Maj Hc2 4.055 Beta 12/08/2015
Plap3014
4.055 Beta Dispo avec beaucoup de mise a jour...
Liste des modifications de la version beta 4.055:Version 4.055 Beta
WARNING: Beta version is designed for user testing and soon should be released as official.
> New Features:
Setpoint and other thermostats are now available to use in block scenes and LUA editor
New "Barrier Operator" device type support
Web interface performance improvements
> New Devices Support:
Z-Wave Thermostats:
2gig CT100 v9.1
RCS TBZ48 v1.2
RCS TZ45 v2.41
Honeywell #TH8320ZW01 v1.3 and v2.0
Trane TZEMT400BB32MAA v2.15
WEXCEL WT510 v2.4
Other Z-Wave devices:
Aeon Siren Gen5 v1.23
Vision ZS6101EU
Think Simple III EU DIMMER Wireless NWE030
Modulo II DIN ON-OFF Wireless ZWD020/SL
Think Simple III EU ON-OFF Wireless NWE030
Think Simple I BS ON_OFF Wireless NWB010
Think Simple IV BS ON-OFF Wireless NWB040
Think Simple II BS ON/OFF Wireless NWB020
Think Simple I BS Satellite Wireless NWB010
Think Simple II BS Satellite Tapparelle Wireless NWB020
Think Simple II BS Tapparelle Wireless NWB020
Think Simple II EU DIMMER Wireless NWE020
Think Simple II EU ON/OFF Wireless NWE020
Think Simple IV EU ON/OFF Wireless ZWE040
Think Simple II EU Satellite Tapparelle Wireless NWE020
Think Simple III EU Satallite Wireless NWE030/SS
Think Simple II EU Tapparelle Wireless NWE021
Linear Garage Door Opener
Cameras:
HIKVISION IP Camera ds2cd2132i
Axis
GeoVision
Speco
GEN IV
Plugins:
Logitech Harmony
Nest improvements
NetAtmo improvements
> Resolved Issues:
#0003434: Number missing in the scale
#0003322: 4.047: Vision Security ZM1601 Z-Wave Siren
#0003065: 4.037 RAM Graph day of the week wrong.
Z-Wave engine stability and other improvements
DSC Alarm support improvements
Web interface improvements for non-admin users
Magic Scenes editor visual improvements
SMS notifications can now be selected for every device type
Energy and Temperature Panel improvements
Slider state synchronization in Virtual Devices
> Known issues:
- Using multichannel associations requires soft reconfiguration of devices
- Android version of the Fibaro mobile app does not display icons for following devices properly:
- NetAtmo Thermostat
- NetAtmo Weather Station
- Sonos
- Inconsistencies in Satel interface.
- Power Metering may not work properly for some devices
- Alarm Panel doesn't work in some specific configurations
- Plugins for TV Sets of various manufacturers may not work with its newer firmware due to restrictions provided by new devices firmware. There will be added detailed information about supported firmware versions within plugins.
- Breached sensor with Arm Delay causes instant alarm after being armed
- Data range selection in event panel doesn't work properly
- Devices imported via Gateway Connection may have no icons
- Gateway Connection status of dead device between master and slave controller may be different
- Devices not properly configured on 3.X may not be converted properly
- On mobile clients devices may be visible in different categories than configured
- Horstmann Thermostat HRT4-ZW higher battery usage in some cases
- Doorlocks some functions may not work properly
@Nico : je vais te faire passer le cap :
Logitech Harmony
Fibar Group S.A.
Compatible :iPad, iPhone, Android Phone, Android Tablet, Home Center 2
Version:1.0
Description
Control even more devices in your house using Fibaro Home Center plugin for Logitech Harmony Home Hub. Using plugin you can control any devices compatible with Logitech Harmony Home Hub directly from Fibaro Home Center. Plugin allows to excecute any “activity†defined inside Home Hub manually or via Fibaro Home Center scenes. Experience benefits from powerful integration of both platforms.
Alors ça c'est juste énorme, je suis juste deg, moi j'ai une harmony One... Snif. Tu me feras un retour sur ce que ça donne et qques screens si possible ?
HAN et Mprinfo, oui, je sais, je suis lourd, mais bon je déspère qu'un gars de chez Fibaro lise ça et m'entende... D'ailleurs j'ai aussi relancé sur le fofo officiel il y a 10 jours, le topic est un peu parti en vrille du coup :)
Super jsuis concerné au moins par trois améliorations
nest , netatmo , hikvison et harmony hub et pour ce dernier j'ai hâte de voir ce qu'ils ont fait car cela va être le pied si cela fonctionne bien  :60:
Peut être...
Pitp2, pige pas pourquoi j'ai le bug là  du coup... Peut être parce que je ne suis pas passé par la 4.054.
EDIT : Euh je me reconnecte là  sur ma box après le repas, et ça fonctionne... Pige pas.
