HC3 & HC3L - 5.140.17 - Stable - 02/03/2023
Lazer
Firmware HC3 & HC3L
Version 5.140.17
Stable
Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Main features:
1. New way of controlling devices from Dashboard sidebar
    Completely redesigned control of color controllers.
    Support of color temperature setting for the Zigbee devices.
2. New predefined scenarios designed to control lights based on time conditions and gates status
What's new:
Climate
    Added possibility to assign temperature sensors for climate zones.
Dashboard
    Possibility to add devices from the dashboard.
    Added battery level indicators on devices tiles.
Devices
    Optimised procedure for adding devices for all protocols.
    Improved UI/UX and performance for device page filters.
    Added filters clearing mechanism when leaving the page.
    Added the description field for every device type.
    Redesigned family of devices view.
Energy
    Modified page layout for energy meters configuration in panel settings.
Gateway connection
    Added an option to define Slave IP address manually.
    Added additional redundancies for unexpected changes in network configuration.
Nice*
    Improved support for OXIBD status updates.
    Added generic support for legacy Bidirectional shutters.
    Improved support for device specific notifications.
Other
    Improved algorithm for gateway overheating notifications.
    Minor UI/UX improvements.
Plugins
    Added support for pulling the latch for the Tedee door lock.
    Improvements for Heat Activator plugin.
Quick Apps
    Added support for the Base Shutter device type.
Scenes
    Added the filters for Scenes page.
    Added "tolerance" option for Energy Panel block scenes.
    Improved blocks content loading performance for large systems.
    Added the description field for every scene type.
    Changed the order of steps for Scenarios.
Update
    Added possibility to update all devices.
    Added additional warning before upgrading to the beta version of the hub.
Zigbee
    Improved generic support for lights and color controllers.
Z-Wave
    Added handling of suspended device interview during the adding procedure for battery-powered devices.**
    Support for different revisions of the Aeotec Multisensor 6.
    Support for the ZW800 series MCO IR2900 thermostat.
    Support for the Everspring SP103.**
Bug fixes:
Climate
    The zone control freezes if the last setpoint is set at 5:00am.
Dashboard
    Redundant page refresh in some cases (introduced in 5.131 beta).
Devices
    Issues with the display of some configuration parameters values.
Elero*
    The RolSolar device is incorrectly marked as disconnected.
    Using favorite positions in group actions does not work.
    Excessive battery drain for the RolSolar shutter.
Energy
    Energy charts are malformed occasionally.
    Negative energy consumption data in the panel after clearing the energy data in some cases.
    Negative power consumption values for "Grid consumption" setting in some cases.
FTI
    No masking of Wi-Fi password during the first configuration on Firefox.
Gateway Connection
    Connection issues in specific network configurations.
    In some cases the system does not boot correctly when the master gateway update fails.
Nice*
    Losing possibility to control devices in some cases.
    Fixed issue with binding some mono-directional devices.
    Custom icons for mono-directional devices not visible.
    Issues when pairing new models of roller shutter with BiDi protocol.
Other
    Added possibility to enable remote access for support from recovery system.
    Standard user cannot remove interactive push.
    Issues with controlling the linked-device thermostat in some configurations.
    System crash while deleting a non-existing notification.
    Wrong time in history after the change from winter time to summer time.
    Adding more than one Other device by clicking the add button excessively.
    The state of devices is not refreshed when pressed run scene button without refreshing the page.
    Other UI/UX fixes.
    System stability fixes  (introduced in 5.131 beta).
    Incorrect radius instead of diameter in the Location tab.
Plugins
    Lack of live preview for Helios 2N plugin.
    Tedee lock plugin loses connection to services (introduced in 5.131 beta).
Profiles
    Incorrect display of climate panel settings.
    Incorrect display of sliders in profiles settings.
Quick Apps
    Secret variable value visible in the webUI after saving.
Scenes
    Elero RolMotion blind is controlled even if excluded from a simple scenario.
    Incorrect display of sliders in block scenes.
    Cannot edit Scenarios via mobile app in remote connection.
    No possibility to enter exact minutes in no later/earlier fields in scenarios (introduced in 5.131 beta).
    The filter in the room drop-down menu does not work properly (introduced in 5.131 beta).
Zigbee
    Wrong time unit during the adding process.
Z-Wave
    No possibility to update Z-Wave devices added in Security mode.
    Lack of handling unsolicited reports from devices using CC Basic.**
    Issues with updating devices from file in some cases.**
    Incorrect default role for the Zooz ZAC36 valve.
    Improved adding procedure when using S2U security level.**
    The exclusion process cannot be closed after an error has occurred.
Known issues:
Z-Wave Engine 3.0
    Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
    Gateway connection is not available in the new Z-Wave engine version.
*  - does not apply to HC3L (Home Center 3 Lite)
** - applies only to Z-Wave Engine 3.0
  • Thanks 2
Impressionnant le code pour éteindre toutes les lumières
api.post("/devices/groupAction/turnOff",
  json.decode("{\"filters\":[{\"filter\":\"or\",
    \"value\":[{\"filter\":\"isTypeOf\",\"value\":[\"com.fibaro.binarySwitch\",
    \"com.fibaro.remoteBinarySwitch\"]}]},
    {\"filter\":\"or\",
      \"value\":[{\"filter\":\"propertyEquals\",
      \"value\":[{\"propertyName\":\"deviceRole\",
      \"propertyValue\":[\"Light\",\"NightLamp\",\"GardenLamp\",\"Bracket\",\"Rgb\",\"Rgbw\"]}]}]}
      ,{\"filter\":\"visible\"
        ,\"value\":[\"true\"]}]}"))
MAJ ok hier mais j'ai une question annexe ...
Ca fait 2 fois que mon dashboard local change de port :42 puis :43 et ce matin impossible sur le 43, et bim le 44: fonctionne ...
C'est lié aux MAJ de la box ? C'est connu ? suis-je le seul ? Comment faites vous, sans allez sur votre routeur pour retrouver votre gateway ?
Merci ;)
Je n'a pas compris ta question.... le port, c'est toujours 80 (http), ou 443 (https), et il ne change jamais.
Ce ne serait pas plutôt l'adresse IP dont tu parles ?
Dans ce cas, le mieux est de fixer l'IP.
Soit depuis ton serveur DHCP (la box internet), ou mieux encore, directement dans la box domotique (Réglages > Réseau)
Je rencontre un soucis avec cette version
le probléme rencontré et lors du démarrage de la box si on a une scéne en autostart qui appel l'api cela retourne un json vide
la solution pour contourner ce probléme et de mettre un sleep de quelques secondes au début de la scéne
ça fait pareil avec les QuickApps ?
Dans tous mes QuickApps, j'avais pris pour habitude de mettre un timeout de quelques secondes avant le démarrage de la main loop, j'ai été bien inspiré :D
Pour les Quickapp je ne sais pas
Ce qui m'a mis la puce à l'oreille pour les scènes c'est la scène qui averti le démarrage de la box qui me retourne un nil à la place du numéro de série
Cette fois, je fais cette m.à.j. La dernière était la 5.120.10 ...
@Lazer, je note le timeout au debut des Main de QA !
(je suppose que c'est pour favoriser l'initialisation des paramètres (dont les variables) de la QA).
+ 1h : mise à jour effectuée, reboot sans souci !
Modifié par Sowliny
m.à.j.
La vraie raison du timeout au début de mes QA, c'est parce que j'en ai beaucoup, et au boot de la box il est inutile qu'ils se déclenchent tous au même moment, créant un pic de surcharge.
Temporiser de quelques secondes ne peut que faire du bien.
Moins le QA est important, plus la tempo est longue.
Et si tu prends tous les QA qui ont un cycle de 60 secondes, ça fait un pic de charge toutes les minutes.
Là encore, décaler le pic de charge au démarrage, permet également d'éviter le pic de charge récurrent toutes les 60s.
Merci pour la précision - très logique.
J'utilisais le principe anciennement sur ma HC2.
Mais sur la HC3, pour le moment, jusque là,
j'évite d'accumuler trop de process simultanément.
Bizarre, bizarre...
Je viens de vérifier, et je confirme.
Plus aucun point d'interrogation, que ce soit dans le "Tableau de bord", ou dans les pièces.
Ma procédure de m.à.j de la HC3 (rien que du classique) :
- sauvegarde locale
- sauvegarde cloud
- mise à jour et reboot (automatique).
Pas non plus de m.à.j de l'appli disponible sur le PlayStore (je suis actuellement en 1.18.0).
J'avais juste reçu la notification de la mise à jour vers la 5.140.17 dans l'app. Yubii. Que j'ai poliment déclinée, car j'ai préférer opérer à partir de mon PC.
Modifié par Sowliny
correction
La mise à jour 1.18 de l'application mobile Yubii a été publiée il y a quelques jours, et corrige normalement le bug des icônes, ce n'est pas lié à la version du firmware de la box (je suis encore sur une vieille version)
On en parle ici :
J'en tombe... !
Je n'ai pas souvenir d'avoir fait cette mise à jour de l'appli. Ou alors... mais dans ce cas ça m'inquiète :(
A moins qu'elle n'ait été automatique ?
Comme je me dis que ce n'est jamais le cas, ça renforce mon inquiétude :(
Je voulais justement aller faire un tour sur le sujet...
Quoi qu'il en soit, la correction est efficace.
Modifié par Sowliny
