some cases, one device is not paired when pairing multiple devices.
- Cannot stop pairing process after occurrence of timeout.
- Redundant stop button for rotating slats.
- Incorrect default polling time interval.
- Device is too early marked as dead but remains available.
- Number of devices is not updated after removing the device.
- In some cases, adding one device after another results in error.
- In some cases, adding previously removed device is not possible.
- Device polling is not stopped after performing action.
- No Notifications tab.
Energy
- In some cases, no energy data after updating from 5.090 to any beta version.
- Cannot remove data from main energy meter.
- Energy cost calculation based on configured tariff works incorrectly.
- Currency settings do not take effect without system reboot.
- No possibility to change filter after filtering room or category with no data.
- Invisible labels in Ecology tab when using dark theme.
- Incorrect plant equivalent chart value.
- No validation for entering negative values of measured energy.
Gateway Connection
- Icon changed for device added to slave gateway is not saved.
- Updating device added to slave is terminated by updating device added to master.
- Resetting the Z-Wave network is applied only to master gateway.
- Favourite position of device added to slave gateway is not saved.
- Incorrect update status of slave gateways.
- Rebooting the master gateway always results in sending devices model to slaves.
- Firmware update possibility disappears for devices added to slaves.
General
- Setting the main energy meter does not enable saving energy data and using stored energy.
History
- Events are displayed even though saving events to history was disabled.
Network
- Cannot connect to unprotected Wi-Fi network.
- In some cases, Wi-Fi network disconnects and does not reconnect automatically.
Nice*
- No user icons for Nice Mono devices after updating from 5.090 to any beta version.
- Some Nice Mono devices have incorrect device type after performing update.
- No possibility to close the adding dialog while binding new device.
- Scene triggered by Mono remote does not control Mono shutter.
- In some cases, adding a new device is aborted before finishing the process.
- No parameters after adding a device with parameters interface.
- Device added on previous versions has its parameters disabled after performing update.
- In some cases, clicking on remotes while binding is not always detected.
- Redundant requests during device creating process.
- No device calibration for BiDi Dimmer device.
- Cannot bind new gate using its remote.
- Incorrect default polling time value.
Notifications
- Fixed titles of notification templates about opening/closing.
- System migration notification is restored and created after each reboot.
Other
- Issue with migration from HC2 resulting in no devices in the mobile app.
- Stability improvements related to "Serious problem detected" notification.
- Changed translation for "Serious problem detected" notification.
- Boot loop after updating to 5.092 Beta in some cases.
- Possibility of entering into inoperable recovery mode via remote access.
- In some cases recovery mode is not fully loaded.
- Some HTTP requests do not require authentication.
Plugins
- In some cases Tedee Lock plugin loses connection with the device.
- Fixes for Philips Hue plugin related to speed of adjusting brightness.
- Fixes for Tedee plugin related to unexpected disconnection.
- Fixes for Fibaro Heat Activator plugin.
- Recording feature in FIBARO Intercom plugin does not work.
Profiles
- Cannot set slider value for Quick Apps.
- In some cases, switching the profile results in an error.
- Some Elero devices are not available in profiles.
Quick Apps
- Issue with displaying Quick Apps in the mobile app for some regions.
- Error 401 in the mobile app after opening a Quick App.**
- fibaro.alert function does not work correctly.
- Connection does not close when using http client.
Scenes
- Average Consumption condition in Energy category does not work correctly.
- Limits for Summary Balance conditions in Energy category are defined incorrectly.
- Removing device used in the middle of the scene results that scene does not fully run.
- No possibility to define multiple values in the date field.
Update
- Cannot cancel Firmware Update process for battery device during "Waiting for wakeup".**
Voice Assistants
- Issue with controlling thermostats from Alexa.
Known issues:
Z-Wave Engine 3.0
- Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
- Gateway connection is not available in the new Z-Wave engine version.
* - does not apply to HC3L (Home Center 3 Lite)
** - applies only to Z-Wave Engine 3.0
  • Like 2
update fait RAS pour l'instant...
par contre je ne pige pas pourquoi je ne vois pas :
- Configuration of favourite positions in device settings Advanced tab
qui doit être lié à :
ça alors que ça devrait être bien visible :
il doit probablement y en avoir d'autre le changelog est long...
J''ai vidé mon cash utilisé un autre browser mais rien, Si quelqu'un pouvait confirmé ?
Déjà ? ils sont allé vite dites donc :13:
il y a une heure, TonyC a dit :
J''ai vidé mon cash
Quoi ? Sans nous prévenir ? Et tu ne l'a même par partagé avec les membres du forum ?
:98:
  • Like 2
  • Haha 1
Plus sérieusement : ce sont des nouveautés des précédentes beta.
Les positions favorites, c'est pour les multilevelswitchs (dimmer, volets), pour préenregistrer des positions intermédiaires (50%, etc) et les utiliser facilement en 1 clic sans devoir manuellement glisser le slider à chaque fois.
  • Thanks 1
Il y a juste un petit bug qui existe depuis version les bêta précédentes
la valeur des arbres planté ne s'affiche pas ((valeurs)) arbre(s) alors que j'en ai 6 sur le graphique
Quelqu'un peu me dire si surveillance station fonctionne ?
Car avec les bêta la création des childs plantaient
On en parlait lors de la beta, la consommation CPU a baissé avec ce nouveau firmware (visible sur le taux d'occupation global du processeurs (4 cœurs) de la box)
Concrètement, pour les QuickApps, ça se traduit par un temps CPU consommé plus faible, donc je suppose de meilleures performances (il faudrait faire tourner un benchmark pour s'en assurer...)
Exemple avec le QuickApp Xiaomi Roborock Vaccum, qui est assez consommateur de CPU à cause des calculs de chiffrement à effectuer pour le protocole de communication avec l'aspirateur robot.
C'est exactement la même version du QA sur mes 2 box, la production tourne avec le firmware 5.070.42 (c'est vieux), et la test en 5.100.22.
A la louche, environ 20% plus rapide, c'est significatif :)
  • HC3 v5.070.42 :
  • HC3 v5.100.22 :
Le 01/02/2022 à 18:39, Cardane a dit :
@mprinfo fait mais je ne sais pas si c'est valable pour la HCL3, je ne vois l'info nulle part (et j'ai pas de HCL3)
Oui c'est valable aussi pour la HC3L ;)
Merci pour ce topic :P
Et voilà, je viens de faire la mise à jour sur ma box de production.
Un peu long... plusieurs longues minutes, mais c'est passé et tout fonctionne.
Ne pas oublier le célèbre vidage de cache après la mise à jour (CTRL+F5 suffit)
J'étais en 5.070, donc depuis mars 2021, soit 11 mois !
Je vais pouvoir profiter des nouveautés.... espérons que cette version 5.100 stable soit vraiment stable :)
@Lazer tu as oublié de dire qu'avant de faire cette mise à jour il a fallu que tu modifies le code de certains QA pour que cela ce passe bien. C'est l'avantage d'avoir une box de test
J'ai modifié des QA, mais ce n'était pas une condition nécessaire pour cette mise à jour.
Ce qui m'a retenu tout ce temps, c'était les instabilités (reboot, serious problem detected, ...), qui semblent avoir été résolues avec cette mise à jour.
Car la 5.070 était vraiment très stable. Seul problème non bloquant, des freeze de temps en temps... on verra si ceux-là sont toujours présents avec la 5.100 ou non.
Ce que je voulais dire c'est que certains script on besoin d'être mis à jour pour que cela fonctionne avec cette version
Comme par exemple le QA surveillance station
Je sais que pour toi ce n'était pas un problème. Je le précise juste pour ceux qui vont lire ce topic
