V4.036 - 13-03-2015
Moicphil
 mise à  jour HC2 > 4.036
> Added Device Support:
Zipato RGBW Bulb
QEES Dimmer UNI 400W
> Resolved Issues:
#0002797: Not possible to enter "rooms" section!
#0002830: Devices with no template cannot save parameters.
#0002335: Zipato RGBW Bulb
#0002857: TypeError: undefined is not an object (evaluating 'r.isTypeOf')
#0002234: sceneActivation doesn't trigger with Zwave.me KeyFob in 4.022
#0002980: No Template for Fibaro FGSD-002
Unjustified push alarms about fire
Improved support for Fibaro Smoke Sensor
UBS Temperature is not visivble on iPhone/iPad client (was known issues)
> Known Issues:
After the update clearing browser cache could be required
Power Mettering may not work properly for some devices
RGBW Controler may not work propery when used in in/out mode
Alarm Panel doesn't work in some specific configurations
Plugins for TV Sets of various manufacturers may not work with its newes firmware due to restricions provided by new devices firmware. There will be added detalied information about suported firmwave versions within plugins.
Satel - adding plugin progress bar disappears during configuration. Please wait about 15 minutes before performing actions on Satel devices.
Devices Polling may not work properly - devices state in UI may be refreshed only after action taken.
Breached sensor with Arm Delay causes instant alarm after being armed
Data range selection in event panel doesn't work properly
Devices imported via Gateway Connection may have no icons
Gateway Connection status of dead device between master and slave controller may be different
Devices not properly configured on 3.X may not be converted properly
Reconfiguration may not work properly in some cases
On mobile clients devices may be visible in different categories than configured
Advanced settings for some imported devices may not work properly
Horstmann Thermostat HRT4-ZW higher battery usage in some cases
Doorlocks some functions may not work properly
  • Upvote 2
Bonjour à  Tous,
a chaque changement de version, a chaque fois, dans les modules virtuel, j'ai des "" qui se mettent dans l'adresse ip.... Du coup il ns ne fonctionnent plus et je dois les retirer module par module.... Quelqu'un à  une solution?
Sébastien
Toujours pas de template pour Qubino FP... mais aussi pour interrupteur SwiidInter et .... Smoke Sensor 2 (FGSD-002)
ni pour Aeon-Labs
Modifié par Moicphil
Bonjour, inutile de citer le message situé juste au dessus.
Je le fais tout le temps le vidage de cache, mais là  cela persiste. Seul solution pour le moment, me connecter sur l'interface anglaise...
EDIT : Après reboot de la HC2 et revidage du cache, c'est ok... Chelou, jamais eu ça, pourtant j'en ai fais des mises à  jour :)
Je suppose que tu utilises FireFox, ce navigateur a sa propre définition du cache, et sa façon d'ignorer les demandes de rafraichissement de l'utilisateur.
Bonjour, merci de ne pas citer un message situé juste au dessus.
Je vois dans les problèmes résolus : #0002980: No Template for Fibaro FGSD-002
Je vais donc regarder de plus près des infos contradictoires :
- j'obtiens le message "L´appareil ne dispose pas d´un modèle ce qui pourrait avoir des fonctionnalités limitées, veuillez contacter le support technique afin d´ajouter le modèle de ce dispositif."
- j'ai la liste des paramètres. Mais je les avais saisies à  la main hier, sans les voir apparaître ? ... et comme ils ont résolus le point suivant "#0002830: Devices with no template cannot save parameters"
A suivre
Tiens, suite à  cette mise à  jour, j'ai une alerte me disant que certains modules (Fibaro) n'ont pas de template.
Je cherche comment résoudre cela.
Un conseil amical : découvrir le forum, n'hésites pas à  chercher....  ;)
Voici la réponse à  ta question : ICI
Une précision : un bon nombre de demandes d'intégration de modules ont déjà  été faites à  Fibaro
Il s'agit de presque tous (mais pas tous étrangement) mes capteurs d'ouverture de porte FGK-103, d'une télécommande 4 boutons Aeonlabs et de mes WallPlug FGWPE-101.
Il n'y a qu'après la mise à  jour que cette alerte de manque de template est apparue.
J'avoue que je ne sais pas bien comment se gèrent ces templates, donc je n'ai pas ce qu'il faut pour comprendre de quelle façon ils auraient pu disparaitre de la box, à  moins d'une erreur lors de la mise à  jour.
