Berale64 Posté(e) le 4 janvier 2017 Signaler Partager Posté(e) le 4 janvier 2017 La petite lampe bleu de ma box clignotait !!! Il y a une nouvelle version "stable" Qui se lance ??? Liste des modifications logicielles 4.110: Version 4.110 This update features migration process from version 3.600, reconfiguring every device, adjusting them for changes which took place in the system. This will assure a possibly smooth transition and continuous operation, allowing each device to work with old settings until reconfiguration is done. Please, refer to the message that appears in the interface and Notification Center for further instructions after finishing upgrade. Important! Updating from version 3.600 may take up to 30 minutes. Do not restart controller during update process. Resolved issues: - Problems with Logitech Harmony plugin. - Faulty configuration of parameters of Heatit Thermostat v1.2. - Disappearing backups. - Global Cache stops working. - Incorrect device counting in Dashboard bar. - #0002195: Low Battery Level Indication on new batteries. - #0002267: Upgrade message inconsistent. - #0002270: zwave.me products not working. - #0003909: xml 448 - adding Meter support on endpoints. - #0004075: Hidden slave devices of RGB become unhidden after rebooting. - #0004188: v4.104 restores English user interface at daily basis. - Error 503 during system startup. - Disabled devices included in the temperature panel. - Time is not updated after changing location. - Improved event panel filtering. - No chart of recovery memory. - Force remove of devices do not work in Czech. - Problem with scenes protected by PIN. - Minor graphic fixes. New devices support: - Popp Thermostat v1.0. - Gerda lock v1.2. - Russound XSource. - Russound XZone4. - Zipato RFID in version AU, IN and RU. - Remotec ZXT-120 versions 1.2, 1.1, 1.0, 1.3, 1.7, 1.12, 1.20, 1.21. Other improvements: - Home Center Wizard - wizard used to set basic Home Center data - user configuration, firmware upgrade, alarm configuration and localization - available only for admin user. - For safety reasons, the admin user format was force changed to an email address format. - For safety reasons, the default admin password was force changed. - Choice of weather information source - the possibility to set various sources of weather in Home Center system, as a part of the update two sources were added: Yr.no and Yahoo. As a source of weather information you can also use other devices, e.g. temperature sensor. - Interactive PUSH notifications for mobile applications - a new block in scenes capable of running a scene PUSH notifications. - Extended information about the power consumption - the list of devices available from the Dashboard bar - Many devices such as switches and dimmers can be synchronized. They will react identically to action from both a button and the interface. Synchronization is possible from the advanced settings of one of the devices. - Improved the display of system status. - Change in Logitech Harmony plugin authentication - NEED TO REINSTALL THE PLUGIN. - Simplified control of scenes from the web interface. - Change in system notifications functionality - the list of notifications available from Dashboard bar. - Change in information about devices with low battery - the list of devices available from the Dashboard bar. - Extensive scenes and devices filtering - the ability to show all, hidden or only visible devices and scenes. - Change in information about incorrect communication with a device. - Rooms synchronization as a part of Gateway Connections functionality. - Functionality of copying scenes. - Functionality of energy consumption data export (CSV file). Additional information: - Due to a technical issue with NEST plugin we are forced to turn off the plugin for some time. Works on certification for NEST have already started. The plugin will be available as soon as possible. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Massalia Posté(e) le 4 janvier 2017 Signaler Partager Posté(e) le 4 janvier 2017 (modifié) Allez j'essaye .... Ca est je suis 4.110 Modifié le 4 janvier 2017 par Massalia 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
pepite Posté(e) le 4 janvier 2017 Signaler Partager Posté(e) le 4 janvier 2017 Allez on clique :-) Lien vers le commentaire Partager sur d’autres sites More sharing options...
razowski Posté(e) le 4 janvier 2017 Signaler Partager Posté(e) le 4 janvier 2017 Moi je me lance Lien vers le commentaire Partager sur d’autres sites More sharing options...
mprinfo Posté(e) le 4 janvier 2017 Signaler Partager Posté(e) le 4 janvier 2017 je laisse passer car la 4.106b fonctionne très bien Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) le 4 janvier 2017 Signaler Partager Posté(e) le 4 janvier 2017 Ahh, je ferai ça rapidement si j'arrive. 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
speedoxx007 Posté(e) le 4 janvier 2017 Signaler Partager Posté(e) le 4 janvier 2017 Déjà fait sur mes 2 box hc2 et hcl pour le moment nickel. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jayce74 Posté(e) le 4 janvier 2017 Signaler Partager Posté(e) le 4 janvier 2017 Hello tous, Actuellement en 4.100 j'hésite a cliquer. ça donne quoi avec GEA? Lien vers le commentaire Partager sur d’autres sites More sharing options...
Sakkhho Posté(e) le 4 janvier 2017 Signaler Partager Posté(e) le 4 janvier 2017 @jojo revient. On a une stable ici !!! 2 Lien vers le commentaire Partager sur d’autres sites More sharing options...
speedoxx007 Posté(e) le 4 janvier 2017 Signaler Partager Posté(e) le 4 janvier 2017 Chez moi GEA fonctionne encore :-) Lien vers le commentaire Partager sur d’autres sites More sharing options...
jmg38 Posté(e) le 4 janvier 2017 Signaler Partager Posté(e) le 4 janvier 2017 C'est fait après un 503 reboot et c'est reparti, GEA tranquille... Lien vers le commentaire Partager sur d’autres sites More sharing options...
Fredmas Posté(e) le 4 janvier 2017 Signaler Partager Posté(e) le 4 janvier 2017 (modifié) Egalement dispo sur HCL, mais j'attends Du coup c'est possible de modifier le titre de ce sujet en se calant sur les modèles standards des autres sujets, afin de s'y retrouver plus rapidement HC2 & HCL - Version 4.110 - STABLE - 04/01/2017 Merci Modifié le 4 janvier 2017 par Fredmas Lien vers le commentaire Partager sur d’autres sites More sharing options...
Fredmas Posté(e) le 4 janvier 2017 Signaler Partager Posté(e) le 4 janvier 2017 (modifié) Il y a 3 heures, mprinfo a dit : je laisse passer car la 4.106b fonctionne très bien @mprinfo tu installes une beta que personne n'a vu passer, et une stable tu ne l'installes pas Modifié le 4 janvier 2017 par Fredmas Lien vers le commentaire Partager sur d’autres sites More sharing options...
Berale64 Posté(e) le 4 janvier 2017 Auteur Signaler Partager Posté(e) le 4 janvier 2017 il y a 15 minutes, Fredmas a dit : Egalement dispo sur HCL, mais j'attends Du coup c'est possible de modifier le titre de ce sujet ... Voilà M'sieur !!! 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Fredmas Posté(e) le 4 janvier 2017 Signaler Partager Posté(e) le 4 janvier 2017 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 4 janvier 2017 Signaler Partager Posté(e) le 4 janvier 2017 Nico ne clique pas trop vite, n'oublie pas que tu devras renommer ton compte admin..... 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) le 4 janvier 2017 Signaler Partager Posté(e) le 4 janvier 2017 Oui oui je sais, je ne ferai au mieux que ce week-end. D'ailleurs j'ai fais un truc le week dernier : J'ai transformé une partie de mon GEA en scène bloc... Pourquoi, car GEA avait toujours encore des plantages de temps en temps. Cela fonctionne nickel. Par contre je me suis rendu compte qu'en fait mon GEA, j'avais mis le délai de mise à jour à 15s au lieu des 30 de Steven, du coup je suis repassé à 30. Et depuis, plus aucun souci avec... Alors bon, un des 2 trucs a réglé le souci, mais lequel... Sinon les scènes en mode bloc, je ne sais pas si qque chose à changé, mais elles sont vraiment pas mal au niveau vitesse, c'est du temps de réaction instantanée vraiment. Donc cette version me plait, vais voir que je la met. 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
pepite Posté(e) le 4 janvier 2017 Signaler Partager Posté(e) le 4 janvier 2017 Suis toujours pas un grtand fan des scenes bloc, j'ai pas du tout l'esprit qui va avec lol bon, je cliquerai plus tard, sinon faut que je modifie aussi alors les retours ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
mprinfo Posté(e) le 4 janvier 2017 Signaler Partager Posté(e) le 4 janvier 2017 Si quelqu'un qui est en 4.110 peu regarder si il y a les associations direct avec les wall Plug ou FGS Device grouping Below, select the devices whose operation is to be grouped with the state of the device, which you control. The selected device will act as one. To save the changes, click the floppy disk icon on the right. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) le 4 janvier 2017 Signaler Partager Posté(e) le 4 janvier 2017 Migration faite à 90% ! Pour le moment, ça roule. J'ai juste pas encore changer le login, j'ai fermé le Wizard, le ferait plus tard ça. Par contre j'utilise du coup dans les API de toutes mes passerelles un autre compte qu'admin, et cela fonctionne nickel. Encore qques check, et je pourrai passé en version email ! Sinon rien à signaler pour le moment, ça tourne ! 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) le 4 janvier 2017 Signaler Partager Posté(e) le 4 janvier 2017 Pascal, tu veux qu'on vérifie quoi exactement ? Car à priori cela fonctionne le device grouping, en tout cas j'arrive à cocher et tout. Lien vers le commentaire Partager sur d’autres sites More sharing options...
lamparo Posté(e) le 4 janvier 2017 Signaler Partager Posté(e) le 4 janvier 2017 Bonsoir à vous, c'est ça que tu veux voir? 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Krikroff Posté(e) le 4 janvier 2017 Signaler Partager Posté(e) le 4 janvier 2017 Il y a 2 heures, Nico a dit : Oui oui je sais, je ne ferai au mieux que ce week-end. D'ailleurs j'ai fais un truc le week dernier : J'ai transformé une partie de mon GEA en scène bloc... Pourquoi, car GEA avait toujours encore des plantages de temps en temps. Cela fonctionne nickel. Par contre je me suis rendu compte qu'en fait mon GEA, j'avais mis le délai de mise à jour à 15s au lieu des 30 de Steven, du coup je suis repassé à 30. Et depuis, plus aucun souci avec... Alors bon, un des 2 trucs a réglé le souci, mais lequel... Sinon les scènes en mode bloc, je ne sais pas si qque chose à changé, mais elles sont vraiment pas mal au niveau vitesse, c'est du temps de réaction instantanée vraiment. Donc cette version me plait, vais voir que je la met. C'est pourtant toujours du LUA qui tourne derrière les scènes en mode bloc 2 Lien vers le commentaire Partager sur d’autres sites More sharing options...
fab971 Posté(e) le 4 janvier 2017 Signaler Partager Posté(e) le 4 janvier 2017 MAJ OK. Quelques nouveautés dans l'interface. Lien vers le commentaire Partager sur d’autres sites More sharing options...
971jmd Posté(e) le 5 janvier 2017 Signaler Partager Posté(e) le 5 janvier 2017 Il y a 7 heures, mprinfo a dit : Si quelqu'un qui est en 4.110 peu regarder si il y a les associations direct avec les wall Plug ou FGS Device grouping Below, select the devices whose operation is to be grouped with the state of the device, which you control. The selected device will act as one. To save the changes, click the floppy disk icon on the right. salut non pas de FGS Lien vers le commentaire Partager sur d’autres sites More sharing options...
