HC3 & HC3L - 5.131.52 - BETA - 27/01/2023
BETA
Important Notice
Installation of this version is not recommend for systems using Gateway Connection feature.
Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Main features:
1. New way of controlling devices from Dashboard sidebar
    Completely redesigned control of color controllers.
    Support of color temperature setting for the Zigbee devices.
2. New predefined scenarios designed to control lights based on time conditions and gates status
What's new:
Climate
    Added possibility to assign temperature sensors for climate zones.
    Added battery level indicators on devices tiles.
Dashboard
    Possibility to add devices from the dashboard.
Devices
    Optimised procedure for adding devices for all protocols.
    Improved UI/UX and performance for device page filters.
    Added filters clearing mechanism when leaving the page.
    Added the description field for every device type.
    Redesigned family of devices view.
Energy
    Modified page layout for energy meters configuration in panel settings.
Gateway connection
    Added an option to define Slave IP address manually.
    Added additional redundancies for unexpected changes in network configuration.
Nice*
    Improved support for OXIBD status updates.
    Added generic support for legacy Bidirectional shutters.
    Improved support for device specific notifications.
Other
    Improved algorithm for gateway overheating notifications.
    Minor UI/UX improvements.
Plugins
    Added support for pulling the latch for the Tedee door lock.
    Improvements for Heat Activator plugin.
Quick Apps
    Added support for the Base Shutter device type.
Scenes
    Added the filters for Scenes page.
    Added "tolerance" option for Energy Panel block scenes.
    Improved blocks content loading performance for large systems.
    Added the description field for every scene type.
    Changed the order of steps for Scenarios.
Update
    Added possibility to update all devices.
    Added additional warning before upgrading to the beta version of the hub.
Zigbee
    Improved generic support for lights and color controllers.
Z-Wave
    Added handling of suspended device interview during the adding procedure for battery-powered devices.**
    Support for different revisions of the Aeotec Multisensor 6.
    Support for the ZW800 series MCO IR2900 thermostat.
    Support for the Everspring SP103.**
Bug fixes:
Climate
    The zone control freezes if the last setpoint is set at 5:00am.
Devices
    Issues with the display of some configuration parameters values.
Elero*
    The RolSolar device is incorrectly marked as disconnected.
    Using favorite positions in group actions does not work.
Energy
    Energy charts are malformed occasionally.
    Negative energy consumption data in the panel after clearing the energy data in some cases.
    Negative power consumption values for "Grid consumption" setting in some cases.
FTI
    No masking of Wi-Fi password during the first configuration on Firefox.
Gateway Connection
    Connection issues in specific network configurations.
Nice*
    Losing possibility to control devices in some cases.
    Fixed issue with binding some mono-directional devices.
    Custom icons for mono-directional devices not visible.
Other
    Added possibility to enable remote access for support from recovery system.
    Standard user cannot remove interactive push.
    Issues with controlling the linked-device thermostat in some configurations.
    System crash while deleting a non-existing notification.
    Wrong time in history after the change from winter time to summer time.
    Adding more than one Other device by clicking the add button excessively.
    The state of devices is not refreshed when pressed run scene button without refreshing the page.
    Other UI/UX fixes.
Plugins
    Lack of live preview for Helios 2N plugin.
Profiles
    Incorrect display of climate panel settings.
    Incorrect display of sliders in profiles settings.
Quick Apps
    Secret variable value visible in the webUI after saving.
Scenes
    Elero RolMotion blind is controlled even if excluded from a simple scenario.
    Incorrect display of sliders in block scenes.
    Cannot edit Scenarios via mobile app in remote connection.
Zigbee
    Wrong time unit during the adding process.
Z-Wave
    No possibility to update Z-Wave devices added in Security mode.
    Lack of handling unsolicited reports from devices using CC Basic.**
    Issues with updating devices from file in some cases.**
    Incorrect default role for the Zooz ZAC36 valve.
    Improved adding procedure when using S2U security level.**
    The exclusion process cannot be closed after an error has occurred.
Known issues:
Z-Wave Engine 3.0
    Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
    Gateway connection is not available in the new Z-Wave engine version.
*  - does not apply to HC3L (Home Center 3 Lite)
** - applies only to Z-Wave Engine 3.0
  • Thanks 1
  • Haha 1
Il y a 10 heures, Lazer a dit :
cela voudrait dire qu'il va y avoir une vrai regulation de la température ?
Bon chez moi c'est une vrai catastrophe
Il y a des lenteurs pas possible, et en plus cela plante la box
Je vais essayer de revenir en arrière
Modifié par flacon030
il y a 7 minutes, Lazer a dit :
PID ? J'en doute...
oui tout à fait.
ben j'ai fais la mise à jour, ajouté les sondes de tempértures dans les zones, mais visiblement ... se passe pas grand chose.
Bon j'ai fait un e deuxième tentative et cela fonctionne presque...
Une petite anomalie constaté
En câble internet je n'ai pas accès au panneau de configuration de la HC3, or en wifi c'est OK
Mais c'est toujours très instable la HC3 n’arrête pas de redémarrer, donc je reviens a la version précédente
Pour moi cette version est a oublier
C'est la première fois que cela m'arrive depuis que je teste les versions bêta
Va falloir que je la fasse cette mise à jour
Mais pas motivé
Rien que le fait d'allumer l'ordi pour la faire ça me fatigue
  • Haha 1
Bonsoir,
Plantage de la sauvegarde en ethernet. Retour par un recovery. Je change de navigateur pour retenter le passage mais la mise à jour n'est plus proposée. J'attends la suivante pour voir.
effectivement cette MAJ n'est plus dispo ... aurait elle été retirée pour cause de soucis trop nombreux?
salut les amis, j'ai une question d'ordre pratique sur les modules ZIGBEE et particulièrement des ampoules ? j'en ai intégrée quelques unes.. qui fonctionnent parfaitement, mais j'en ai 3 qui ont bien été intégrées et que je ne vois plus dans ma box. donc je me dis je vais relancer l'intégration... rien ne se passe...Je me dis je vais réinitialiser tout le réseau ZIGBEE.. je m'execute et pis bien rien. Comme si les modules déjà intégrés n'avaient pas la possibilités d'être exclus.. y a une astuce ????
ah bah non rien j'ai trouvé, il faut les éteindre et les rallumer plusieurs fois jusqu'à ce qu'elles clignottent.. ça peut servir !!
il y a une heure, Yannick a dit :
y a une astuce ????
j'ai le même soucis, impossible d'exclure les modules zigbee si ils ne répondent plus.
j'en ai 2 que je n'arrive pas à supprimer.
Il y a 6 heures, flacon030 a dit :
c’était une version alpha poussé par erreur
https://forum.fibaro.com/topic/64376-important-update-513152-unavailable/
Il est fortement conseillé de revenir en arrière (chose que j'ai fait)
Et bien... cette version Alpha aura au moins eu un mérite, c'est de me faire apparaitre mon premier message "Le système a récupéré d'une erreur inattendue" :
Du coup... on en parlait récemment, pas sûr que ça soit un problème hardware comme je le suggérais, vu qu'une simple mise à jour de firmware permet de faire apparaitre ce message.
Je laisse tourner encore quelques jours, on verra si le problème se reproduit.. Puis je ferai un retour arrière, et on verra si le problème disparait.
Heureusement que c'est sur ma box de test.
Ca alors ce problème est de plus en plus étrange
Je viens de tourner 30 jours sans REBOOT puis plouf  "le canard est toujours vivant"
Modifié par henri-allauch
Il y a 15 heures, flacon030 a dit :
Citation
If you are experiencing any issues regarding the performance of 5.131.52 firmware and you are willing to be a part of this firmware version troubleshooting, you can reach us at support@fibaro.com where your ticket will be forwarded to the developers to take immediate action to diagnose the issue*
je vais pas faire le complotiste mais j'ai l'impression que c'est une fausse vrai erreur ... pour tester a grande echelle non ? :ph34r:
Un air de déjà vu avec le vaccin Covid !.... Le vaccins est au point et sans danger MAIS si vous souhaitez nous faire part des effets indésirables qu'il provoque systématiquement en cas d'injection, envoyez nous un mail at Co.Baye.gouv.
  • Haha 1
Le 30/01/2023 à 20:11, jjacques68 a dit :
Salut @jjacques68, tu as vu après j'ai mis l'astuce. il faut les débrancher et les rebrancher électriquement plusieurs fois de suite jusqu'à ce qu'elles se mettent à fader
