speedoxx007 Posté(e) 22 novembre 2018 Signaler Share Posté(e) 22 novembre 2018 Version 4.520 New improvements: Possibility of giving access to managing heating zones and heating schedules to non-admin users. Added the popup notification while trying to disable Remote Access with active installer access. Added the button for rebooting in recovery mode. Improved communication security of plugins. Some HTTP requests which use https may require disabling certificate validation by adding 'checkCertificate = false' command in the Lua scene code. Added support for Fakro ZWS12. Added support for Remotec ZXT-600. Added support for Heiman/Zipato HS1CG Gas Sensor. Resolved issues: Five second delay when requesting non-existing variable, mobile, or trying to arm breached sensor. No connection with the Netatmo plugin. Raised memory usage after creating the backup. Specified version of Fakro ZWS12 is not fully supported. System hangs on starting services. Unable to reboot or turn off the gateway using a scene. Unable to transfer configuration via id.cloud.fibaro.com between gateways linked to Fibaro ID account. Gateway does not start after restoring cloud backup. 'API: Host not found' error. Incorrect icon for Roller Shutter which controls a garage gateway. Alarm events disappear after refreshing the page. No data in LAN Settings after rebooting. Lists of scenes and rooms do not update correctly. Scenes based on weather do not start. Removed dashboard. Other minor fixes. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Renan Posté(e) 22 novembre 2018 Signaler Share Posté(e) 22 novembre 2018 Installation faite : Mes scènes de récupération des données Météo et thermostats Netatmo ne fonctionnent plus. Lien vers le commentaire Partager sur d’autres sites More sharing options...
mprinfo Posté(e) 22 novembre 2018 Signaler Share Posté(e) 22 novembre 2018 Cools tout est la : Other minor fixes. 2 Lien vers le commentaire Partager sur d’autres sites More sharing options...
jjacques68 Posté(e) 22 novembre 2018 Signaler Share Posté(e) 22 novembre 2018 semble tout ok chez moi, RAS... (15 min pour faire la MAJ) Lien vers le commentaire Partager sur d’autres sites More sharing options...
mprinfo Posté(e) 22 novembre 2018 Signaler Share Posté(e) 22 novembre 2018 Voici la taille de la mise a jour Lien vers le commentaire Partager sur d’autres sites More sharing options...
Renan Posté(e) 22 novembre 2018 Signaler Share Posté(e) 22 novembre 2018 J'ai peut être été un peu vite. Les serveurs NETATMO sont en maintenance, ce qui explique peut être les messages d'erreur. (coïncidence?) Désolé Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) 22 novembre 2018 Signaler Share Posté(e) 22 novembre 2018 il y a 46 minutes, Renan a dit : Installation faite : Mes scènes de récupération des données Météo et thermostats Netatmo ne fonctionnent plus. Il faut ajouter le paramètre suivant dans les options de la fonction httpclient:request() utilisée dans les scènes : checkCertificate = false, 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
schwinny Posté(e) 22 novembre 2018 Signaler Share Posté(e) 22 novembre 2018 mise à jour en cours Lien vers le commentaire Partager sur d’autres sites More sharing options...
Massalia Posté(e) 22 novembre 2018 Signaler Share Posté(e) 22 novembre 2018 Mise a jour ok Lien vers le commentaire Partager sur d’autres sites More sharing options...
C4mth4 Posté(e) 22 novembre 2018 Signaler Share Posté(e) 22 novembre 2018 Incorrect Checksum pour ma part, après 2 tentatives ... Je suis en 4.510 actuellement Lien vers le commentaire Partager sur d’autres sites More sharing options...
Did Posté(e) 22 novembre 2018 Signaler Share Posté(e) 22 novembre 2018 C'est partit pour ma N°2. Vous avez eu la difficulté pour avoir la main au dessus de Back & Next (pour valider le lancement de la MàJ) dans le Wizard HC2? Pratiquement deux lignes seulement pour valider. Lien vers le commentaire Partager sur d’autres sites More sharing options...
C4mth4 Posté(e) 22 novembre 2018 Signaler Share Posté(e) 22 novembre 2018 Oui, il était là, plus la... avec en dessous le lancement pour la bêta 4.512 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Dragoniacs Posté(e) 22 novembre 2018 Signaler Share Posté(e) 22 novembre 2018 C'est partiiii C'est marrant que la box propose à la fois la version 4.520 et la bêta 4.512, non ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
C4mth4 Posté(e) 22 novembre 2018 Signaler Share Posté(e) 22 novembre 2018 J’ai pas testé de passer en bêta avant la finale. Je verrais demain, je referais une tentative. Sinon je sais pas trop comment faire! Lien vers le commentaire Partager sur d’autres sites More sharing options...
Did Posté(e) 22 novembre 2018 Signaler Share Posté(e) 22 novembre 2018 Déjà deux tentatives où elle me renvoie sur un écran d'erreur suivi du reboot. Je vais peut-être attendre que ça se calme. Lien vers le commentaire Partager sur d’autres sites More sharing options...
C4mth4 Posté(e) 22 novembre 2018 Signaler Share Posté(e) 22 novembre 2018 il y a 1 minute, Did a dit : Déjà deux tentatives où elle me renvoie sur un écran d'erreur suivi du reboot. Je vais peut-être attendre que ça se calme. Aaahhhh. Bon c’est pas sympa mais ça me rassure de voir que je suis pas seul! Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) 22 novembre 2018 Signaler Share Posté(e) 22 novembre 2018 Elles sont plus grosses, donc je pense saturation du serveur côté Fibaro. Lien vers le commentaire Partager sur d’autres sites More sharing options...
C4mth4 Posté(e) 22 novembre 2018 Signaler Share Posté(e) 22 novembre 2018 Ok, on verra plus tard Lien vers le commentaire Partager sur d’autres sites More sharing options...
Did Posté(e) 22 novembre 2018 Signaler Share Posté(e) 22 novembre 2018 Oui, les serveurs ne savent plus ou donner de la tête. J'essaie une dernière fois... Lien vers le commentaire Partager sur d’autres sites More sharing options...
schwinny Posté(e) 22 novembre 2018 Signaler Share Posté(e) 22 novembre 2018 (modifié) bon maj faite mail plus d'accès a la web interface accès possible via l'application iPhone et celle ci m'indique une version 4.510 bon apres un coup de fibaro finder, ma hc2 a changé d'ip et est toujours en 4.510 car comme tout le monde, ca plante sur le backup cloud... :p Modifié 22 novembre 2018 par schwinny Lien vers le commentaire Partager sur d’autres sites More sharing options...
Did Posté(e) 22 novembre 2018 Signaler Share Posté(e) 22 novembre 2018 La troisième était la bonne, c'est bien passé en v4.520. Lien vers le commentaire Partager sur d’autres sites More sharing options...
971jmd Posté(e) 23 novembre 2018 Signaler Share Posté(e) 23 novembre 2018 moi pour le moment impossible de télécharger, erreur bon on verra demain Lien vers le commentaire Partager sur d’autres sites More sharing options...
flacon030 Posté(e) 23 novembre 2018 Signaler Share Posté(e) 23 novembre 2018 OK pour moi RAS Lien vers le commentaire Partager sur d’autres sites More sharing options...
971jmd Posté(e) 23 novembre 2018 Signaler Share Posté(e) 23 novembre 2018 pour moi toujours pas Lien vers le commentaire Partager sur d’autres sites More sharing options...
971jmd Posté(e) 23 novembre 2018 Signaler Share Posté(e) 23 novembre 2018 tout fonctionne ou presque, toujours pas de possibilité de réalisée un sauvegarde CLOUD. Lien vers le commentaire Partager sur d’autres sites More sharing options...
