Hc 2 - 4.057 Béta - 23/09/2015
mprinfo
Mise À Jour Hc2 du 23 et 24 septembre 2015
Nouvelle version beta:4.057
Etes vous sà»r de vouloir lancer la mise à  jour avec une version beta ?
Les versions beta ne sont pas officielles et :2:  peuvent contenir des erreurs. :2:
Liste des modifications de la version beta 4.057:
Version 4.057 Beta
WARNING : Beta version is designed for user testing and soon should be released as official.
This update introduces whole new migration process from version 3.600, featuring configuration for every device, adjusting it for changes which took place in the system. This will assure possibly smooth transition and continuous operation, allowing each device to work with old settings until reconfiguration is done. Please refer to message that appears in interface and Notification Center after finishing upgrade for further instructions.
Important!
Updating from version 3.600 may take longer than usual, up to 30 minutes, please do not restart controller during update process.
Resolved issues:
- #0003502 Aeon (4 in 1) Humidity Sensor - humidity now updates correctly
- Devices no longer show up as "Not configured" after controller reboot
- Values in Seismometer Mode in Motion Sensor v2.7 are now reported correctly
- Logitech Harmony plug-in behaviour is adjusted to recent changes in Logitech's API
- PTZ cameras movement can now be controlled as plug-in with mobile devices
- Drop-down lists on Firefox version 40 and above are now fully functional
- Devices with multiple endpoint are now building correctly even without templates
- Minor UI bugs fixes
Other improvements:
- UI was optimised, increasing interface performance significantly
- Following devices received generic templates that cover devices in various versions:
- Aeon Minimote
- Aeon Micro Smart Energy
- Aeon Home Energy Meter
- Aeon Smart Energy Switch
- Aeon Dimmer
- Aeon Door Window Sensor
- Aeon Z Wave Multi Sensor
- Aeon Key Fob
- Aeon Siren
- Aeon Recessed Door Sensor
- Aeon On Off Switch
- Aeon Smart Switch ZW075
- Aeon Smart Strip
- Aeon DSD37
- Poly-control Danalock
- TKB Home TZ69
Generic templates guarantee compatibility of all devices of given kind, regardless the version, as long as device has the same product ID (which depends on its manufacturer)
- Template matching mechanism optimized
Known issues:
- Inconsistencies in Satel interface
- Plugins for TV Sets of various manufacturers may not work with its newer firmware due to restrictions provided by new devices firmware
- Breached sensor with Arm Delay causes instant alarm after being armed
- Data range selection in event panel doesn't work properly
- Devices imported via Gateway Connection may have no icons
- Gateway Connection status of dead device between master and slave controller may be different
- On mobile clients devices may be visible in different categories than configured
- Horstmann Thermostat HRT4-ZW higher battery usage in some cases
- Doorlocks some functions may not work properly
Important!
Due to changes that took place in Logitech API, Harmony plug-in must have been adjusted. Because of manufacturer's restrictions new Harmony plug-in no longer polls Logitech service for changes, meaning, that plug-in values will not be updated when activity state is changed with some other device. This way of operation will maintain until Logitech establishes new way of requesting such data.
CHANGES INTRODUCED IN VERSION 4.X:
- Drag & Drop for devices and scenes - available on home, devices and rooms screens. Assigning devices to rooms and changing its order is now much easier and faster.
- Temperature Panel - allows to see history of temperature changes in rooms and on each device.
- Diagnostic Panel - general information about HC working condition like CPU & RAM usage, free space on hard drive. Will be extended in future versions.
- Soft Device Reconfiguration - option allows to save settings, parameters and device ID. Thanks to that scenes with reconfigurable device will not require editing. Full reconfiguration will remove and add the device to the Z-Wave network, resulting in the loss of its settings, parameters and change the device ID..
- Mesh Network Reconfiguration - available on Configuration -> Z-Wave Network
- New Z-Wave engine - redesigned and rewritten from the scratch. Now is faster and has better support for devices.
- Z-Wave Door Locks support - controlling and PIN settings.
- Thermostats - extended controlling for thermostats from manufacturers like: Honeywell, Trane Corporation.
- Extended tamper for sensors - exclusive information for motion detection and violation of sensors.
- Fibaro Smoke Sensor extended support - level of smoke and gap to alarm level is reported and visible on charts. Sensitivity level is now easier to set.
- Fibro Motion Sensor new device - when seismometer mode is turned on new device reporting tremors is available. Charts for temperature and illuminance. Additionally information about sensor violation.
- Device hiding - device that is not in use can be hide without removing it.
- Device deactivation - deactivated device is visible in UI but can't be controlled.
- Multithreading added for HC (server and z-wave) - now engines work much faster.
- Event panel moved - for better usability now is available in menu on right side of screen.
- Pre-Update Confirmation - installing update will prompt user additional confirmation.
- Added support for American English (EN-US)
- User rights management - moved to Configuration.
- Recovery Memory Health - can be checked on Backup & Recovery
- Backups has information about compatibility with current HC version
- Block scenes improvements - for device only available actions are visible, scene activation block added and logical conditions grouping using brackets.
- Lua Scenes - updated tool-tips for devices.
- Rest API Active Documentation - documentation and ability to test REST API requests, access at HOME_CENTER_IP/docs
Plugins:
- Plugins are grouped in categories: Safety, Cameras, Climate, Multimedia, Others
- Plugins search
- Network devices search via ARP
Plugins category Safety:
- DSC Alarm - for DSC Alarms,
- Helios Basic - integration using Basic license,
- Helios Gold - integration using Gold license
- Mobotix - for Mobotix videophone,
- Satel Alarm - for SATEL
- Modular Alarm
Plugins category Cameras
- more than 130 devices from various manufacturers
Plugin category Climate
- Carrier Furance
- WS Davis Vantage
- Nest - plugin for well-known thermostat
- Netatmo - plugin for thermostat and weather station from netatmo
Plugins category Multimedia
- LG Bluray
- LG TV*
- NC + mediabox
- XBMC Remote Control
- Denon Amplifier
- LG Bluray
- Onkyo Amplifier
- Philips Bluray
- Pioneer Amplifier
- Samsung TV*
- Sonos
- Sony Bluray
- Sony TV*
- Logitech Harmony
* some TV Sets firmware version may not be supported
Plugins category Other
- Philips Hue
- Wake on LAN
- Planika Fireplace
Other changes, many other improvements to the system
Il n'y a plus de beta testeur ?
La femme ferait il plus peur que les bugs fibaro ?
On voit qui commande àla maison mdr
Je vois que l'on a de plus en plus de petit joueur avec ces mise a jour.
Il y a une solution le divorce. Avec madame ou fibaro voir même les deux si elle garde la box lors du partage lol
Panneau des événements toujours incohérents .... on sélectionne des dates et des heures et cela n'est pas pris en compte. Ce n'est pourtant pas si compliqué que cela de faire des tris dans une bdd ..
Qubino fil pilote non reconnu  :(
Lazer, sur un autre post tu semblais optimiste sur la bonne intégration des périphériques n'ayants pas de template cela ne semble pas le cas .. de plus si on n'a pas la possibilité de choisir le "device kind" cela ne servirait pas à  grand chose.
Donc mise à  jour neutre hormis le fait que l'on a bien rigolé en attendant la mise à  jour  :)
Pour ceux qui ont effectué la mise à  jour pourriez vous m'indiquer si les templates suivant ont été intégrés ?
J'ai la réponse pour le Qubino Fil pilote  :(
Il semblerait dans la note de mise à  jour que c'est ok pour le DSD37 ?
Manufacturer => Qubino
Model => QUBINO ZMNHJA2 - Module fil pilote 6 ordres Z-Wave
Version => 1.12
Manufacturer => AEOTEC by AEON Labs
Model => DSD37
Version => 1.6
Manufacturer => Benext
Model => Tagreader
Version => 1.7
Je pense comme tout, prends le temps,,,,le template doit peut etre avoir 24h de données , (ce n,est pas parce que tu as fais MaJ que tout le systeme est operationnel, il lui faut un petit moment)
as tu redemarrer deux , trois fois avant, pour que tout se place correctement !
Pouvez vous me dire si le systeme GPS est operationnel ?
+ que neutre, même les performance du moteur non pas évolué ... aucune amélioration notable chez moi non plus. :
[DEBUG] 14:44:32:   Nb runs : 1000 | id : 56 | G.Variable : Chauffage
[DEBUG] 14:44:32:   ----------------------------------------------
[DEBUG] 14:44:32:
[DEBUG] 14:44:35:   getValue Exist      : instruction time : 3s | cpu time : 1.58s
[DEBUG] 14:44:37:   getValue Not Exist  : instruction time : 2s | cpu time : 1.46s
[DEBUG] 14:44:45:   setValue            : instruction time : 8s | cpu time : 3.21s
[DEBUG] 14:44:47:   getGlobal Exist     : instruction time : 2s | cpu time : 1.8s
[DEBUG] 14:44:49:   getGlobal Not Exist : instruction time : 2s | cpu time : 1.46s
[DEBUG] 14:45:42:   setGlobal           : instruction time : 53s | cpu time : 4.83s
[DEBUG] 14:45:51:   getType             : instruction time : 9s | cpu time : 6.51s
[DEBUG] 14:45:58:   getName             : instruction time : 7s | cpu time : 5.68s
[DEBUG] 14:46:05:   getRoomID           : instruction time : 7s | cpu time : 5.61s
[DEBUG] 14:46:15:   getRoomName         : instruction time : 10s | cpu time : 7.4s
[DEBUG] 14:46:17:   getSunrise          : instruction time : 2s | cpu time : 1.62s
[DEBUG] 14:46:17:   boucle 1000         : instruction time : 0s | cpu time : 0.15s
[DEBUG] 14:46:17:
[DEBUG] 14:46:17:   ----------------------------------------------
[DEBUG] 14:46:17:   ALL DONE
Oh l'évolution n'est pas neutre dutout vu que tu es revenu  :2:
Je n'avais pas vu la ré-apparition de Steven dans le change log  :60:  ils ont intégré le template Steven 2,0  :P
Cela devient donc une très bonne mise à  jour Merci Monsieur Fibaro
  • Upvote 2
Je lis de temps en temps mes mails et j'ai malheureusement installé un MV de Krikroff qui me spam quand une mise à  jour est disponible.
De plus, je suis un faible, dès que je vois le mot "nouveautés" , je suis pris de clicomanie ... malheureusement très souvent suivis de déceptiomanie.
%% globals
-- Parameters --
local id_exist = 56
local global_exist = "Chauffage"
local nbIteration = 1000
-- Do not touch please ---
local id_not_exist = 100056
local global_not_exist = "AABBCCDDEEFFGGHHIIFFF"
function log(name, start, cpu)
   if (start) then
fibaro:debug(string.format("<span style=\"font-family:monospace; white-space:pre; clear:both; float:right\">  %s instruction time : %ds | cpu time : %gs </span>", name, os.time()-start, os.clock()-cpu))
else
fibaro:debug(string.format("<span style=\"font-family:monospace; white-space:pre; clear:both; float:right\">  %s </span>", name))
function execute(name, func)
  if (not pcall(function()
        local start = os.time()
        local cpu = os.clock()
        for i= 1,nbIteration do
            func()
    end)) then
   fibaro:debug("ERROR : " .. name)
log("Nb runs : " .. nbIteration .. " | id : " .. id_exist .. " | G.Variable : " .. global_exist)
log("----------------------------------------------")
log("")
-- Tests ---
execute("getValue Exist      :", function() fibaro:getValue(id_exist, "value") end)
execute("getValue Not Exist  :", function() fibaro:getValue(id_not_exist, "value") end)
execute("setValue            :", function() fibaro:call(id_exist, "setValue", fibaro:getValue(id_exist, "value")) end)
execute("getGlobal Exist     :", function() fibaro:getGlobalValue(global_exist) end)
execute("getGlobal Not Exist :", function() fibaro:getGlobalValue(global_not_exist) end)
execute("setGlobal           :", function() fibaro:setGlobal(global_exist, fibaro:getGlobalValue(global_exist)) end)
execute("getType             :", function() fibaro:getType(id_exist) end)
execute("getName             :", function() fibaro:getName(id_exist) end)
execute("getRoomID           :", function() fibaro:getRoomID(id_exist) end)
execute("getRoomName         :", function() fibaro:getRoomName(fibaro:getRoomID(id_exist)) end)
execute("getSunrise          :", function() fibaro:getValue(1, "sunsetHour") end)
execute("boucle 1000         :", function() for j=1,1000 do k=j end end)
log("")
log("ALL DONE")
Salut à  tous
J'ai fais la mise à  niveau en Bêta depuis le temps que j'attendais de passer en V4 pour l'instant je n'ai rien vu d'exceptionnel à  part des trucs bizarres qui me donne des Main_Zwave_Device quaiment à  chaque module. Quelqu'un sait y ce que c'est ? Autre question complètement à  part : On ne peut pas se réapproprier les anciens ID des modules ??? (j'ai une HCL en passerelle, et j'ai du la réintégrer mais il m'a mis de nouveaux ID partout !!!)
Merci les gars
