couillerot Posté(e) 25 novembre 2021 Signaler Share Posté(e) 25 novembre 2021 (modifié) Dear users, Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.Main features: 1. A new, user-friendly wizard for adding Elero devices Device configuration within the pairing process. Pairing multiple devices in one process. Redesigned default icons. 2. Configuration of favourite positions in device settings Advanced tab Easy, single-button step-by-step wizard. Possibility to name positions and use them in scenes and profiles.What's new:Access Mobile device status indication.Dashboard Distinction of actions sent on click and hold of the slat rotation button. Support for holding the level change button on device sidebar. Favourite positions buttons available on device sidebar.Devices Possibility of enabling inversion in device Advanced tab for blinds/shutters/gates etc. Improved and unified support of device control types. New default icons for switches, dimmers, shutters, gates, and garage doors. Added icons for missing device states (favourite positions, brightening, dimming, etc.). Devices of the com.fibaro.baseShutter type available in the Blinds linked device. Improved detecting if device is awake and checking its wake-up interval.** Added missing support for FIBARO Roller Shutter 2 FGRM-222.** Reinterview process optimisation.**Elero* Configuration of device name, assignment, and its type as a part of pairing process. Possibility of pairing multiple devices of different types in one process. Testing the device detected during the pairing process to allow its identification. Inversion feature enabled by default for devices detected as awnings. Support for controlling the slats position. Support for alarms and notifications. Possibility of configuring favourite positions. Possibility of changing the device role. Possibility of forcing the device polling. Support for Elero Unio-868, Combio-868 HE, and Combio-868 LI.Energy New Ecology tab for ecu-enthusiasts and everyone who produces energy. Displaying self-sufficiency level, equivalent trees planted, and CO2 reduction. Animated graphs of achievements and their impact on the environment. Possibility of setting the return rate in Panel Settings. Calculation of already returned installation cost including set return rate. Redesigned interface for configuring additional rates in Tariffs.Network Access Point remains enabled after finishing FTI if no network is connected.Nice* Improved and unified support of Nice Mono devices. Global abort for all types of binding procedures. Possibility of configuring favourite positions. Possibility of changing the device role. Possibility of forcing the device polling.Quick Apps Possibility of adding custom icon for all single-state devices (players, remotes, etc.).Bug fixes:Alarm Alarm partitions (com.fibaro.alarmPartition) are not available as zones in alarm panel.Dashboard Holding the button on device sidebar does not work in mobile app.Devices Device properties and its interfaces are removed after the soft reconfiguration. Soft reconfiguration of the device removes it from the linked device. Maximum value reported by the sensor connected to analog input is limited to 4 digits. In some cases, com.fibaro.baseShutter type device lose its configuration. Incorrect setpoint temperature range for some thermostats. Attempt to update firmware of some battery devices always fails. Node provisioning list is not available.** No power charts for power meters (com.fibaro.powerMeter).Elero* Incorrect default polling time interval. Device is too early marked as dead but remains available. Number of devices is not updated after removing the device. In some cases, adding one device after another results in error. In some cases, adding previously removed device is not possible. Device polling is not stopped after performing action. No Notifications tab.Energy No validation for entering negative values of measured energy.Gateway Connection Rebooting the master gateway always results in sending devices model to slaves. Firmware update possibility disappears for devices added to slaves.Nice* In some cases, adding a new device is aborted before finishing the process. Number of devices is not updated after removing the device. No parameters after adding a device with parameters interface. Device added on previous versions has its parameters disabled after performing update. In some cases, clicking on remotes while binding is not always detected. Redundant requests during device creating process. No device calibration for BiDi Dimmer device. Cannot bind new gate using its remote. Incorrect default polling time value.Notifications System migration notification is restored and created after each reboot.Other Some HTTP requests do not require authentication.Plugins Recording feature in FIBARO Intercom plugin does not work.Profiles Some Elero devices are not available in profiles.Scenes No possibility to define multiple values in the date field.Known issues:Z-Wave engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. Gateway connection is not available in the new Z-Wave engine version. * - does not apply to HC3L (Home Center 3 Lite) ** - applies only to Z-Wave Engine 3.0 Modifié 26 novembre 2021 par couillerot 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
couillerot Posté(e) 25 novembre 2021 Auteur Signaler Share Posté(e) 25 novembre 2021 MAJ effectuée et RAS Stef Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) 25 novembre 2021 Signaler Share Posté(e) 25 novembre 2021 Citation Quick Apps : Possibility of adding custom icon for all single-state devices (players, remotes, etc.). Han 1 an et demi qu'on l'attendait il y a 12 minutes, couillerot a dit : Displaying self-sufficiency level, equivalent trees planted, and CO2 reduction. Animated graphs of achievements and their impact on the environment. Il y a un marketeux qui s'est fait plaisir, ils ne vont pas manquer d'en faire mention sur leurs plaquettes commerciales... Lien vers le commentaire Partager sur d’autres sites More sharing options...
jjacques68 Posté(e) 25 novembre 2021 Signaler Share Posté(e) 25 novembre 2021 semble ok chez moi aussi... Lien vers le commentaire Partager sur d’autres sites More sharing options...
ROBBEJP Posté(e) 25 novembre 2021 Signaler Share Posté(e) 25 novembre 2021 il y a 58 minutes, Lazer a dit : Il y a un marketeux qui s'est fait plaisir, ils ne vont pas manquer d'en faire mention sur leurs plaquettes commerciales... ... et ils ont payé combien de mecs pour faire ça... ?? Hummm ... il y avait quand même plus urgent à faire. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Sowliny Posté(e) 25 novembre 2021 Signaler Share Posté(e) 25 novembre 2021 D'accord avec @ROBBEJP. C'est vrai que j'attends une géolocalisation qui fonctionne vraiment (à moins que j'aie raté quelque chose ? - j'ai laissé tomber depuis un bon bout de temps déjà). Mais désormais la "gestion environnementale" est implémentée, et c'est quelque chose qui risque de m'intéresser... Si toutefois c'est quelque chose qui : a) fonctionne; b) présente un intérêt réel; c) et ne soit donc pas un gadget commercial. Je ferai la m.à.j. ce weekend, tranquillement. 2 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) 25 novembre 2021 Signaler Share Posté(e) 25 novembre 2021 Punaise que c'est beau Mais... ça sert à quoi ? Comme je disais, on est à fond dans le pipeau marketing et la présentation commerciale. Faut bien vendre. Parait que le CES va revenir en présentiel en janvier 2022, du coup... ils auront un truc à montrer. 3 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Dragoniacs Posté(e) 25 novembre 2021 Signaler Share Posté(e) 25 novembre 2021 Super ! Des icônes, des positions favorites nomables, l'intégration du roller shutter 2,.... Même des corrections sur l'application !Trop bien cette beta !Si ça tourne bien chez vous, dans quelques jours je me lance [emoji16]Envoyé de mon M2012K11AG en utilisant Tapatalk Lien vers le commentaire Partager sur d’autres sites More sharing options...
TonyC Posté(e) 25 novembre 2021 Signaler Share Posté(e) 25 novembre 2021 (modifié) mise à jour suspendue, trop de crash. Pas eu le temps de cliquer https://forum.fibaro.com/topic/56815-fibaro-system-update-5091-beta-for-home-center-3-crashing/?tab=comments#comment-239688 https://forum.fibaro.com/topic/56818-important-fibaro-system-update-5091-beta-for-home-center-3-suspended/?tab=comments#comment-239677 il y a une heure, Lazer a dit : Punaise que c'est beau en lisant ton thread, je pensais que c'était une blague, on dirait que non Modifié 25 novembre 2021 par TonyC 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) 25 novembre 2021 Signaler Share Posté(e) 25 novembre 2021 Je viens de voir ça sur le forum officiel, je reviens ici, et tu l'as partagé Ma box n'a pas rebooté, mais c'est celle de test, il y a peu de choses dessus. 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
TonyC Posté(e) 25 novembre 2021 Signaler Share Posté(e) 25 novembre 2021 moi la MAJ c'est affichée, j'ai vu qu'il y avait des MAJ sur des devices, j'ai jeté un oeil, je suis revenu sur la maj de la hc3 et rien. Après l'apéro j'aurai compris mais là !!??!! ben vite compris en lisant le fofo officiel. Et il y a un fix que j'attends depuis des lustres qui corrige la perte de paramètres sur les devices incluses dans les slaves après reboot de la master. Bon va falloir être encore patient quelques jours Lien vers le commentaire Partager sur d’autres sites More sharing options...
couillerot Posté(e) 25 novembre 2021 Auteur Signaler Share Posté(e) 25 novembre 2021 (modifié) Pour le moment, pas de crash... et donc j'hésite à faire une restauration ! ps : si Fibaro a retiré cette maj des ces serveurs, c'est donc une beta collector ?! Stef Modifié 25 novembre 2021 par couillerot 1 2 Lien vers le commentaire Partager sur d’autres sites More sharing options...
TonyC Posté(e) 25 novembre 2021 Signaler Share Posté(e) 25 novembre 2021 Je pense que le problème arrive juste après la MAJ lors du reboot. Donc si c'est passé, je ne sais pas si ça vaut le coup de restaurer. Au pire il y aura une nouvelle MAJ qui fixera le problème qui impacte certains utilisateurs. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) 25 novembre 2021 Signaler Share Posté(e) 25 novembre 2021 A vendre, HC3 avec firmware 5.091.039 beta instable mais stable quand même Rare pièce de collection 1 3 Lien vers le commentaire Partager sur d’autres sites More sharing options...
ROBBEJP Posté(e) 25 novembre 2021 Signaler Share Posté(e) 25 novembre 2021 Il y a 1 heure, Lazer a dit : Entre l'encre que c'est en train de faire couler et les RollBack de conf qu'elle génère, on peut leur dire que ça va leur couter 10 arbres ? 1 2 Lien vers le commentaire Partager sur d’autres sites More sharing options...
MAM78 Posté(e) 25 novembre 2021 Signaler Share Posté(e) 25 novembre 2021 Meme pas eu le temps de lancer la MAJ qu’elle a disparue [emoji2957] Lien vers le commentaire Partager sur d’autres sites More sharing options...
flacon030 Posté(e) 25 novembre 2021 Signaler Share Posté(e) 25 novembre 2021 idem pour moi j'ai vu la mise a jour que quelques minutes Lien vers le commentaire Partager sur d’autres sites More sharing options...
couillerot Posté(e) 25 novembre 2021 Auteur Signaler Share Posté(e) 25 novembre 2021 (modifié) Bon je vais laisser tel quel et croiser ce que je peux en attendant la prochaine maj ! sinon @Lazer, si tu es intéressé, je vends une HC3 en beta collector (ça t'en fera une deuxième de non stable mais stabilisée) Stef Modifié 25 novembre 2021 par couillerot 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
mprinfo Posté(e) 25 novembre 2021 Signaler Share Posté(e) 25 novembre 2021 Chez moi la mise a jour n'est pas disponible Lien vers le commentaire Partager sur d’autres sites More sharing options...
Sowliny Posté(e) 26 novembre 2021 Signaler Share Posté(e) 26 novembre 2021 (modifié) Oui, effectivement c'est très beau ! Cependant, ça me paraît plus tenir du diaporama que d'une info locale pertinente. Mais bon, je n'émet cet avis qu'après avoir la capture de @Lazer... J'ai aussi reçu la beta 5.091.41 - mais ma box n'étant pas en test, je vais lâchement m'abstenir de tenter une m.à.j. avant quelques jours. Par exemple, après avoir lus quelques commentaires plus haut, le non-redémarrage "AFTER" persiste. Pour éviter de menus emm... Modifié 26 novembre 2021 par Sowliny Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) 26 novembre 2021 Signaler Share Posté(e) 26 novembre 2021 Et encore, vous n'avez pas tout vu, car c'est une animation.... la fumée des cheminées, les éoliennes, etc... 1 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Dragoniacs Posté(e) 26 novembre 2021 Signaler Share Posté(e) 26 novembre 2021 Tu pourrais nous faire un petit film ? Si ça se trouve, c'est collector [emoji16]Envoyé de mon M2012K11AG en utilisant Tapatalk Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) 26 novembre 2021 Signaler Share Posté(e) 26 novembre 2021 Regarde sur le topic du nouveau firmware, @couillerot a mis un GIF animé : Je viens de comprendre pourquoi tout le monde ne voit pas les usines à droites, car il faut un grand écran. L'image a une définition fixe, on peut tout voir en dézoomant dans la page (<CTRL> + <-> ou bien Ctrl + molette)... et après l'image se répète à l'infini, on sera embêté quand on aura tous des écrans 8K, il faudra que Fibaro fasse un nouveau firmware rien que pour corriger ce bug Et on peut même faire une course de nuages 3 Lien vers le commentaire Partager sur d’autres sites More sharing options...
