HANSOLO 381 Signaler ce message Posté(e) 3 août 2015 à‡a dort sur le forum! Dear Users, We just released version 4.054 for Home Center Lite. It is available for versions 4.041 and newer. This version fixes some of issues reported by users.4.054:> New Devices Support:- MCO MH8-FC-EU- MCO MH8-FC4- MCO MH6-HP- AEON LABS Siren GEN5> Resolved Issues:- Fixed Multi Channel Association Support for versions 2.4 and 2.5 of Fibaro Wall Plug - soft reconfiguration required- Shedule based activities (e.g. panels) improvements- Fixed General page issue, regarding temperature thresholds and main sensors> Known issues:- Using multichannel associations requires soft reconfiguration of devices- Android version of the Fibaro mobile app does not display icons for following devices properly: - NetAtmo Thermostat - NetAtmo Weather Station - Sonos- Inconsistencies in Satel interface.- Power Metering may not work properly for some devices- Alarm Panel doesn't work in some specific configurations- Plugins for TV Sets of various manufacturers may not work with its newer firmware due to restrictions provided by new devices firmware. There will be added detailed information about supported firmware versions within plugins.- Breached sensor with Arm Delay causes instant alarm after being armed- Data range selection in event panel doesn't work properly- Devices imported via Gateway Connection may have no icons- Gateway Connection status of dead device between master and slave controller may be different- On mobile clients devices may be visible in different categories than configured- Horstmann Thermostat HRT4-ZW higher battery usage in some cases- Doorlocks some functions may not work properly 1 Partager ce message Lien à poster Partager sur d’autres sites
Fredric 297 Signaler ce message Posté(e) 3 août 2015 je l'ai aussi sur le HC2 1 Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 148 Signaler ce message Posté(e) 3 août 2015 Yes, dispo en HC2. Cela règle le bug des sensors principaux. Mais bon, la flemme de la mettre juste pour ça, sinon il faut que je me retape mes VS... Partager ce message Lien à poster Partager sur d’autres sites
Fredric 297 Signaler ce message Posté(e) 3 août 2015 j'ose pas, ça tourne tellement bien en ce moment Partager ce message Lien à poster Partager sur d’autres sites
Syris 16 Signaler ce message Posté(e) 3 août 2015 N'ayant pas encore refait mes VS, je l'ai faite, mais sa ne m'a pas résolu l'histoire des capteurs principaux. EDIT : Après une sauvegarde manuel, sa c'est mis a fonctionner ???... Partager ce message Lien à poster Partager sur d’autres sites
jojo 2 608 Signaler ce message Posté(e) 3 août 2015 @Halonso, peux-tu modifier le premier topique : c'est pour HC2 (et peut-être HCL ?) @mprinfo : ton sondage devient obsolète ... il faudrait pouvoir rajouter des versions et modifier ses votes. Partager ce message Lien à poster Partager sur d’autres sites
trainkill666 70 Signaler ce message Posté(e) 3 août 2015 Que signifie "Fixed Multi Channel Association Support for versions 2.4 and 2.5 of Fibaro Wall Plug" or traduction direct ? Partager ce message Lien à poster Partager sur d’autres sites
HANSOLO 381 Signaler ce message Posté(e) 3 août 2015 (modifié) @Halonso, peux-tu modifier le premier topique : c'est pour HC2 (et peut-être HCL ?) Visiblement comme pour les sondages je ne peux pas modifier le titre (j’édite bien le premier message) ah si en passant par l'éditeur complet. Modifié 3 août 2015 par HANSOLO Partager ce message Lien à poster Partager sur d’autres sites
Did 1 722 Signaler ce message Posté(e) 3 août 2015 C'est peut-être pour moi demain? Partager ce message Lien à poster Partager sur d’autres sites
Titof_44 30 Signaler ce message Posté(e) 3 août 2015 N'ayant pas encore refait mes VS, je l'ai faite, mais sa ne m'a pas résolu l'histoire des capteurs principaux. EDIT : Après une sauvegarde manuel, sa c'est mis a fonctionner ???... +1. Merci Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 332 Signaler ce message Posté(e) 3 août 2015 J'ai mis 4.05x Envoyé de mon SM-G900F en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
chrispec 31 Signaler ce message Posté(e) 3 août 2015 Mise à jour lancée ... 45 minutes bloqué sur l'installation ... puis accès ... et donc 4.054. RAS pour le moment! Partager ce message Lien à poster Partager sur d’autres sites
Rem's 59 Signaler ce message Posté(e) 4 août 2015 Je ne sais si je vais faire cette MAJ tout de suite, mais en tout cas, je trouve que Fibaro a considérablement stabilisé et améliorer cette version. Perso, j'ai beaucoup moins de problème avec l'ensemble de mes modules, ZXT , minimote, Green Wavre, ... Ces release ne génère non plus pas de nouveau problème !!! Faudrait que je fasse un post intitule tout va bien, car pour une fois on ne peut pas leur enlever ca et reconnaître leurs efforts ces derniers mois. Merci M. FIBARO !!! 1 Partager ce message Lien à poster Partager sur d’autres sites
pepite 1 272 Signaler ce message Posté(e) 4 août 2015 Mise àjour effectuée et OK pour moi pour le moment ;-) Partager ce message Lien à poster Partager sur d’autres sites
Did 1 722 Signaler ce message Posté(e) 4 août 2015 Le scoop du jour: La mise à jour est lancée... toujours à 20%. 1 Partager ce message Lien à poster Partager sur d’autres sites
pepite 1 272 Signaler ce message Posté(e) 4 août 2015 suspens, le support bosse sur ta HC2, bonne nouvelle Partager ce message Lien à poster Partager sur d’autres sites
i-magin 864 Signaler ce message Posté(e) 4 août 2015 Mise à jour effectuée en V4.054 (depuis V4.053) : pas de problème .... pour l'instant Partager ce message Lien à poster Partager sur d’autres sites
Did 1 722 Signaler ce message Posté(e) 4 août 2015 Toujours à 20% depuis 3/4 d'heure. Je ne touche à rien. Partager ce message Lien à poster Partager sur d’autres sites
HANSOLO 381 Signaler ce message Posté(e) 4 août 2015 Reboot ta HC2.... Partager ce message Lien à poster Partager sur d’autres sites
pepite 1 272 Signaler ce message Posté(e) 4 août 2015 @Hansolo : peut-etre que le support est sur la box de @did Partager ce message Lien à poster Partager sur d’autres sites
Did 1 722 Signaler ce message Posté(e) 4 août 2015 Non, je ne pense pas, il m'ont envoyé cette réponse toute àl'heure (message #65): http://www.domotique-fibaro.fr/index.php/topic/5423-update-error10/page-4 Partager ce message Lien à poster Partager sur d’autres sites
Sakkhho 467 Signaler ce message Posté(e) 4 août 2015 @Did ???? Le grand saut ?? :-) Moi en vacances donc pas d update àdistance. En tout cas sirène gen5 officiellement supportée. Cool Envoyé de mon iPad en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
HANSOLO 381 Signaler ce message Posté(e) 4 août 2015 @Hansolo : peut-etre que le support est sur la box de @did Je sais d'ou le smiley.... Partager ce message Lien à poster Partager sur d’autres sites
Did 1 722 Signaler ce message Posté(e) 4 août 2015 Oui, ça y est mais je n'est pas encore touché le sol. Bonne vacances. Tu as pu terminer ton câblage au sous-sol avant de partir? Partager ce message Lien à poster Partager sur d’autres sites
melinm 2 Signaler ce message Posté(e) 4 août 2015 bloqué aussi depuis 1heure à20%. (update de 3.60 vers 4.054) Partager ce message Lien à poster Partager sur d’autres sites
