mprinfo
HC2 & HCL - 4.521 Beta du 18/12/2018
HC2 &HCL - 4.521 beta
Liste des modifications de la version
Version 4.521 Beta
New improvements:
- Added support for FIBARO Roller Shutter 3.
- Displaying the temperature from the built-in sensor for FIBARO Heat Controller in version 4.5 or higher.
- Displaying status of the temperature sensor in the advanced configuration of FIBARO Heat Controller.
- Saving measurements of both types of temperature sensor for FIBARO Heat Controller.
- Possibility of changing the name of your Home Center in the configuration settings.
- Devices are assigned to categories, which may be freely modified.
- Scenes are assigned to categories, which may be freely modified.
- Added Thermostat & Heating Zone plugin, which allows to control the heating zone temperature using a physical thermostat.
Resolved issues:
- Mesh network reconfiguration causes delays in system operation.
- Unable to add more than one empty button in a virtual device.
- YR Weather plugin generates too many requests.
- Empty fields in the LAN settings after switching from Static IP to DHCP.
- Changing DNS and enabling remote support results in an interface error.
- Notification about no compatible backups is displayed despite having them.
- No auto-reboot after editing the location settings.
- Incorrect redirect from the PIN code change notification.
- IP camera settings tab hangs the interface.
- Security fixes for remote access scripts.
- Other minor fixes.
C'est à cela qu'on reconnait les buveurs de mirabelles, la vue se trouble  :2:
  • Haha 2
Affectation de catégorie aux Modules Z-Wave et Scènes (les VD sont oubliés dans l'affaire...) :
Par contre je n'ai pas encore compris à quoi ça sert, comment exploiter ces catégories :
Plugin Thermostat & Heating Zone :
Par contre je ne peux pas le tester, car je n'ai pas de thermostat sur ma box de test :
Et pour le Other Minor bugfixes, on le découvrira par hasard plus tard...... :D
Les catégories ça correspond pas au type d'appareil connecté ? Tu sais genre quand t'installes un module il te demande de choisir light / heating / others / etc... C'est peut être pour les classer et mieux les retrouver dans l'appli à venir ?
Super on peut donner un nom a la HC2 je l'ai appelé MinorBug
  • Haha 2
Pour tout te dire, j'avais tenté de l'appeler Home Center 3 et faire un screenshot, mais impossible, on est limité en longueur.
@BenjyNet non je ne pense pas, surtout que les appareils connectés, on peut toujours le changer après coup dans les propriétés avancées des actionneurs Z-Wave.
Tandis que ces nouveaux tags s'appliquent à tous les types de modules, et aussi aux scènes.
J'ai l'impression que c'est pour pouvoir filtrer facilement la page quand on a des 100aines de tuiles, mais je ne trouve pas le filtre justement.
Et je n'ai pas cherché comment exploiter cette information, par exemple via l'API etc.... il y a surement des usages à trouver, attendons que Fibaro nous fasse un exemple sur le fofo officiel.
  • Haha 1
 Mais non, les mirabelles sont plus petites, tu n'as pas dû en voir souvent. :2::2::2::2::2::2::2::2::2::2:
Je pense que c'est pour préparer l'arriver de la nouvelle version Smartphone de l'appli, cela donnera un tri et filtre supplémentaire. Et peut être aussi pour Alexa ou GH qui peuvent travailler avec des groupes. Dommage que les VDs n'y soient pas.
Par contre le thermostat j'ai hâte de voir ce que c'est, car si j'ai bien compris c'est une thermostat qui permet de contrôler une zone complète, ce qui serait top de chez top (Une de mes vieilles demandes sur l'ancien bugtracker d'ailleurs) : Car du coup on pourrait enfin mettre un vrai thermostat type MChome au milieu du salon et donc contrôler toutes les pièces de vie sur cette même zone directement depuis là. Ce serait top ça !!
Je leur avais demandé si on pouvait changé les modules volet roulant pour autre chose, écran home cinéma par exemple, car si je faire tous les volet par l'appli cela me le descend, ils m'ont répondu que cela arriverait bientôt.
c'est possible dans cette beta?
Oui Fredric, même chose pour moi avec une vanne motorisée, mais là je pense que c'est différent, ça ne change pas le type des actionneurs.
Comme dit Nico, ça sera surement utile avec la nouvelle application mobile.
Réponse sur le fofo officiel : https://forum.fibaro.com/topic/32615-new-function-category/
Donc c'est pour des nouveautés à venir début 2019, donc je pense effectivement la partie appli smartphone et peut être autre chose en plus.
En tout cas pour moi c'est une excellente nouvelle, cela veut dire que la HC2 même après le rachat par CAME est pas du tout laissé de côté, bien au contraire même.
Je n'en n'ai jamais douté :)
Pour info Fibaro déménage en janvier, je n'ai pas plus d'infos, mais ils sont donc en pleine réorganisation.
Pour ceux qui n'ont pas de compte sur le forum officiel :
Citation
Hi guys!
Thanks for your interests in this new feature.
Unfortunately, there is no way to use its potential now.
It's a part of the upcoming changes scheduled for the next year and I cannot say anything more about it now ;)
Il y a 3 heures, Nico a dit :
rachat par CAME est
Le rachat c'est par Nice ou CAME ou c'est la même chose. J'ai rien trouvé sur le NET sur un rachat par CAME ?
Ici, c'est bien Nice.
C'est de la faute de Nico et de la Came qu'il prend :98:
  • Haha 1
 Je ne crois pas que ce soit Came mais bien Nice qui avait racheté Fibaro.
Ah, déjà répondu.
Oui, ça doit être de la bonne... Mince, je vois aussi un éléphant rose, pas vous? :2:
  • Haha 2
Oups :)
Et ils déménagent ailleurs en Pologne ou ailleurs en Europe ?
Apparemment ils restent à Poznan en Pologne, mais ils regroupent les différents services (usine, bureaux, etc)
Ca ne semble pas directement lié au rachat par Nice.
Ahh oki. Vive le made in Europe :)
Il y a 3 heures, Did a dit :
Ah, déjà répondu.
si moi aussi et il a de grandes oreilles !!!!
Je le connais celui là ?
Au fait qqun a testé la partie Thermostat, c'est bien ce que je décris plus haut ?
Le 18/12/2018 à 19:24, mprinfo a dit :
Avec un peu de chance, c'est ce nom qui apparaitra dans les notification mail.
c'est @ziamay qui va être contente si c'est le cas.
