HC3 & HC3L - 5.131.57 - BETA - 02/02/2023
Lazer
BETA
Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Important Notice:
In some random cases, the HC3 upgrade may not succeed.
In such cases, the gateway will automatically revert to the previous system version.
Main features:
1. New way of controlling devices from Dashboard sidebar
    Completely redesigned control of color controllers.
    Support of color temperature setting for the Zigbee devices.
2. New predefined scenarios designed to control lights based on time conditions and gates status
What's new:
Climate
    Added possibility to assign temperature sensors for climate zones.
Dashboard
    Possibility to add devices from the dashboard.
    Added battery level indicators on devices tiles.
Devices
    Optimised procedure for adding devices for all protocols.
    Improved UI/UX and performance for device page filters.
    Added filters clearing mechanism when leaving the page.
    Added the description field for every device type.
    Redesigned family of devices view.
Energy
    Modified page layout for energy meters configuration in panel settings.
Gateway connection
    Added an option to define Slave IP address manually.
    Added additional redundancies for unexpected changes in network configuration.
Nice*
    Improved support for OXIBD status updates.
    Added generic support for legacy Bidirectional shutters.
    Improved support for device specific notifications.
Other
    Improved algorithm for gateway overheating notifications.
    Minor UI/UX improvements.
Plugins
    Added support for pulling the latch for the Tedee door lock.
    Improvements for Heat Activator plugin.
Quick Apps
    Added support for the Base Shutter device type.
Scenes
    Added the filters for Scenes page.
    Added "tolerance" option for Energy Panel block scenes.
    Improved blocks content loading performance for large systems.
    Added the description field for every scene type.
    Changed the order of steps for Scenarios.
Update
    Added possibility to update all devices.
    Added additional warning before upgrading to the beta version of the hub.
Zigbee
    Improved generic support for lights and color controllers.
Z-Wave
    Added handling of suspended device interview during the adding procedure for battery-powered devices.**
    Support for different revisions of the Aeotec Multisensor 6.
    Support for the ZW800 series MCO IR2900 thermostat.
    Support for the Everspring SP103.**
Bug fixes:
Climate
    The zone control freezes if the last setpoint is set at 5:00am.
Devices
    Issues with the display of some configuration parameters values.
Elero*
    The RolSolar device is incorrectly marked as disconnected.
    Using favorite positions in group actions does not work.
Energy
    Energy charts are malformed occasionally.
    Negative energy consumption data in the panel after clearing the energy data in some cases.
    Negative power consumption values for "Grid consumption" setting in some cases.
FTI
    No masking of Wi-Fi password during the first configuration on Firefox.
Gateway Connection
    Connection issues in specific network configurations.
Nice*
    Losing possibility to control devices in some cases.
    Fixed issue with binding some mono-directional devices.
    Custom icons for mono-directional devices not visible.
Other
    Added possibility to enable remote access for support from recovery system.
    Standard user cannot remove interactive push.
    Issues with controlling the linked-device thermostat in some configurations.
    System crash while deleting a non-existing notification.
    Wrong time in history after the change from winter time to summer time.
    Adding more than one Other device by clicking the add button excessively.
    The state of devices is not refreshed when pressed run scene button without refreshing the page.
    Other UI/UX fixes.
Plugins
    Lack of live preview for Helios 2N plugin.
Profiles
    Incorrect display of climate panel settings.
    Incorrect display of sliders in profiles settings.
Quick Apps
    Secret variable value visible in the webUI after saving.
Scenes
    Elero RolMotion blind is controlled even if excluded from a simple scenario.
    Incorrect display of sliders in block scenes.
    Cannot edit Scenarios via mobile app in remote connection.
Zigbee
    Wrong time unit during the adding process.
Z-Wave
    No possibility to update Z-Wave devices added in Security mode.
    Lack of handling unsolicited reports from devices using CC Basic.**
    Issues with updating devices from file in some cases.**
    Incorrect default role for the Zooz ZAC36 valve.
    Improved adding procedure when using S2U security level.**
    The exclusion process cannot be closed after an error has occurred.
Known issues:
Z-Wave Engine 3.0
    Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
    Gateway connection is not available in the new Z-Wave engine version.
*  - does not apply to HC3L (Home Center 3 Lite)
** - applies only to Z-Wave Engine 3.0
  • Thanks 2
Il y a 22 heures, mprinfo a dit :
Une bonne immunothérapie orale produit le même effet :yes:
Bref, encore une bêta que je vais éviter...
Modifié par Sowliny
ajout
Bon, et bien rebelote :(
Le système a récupéré d'une erreur inattendue
Et dire que cette box que j'ai depuis le tout début (numéro de série dans la centaine 300) ne m'avait jamais fait ces erreurs, alors qu'elle a subit toutes les mises à jour sans exception, beta, stable, etc... et depuis les 2 dernières beta, apparition de ce message :angry:
Je crois que ma box de prod va rester très longtemps en version 5.120, la dernière vraie stable.
  • Sad 1
Il y a 1 heure, Lazer a dit :
Erreur lors du démarrage du système
J'ai déjà eu aussi ce message et parfois une tentative de redémarrage ( chenillard des voyants de droite à gauche ) avec le voyant gauche qui clignote sans fin et obligé de couper par l'alimentation pour rebooter
C'est incroyable que cette version beta mette en évidence un truc que tu n'a jamais eu auparavant et qui existait déjà depuis longtemps chez d'autre comme moi.
Paradoxalement chez moi ça s'est calmé suis toujours en 5.120.10.
Comme j'avais un doute, j'ai modifié une appli php qui faisait beaucoup de requete curl sur /api/devices/ et /api/quickApp/export/  (12 requêtes toute les 8 secondes)
j'ai remplacé par des requêtes sql qui vont chercher les mêmes données dans domocharts. Est-ce cette diminution de charge sur la hc3 qui à espacé mes plantages ?
depuis 28 jours sans pb
puis 31 jours sans pb.
Puis 3h00 après une sauvegarde cloud
Puis actuellement ok depuis 5 jours.
Il y a 11 heures, henri-allauch a dit :
Si tu as DomoCharts, tu peux regarder le graph CPU, tu verras si la charge processeur a diminué entre avant/après ta modif.
Je me trompe peut être, mais je ne pense pas que cela soit dû à la charge de la machine. Je m'explique, j'ai une master et qlqs slaves, la master est bien chargée en terme de modules, QA, scènes... et n'a jamais eut le moindre crash en tout cas pas avec cette erreur.
Néanmoins une slave HC3 n'ayant que quelques modules et donc pas de QA/scènes et avec une charge proche d'un encéphalogramme plat plante régulièrement avec ces erreurs. La même typo de modules sur la slave se retrouve également existants sur ma master, j'exclus également la typo de module ... bref, je  n'ai pas consacré de temps à chercher à comprendre car jusqu'à présent je n'ai pas été incommodé, je ne vois (ressent ..)  même pas les plantages, mais je n'exclurais pas que ça soit hard(?) la master est au frais dans un coin de la maison la slave qui plante de temps à autre est à coté d'une baie réseau qui chauffe pas mal et je me demande si ce n'est pas la cause des plantages. Suis pas hyper convaincu de se que j'avance car vraiment pas essayé d'investigué...
@Lazer ta box est plutôt bien aérée ou dans un endroit un peu chauffé du genre baie de ou autre ?
Modifié par TonyC
