3709 -
18
messieurs, besoin d'aide ... car je suis perdu le json https://api-ratp.pierre-grimaud.fr/v3/traffic?format=json j'ai tenté ceci --[[ %% autostart %% properties %% globals --]] -- User variables local URL = "https://api-ratp.pierre-grimaud.fr/v3" local httpClient = net.HTTPClient() ---- Appel Api --- httpClient:request(URL .. "/traffic?format=json", {options = { method = 'GET'}, success = function(result) local jsonTable = json.decode(result) local LineRer = jsonTable.result.rers[1].line local EtatRer = jsonTable.result.rers[1].title local EtatLongRer = jsonTable.result.rers[1].message local LineMetro = jsonTable.result.metros[1].line local EtatMetro = jsonTable.result.metros[1].title fibaro:debug("OK") end, error = function(err) fibaro:debug("Error: " ..err) end }) --local dateTag = os.date("%H:%M", os.time()) --fibaro:call(selfId, "setProperty", "ui.Date.value", dateTag) --fibaro:call(selfId, "setProperty", "ui.LineRer.value", LineRer .. " ") --fibaro:call(selfId, "setProperty", "ui.EtatRer.value", EtatRer .. " ") --fibaro:call(selfId, "setProperty", "ui.LineMetro.value", LineMetro .. " ") --fibaro:call(selfId, "setProperty", "ui.EtatMetro.value", EtatMetro .. " ") -- Gestion des icônes et mise à jour de la variable --if EtatRer == "Trafic normal" then -- fibaro:call(selfId , "setProperty", "currentIcon", TraficOk) -- fibaro:setGlobal("EtatTrafic", "OK") --else -- fibaro:call(selfId , "setProperty", "currentIcon", TraficNok) -- fibaro:setGlobal("EtatTrafic", EtatLongRer) print(LineRer) print(EtatRer) print(LineMetro) print(EtatMetro) print(EtatRer) mais j'obtiens [DEBUG] 14:12:24: nil [DEBUG] 14:12:24: nil [DEBUG] 14:12:24: nil [DEBUG] 14:12:24: nil [DEBUG] 14:12:24: nil [DEBUG] 14:12:24: [1;31m2017-07-08 14:12:24.534764 [ fatal] LUA error: /usr/share/lua/5.2/json/decode.lua:74: bad argument #1 to 'match' (string expected, got table) pouvez vous me guider un peu plus ? merci
Merci. Je corrige ce week-end alors
Hum. Tu m en dit plus ou un exemple quelque part [emoji120] ?
Hello j'ai vu que récemment l'api est passé en V3 sauf que c'est du HTTPS me semble il maintenant https://api-ratp.pierre-grimaud.fr/v3/traffic?format=json alors qu'avant on était en http http://api-ratp.pierre-grimaud.fr/v2/traffic?format=json du coup j'ai tenté la modif local TRAFIC = Net.FHttp("api-ratp.pierre-grimaud.fr",443) local selfId = fibaro:getSelfId() local response ,status, err = TRAFIC:GET("/v3/traffic?format=json") mais ca marche pas Je crois que HTTPS ne se fait avec la fibaro si ?
j'ai loupé qq chose ... @Did tu es sur jeedom ?
ou peut être un resumé des motifs faits et ou (petit tuto) pour ceux qui ont deja installé l'ancienne version. merci @pedia
c'était désactivé chez moi. mais je pense que si ON, alors il y a un rafraichissement en fond de l'app, donc si tu l'ouvres par la suite, tu es directement connecté. pas le loading du départ qui suivant le réseau est plus ou moins long
super interessant ca si ca bouffe pas trop la batterie ca éviter le LOADING .....
Serrure + domotique Ou Serrure + fibaro. Non merci !!! [emoji1]
Bonjour. Depuis qq temps le bouton qui fonctionnait très bien depuis 4/5 mois fonctionne de manière aléatoire. (Comme décrit dans les pages précédentes.) Pareil chez vous ? Que faire ?
par contre gros gros bouffeur de pile .. et donc que les piles sont faibles la remontée est pas stable
tout comme @Did, ca fait quelques jours que le watchdog redémarre GEA, SONOS etc... A config 100% équivalente, je peux passer des périodes très bon longues sans problèmes et parfois comme depuis 2-3 jours de nombreux reboot de la part du watchdog. comprends pas vraiment
bon alors cette version ? j'ai suivi le debut, ca paraissait pas terrible, mais finalement si ? je passe dessus ?
Choix Point D'accès Wifi Pour Remplacer Wifi Freebox
Sakkhho a répondu à un(e) sujet de lolomail dans Le bistrot
Merci à tous. Effectivement borne wifi au cul de la freebox. Mais je couperai vraiment le wifi de la box que je trouve tout pourri -
bon j'en peux plus du wifi de ma freebox revolution du coup que me conseillez vous ? sachant que c'est uniquement pour connecter les tablettes, smartphone, station neatmo et thermostat et le Roomba :-) tout le reste est en filiaire/cpl je pensai mettre un routeur wifi au cul de la freebox et éteindre le wifi de la freebox ? (mais les 4 ports de la freebox sont utilisés) Quel matos ? max 100 -150Euros. merci -
il semble y avoir du mieux sur le bulb https://forum.fibaro.com/index.php?/topic/25756-aeon-labs-led-bulb/
Je rentre de déplacement et je vois une belle version stable. Je peux lancer la procédure apéro mise à jour sans risque ?
salut je voulais dire une calibration du module. tu vais dans les paramètres du module et tu clicques sur calibration il lancera une fermeture et ouverture complete
relance une calibration
indeed ca serait plus pratique de tout mettre dans 1 seule scene. possible ? je devrai avoir le temps de tester ce weekend
Intégration Têtes Danfoss LC13 avec chaudière Frisquet
Sakkhho a répondu à un(e) sujet de MAM78 dans Chauffage et Energie
je voulais qq chose qui se pilote à distance et via la HC2. le thermostat d'origine de ma frisquet de 2010 ne le faisait pas J'ai branché le netatmo avec le cable qui va bien Non, tout avec GEA Le principe reste le meme 1 thermostat unique dans la maison. la seule difference c'est de jouer avec les LC13 pour fermer les pieces quand tu n'as pas besoins et ouvrir à fond quand tu veux de la chaleur rapide (salle de bain) Comme j'ai dit le Netatmo est indépendant (programme propre sur le cloud netatmo) pour le moment car le plugin merdouillait mais sur le fofo quelqu'un à fait la scene qui va bien - j'ai pas testé encore. avec GEA j'ai ca par exemple GEA.add(Chauffage, 30, "Chauffage Entrée 22°", {{"Time", "06:00", "06:01"},{"Time", "17:00", "17:01"}, {"function", function() fibaro:call(id["TT_ENTREE"], "setTargetLevel",22) end}}) un VG globale "Chauffage" qui passe de ON à OFF , ca permet d'éviter de bouger les LC13 en été pour économiser les piles GEA.add({id["OUV_FENETRE_EMMA"],Chauffage}, 60, "Chauffage Emmma coupé", {{"function", function() fibaro:call(id["TT_CHAMBRE_EMMA"], "setTargetLevel",16) end}}) -- Chauffage chambre Emma coupé car fenetre ouverte -
je suis dans le même cas que toi, chaudière central frisquet prestige, Thermostat Netatmo, et LC13 un peu partout. j'ai qu'1 seul circulateur pour toute la maison... (maison ancienne ...) ma config : - thermostat dans la piece la plus froide (l'entree) avec un radiateur équipée d'un lc13 pourquoi le thermostat dans cette piece ? car ca me parait d'avoir la chaudière qui tourne régulièrement. - dans le salon des LC13 qui gère la temperature du salon sur 3 radiateurs - idem dans les chambres des enfants et SdBs quand nous sommes à la maison, la LC13 de l'entrée est réglé de façon à ce que la temperature de consigne du netatmo soit atteinte difficilement (mais possible quand meme pour éviter que la chaudière tourne à fond) pour avoir de l'eau chaude dans les autres parties de la maison (toute gérée en LC13) quand nous sommes dehors, cette meme LC13 est largement ouverte de façon à limiter les consos. tout ceci avec des scenarios GEA par dessus de façon à jouer les consignes des LC13 en fonction des moments de la journée etc... et aussi de l'ouverture des fenêtres (avec des fgk) le thermostat netatmo à aussi son propre scenario. pas l'ideal pour la conso de gaz je pense mais je peux pas faire mieux, ayant qu'un 1 seul circulateur et pas de bypass... mais pour le confort, toujours la bonne temeperature dans les pieces à vivre, chaud dans les salles de bain le matin et le soir ... c'est WAF approuved. -
doit avoir moyen de toute mettre dans la même scène non ? j'hésite toujours à supprimer le plugin thermostat
Ok. Pensez vous que si je supprime via X le thermostat mais je touche pas le plugin (car j ai la station météo) ca sera ok ?
Yes ça serait pas mal que qq un publie un me version complète avec un beau Tuto ( et un VD pour jouer avec ?) Est ce que vous avez le plugin d installer ? Et / ou comment le virer sans virer la station météo ?
